Public Member Functions | Private Member Functions | List of all members
ossimAuxXmlSupportData Class Reference
Utility/support data class to extract the projection from a dot aux dot xml file commonly found with mrsid data. More...
#include <ossimAuxXmlSupportData.h>
 ossimAuxXmlSupportData ()
 default constructor More...
virtual ~ossimAuxXmlSupportData ()
 virtual destructor More...
ossimRefPtr< ossimProjectiongetProjection (const ossimFilename &file) const
 Method to get a projection if possible. More...
bool getPath (const ossimString &path, const ossimXmlDocument &xdoc, ossimString &s) const
 Gets path from doc and initializes string. More...
bool initializeProjection (const ossimXmlDocument xdoc, const std::string &wkt, ossimProjection *proj) const
 Sets tie and scale. More...
bool getProjcsName (const std::string &wkt, std::string &name) const
 Get first parameter from PROJCS[ ... More...
ossimUnitType getUnits (const std::string &wkt) const
 Gets units of Projected Coordinate System. More...
Detailed Description
Definition at line 34 of file ossimAuxXmlSupportData.h.
◆ ossimAuxXmlSupportData()
ossimAuxXmlSupportData::ossimAuxXmlSupportData ( )
default constructor
Definition at line 37 of file ossimAuxXmlSupportData.cpp.
38 {
39 }
◆ ~ossimAuxXmlSupportData()
ossimAuxXmlSupportData::~ossimAuxXmlSupportData ( )
virtual
virtual destructor
Definition at line 41 of file ossimAuxXmlSupportData.cpp.
42 {
43 }
Member Function Documentation
◆ getPath()
bool ossimAuxXmlSupportData::getPath ( const ossimString path,
ossimString s
) const
private
Parameters
pathXml path to look for.
xdocXml doc to look in.
sString to initialize.
Returns
true on success and false if path is not found or if there are more than one of path.
Definition at line 234 of file ossimAuxXmlSupportData.cpp.
References ossimXmlDocument::findNodes().
Referenced by getProjection().
236 {
237  bool result = false;
238
239  std::vector<ossimRefPtr<ossimXmlNode> > xnodes;
240  xdoc.findNodes(path, xnodes);
241  if ( xnodes.size() == 1 ) // Error if more than one.
242  {
243  if ( xnodes[0].valid() )
244  {
245  s = xnodes[0]->getText();
246  result = true;
247  }
248  else if(traceDebug())
249  {
251  << "ossimAuxXmlSupportData::getPath ERROR:\n"
252  << "Node not found: " << path
253  << std::endl;
254  }
255  }
256  else if ( xnodes.size() == 0 )
257  {
258  if(traceDebug())
259  {
261  << "ossimAuxXmlSupportData::getPath ERROR:\n"
262  << "Node not found: " << path
263  << std::endl;
264  }
265  }
266  else
267  {
268  if(traceDebug())
269  {
271  << "ossimAuxXmlSupportData::getPath ERROR:\n"
272  << "Multiple nodes found: " << path
273  << std::endl;
274  }
275  }
276
277  if (!result)
278  {
279  s.clear();
280  }
281  return result;
282
283 } // bool ossimAuxXmlSupportData::getPath
void clear()
Erases the entire container.
Definition: ossimString.h:432
void findNodes(const ossimString &xpath, std::vector< ossimRefPtr< ossimXmlNode > > &nodelist) const
Appends any matching nodes to the list supplied (should be empty):
◆ getProjcsName()
bool ossimAuxXmlSupportData::getProjcsName ( const std::string &  wkt,
std::string &  name
) const
private
] string.
Parameters
wktWell known tet string.
nameInitialized by this with name if found.
Returns
Definition at line 287 of file ossimAuxXmlSupportData.cpp.
289 {
290  bool result = false;
291
292  if ( wkt.size() )
293  {
294  // Find "PROJCS":
295  std::string::size_type startPos = wkt.find( std::string("PROJCS[") );
296  if ( startPos != std::string::npos )
297  {
298  startPos += 7; // Move to end of projcs[ string.
299
300  // Find first comma ',':
301  std::string::size_type endPos = wkt.find( ',', startPos+1 );
302  if ( endPos != std::string::npos )
303  {
304  if ( startPos < endPos )
305  {
306  name = wkt.substr( startPos, endPos-startPos );
307  if ( name.size() )
308  {
309  result = true;
310  }
311  }
312  }
313  }
314  }
315
316  return result;
317
318 } // End: ossimAuxXmlSupportData::getProgcsName
◆ getProjection()
ossimRefPtr< ossimProjection > ossimAuxXmlSupportData::getProjection ( const ossimFilename file) const
Parameters
fileFile name to open.
Returns
Projection pointer wrapped in ref pointer. Can be null if projection cannot be established.
Definition at line 45 of file ossimAuxXmlSupportData.cpp.
