ossimAtbController Class Reference
#include <ossimAtbController.h>
Inheritance diagram for ossimAtbController:
ossimConnectableObject ossimProcessInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimAtbController ()
 ossimAtbController (ossimImageCombiner *combiner, ossimGridRemapEngine *engine=0)
 ossimAtbController (ossimGridRemapEngine *engine)
 ~ossimAtbController ()
void initializeWithCombiner (ossimImageCombiner *combiner, ossimGridRemapEngine *engine=0)
bool enableImage (unsigned int index)
bool disableImage (unsigned int index)
bool lockImage (unsigned int index)
bool unlockImage (unsigned int index)
virtual bool execute ()
virtual void abort ()
void setKernelSize (int side_size)
void setGridSpacing (const ossimIpt &spacing)
void setGridRemapEngine (ossimGridRemapEngine *engine)
virtual bool saveState (ossimKeywordlist &kwl) const
virtual bool loadState (const ossimKeywordlist &kwl)
virtual bool canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
Protected Member Functions
void initializeRemappers ()
virtual ~ossimReferenced ()
Protected Attributes
ossimDrect theBoundingRect
ossimRefPtr< ossimConnectableContainertheContainer
ossimGridRemapEnginetheGridRemapEngine
std::vector< ossimRefPtr< ossimAtbMatchPoint > > theMatchPoints
ossimIpt theGridSpacing
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Definition at line 37 of file ossimAtbController.h.
◆ ossimAtbController() [1/3]
ossimAtbController::ossimAtbController ( )
default Constructor initializes the member combiner pointer to NULL.
Definition at line 43 of file ossimAtbController.cpp.
44  :
45  ossimConnectableObject(NULL, 0, 0, false, true),
46  theContainer (0),
48  theGridSpacing (DEFAULT_GRID_SPACING)
49 {
50  static const char MODULE[] = "ossimAtbController Default Constructor";
51  if (traceExec()) CLOG << "entering..." << endl;
52
53  //***
54  // Instantiate a default remap engine:
55  //***
57  = ossimGridRemapEngineFactory::create(DEFAULT_ATB_REMAP_ENGINE);
58
59  if (traceExec()) CLOG << "returning..." << endl;
60 }
static ossimGridRemapEngine * create(const char *spec)
ossimGridRemapEngine * theGridRemapEngine
ossimRefPtr< ossimConnectableContainer > theContainer
#define CLOG
Definition: ossimTrace.h:23
ossimConnectableObject(ossimObject *owner=0)
Base constructor of this object.
◆ ossimAtbController() [2/3]
ossimAtbController::ossimAtbController ( ossimImageCombiner combiner,
ossimGridRemapEngine engine = 0
Constructor with Combiner reference. This combiner is used for the ATB.
Definition at line 66 of file ossimAtbController.cpp.
68  :
69  ossimConnectableObject(NULL, 0, 0, false, true),
70  theContainer (0),
72  theGridSpacing (DEFAULT_GRID_SPACING)
73 {
74  static const char MODULE[] = "ossimAtbController Constructor #1";
75  if (traceExec()) CLOG << "entering..." << endl;
76
77  initializeWithCombiner(combiner, engine);
78
79  if (traceExec()) CLOG << "returning..." << endl;
80 }
#define CLOG
void initializeWithCombiner(ossimImageCombiner *combiner, ossimGridRemapEngine *engine=0)
◆ ossimAtbController() [3/3]
ossimAtbController::ossimAtbController ( ossimGridRemapEngine engine)
Constructor with a specified remap engine.
Definition at line 86 of file ossimAtbController.cpp.
87  :
88  theContainer (0),
90  theGridSpacing (DEFAULT_GRID_SPACING)
91 {
92  static const char MODULE[] = "ossimAtbController Constructor #1";
93  if (traceExec()) CLOG << "entering..." << endl;
94
95  //***
96  // Assign default engine if non provided:
97  //***
98  if (engine)
99  {
100  theGridRemapEngine = engine;
101  }
102  else
103  {
105  = ossimGridRemapEngineFactory::create(DEFAULT_ATB_REMAP_ENGINE);
106  }
107
108  if (traceExec()) CLOG << "returning..." << endl;
109 }
#define CLOG
◆ ~ossimAtbController()
ossimAtbController::~ossimAtbController ( )
Definition at line 120 of file ossimAtbController.cpp.
