Public Member Functions | Protected Attributes | List of all members
ossim2dBilinearTransform Class Reference
ossim2dBilinearTransform allows one to specify a set of input points and output points and will fit a bilinear transform to those points. More...
#include <ossim2dBilinearTransform.h>
Inheritance diagram for ossim2dBilinearTransform:
ossim2dTo2dTransform ossimObject ossimReferenced
 ossim2dBilinearTransform ()
 Initialize to the identity. More...
 ossim2dBilinearTransform (const ossimDpt *input, const ossimDpt *output, ossim_uint32 arraySize)
 Initialize the transform that best fits the input and output arrays. More...
 ossim2dBilinearTransform (const ossimDpt &in1, const ossimDpt &in2, const ossimDpt &in3, const ossimDpt &in4, const ossimDpt &out1, const ossimDpt &out2, const ossimDpt &out3, const ossimDpt &out4)
 Mapping 4 corners to an output 4 corners. More...
 ossim2dBilinearTransform (const ossim2dBilinearTransform &src)
 Copy constructor. More...
 Duplication method that duplicates this object. More...
const ossim2dBilinearTransformoperator= (const ossim2dBilinearTransform &src)
 Overloaded operator equal that allows for assignment. More...
void setFromPoints (const ossimDpt &in1, const ossimDpt &in2, const ossimDpt &in3, const ossimDpt &in4, const ossimDpt &out1, const ossimDpt &out2, const ossimDpt &out3, const ossimDpt &out4)
void setFromPoints (const ossimDpt *input, const ossimDpt *output, ossim_uint32 arraySize)
virtual void forward (const ossimDpt &input, ossimDpt &output) const
 forward transform will transform an input point to the output. More...
virtual void forward (ossimDpt &modify_this) const
 forward transform will transform an input point to the output and modify the passed in point to the new value More...
virtual void inverse (const ossimDpt &input, ossimDpt &output) const
 Inverts the point back to the original input value. More...
virtual void inverse (ossimDpt &modify_this) const
 Inverts the point back to the original input value and modifies the passed in point to the new value. More...
 Saves the state of this object. More...
 loads the state of this object from a keywordlist. More...
 prints the contents of this object. More...
- Public Member Functions inherited from ossim2dTo2dTransform
virtual const ossim2dTo2dTransformoperator= (const ossim2dTo2dTransform &rhs)
virtual ossimDpt getOrigin () const
void setConvergenceThreshold (const double &new_threshold)
void setMaxIterations (int new_max_iters)
void setDxDy (const ossimDpt &dxdy)
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
ossim_float64 m_coefficientsXTerm [4]
ossim_float64 m_coefficientsYTerm [4]
ossim_float64 m_inverseCoefficientsXTerm [4]
ossim_float64 m_inverseCoefficientsYTerm [4]
 TYPE_DATA
- Protected Attributes inherited from ossim2dTo2dTransform
double theConvergenceThreshold
int theMaxIterations
ossimDpt theDxDy
Additional Inherited Members
- Protected Member Functions inherited from ossim2dTo2dTransform
 ossim2dTo2dTransform ()
virtual ~ossim2dTo2dTransform ()
virtual ~ossimReferenced ()
Detailed Description
Function of the form is solved for each
output dimension.
z(x,y) = a + b*x + c*y + d*x*y
We use the ossimLeastSquareBilin solver to solve for the coefficients.
Definition at line 15 of file ossim2dBilinearTransform.h.
◆ ossim2dBilinearTransform() [1/4]
ossim2dBilinearTransform::ossim2dBilinearTransform ( )
Definition at line 6 of file ossim2dBilinearTransform.cpp.
References m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, and m_inverseCoefficientsYTerm.
7 {
8  std::fill(m_coefficientsXTerm, m_coefficientsXTerm+4, 0.0);
9  std::fill(m_coefficientsYTerm, m_coefficientsYTerm+4, 0.0);
12
13  // setup identity
14  //
15  m_coefficientsXTerm[1] = 1.0;
16  m_coefficientsYTerm[2] = 1.0;
19 }
ossim_float64 m_inverseCoefficientsXTerm[4]
ossim_float64 m_inverseCoefficientsYTerm[4]
◆ ossim2dBilinearTransform() [2/4]
ossim2dBilinearTransform::ossim2dBilinearTransform ( const ossimDpt input,
const ossimDpt output,
inline
If the input and output are well dispersed and are 4 points it should fit exactly. Both arrays should be of equal number of points
Parameters
inputthe list of input points
outputthe list of output points to transform the input to
arraySizethe number of points for the arrays.