References ossimString::contains(), ossimProjectionFactoryRegistry::createProjection(), ossimRefPtr< T >::get(), getPath(), getProjcsName(), ossimString::gsub(), initializeProjection(), ossimProjectionFactoryRegistry::instance(), ossim::StreamFactoryRegistry::instance(), ossimXmlDocument::read(), ossimString::size(), ossimString::string(), ossimString::substitute(), and ossimRefPtr< T >::valid().
Referenced by ossimMrSidReader::getExternalImageGeometry().
46 {
48
49  std::shared_ptr<ossim::istream> is = ossim::StreamFactoryRegistry::instance()->
50  createIstream(file, std::ios_base::in | std::ios_base::binary);
51
52  if ( is && is->good() )
53  {
54  // Read the xml document:
55  ossimXmlDocument xdoc;
56  if ( xdoc.read( *is ) )
57  {
58  // Get the WKT string
59  ossimString wkt;
60  ossimString path = "/PAMDataset/Metadata/GeodataXform/SpatialReference/WKT";
61  if ( getPath( path, xdoc, wkt ) )
62  {
63  if ( wkt.size() )
64  {
65  // Substitute "&quot;":
66  ossimString tmpWkt = wkt.substitute( ossimString("&quot;"), ossimString(""), true );
67
68  ossimString name;
69  if ( getProjcsName( tmpWkt.string(), name.string() ) )
70  {
72  if ( result.valid() == false )
73  {
74  // Hack...
75  if ( name.contains("_NAD83_") )
76  {
77  cout << "name1: " << name << endl;
78  name.gsub( ossimString("Georef_NAD83_m"), ossimString("GeoRef_M"), false );
79  name.string() = std::string("NAD_1983_") + name.string();
80  cout << "name2: " << name << endl;
82  createProjection( name );
83  }
84  }
85
86  if ( result.valid() )
87  {
88  if ( initializeProjection( xdoc, tmpWkt.string(), result.get() ) == false )
89  {
90  // Zero out the result if tie or scale not set.
91  result = 0;
92  }
93  }
94  }
95  }
96  }
97  }
98  }
99
100  return result;
101
102 } // End: ossimAuxXmlSupportData::getProjection
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
bool valid() const
Definition: ossimRefPtr.h:75
bool contains(char aChar) const
Definition: ossimString.h:58
static StreamFactoryRegistry * instance()
bool getPath(const ossimString &path, const ossimXmlDocument &xdoc, ossimString &s) const
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
std::string::size_type size() const
Definition: ossimString.h:405
bool initializeProjection(const ossimXmlDocument xdoc, const std::string &wkt, ossimProjection *proj) const
Sets tie and scale.
static ossimProjectionFactoryRegistry * instance()
bool read(std::istream &in)
ossimString & gsub(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false)
Substitutes searchKey string with replacementValue and returns a reference to *this.
const std::string & string() const
Definition: ossimString.h:414
bool getProjcsName(const std::string &wkt, std::string &name) const
◆ getUnits()
ossimUnitType ossimAuxXmlSupportData::getUnits ( const std::string &  wkt) const
private
Parameters
Returns
Units.
Definition at line 320 of file ossimAuxXmlSupportData.cpp.
References ossimString::contains(), ossimString::downcase(), OSSIM_DEGREES, OSSIM_FEET, OSSIM_UNIT_UNKNOWN, and OSSIM_US_SURVEY_FEET.
Referenced by initializeProjection().
321 {
323  if ( wkt.size() )
324  {
325  // Note this is order dependent, i.e. you have to look for "Foot_US" before "Foot".
326  ossimString os = wkt;
327  os.downcase();
328  if ( os.contains("feet_intl") )
329  {
330  units = OSSIM_FEET;
331  }
332  else if ( os.contains("foot_us") )
333  {
334  units = OSSIM_US_SURVEY_FEET;
335  }
336  else if ( os.contains("feet") || os.contains("foot") )
337  {
338  units = OSSIM_FEET;
339  }
340  //---
341  // There can be two "unit" blocks. One for PROJCS and one for GEOGCS.
342  // Do this last as the GEOGCS block will have Degree in it. May need to split
343  // the two blocks and then search if this doesn't work.
344  //---
345  else if ( os.contains("degree") )
346  {
347  units = OSSIM_DEGREES;
348  }
349  }
350
351  return units;
352
353 } // End: ossimAuxXmlSupportData::getUnits
ossimUnitType
◆ initializeProjection()
bool ossimAuxXmlSupportData::initializeProjection ( const ossimXmlDocument  xdoc,
ossimProjection proj
) const
private
Sets tie and scale.
Parameters
xdocXml document.
Returns
True on success, false on error.
Definition at line 104 of file ossimAuxXmlSupportData.cpp.