References theContainer, and theGridRemapEngine.
121 {
122  theContainer = 0;
123  theGridRemapEngine = 0;;
124 }
Member Function Documentation
◆ abort()
void ossimAtbController::abort ( )
virtual
Reimplemented from ossimProcessInterface.
Definition at line 401 of file ossimAtbController.cpp.
402 {
403  static const char MODULE[] = "ossimAtbController::abort()";
404  if (traceExec()) CLOG << "entering..." << endl;
405
406  CLOG << "NOTICE: this method not yet implemented." << endl;
407
408  if (traceExec()) CLOG << "returning..." << endl;
409 }
#define CLOG
◆ canConnectMyInputTo()
bool ossimAtbController::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
virtual
Implementation of ossimConnectableObject pure virtual.
Implements ossimConnectableObject.
Definition at line 564 of file ossimAtbController.cpp.
References PTR_CAST.
566 {
567  return (object&& PTR_CAST(ossimGridRemapSource, object));
568 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ disableImage()
bool ossimAtbController::disableImage ( unsigned int  index)
Disnable an image in the mosaic from the tonal balancing process
Definition at line 239 of file ossimAtbController.cpp.
References ossimSource::disableSource(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), and PTR_CAST.
240 {
241  if (index >= getNumberOfInputs())
242  return false;
243
244  ossimSource* remapper = PTR_CAST(ossimSource,
245  getInput(index));
246  if (remapper)
247  remapper->disableSource();
248
249  return true;
250 }
virtual void disableSource()
Definition: ossimSource.cpp:89
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
◆ enableImage()
bool ossimAtbController::enableImage ( unsigned int  index)
Enable an image in the mosaic for the tonal balancing process
Definition at line 220 of file ossimAtbController.cpp.
References ossimSource::enableSource(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), and PTR_CAST.
221 {
222  if (index >= getNumberOfInputs())
223  return false;
224
225  ossimSource* remapper = PTR_CAST(ossimSource,
226  getInput(index));
227  if (remapper)
228  remapper->enableSource();
229
230  return true;
231 }
virtual void enableSource()
Definition: ossimSource.cpp:84
◆ execute()
bool ossimAtbController::execute ( )
virtual
Implementation of ossimProcessInterface pure virtual method.
Implements ossimProcessInterface.
Definition at line 297 of file ossimAtbController.cpp.
298 {
299  static const char MODULE[] = "ossimAtbController::execute()";
300  if (traceExec()) CLOG << "entering..." << endl;
301
302  setPercentComplete(0.0);
303
304  ossimGridRemapSource* source;
305
306  //***
307  // First verify that all objects needed are initialized:
308  //***
309  int num_images = getNumberOfInputs();
310  if ((!theGridRemapEngine) || (num_images < 2))
311  {
312  CLOG << "WARNING: execute method was called but the controller has not "
313  << "been properly initialized. Ignoring request..." << endl;
314  if (traceExec()) CLOG << "returning..." << endl;
315  return false;
316  }
317
318  //***
319  // establish the remap grids:
320  //***
322  setPercentComplete(10.0);
323
324  //***
325  // Establish grid of matchpoints:
326  //***
327  int numPoints = 0;
328  ossimDpt mp_view_pt;
329  theMatchPoints.clear();
330  for (mp_view_pt.line = theBoundingRect.ul().line;
331  mp_view_pt.line <= theBoundingRect.lr().line;
332  mp_view_pt.line += theGridSpacing.line)
333  {
334  for (mp_view_pt.samp = theBoundingRect.ul().samp;
335  mp_view_pt.samp <= theBoundingRect.lr().samp;
336  mp_view_pt.samp += theGridSpacing.samp)
337  {
338  ossimAtbMatchPoint* mp = new ossimAtbMatchPoint(mp_view_pt,
340  theMatchPoints.push_back(mp);
341  numPoints++;
342  }
343  }
344
345  //***
346  // Loop over each matchpoint to determine which images contribute statistics:
347  //***
348  setPercentComplete(20.0);
349  for (int mp=0; mp<numPoints; mp++)
350  {
351  ossimDpt view_point (theMatchPoints[mp]->viewPoint());
352
353  //***
354  // Loop over each image source to check if point lies inside its bounding
355  // rectangle, and add its contribution to the matchpoint's collection:
356  //***
357  for (int src=0; src<num_images; src++)
358  {
359  source = PTR_CAST(ossimGridRemapSource, getInput(src));
360  if (source)
361  {
362  ossimDrect image_rect (source->getBoundingRect());
363  if (image_rect.pointWithin(view_point))
364  theMatchPoints[mp]->addImage(source);
365  }
366  }
367
368  setPercentComplete(20.0 + 50.0*(mp/numPoints));
369  }
370
371  //***
372  // All contributors have been included in all matchpoints' collections.
