Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimGeoPdfReaderFactory Class Reference
Factory for GeoPdf image reader. More...
#include <ossimGeoPdfReaderFactory.h>
Inheritance diagram for ossimGeoPdfReaderFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimGeoPdfReaderFactory ()
 virtual destructor More...
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
 open that takes a file name. More...
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
 open that takes a keyword list and prefix. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimGeoPdfReader) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list and prefix. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds ossimGeoPdfWriter to the typeList. More...
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
 Method to add supported extension to the list, like "pdf". More...
virtual void getImageHandlersBySuffix (ImageHandlerList &result, const ossimString &ext) const
virtual void getImageHandlersByMimeType (ImageHandlerList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
 Open method that takes a stream. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
 Open overview that takes a file name. More...
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimGeoPdfReaderFactoryinstance ()
 static method to return instance (the only one) of this class. More...
bool hasExcludedExtension (const ossimFilename &file) const
 Method to weed out extensions that this plugin knows it does not support. More...
 hidden from use default constructor More...
 ossimGeoPdfReaderFactory (const ossimGeoPdfReaderFactory &)
 hidden from use copy constructor More...
void operator= (const ossimGeoPdfReaderFactory &)
virtual ~ossimReferenced ()
static ossimGeoPdfReaderFactorytheInstance = 0
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
Detailed Description
Definition at line 21 of file ossimGeoPdfReaderFactory.h.
◆ ~ossimGeoPdfReaderFactory()
ossimGeoPdfReaderFactory::~ossimGeoPdfReaderFactory ( )
virtual
virtual destructor
Definition at line 29 of file ossimGeoPdfReaderFactory.cpp.
References theInstance.
30 {
31  theInstance = 0;
32 }
static ossimGeoPdfReaderFactory * theInstance
◆ ossimGeoPdfReaderFactory() [1/2]
ossimGeoPdfReaderFactory::ossimGeoPdfReaderFactory ( )
protected
Definition at line 166 of file ossimGeoPdfReaderFactory.cpp.
Referenced by instance().
166 {}
◆ ossimGeoPdfReaderFactory() [2/2]
ossimGeoPdfReaderFactory::ossimGeoPdfReaderFactory ( const ossimGeoPdfReaderFactory )
protected
Definition at line 168 of file ossimGeoPdfReaderFactory.cpp.
168 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimGeoPdfReaderFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimKakaduReader".
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 103 of file ossimGeoPdfReaderFactory.cpp.
References ossimRefPtr< T >::release().
105 {
106  ossimRefPtr<ossimObject> result = 0;
107  if(typeName == "ossimGeoPdfReader")
108  {
109  result = new ossimGeoPdfReader;
110  }
111
112  return result.release();
113 }
T * release()
Definition: ossimRefPtr.h:93
◆ createObject() [2/2]
ossimObject * ossimGeoPdfReaderFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image handler on success, NULL on failure.
Definition at line 115 of file ossimGeoPdfReaderFactory.cpp.
References open().
118 {
119  return this->open(kwl, prefix);
120 }
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
◆ getImageHandlersByMimeType()
void ossimGeoPdfReaderFactory::getImageHandlersByMimeType ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 156 of file ossimGeoPdfReaderFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
158 {
159  ossimString testExt = mimeType.downcase();
160  if(testExt == "image/pdf")
161  {
162  result.push_back(new ossimGeoPdfReader);
163  }
164 }
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ getImageHandlersBySuffix()
void ossimGeoPdfReaderFactory::getImageHandlersBySuffix ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString ext
) const
virtual
Definition at line 146 of file ossimGeoPdfReaderFactory.cpp.
148 {
149  ossimString testExt = ext.downcase();
150  if(ext == "pdf")
151  {
152  result.push_back(new ossimGeoPdfReader);
153  }
154 }
◆ getSupportedExtensions()
void ossimGeoPdfReaderFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Parameters
extensionListThe list to add to.
Implements ossimImageHandlerFactoryBase.
Definition at line 128 of file ossimGeoPdfReaderFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
130 {
131  extensionList.push_back(ossimString("pdf"));
132 }
◆ getTypeNameList()
void ossimGeoPdfReaderFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 122 of file ossimGeoPdfReaderFactory.cpp.
124 {
125  typeList.push_back(ossimString("ossimGeoPdfReader"));
126 }
◆ hasExcludedExtension()
bool ossimGeoPdfReaderFactory::hasExcludedExtension ( const ossimFilename file) const
protected
This is to avoid a costly open on say a tiff or jpeg that is not handled by this plugin.
Returns
true if extension, false if not.
Definition at line 134 of file ossimGeoPdfReaderFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
136 {
137  bool result = true;
138  ossimString ext = file.ext().downcase();
139  if (ext == "pdf") //only include the file with .pdf extension and exclude any other files
140  {
141  result = false;
142  }
143  return result;
144 }
ossimString ext() const
◆ instance()
ossimGeoPdfReaderFactory * ossimGeoPdfReaderFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 34 of file ossimGeoPdfReaderFactory.cpp.
References ossimGeoPdfReaderFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
35 {
36  if(!theInstance)
37  {
39  }
40  return theInstance;
41 }
◆ open() [1/2]
ossimImageHandler * ossimGeoPdfReaderFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Parameters
fileThe file to open.
openOverviewIf true image handler will attempt to open overview. default = true
Returns
Definition at line 43 of file ossimGeoPdfReaderFactory.cpp.
Referenced by createObject().
45 {
46  if(traceDebug())
47  {
49  << "ossimGeoPdfReaderFactory::open(filename) DEBUG: entered..."
50  << "\ntrying ossimKakaduNitfReader"
51  << std::endl;
52  }
53
55
56  if ( hasExcludedExtension(fileName) == false )
57  {
58  reader = new ossimGeoPdfReader;
60  if(reader->open(fileName) == false)
61  {
62  reader = 0;
63  }
64  }
65
66  if(traceDebug())
67  {
69  << "ossimGeoPdfReaderFactory::open(filename) DEBUG: leaving..."
70  << std::endl;
71  }
72
73  return reader.release();
74 }
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
bool hasExcludedExtension(const ossimFilename &file) const
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
T * release()
◆ open() [2/2]
ossimImageHandler * ossimGeoPdfReaderFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
Definition at line 76 of file ossimGeoPdfReaderFactory.cpp.
78 {
79  if(traceDebug())
80  {
82  << "ossimGeoPdfReaderFactory::open(kwl, prefix) DEBUG: entered..."
83  << "Trying ossimKakaduNitfReader"
84  << std::endl;
85  }
86
88  if(reader->loadState(kwl, prefix) == false)
89  {
90  reader = 0;
91  }
92
93  if(traceDebug())
94  {
96  << "ossimGeoPdfReaderFactory::open(kwl, prefix) DEBUG: leaving..."
97  << std::endl;
98  }
99
100  return reader.release();
101 }
T * release()
◆ operator=()
void ossimGeoPdfReaderFactory::operator= ( const ossimGeoPdfReaderFactory )
protected
Definition at line 170 of file ossimGeoPdfReaderFactory.cpp.
170 {}
Member Data Documentation
◆ theInstance
ossimGeoPdfReaderFactory * ossimGeoPdfReaderFactory::theInstance = 0
staticprotected
Definition at line 109 of file ossimGeoPdfReaderFactory.h.
Referenced by instance(), and ~ossimGeoPdfReaderFactory().
