The DTED elevation data base is also an elevation source but allows one to point to an file based elevation tree. More...
#include <ossimDtedElevationDatabase.h>
Public Types | |
typedef std::vector< ossimRefPtr< CellInfo > > | DirectMap |
typedef std::map< ossim_uint64, ossimRefPtr< CellInfo > > | CellMap |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimDtedElevationDatabase () | |
ossimDtedElevationDatabase (const ossimDtedElevationDatabase &rhs) | |
virtual | ~ossimDtedElevationDatabase () |
virtual ossimObject * | dup () const |
virtual bool | open (const ossimString &connectionString) |
Open a connection to a database. More... | |
virtual bool | pointHasCoverage (const ossimGpt &gpt) const |
METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
virtual double | getHeightAboveMSL (const ossimGpt &) |
Height access methods: More... | |
virtual double | getHeightAboveEllipsoid (const ossimGpt &gpt) |
virtual ossim_uint64 | createId (const ossimGpt &pt) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimElevationCellDatabase () | |
ossimElevationCellDatabase (const ossimElevationCellDatabase &src) | |
virtual ossim_uint32 | getMinOpenCells () const |
virtual ossim_uint32 | getMaxOpenCells () const |
virtual void | setMinMaxOpenCells (ossim_uint64 minCellCount, ossim_uint64 maxCellCount) |
virtual bool | getMemoryMapCellsFlag () const |
virtual void | setMemoryMapCellsFlag (bool flag) |
virtual void | getOpenCellList (std::vector< ossimFilename > &list) const |
void | getCellsForBounds (const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0) |
Gets a list of elevation cells needed to cover bounding box. More... | |
virtual ossimRefPtr< ossimElevCellHandler > | getOrCreateCellHandler (const ossimGpt &gpt) |
ossimElevationDatabase () | |
ossimElevationDatabase (const ossimElevationDatabase &src) | |
virtual double | getMeanSpacingMeters () const |
METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
virtual void | setGeoid (ossimGeoid *geoid) |
ossimGeoid * | getGeoid () |
const ossimGeoid * | getGeoid () const |
const ossimString & | getConnectionString () const |
bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
METHOD: intersectRay() More... | |
virtual double | getMinHeightAboveMSL () const |
Access methods for the bounding elevations: More... | |
virtual double | getMaxHeightAboveMSL () const |
double | getNullHeightValue () const |
Special numeric quantities as defined by this source: More... | |
double | getSeaLevelValue () const |
virtual const ossimGrect & | getBoundingGndRect () const |
METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | initialize () |
Implement ossimSource base-class pure virtuals: More... | |
virtual bool | getComputeStatisticsFlag () const |
Opens a stream to an elevation cell. More... | |
virtual void | setComputeStatisticsFlag (bool flag) |
Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
bool | openDtedDirectory (const ossimFilename &dir) |
void | createRelativePath (ossimFilename &file, const ossimGpt &gpt) const |
void | createFullPath (ossimFilename &file, const ossimGpt &gpt) const |
virtual ossimRefPtr< ossimElevCellHandler > | createCell (const ossimGpt &gpt) |
bool | inititializeExtension (const ossimFilename &dir) |
Scans directory and set m_extension to extension of first dted file found. More... | |
virtual void | remove (ossim_uint64 id) |
void | flushCacheToMinOpenCells () |
virtual | ~ossimElevationDatabase () |
virtual double | getOffsetFromEllipsoid (const ossimGpt &gpt) |
virtual | ~ossimElevSource () |
ossimElevSource () | |
Constructors/Destructors: More... | |
ossimElevSource (const ossimElevSource &src) | |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
The general format of a DTED elevation tree:
<root dir>="">/e|w<longitude value>="">/n|s<latitiude value>="">.<extension> Exmaple 1 kilometer: <root dir>="">/w023/n15.dt0
Note for 1 kilimeter the extension is dt0 and for 90 meter post spacing it is .dt1 and for 30 meter spacing it is .dt2
Definition at line 22 of file ossimDtedElevationDatabase.h.
typedef std::vector<ossimRefPtr<CellInfo> > ossimDtedElevationDatabase::DirectMap |
Definition at line 25 of file ossimDtedElevationDatabase.h.
ossimDtedElevationDatabase::ossimDtedElevationDatabase | ( | ) |
Definition at line 14 of file ossimDtedElevationDatabase.cpp.