373  // Compute the target pixel value for each matchpoint and communicate it
374  // to the corresponding remappers:
375  //***
376  for (int mp=0; mp<numPoints; mp++)
377  {
378  setPercentComplete(70.0 + 30.0*(mp/numPoints));
379  theMatchPoints[mp]->assignRemapValues();
380  }
381
382  //***
383  // Finally, enable the remappers:
384  //***
385  for (int src=0; src<num_images; src++)
386  {
387  source = PTR_CAST(ossimGridRemapSource, getInput(src));
388  if (source)
389  source->enableSource();
390  }
391  setPercentComplete(100.0);
392
393  if (traceExec()) CLOG << "returning..." << endl;
394  return true;
395 }
This will return the bounding rect of the source.
#define CLOG
double samp
Definition: ossimDpt.h:164
const ossimDpt & ul() const
Definition: ossimDrect.h:339
virtual void setPercentComplete(double percentComplete)
double line
Definition: ossimDpt.h:165
ossim_int32 samp
Definition: ossimIpt.h:141
ossim_int32 line
Definition: ossimIpt.h:142
const ossimDpt & lr() const
Definition: ossimDrect.h:341
◆ getObject() [1/2]
virtual ossimObject* ossimAtbController::getObject ( )
inlinevirtual
Definition at line 60 of file ossimAtbController.h.
61  {
62  return this;
63  }
◆ getObject() [2/2]
virtual const ossimObject* ossimAtbController::getObject ( ) const
inlinevirtual
Definition at line 64 of file ossimAtbController.h.
65  {
66  return this;
67  }
◆ initializeRemappers()
void ossimAtbController::initializeRemappers ( )
protected
Definition at line 467 of file ossimAtbController.cpp.
468 {
469  static const char MODULE[] = "ossimAtbController::initializeRemappers()";
470  if (traceExec()) CLOG << "entering..." << endl;
471
472  int num_images = getNumberOfInputs();
473
474  //***
475  // Fetch the overall mosaic bounding rect:
476  //***
478  getInput(0));
479  theBoundingRect = remapper->getBoundingRect();
480  for (int src=1; src<num_images; src++)
481  {
483  }
484
485  //***
486  // Loop over each contribution image source chain to fetch each image
487  // bounding rect:
488  //***
489  double dx_ul, dy_ul, dx_lr, dy_lr;
490  double grid_ul_x, grid_ul_y, grid_lr_x, grid_lr_y;
491  for (int src=0; src<num_images; src++)
492  {
493  remapper = PTR_CAST(ossimGridRemapSource, getInput(src));
494  ossimDrect image_rect (remapper->getBoundingRect());
495
496  //***
497  // Arrive at the number of grid posts from mosaic origin to image's grid
498  // UL and LR corners:
499  //***
500  dx_ul = (image_rect.ul().x - theBoundingRect.ul().x)/theGridSpacing.x;
501  dy_ul = (image_rect.ul().y - theBoundingRect.ul().y)/theGridSpacing.y;
502  dx_lr = (image_rect.lr().x - theBoundingRect.lr().x)/theGridSpacing.x;
503  dy_lr = (image_rect.lr().y - theBoundingRect.lr().y)/theGridSpacing.y;
504
505  //***
506  // Establish the view coordinates for the adjusted image grid:
507  //***
508  grid_ul_x = theBoundingRect.ul().x + ceil(dx_ul)*theGridSpacing.x;
509  grid_ul_y = theBoundingRect.ul().y + ceil(dy_ul)*theGridSpacing.y;
510  grid_lr_x = theBoundingRect.lr().x + floor(dx_lr)*theGridSpacing.x;
511  grid_lr_y = theBoundingRect.lr().y + floor(dy_lr)*theGridSpacing.y;
512
513  //***
514  // Have the remapper initialize a new grid with the given rectangle and
515  // spacing:
516  //***
517  ossimDrect grid_rect (grid_ul_x, grid_ul_y, grid_lr_x, grid_lr_y);
518  remapper->initialize(grid_rect, theGridSpacing);
519  }
520
521  if (traceExec()) CLOG << "returning..." << endl;
522  return;
523 }
#define CLOG
double y
ossimDrect combine(const ossimDrect &rect) const
Definition: ossimDrect.h:826
ossim_int32 y
double x
ossim_int32 x
virtual void initialize(const ossimDrect &uv_rect, const ossimDpt &grid_spacing)
◆ initializeWithCombiner()
void ossimAtbController::initializeWithCombiner ( ossimImageCombiner combiner,
Provide alternate means of initialization in case default constructor used.
