#include <ossimProjectionFactoryRegistry.h>
virtual | ~ossimProjectionFactoryRegistry () |
ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
ossimProjection * | createProjection (const ossimString &name) const |
ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=NULL) const |
virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
This should return the type name of all objects in all factories. More... | |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimFactoryListInterface () | |
void | addFactory (ossimProjectionFactoryBase *factory) |
This is for backward compatability and calls registerFactory for simple adds. More... | |
bool | isFactoryRegistered (ossimProjectionFactoryBase *factory) const |
Public access method to determine if a factory is already registered to this list. More... | |
void | registerFactory (ossimProjectionFactoryBase *factory, bool pushToFrontFlag=false) |
Will register a factory to the factory list. More... | |
void | unregisterFactory (ossimProjectionFactoryBase *factory) |
Will remove the factory from the registry. More... | |
void | unregisterFactory (const ossimString &factoryTypeName) |
Will remove the factory from the registry by name. More... | |
void | unregisterAllFactories () |
Will remove all factories from the registry. More... | |
void | registerFactoryToFront (ossimProjectionFactoryBase *factory) |
Inserts the factory to the front of the list. More... | |
void | registerFactoryBefore (ossimProjectionFactoryBase *factory, ossimProjectionFactoryBase *beforeThisFactory) |
Will insert the factory before the beforeThisFactory. More... | |
void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
Will add all object types the factories can allocate. More... | |
ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
This is the base object return for all objects in the system. More... | |
ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
ossimProjection * | createNativeObjectFromRegistry (const ossimString &typeName) const |
This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
ossimProjection * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
static ossimProjectionFactoryRegistry * | instance () |
ossimProjectionFactoryRegistry () | |
ossimProjectionFactoryRegistry (const ossimProjectionFactoryRegistry &rhs) | |
void | operator= (const ossimProjectionFactoryRegistry &) |
void | initializeDefaults () |
virtual | ~ossimReferenced () |
bool | findFactory (ossimProjectionFactoryBase *factory) const |
Utility to find a factory in the list. More... | |
typedef std::vector< ossimProjectionFactoryBase *> | FactoryListType |
typedef ossimProjectionFactoryBase | FactoryType |
typedef ossimProjection | NativeReturnType |
std::mutex | m_factoryListMutex |
FactoryListType | m_factoryList |
Definition at line 20 of file ossimProjectionFactoryRegistry.h.
Definition at line 44 of file ossimProjectionFactoryRegistry.cpp.
protected |
Definition at line 30 of file ossimProjectionFactoryRegistry.cpp.
References initializeDefaults(), ossimObjectFactoryRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
protected |
Definition at line 36 of file ossimProjectionFactoryRegistry.cpp.
inlinevirtual |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 44 of file ossimProjectionFactoryRegistry.h.
References ossimFactoryListInterface< T, NativeType >::createObjectFromRegistry().
inlinevirtual |
Creates and object given a keyword list.
Definition at line 52 of file ossimProjectionFactoryRegistry.h.
ossimProjection * ossimProjectionFactoryRegistry::createProjection | ( | const ossimFilename & | filename, |
ossim_uint32 | entryIdx | ||
) | const |
Definition at line 62 of file ossimProjectionFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::m_factoryList.
Referenced by ossimKakaduJpipImageGeometryFactory::createGeometry(), ossimIgenGenerator::createProductProjection(), ossimJpipProjectionFactory::createProjection(), ossimTiffProjectionFactory::createProjection(), ossimKakaduJpipImageGeometryFactory::createProjection(), ossimImageGeometryFactory::createProjection(), ossimMapProjectionFactory::createProjection(), ossimMG4LidarReader::getGeoProjection(), ossimMrSidReader::getGeoProjection(), ossimAuxXmlSupportData::getProjection(), ossim::Image::loadJSON(), ossimMapViewController::loadState(), main(), ossimMapViewController::setFilename(), ossimRpcProjection::setupOptimizer(), and ossimRpcModel::setupOptimizer().
inline |
Definition at line 33 of file ossimProjectionFactoryRegistry.h.
References ossimFactoryListInterface< T, NativeType >::createNativeObjectFromRegistry().
ossimProjection * ossimProjectionFactoryRegistry::createProjection | ( | const ossimKeywordlist & | kwl, |
const char * | prefix = NULL |
) | const |
Definition at line 87 of file ossimProjectionFactoryRegistry.cpp.
References ossimString::c_str(), ossimKeywordlist::getMap(), ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::m_factoryList, ossimString::size(), and ossimString::split().
Definition at line 75 of file ossimProjectionFactoryRegistry.cpp.
inlinevirtual |
This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 63 of file ossimProjectionFactoryRegistry.h.
References ossimFactoryListInterface< T, NativeType >::getAllTypeNamesFromRegistry().
protected |
Definition at line 152 of file ossimProjectionFactoryRegistry.cpp.
References ossimHdf5ProjectionFactory::instance(), ossimNgaProjectionFactory::instance(), ossimSensorModelFactory::instance(), ossimMiscProjectionFactory::instance(), ossimTiffProjectionFactory::instance(), ossimMapProjectionFactory::instance(), ossimWktProjectionFactory::instance(), ossimEpsgProjectionFactory::instance(), ossimNitfProjectionFactory::instance(), and ossimFactoryListInterface< ossimProjectionFactoryBase, ossimProjection >::registerFactory().
Referenced by ossimProjectionFactoryRegistry().
static |
Definition at line 48 of file ossimProjectionFactoryRegistry.cpp.
Referenced by ossimKakaduJpipImageGeometryFactory::createGeometry(), ossimIgenGenerator::createProductProjection(), ossimJpipProjectionFactory::createProjection(), ossimTiffProjectionFactory::createProjection(), ossimKakaduJpipImageGeometryFactory::createProjection(), ossimMapProjectionFactory::createProjection(), ossimImageGeometryFactory::createProjection(), ossim::Image::getAvailableModels(), ossimMG4LidarReader::getGeoProjection(), ossimMrSidReader::getGeoProjection(), ossimQbTileFilesHandler::getImageGeometry(), ossimplugins::ossimTerraSarTiffReader::getInternalImageGeometry(), ossimChipperUtil::getNewProjectionFromSrsCode(), ossimAuxXmlSupportData::getProjection(), ossimInit::initializeDefaultFactories(), ossim::Image::loadJSON(), ossimMapViewController::loadState(), ossimH5GridModel::loadState(), ossimImageGeometry::loadState(), main(), ossimAffineProjection::ossimAffineProjection(), ossimProjectionFactoryRegistryGetInstance(), ossimplugins::ossimSharedLibraryFinalize(), ossimSharedLibraryFinalize(), ossimplugins::ossimSharedLibraryInitialize(), ossimSharedLibraryInitialize(), ossimWarpProjection::ossimWarpProjection(), ossimInfo::printProjections(), ossimMapViewController::setFilename(), ossimRpcProjection::setupOptimizer(), and ossimRpcModel::setupOptimizer().
protected |
Definition at line 41 of file ossimProjectionFactoryRegistry.cpp.