Definition at line 32 of file ossim2dBilinearTransform.h.
35  {
36  setFromPoints(input, output, arraySize);
37  }
void setFromPoints(const ossimDpt &in1, const ossimDpt &in2, const ossimDpt &in3, const ossimDpt &in4, const ossimDpt &out1, const ossimDpt &out2, const ossimDpt &out3, const ossimDpt &out4)
◆ ossim2dBilinearTransform() [3/4]
ossim2dBilinearTransform::ossim2dBilinearTransform ( const ossimDpt in1,
const ossimDpt in2,
const ossimDpt in3,
const ossimDpt in4,
const ossimDpt out1,
const ossimDpt out2,
const ossimDpt out3,
const ossimDpt out4
inline
Definition at line 43 of file ossim2dBilinearTransform.h.
45  {
46  setFromPoints(in1, in2, in3, in4, out1, out2, out3, out4);
47  }
◆ ossim2dBilinearTransform() [4/4]
ossim2dBilinearTransform::ossim2dBilinearTransform ( const ossim2dBilinearTransform src)
Member Function Documentation
◆ dup()
virtual ossimObject* ossim2dBilinearTransform::dup ( ) const
inlinevirtual
Definition at line 57 of file ossim2dBilinearTransform.h.
57 {return new ossim2dBilinearTransform(*this);}
◆ forward() [1/2]
virtual void ossim2dBilinearTransform::forward ( const ossimDpt input,
ossimDpt output
) const
inlinevirtual
Implements ossim2dTo2dTransform.
Definition at line 101 of file ossim2dBilinearTransform.h.
References ossimDpt::x, and ossimDpt::y.
103  {
104  output.x = (m_coefficientsXTerm[0] +
105  m_coefficientsXTerm[1]*input.x +
106  m_coefficientsXTerm[2]*input.y +
107  m_coefficientsXTerm[3]*input.x*input.y);
108  output.y = (m_coefficientsYTerm[0] +
109  m_coefficientsYTerm[1]*input.x +
110  m_coefficientsYTerm[2]*input.y +
111  m_coefficientsYTerm[3]*input.x*input.y);
112  }
double y
Definition: ossimDpt.h:165
double x
Definition: ossimDpt.h:164
◆ forward() [2/2]
virtual void ossim2dBilinearTransform::forward ( ossimDpt modify_this) const
inlinevirtual
Reimplemented from ossim2dTo2dTransform.
Definition at line 118 of file ossim2dBilinearTransform.h.
119  {
120  double saveX = modify_this.x;
121  modify_this.x = (m_coefficientsXTerm[0] +
122  m_coefficientsXTerm[1]*modify_this.x +
123  m_coefficientsXTerm[2]*modify_this.y +
124  m_coefficientsXTerm[3]*modify_this.x*modify_this.y);
125  modify_this.y = (m_coefficientsYTerm[0] +
126  m_coefficientsYTerm[1]*saveX +
127  m_coefficientsYTerm[2]*modify_this.y +
128  m_coefficientsYTerm[3]*saveX*modify_this.y);
129  }
double y
double x
◆ inverse() [1/2]
virtual void ossim2dBilinearTransform::inverse ( const ossimDpt input,
ossimDpt output
) const
inlinevirtual
Definition at line 134 of file ossim2dBilinearTransform.h.
136  {
137  output.x = (m_inverseCoefficientsXTerm[0] +
138  m_inverseCoefficientsXTerm[1]*input.x +
139  m_inverseCoefficientsXTerm[2]*input.y +
140  m_inverseCoefficientsXTerm[3]*input.x*input.y);
141  output.y = (m_inverseCoefficientsYTerm[0] +
142  m_inverseCoefficientsYTerm[1]*input.x +
143  m_inverseCoefficientsYTerm[2]*input.y +
144  m_inverseCoefficientsYTerm[3]*input.x*input.y);
145  }
double y
double x
◆ inverse() [2/2]
virtual void ossim2dBilinearTransform::inverse ( ossimDpt modify_this) const
inlinevirtual
Definition at line 151 of file ossim2dBilinearTransform.h.
