Public Member Functions | Static Public Member Functions | Static Protected Attributes | List of all members
ossimElevationDatabaseFactory Class Reference
This is our default elevation factory in the ossim core. More...
#include <ossimElevationDatabaseFactory.h>
Inheritance diagram for ossimElevationDatabaseFactory:
ossimElevationDatabaseFactoryBase ossimObjectFactory ossimObject ossimReferenced
 ossimElevationDatabaseFactory ()
ossimElevationDatabasecreateDatabase (const ossimString &typeName) const
ossimElevationDatabasecreateDatabase (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossimElevationDatabaseopen (const ossimString &connectionString) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimElevationDatabaseFactoryBase
virtual ossimObjectcreateObject (const ossimString &typeName) const
 Creates an object given a type name. More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimElevationDatabaseFactoryinstance ()
static ossimElevationDatabaseFactorym_instance = 0
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
It supports general_raster, general imagery, DTED and SRTM directory layouts.
Example DTED Keywordlist:
elevation_manager.elevation_source1.type: dted_directory
elevation_manager.elevation_source1.connection_string: /data/elevation/dted/level0
elevation_manager.elevation_source1.min_open_cells: 5
elevation_manager.elevation_source1.max_open_cells: 25
elevation_manager.elevation_source1.enabled: true
elevation_manager.elevation_source1.memory_map_cells: true
Note: only use memory_map_cells to true if they are small files. DTED0 is small so we set it to true. Where the dted file tree has the form: <rootdir>/w056/n49.dt0
Example General Raster directory:
elevation_manager.elevation_source2.type: general_raster_directory
elevation_manager.elevation_source2.connection_string: /data/tutorial/data/elevation/general_raster_pk_90m
elevation_manager.elevation_source2.min_open_cells: 25
elevation_manager.elevation_source2.max_open_cells: 50
elevation_manager.elevation_source2.enabled: false
elevation_manager.elevation_source2.memory_map_cells: false
where the directory is a flat directory with general raster files
Example SRTM directory:
elevation_manager.elevation_source10.type: srtm_directory
elevation_manager.elevation_source10.connection_string: /Volumes/DataDrive/data/elevation/srtm1/
elevation_manager.elevation_source10.min_open_cells: 25
elevation_manager.elevation_source10.max_open_cells: 50
elevation_manager.elevation_source10.memory_map_cells: false
elevation_manager.elevation_source10.enabled: true
where the directory has files of the form N39W112.hgt and are 1x1 degree cells
Example image directory format:
elevation_manager.elevation_source20.type: image_directory
elevation_manager.elevation_source20.connection_string: /data/elevation/image
elevation_manager.elevation_source20.min_open_cells: 25
elevation_manager.elevation_source20.max_open_cells: 50
elevation_manager.elevation_source20.memory_map_cells: false
elevation_manager.elevation_source20.enabled: false
where the directory can have any image the ossim supports and is a flat directory
Definition at line 57 of file ossimElevationDatabaseFactory.h.
◆ ossimElevationDatabaseFactory()
ossimElevationDatabaseFactory::ossimElevationDatabaseFactory ( )
inline
Definition at line 60 of file ossimElevationDatabaseFactory.h.
Referenced by instance().
61  {
62  m_instance = this;
63  }
static ossimElevationDatabaseFactory * m_instance
Member Function Documentation
◆ createDatabase() [1/2]
ossimElevationDatabase * ossimElevationDatabaseFactory::createDatabase ( const ossimString typeName) const
virtual
Parameters
typeNameis the type name of the database you wish to create.
Returns
the elevation database or null otherwise
Implements ossimElevationDatabaseFactoryBase.
Definition at line 20 of file ossimElevationDatabaseFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createDatabase().