Definition at line 130 of file ossimAtbController.cpp.
132 {
133  static const char MODULE[] = "ossimAtbController::initializeWithCombiner()";
134  if (traceExec()) CLOG << "entering..." << endl;
135
136  //***
137  // Assign default engine if non provided:
138  //***
139  if (engine)
141  else
143  = ossimGridRemapEngineFactory::create(DEFAULT_ATB_REMAP_ENGINE);
144
145  //***
146  // This is the first combiner initializing the controller. The combiner
147  // will have all of the input sources connected already. We attach to
148  // these:
149  //***
151
152  //***
153  // Need to scan the input connections of the combiner and insert a
154  // remapper if there is not one already at the end of the input chain:
155  //***
156  vector<ossimConnectableObject*> del_list;
157  vector<ossimConnectableObject*> add_list;
158  int numInputs = combiner->getNumberOfInputs();
159  for(int i=0; i<numInputs; i++)
160  {
162  combiner->getInput(i));
163
164  if (input_image)
165  {
167  input_image);
168  if (remapper)
169  {
170  //***
171  // Remapper already present, set its remap engine to this
172  // controller's remap engine:
173  //***
175  }
176
177  else
178  {
179  //***
180  // Need to instantiate remapper:
181  //***
182  remapper = new ossimGridRemapSource(input_image,
184  if (theContainer.valid())
185  theContainer->addChild(remapper);
186
187  add_list.push_back(remapper);
188  del_list.push_back(input_image);
189  }
190
191  connectMyInputTo(remapper);
192  }
193  }
194
195  //***
196  // Need to delete the old inputs and add the new remappers to the
197  // combiner's input list:
198  //***
199  vector<ossimConnectableObject*>::iterator add_iter = add_list.begin();
200  vector<ossimConnectableObject*>::iterator del_iter = del_list.begin();
201  while (add_iter != add_list.end())
202  {
203  (*add_iter)->connectMyInputTo(*del_iter);
204  combiner->disconnect(*del_iter);
205  combiner->connectMyInputTo(*add_iter);
206  add_iter++;
207  del_iter++;
208  }
209  combiner->initialize();
210
211  if (traceExec()) CLOG << "returning..." << endl;
212 }
virtual ossimObject * dup() const =0
void setRemapEngine(ossimGridRemapEngine *engine)
const ossimObject * getOwner() const
Fetches the current owner, most likely a container but not limited to one.
#define CLOG
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
virtual bool addChild(ossimConnectableObject *attachableObject)
◆ loadState()
bool ossimAtbController::loadState ( const ossimKeywordlist kwl)
virtual
Definition at line 430 of file ossimAtbController.cpp.
431 {
432  static const char MODULE[] = "ossimAtbController::loadState()";
433  if (traceExec()) CLOG << "entering..." << endl;
434
435  CLOG << "NOTICE: this method not yet implemented." << endl;
436
437  if (traceExec()) CLOG << "returning..." << endl;
438  return true;
439 }
#define CLOG
◆ lockImage()
bool ossimAtbController::lockImage ( unsigned int  index)
Locks a particular source for adjustment. A locked image effectively defines the target values for all overlapping imagery.
Definition at line 259 of file ossimAtbController.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimGridRemapSource::lock(), and PTR_CAST.