References ossimXmlDocument::findNodes(), getUnits(), ossimXmlAttribute::getValue(), ossimDpt::hasNans(), ossimMapProjection::isGeographic(), ossimDpt::makeNan(), MTRS_PER_FT, OSSIM_FEET, OSSIM_METERS, OSSIM_US_SURVEY_FEET, ossimNotify(), ossimNotifyLevel_WARN, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlTiePoints(), ossimString::size(), size, ossimString::split(), ossimString::toFloat64(), US_METERS_PER_FT, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
107 {
108  bool result = false;
109
110  ossimRefPtr<ossimMapProjection> mapProj = dynamic_cast<ossimMapProjection*>( proj );
111  if ( mapProj.valid() )
112  {
113  // Find the tie and scale.
114  ossimString path = "/PAMDataset/Metadata/MDI";
115  std::vector<ossimRefPtr<ossimXmlNode> > xnodes;
116  xdoc.findNodes(path, xnodes);
117  if ( xnodes.size() )
118  {
119  ossimDpt tie;
120  ossimDpt scale;
121  tie.makeNan();
122  scale.makeNan();
123
124  for ( ossim_uint32 i = 0; i < xnodes.size(); ++i )
125  {
126  if ( xnodes[i].valid() )
127  {
128  ossimString value;
129  ossimString attrName = "key";
130
131  ossimRefPtr<ossimXmlAttribute> attr = xnodes[i]->findAttribute( attrName );
132  if ( attr.valid() )
133  {
134  if (attr->getValue() == "IMAGE__XY_ORIGIN" )
135  {
136  value = xnodes[i]->getText();
137  if ( value.size() )
138  {
139  // Split it:
140  std::vector<ossimString> list;
141  value.split( list, ossimString(","), true );
142  if ( list.size() == 2 )
143  {
144  if ( list[0].size() )
145  {
146  tie.x = list[0].toFloat64();
147  }
148  if ( list[1].size() )
149  {
150  tie.y = list[1].toFloat64();
151  }
152  }
153  }
154  }
155  else if (attr->getValue() == "IMAGE__X_RESOLUTION" )
156  {
157  value = xnodes[i]->getText();
158  if ( value.size() )
159  {
160  scale.x = value.toFloat64();
161  }
162  }
163  else if (attr->getValue() == "IMAGE__Y_RESOLUTION" )
164  {
165  value = xnodes[i]->getText();
166  if ( value.size() )
167  {
168  scale.y = value.toFloat64();
169  }
170  }
171  }
172
173  } // Matches: if ( xnodes[i].valid() )
174
175  } // Matches: for ( ossim_uint32 i = 0; i < xnodes.size(); ++i )
176
177  if ( !tie.hasNans() && !scale.hasNans() )
178  {
179  if ( mapProj->isGeographic() )
180  {
181  // Assuming tie and scale in decimal degrees:
182  mapProj->setDecimalDegreesPerPixel( scale );
183  ossimGpt gpt(tie.y, tie.x, 0.0);
184  mapProj->setUlTiePoints( ossimGpt( gpt ) );
185  result = true;
186  }
187  else
188  {
189  // Get the units:
190  ossimUnitType units = getUnits( wkt );
191
192  // Convert to meters:
193  result = true;
194  if ( units != OSSIM_METERS )
195  {
196  if ( units == OSSIM_FEET )
197  {
198  tie.x = tie.x * MTRS_PER_FT;
199  tie.y = tie.y * MTRS_PER_FT;
200  scale.x = scale.x * MTRS_PER_FT;
201  scale.y = scale.y * MTRS_PER_FT;
202  }
203  else if ( units == OSSIM_US_SURVEY_FEET)
204  {
205  tie.x = tie.x * US_METERS_PER_FT;
206  tie.y = tie.y * US_METERS_PER_FT;
207  scale.x = scale.x * OSSIM_US_SURVEY_FEET;
208  scale.y = scale.y * OSSIM_US_SURVEY_FEET;
209  }
210  else
211  {
213  << "ossimAuxXmlSupportData::initializeProjection WARNING: "
214  << "Unhandled unit type: " << units << std::endl;
215  result = false;
216  }
217  }
218
219  if ( result )
220  {
221  mapProj->setMetersPerPixel( scale );
222  mapProj->setUlTiePoints( tie );
223  }
224  }
225  }
226
227  } // Matches: if ( xnodes.size() )
228  }
229
230  return result;
231
232 } // ossimAuxXmlSupportData::initializeProjection
ossimUnitType
bool valid() const
double y
Definition: ossimDpt.h:165
virtual bool isGeographic() const
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
const ossimString & getValue() const
virtual void setMetersPerPixel(const ossimDpt &gsd)
#define US_METERS_PER_FT
yy_size_t size
unsigned int ossim_uint32
ossim_float64 toFloat64() const
bool hasNans() const
Definition: ossimDpt.h:67
#define MTRS_PER_FT
double x
Definition: ossimDpt.h:164
virtual void setUlTiePoints(const ossimGpt &gpt)
ossimUnitType getUnits(const std::string &wkt) const
void makeNan()
Definition: ossimDpt.h:65