152  {
153  double saveX = modify_this.x;
154  modify_this.x = (m_inverseCoefficientsXTerm[0] +
155  m_inverseCoefficientsXTerm[1]*modify_this.x +
156  m_inverseCoefficientsXTerm[2]*modify_this.y +
157  m_inverseCoefficientsXTerm[3]*modify_this.x*modify_this.y);
158  modify_this.y = (m_inverseCoefficientsYTerm[0] +
159  m_inverseCoefficientsYTerm[1]*saveX +
160  m_inverseCoefficientsYTerm[2]*modify_this.y +
161  m_inverseCoefficientsYTerm[3]*saveX*modify_this.y);
162  }
double y
double x
◆ loadState()
bool ossim2dBilinearTransform::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 102 of file ossim2dBilinearTransform.cpp.
References ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, and ossimString::split().
104 {
105  bool result = true;
106  ossimString xterm = kwl.find(prefix, "xterm");
107  ossimString yterm = kwl.find(prefix, "yterm");
108  ossimString inverse_xterm = kwl.find(prefix, "inverse_xterm");
109  ossimString inverse_yterm = kwl.find(prefix, "inverse_yterm");
110
111  std::vector<ossimString> values;
112  xterm.split(values, " ");
113  if(values.size() == 4)
114  {
115  m_coefficientsXTerm[0] = values[0].toDouble();
116  m_coefficientsXTerm[1] = values[1].toDouble();
117  m_coefficientsXTerm[2] = values[2].toDouble();
118  m_coefficientsXTerm[3] = values[3].toDouble();
119  }
120  else
121  {
122  result = false;
123  }
124  values.clear();
125  yterm.split(values, " ");
126  if(values.size() == 4)
127  {
128  m_coefficientsYTerm[0] = values[0].toDouble();
129  m_coefficientsYTerm[1] = values[1].toDouble();
130  m_coefficientsYTerm[2] = values[2].toDouble();
131  m_coefficientsYTerm[3] = values[3].toDouble();
132  }
133  else
134  {
135  result = false;
136  }
137  values.clear();
138  inverse_xterm.split(values, " ");
139  if(values.size() == 4)
140  {
141  m_inverseCoefficientsXTerm[0] = values[0].toDouble();
142  m_inverseCoefficientsXTerm[1] = values[1].toDouble();
143  m_inverseCoefficientsXTerm[2] = values[2].toDouble();
144  m_inverseCoefficientsXTerm[3] = values[3].toDouble();
145  }
146  else
147  {
148  result = false;
149  }
150  values.clear();
151  inverse_yterm.split(values, " ");
152  if(values.size() == 4)
153  {
154  m_inverseCoefficientsYTerm[0] = values[0].toDouble();
155  m_inverseCoefficientsYTerm[1] = values[1].toDouble();
156  m_inverseCoefficientsYTerm[2] = values[2].toDouble();
157  m_inverseCoefficientsYTerm[3] = values[3].toDouble();
158  }
159  else
160  {
161  result = false;
162  }
163
164  if(result)
165  {
166  result = ossim2dTo2dTransform::loadState(kwl, prefix);
167  }
168
169  return result;
170 }
◆ operator=()
const ossim2dBilinearTransform& ossim2dBilinearTransform::operator= ( const ossim2dBilinearTransform src)
inline
Parameters
srcthe src data to copy into this object. It will call the base classes equal operator.
Definition at line 65 of file ossim2dBilinearTransform.h.
References m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, and ossim2dTo2dTransform::operator=().
66  {
67  if(this == &src) return *this;
68
69  ossim2dTo2dTransform::operator =(*this); // call base classes equal operator
74
75  return *this;
76  }
virtual const ossim2dTo2dTransform & operator=(const ossim2dTo2dTransform &rhs)
◆ print()
virtual std::ostream& ossim2dBilinearTransform::print ( std::ostream &  out) const
inlinevirtual
Will also cal the base classes print method.
Definition at line 180 of file ossim2dBilinearTransform.h.
References ossim2dTo2dTransform::print().
