AlosPalsarLeader.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // "Copyright Centre National d'Etudes Spatiales"
4 // "Copyright Centre for Remote Imaging, Sensing and Processing"
5 //
6 // License: LGPL
7 //
8 // See LICENSE.txt file in the top level directory for more details.
9 //
10 //----------------------------------------------------------------------------
11 // $Id$
12
13 #ifndef AlosPalsarLeader_h
14 #define AlosPalsarLeader_h
15
16 #include <iostream>
23 #include <map>
24
25 class ossimKeywordlist;
26
27 namespace ossimplugins
28 {
29
30 class AlosPalsarPlatformPositionData;
31 class AlosPalsarMapProjectionData;
32 class AlosPalsarDataSetSummary;
33 class AlosPalsarFileDescriptor;
34 class AlosPalsarFacilityData;
35 class AlosPalsarRadiometricData;
36
42 {
43 public:
48
52  virtual ~AlosPalsarLeader();
53
57  friend std::ostream& operator<<(std::ostream& os, const AlosPalsarLeader& data);
58
63
68
73
77  void ClearRecords();
78
79
86  virtual bool saveState(ossimKeywordlist& kwl,
87  const char* prefix = 0) const;
88
89
93 // const AlosPalsarMapProjectionData * get_AlosPalsarMapProjectionData() const;
96
97 protected:
98  typedef std::map<int, AlosPalsarRecord*> RecordType;
100
101  static const int AlosPalsarFacilityDataID;
102  static const int AlosPalsarRadiometricDataID;
104 // static const int AlosPalsarMapProjectionDataID;
105  static const int AlosPalsarDataSetSummaryID;
106  static const int AlosPalsarFileDescriptorID;
107 private:
108
109 };
110 }
111 #endif
This class is able to read the Leader file of the AlosPalsar file structure.
std::map< int, AlosPalsarRecord * > RecordType
friend std::ostream & operator<<(std::ostream &os, const AlosPalsarLeader &data)
This function write the AlosPalsarLeader in a stream.
const AlosPalsarDataSetSummary * get_AlosPalsarDataSetSummary() const
Destructor.
Method to save object state to a keyword list.
This class is able to read the SAR leader data set summary record of the leader file.
static const int AlosPalsarPlatformPositionDataID
This class is able to read a Platform position data record.
const AlosPalsarRadiometricData * get_AlosPalsarRadiometricData() const
const AlosPalsarPlatformPositionData * get_AlosPalsarPlatformPositionData() const
friend std::istream & operator>>(std::istream &is, AlosPalsarLeader &data)
This function read a AlosPalsarLeader from a stream.
const AlosPalsarFacilityData * get_AlosPalsarFacilityData() const
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
void ClearRecords()
Remove all the previous records from the AlosPalsarLeader.
This class is able to read a radiometric data record.
AlosPalsarLeader & operator=(const AlosPalsarLeader &rhs)
Copy operator.
const AlosPalsarFileDescriptor * get_AlosPalsarFileDescriptor() const
This class is able to read the SAR leader file descriptor record of the leader file.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