Referenced by dup().
ossimDtedElevationDatabase::ossimDtedElevationDatabase | ( | const ossimDtedElevationDatabase & | rhs | ) |
Definition at line 23 of file ossimDtedElevationDatabase.cpp.
Definition at line 32 of file ossimDtedElevationDatabase.cpp.
protectedvirtual |
Reimplemented from ossimElevationCellDatabase.
Definition at line 192 of file ossimDtedElevationDatabase.cpp.
References createFullPath(), ossimFilename::exists(), ossimRefPtr< T >::get(), ossimErrorStatusInterface::getErrorStatus(), and ossimElevationCellDatabase::m_memoryMapCellsFlag.
inlineprotected |
Definition at line 71 of file ossimDtedElevationDatabase.h.
References ossimFilename::dirCat().
Referenced by createCell().
inlinevirtual |
Definition at line 47 of file ossimDtedElevationDatabase.h.
References ossimGpt::latd(), ossimGpt::lond(), ossim::wrap(), x, and y.
protected |
Definition at line 152 of file ossimDtedElevationDatabase.cpp.
References abs, ossimString::c_str(), ossimFilename::dirCat(), ossimGpt::latd(), ossimGpt::lond(), m_extension, and m_upcase.
Implements ossimElevSource.
Definition at line 36 of file ossimDtedElevationDatabase.cpp.
References ossimDtedElevationDatabase().
Reimplemented from ossimElevationDatabase.
Definition at line 136 of file ossimDtedElevationDatabase.cpp.
References ossimElevCellHandler::getAccuracyInfo(), ossimElevationCellDatabase::getOrCreateCellHandler(), m_mutex, and ossimRefPtr< T >::valid().
Reimplemented from ossimElevSource.
Definition at line 62 of file ossimDtedElevationDatabase.cpp.
References getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), and ossim::nan().
Definition at line 42 of file ossimDtedElevationDatabase.cpp.
References ossimElevSource::getHeightAboveMSL(), ossimElevationCellDatabase::getOrCreateCellHandler(), ossimSource::isSourceEnabled(), m_lastHandler, m_mutex, ossim::nan(), ossimElevCellHandler::pointHasCoverage(), and ossimRefPtr< T >::valid().
Referenced by getHeightAboveEllipsoid().
protected |
dir | Directory to scan. |
Definition at line 293 of file ossimDtedElevationDatabase.cpp.
References ossimString::c_str(), ossimString::empty(), ossimFilename::ext(), ossimFilename::file(), ossimDirectory::getFirst(), ossimFilename::isDir(), ossimString::match(), ossimDirectory::open(), ossimDtedHandler::open(), ossimDirectory::OSSIM_DIR_DIRS, ossimDirectory::OSSIM_DIR_FILES, and ossimString::size().
Definition at line 208 of file ossimDtedElevationDatabase.cpp.
References ossimString::empty(), ossimFilename::exists(), ossimKeywordlist::findKey(), ossimPreferences::instance(), ossimElevationCellDatabase::loadState(), ossimElevationDatabase::m_connectionString, m_extension, ossimNotify(), ossimNotifyLevel_WARN, ossimPreferences::preferencesKWL(), ossimString::size(), and ossimString::string().
In most cases this will be a pointer to a directory like in a Dted directory reader.
Implements ossimElevationDatabase.
Definition at line 74 of file ossimDtedElevationDatabase.cpp.
References openDtedDirectory().
protected |
Definition at line 84 of file ossimDtedElevationDatabase.cpp.
Referenced by open().
inlinevirtual |
Definition at line 36 of file ossimDtedElevationDatabase.h.
References ossimFilename::exists().
Definition at line 284 of file ossimDtedElevationDatabase.cpp.
References saveState().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 274 of file ossimDtedElevationDatabase.cpp.
References ossimKeywordlist::add(), m_extension, m_upcase, and ossimElevationCellDatabase::saveState().
Referenced by print().
protected |
Definition at line 89 of file ossimDtedElevationDatabase.h.
Referenced by createRelativePath(), loadState(), and saveState().
protected |
Definition at line 94 of file ossimDtedElevationDatabase.h.
Referenced by getHeightAboveMSL().
mutableprotected |
Definition at line 95 of file ossimDtedElevationDatabase.h.
Referenced by getAccuracyInfo(), and getHeightAboveMSL().
protected |
Definition at line 92 of file ossimDtedElevationDatabase.h.
Referenced by createRelativePath(), and saveState().