21 {
22  if((typeName == STATIC_TYPE_NAME(ossimDtedElevationDatabase)) ||
23  (typeName == "dted")||
24  (typeName == "dted_directory"))
25
26  {
27  return new ossimDtedElevationDatabase();
28  }
29  else if((typeName == STATIC_TYPE_NAME(ossimSrtmElevationDatabase)) ||
30  (typeName == "srtm")||
31  (typeName == "srtm_directory"))
32
33  {
34  return new ossimSrtmElevationDatabase();
35  }
37  (typeName == "general_raster")||
38  (typeName == "general_raster_directory"))
39
40  {
42  }
43  else if( (typeName == "ossimImageElevationDatabase") ||
44  (typeName == "image_directory"))
45
46  {
47  return new ossimImageElevationDatabase();
48  }
49
50  return 0;
51 }
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
The DTED elevation data base is also an elevation source but allows one to point to an file based ele...
◆ createDatabase() [2/2]
ossimElevationDatabase * ossimElevationDatabaseFactory::createDatabase ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlkewyord list that has state information about how to create a database
prefixprefix key to use when loading the state information.
Returns
Definition at line 53 of file ossimElevationDatabaseFactory.cpp.
References createDatabase(), ossimString::empty(), ossimKeywordlist::find(), ossimElevationDatabase::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
55 {
57  ossimString type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
58  if(!type.empty())
59  {
60  result = createDatabase(type);
61  if(result.valid())
62  {
63  if(!result->loadState(kwl, prefix))
64  {
65  result = 0;
66  }
67  }
68  }
69
70  return result.release();
71 }
bool valid() const
Definition: ossimRefPtr.h:75
static const char * TYPE_KW
T * release()
Definition: ossimRefPtr.h:93
ossimElevationDatabase * createDatabase(const ossimString &typeName) const
bool empty() const
Definition: ossimString.h:411
◆ getTypeNameList()
void ossimElevationDatabaseFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListappends to the typeList all the type names this factory supports
Implements ossimObjectFactory.
Definition at line 106 of file ossimElevationDatabaseFactory.cpp.
107 {
108  typeList.push_back(STATIC_TYPE_NAME(ossimDtedElevationDatabase));
109  typeList.push_back(STATIC_TYPE_NAME(ossimSrtmElevationDatabase));
111  typeList.push_back(STATIC_TYPE_NAME(ossimImageElevationDatabase));
112 }
◆ instance()
ossimElevationDatabaseFactory * ossimElevationDatabaseFactory::instance ( )
static
Returns
a singleton instance of this factory
Definition at line 10 of file ossimElevationDatabaseFactory.cpp.
References m_instance, and ossimElevationDatabaseFactory().
Referenced by ossimElevationDatabaseRegistry::instance().
11 {
12  if(!m_instance)
13  {
15  }
16
17  return m_instance;
18 }
◆ open()
ossimElevationDatabase * ossimElevationDatabaseFactory::open ( const ossimString connectionString) const
virtual
Parameters
connectionStringused to determine which database can support that connection.
Returns
Definition at line 73 of file ossimElevationDatabaseFactory.cpp.
References ossimFilename::isFile(), ossimElevationDatabase::open(), and ossimRefPtr< T >::release().
74 {
76  do
77  {
78  result = new ossimDtedElevationDatabase();
79  if (result->open(connectionString))
80  break;
81
82  result = new ossimSrtmElevationDatabase;
83  if (result->open(connectionString))
84  break;
85
87  if (result->open(connectionString))
88  break;
89
90  // This method will only open individual image files for use as dems. It will not utilize the
91  // file walker to search over directories:
92  ossimFilename filename (connectionString);
93  if (filename.isFile())
94  {
95  result = new ossimImageElevationDatabase;
96  if (result->open(connectionString))
97  break;
98  }
99
100  result = 0;
101  } while (0);
102
103  return result.release();
104 }
T * release()
virtual bool open(const ossimString &connectionString)=0
Open a connection to a database.
Member Data Documentation
◆ m_instance
ossimElevationDatabaseFactory * ossimElevationDatabaseFactory::m_instance = 0
staticprotected
Definition at line 99 of file ossimElevationDatabaseFactory.h.