181  {
183  out << "xTerm: " << m_coefficientsXTerm[0] << ", " << m_coefficientsXTerm[1] << ", "
184  << m_coefficientsXTerm[2] << ", " << m_coefficientsXTerm[3] << "\n";
185  out << "yTerm: " << m_coefficientsYTerm[0] << ", " << m_coefficientsYTerm[1] << ", "
186  << m_coefficientsYTerm[2] << ", " << m_coefficientsYTerm[3] << "\n";
187
188  out << "xInverseTerm: " << m_inverseCoefficientsXTerm[0] << ", " << m_inverseCoefficientsXTerm[1] << ", "
189  << m_inverseCoefficientsXTerm[2] << ", " << m_inverseCoefficientsXTerm[3] << "\n";
190  out << "yInverseTerm: " << m_inverseCoefficientsYTerm[0] << ", " << m_inverseCoefficientsYTerm[1] << ", "
191  << m_inverseCoefficientsYTerm[2] << ", " << m_inverseCoefficientsYTerm[3] << "\n";
192
193  return out;
194  }
Generic print method.
◆ saveState()
bool ossim2dBilinearTransform::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 75 of file ossim2dBilinearTransform.cpp.
References ossimKeywordlist::add(), m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, ossim2dTo2dTransform::saveState(), and ossimString::toString().
77 {
94
95  kwl.add(prefix, "xterm", xterm, true);
96  kwl.add(prefix, "yterm", yterm, true);
97  kwl.add(prefix, "inverse_xterm", inverse_xterm, true);
98  kwl.add(prefix, "inverse_yterm", inverse_yterm, true);
99  return ossim2dTo2dTransform::saveState(kwl, prefix);
100 }
Numeric to string methods.
◆ setFromPoints() [1/2]
void ossim2dBilinearTransform::setFromPoints ( const ossimDpt in1,
const ossimDpt in2,
const ossimDpt in3,
const ossimDpt in4,
const ossimDpt out4
Will use the ossimLeastSquareBilin class to solve the bilinear coefficients that maps the given input points to the output points.
Definition at line 30 of file ossim2dBilinearTransform.cpp.
32 {
33  ossimDpt input[4];
34  ossimDpt output[4];
35
36  input[0] = in1;
37  input[1] = in2;
38  input[2] = in3;
39  input[3] = in4;
40
41  output[0] = out1;
42  output[1] = out2;
43  output[2] = out3;
44  output[3] = out4;
45
46  setFromPoints(&input[0], &output[0], 4);
47 }
◆ setFromPoints() [2/2]
void ossim2dBilinearTransform::setFromPoints ( const ossimDpt input,
Parameters
Definition at line 49 of file ossim2dBilinearTransform.cpp.
References ossimLeastSquaresBilin::addSample(), ossimLeastSquaresBilin::getLSParms(), m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, ossimLeastSquaresBilin::solveLS(), x, and y.
52 {
54  ossimLeastSquaresBilin inversex;
56  ossimLeastSquaresBilin inversey;
57  ossim_uint32 idx = 0;
58  for(idx=0; idx < arraySize; ++idx)
59  {
60  inx.addSample(input[idx].x, input[idx].y, output[idx].x);
61  inversex.addSample(output[idx].x, output[idx].y, input[idx].x);
62  iny.addSample(input[idx].x, input[idx].y, output[idx].y);
63  inversey.addSample(output[idx].x, output[idx].y, input[idx].y);
64  }
65  inx.solveLS();
66  inversex.solveLS();
67  iny.solveLS();
68  inversey.solveLS();
73 }
ossim_uint32 x
virtual void addSample(double x, double yy, double zmea)
add a single data sample.
ossim_uint32 y
unsigned int ossim_uint32
Provide 2D Least Squares Bilinear model fitting The math model is that of a bilinear surface of the ...
virtual bool getLSParms(double &pa, double &pb_x, double &pc_y, double &pd_xy) const
return LS solution parameters.
bool solveLS()
compute least squares parameter solution - true if succesfull.
Member Data Documentation
◆ m_coefficientsXTerm
ossim_float64 ossim2dBilinearTransform::m_coefficientsXTerm[4]
protected
◆ m_coefficientsYTerm
ossim_float64 ossim2dBilinearTransform::m_coefficientsYTerm[4]
protected
◆ m_inverseCoefficientsXTerm
ossim_float64 ossim2dBilinearTransform::m_inverseCoefficientsXTerm[4]
protected
◆ m_inverseCoefficientsYTerm
ossim_float64 ossim2dBilinearTransform::m_inverseCoefficientsYTerm[4]
protected
◆ TYPE_DATA
ossim2dBilinearTransform::TYPE_DATA
protected
Definition at line 202 of file ossim2dBilinearTransform.h.