260 {
261  if (index >= getNumberOfInputs())
262  return false;
263
265  getInput(index));
266  if (remapper)
267  remapper->lock();
268
269  return true;
270 }
◆ saveState()
bool ossimAtbController::saveState ( ossimKeywordlist kwl) const
virtual
Implementations of ossimStateInterface pure virtuals
Definition at line 415 of file ossimAtbController.cpp.
416 {
417  static const char MODULE[] = "ossimAtbController::saveState()";
418  if (traceExec()) CLOG << "entering..." << endl;
419
420  CLOG << "NOTICE: this method not yet implemented." << endl;
421
422  if (traceExec()) CLOG << "returning..." << endl;
423  return true;
424 }
#define CLOG
◆ setGridRemapEngine()
void ossimAtbController::setGridRemapEngine ( ossimGridRemapEngine engine)
Sets the ATB remap engine. This object implements the specific tonal balancing algorithm. The dependency on number of bands and color space, is limited only to this engine. This facilitates the implementation of various grid-based image matching schemes.
Definition at line 529 of file ossimAtbController.cpp.
530 {
531  static const char MODULE[] = "ossimAtbController::setGridRemapEngine()";
532  if (traceExec()) CLOG << "entering..." << endl;
533
534  theGridRemapEngine = engine;
535
536  //***
537  // Communicate the new engine to all member's interested:
538  //***
539  ossimGridRemapSource* remapper;
540  ossimConnectableObject::ConnectableObjectList::iterator iter=theInputObjectList.begin();
541  while (iter != theInputObjectList.end())
542  {
543  remapper = PTR_CAST(ossimGridRemapSource, (*iter).get());
544  remapper->setRemapEngine(engine);
545  iter++;
546  }
547
548  vector<ossimRefPtr<ossimAtbMatchPoint> >::iterator match_point = theMatchPoints.begin();
549  while (match_point != theMatchPoints.end())
550  {
551  (*match_point)->setGridRemapEngine(engine);
552  match_point++;
553  }
554
555  if (traceExec()) CLOG << "returning..." << endl;
556  return;
557 }
#define CLOG
ConnectableObjectList theInputObjectList
Holds a list of input objects.
◆ setGridSpacing()
void ossimAtbController::setGridSpacing ( const ossimIpt spacing)
Sets the grid spacing used in gridding the mosaic's bounding rectangle.
◆ setKernelSize()
void ossimAtbController::setKernelSize ( int  side_size)
Hook to set the size of the kernel used by all point sources in computing their mean pixel value. The kernels will be resized to NxN.
Definition at line 449 of file ossimAtbController.cpp.
450 {
451  static const char MODULE[] = "ossimAtbController::setKernelSize(N)";
452  if (traceExec()) CLOG << "entering..." << endl;
453
454  vector<ossimRefPtr<ossimAtbMatchPoint> >::iterator mpi = theMatchPoints.begin();
455  while (mpi != theMatchPoints.end())
456  (*mpi)->setKernelSize(side_size);
457
458  if (traceExec()) CLOG << "returning..." << endl;
459  return;
460 }
#define CLOG
◆ unlockImage()
bool ossimAtbController::unlockImage ( unsigned int  index)
Unlock a particular source for adjustment.
Definition at line 279 of file ossimAtbController.cpp.
280 {
281  if (index >= getNumberOfInputs())
282  return false;
283
285  getInput(index));
286  if (remapper)
287  remapper->lock();
288
289  return true;
290 }
Member Data Documentation
◆ theBoundingRect
ossimDrect ossimAtbController::theBoundingRect
protected
Definition at line 137 of file ossimAtbController.h.
◆ theContainer
ossimRefPtr<ossimConnectableContainer> ossimAtbController::theContainer
protected
Definition at line 138 of file ossimAtbController.h.
Referenced by ~ossimAtbController().
◆ theGridRemapEngine
ossimGridRemapEngine* ossimAtbController::theGridRemapEngine
protected
Definition at line 139 of file ossimAtbController.h.
◆ theGridSpacing
ossimIpt ossimAtbController::theGridSpacing
protected
Definition at line 141 of file ossimAtbController.h.
◆ theMatchPoints
std::vector<ossimRefPtr<ossimAtbMatchPoint> > ossimAtbController::theMatchPoints
protected
Definition at line 140 of file ossimAtbController.h.
