16 #ifndef ossimGeoPdfReader_HEADER 17 #define ossimGeoPdfReader_HEADER 1 24 #include <podofo/podofo.h> 160 virtual bool isOpen()
const;
169 virtual void closeEntry();
188 const char* prefix=0);
202 virtual void getEntryList(std::vector<ossim_uint32>& entryList)
const;
209 const char* prefix=0)
const;
225 std::vector<PoDoFo::PdfObject*> entry)
228 thePixelRow(pixelRow),
229 thePixelCol(pixelCol),
235 thePixelRow(rhs.thePixelRow),
236 thePixelCol(rhs.thePixelCol),
237 theFrameEntry(rhs.theFrameEntry)
257 std::vector<ossimFrameEntryData> getIntersectingEntries(
const ossimIrect& rect);
271 void setPodofoInfo(PoDoFo::PdfObject*
object);
273 void setPodofoRefInfo(PoDoFo::PdfObject*
object);
275 void setPodofoArrayInfo(PoDoFo::PdfObject*
object);
277 void setPodofoDictInfo(PoDoFo::PdfObject*
object);
279 void parseTileStructure(std::vector<ossimString> tileInfo);
281 void setPodofoImageInfo();
283 void buildFrameEntryArray();
virtual bool open()=0
Pure virtual open.
PoDoFo::PdfMemDocument * m_pdfMemDocument
ossimScalarType m_scalarType
std::map< ossim_int32, ossim_int32 > m_frameWidthVector
ossimFrameEntryData(const ossimFrameEntryData &rhs)
std::vector< std::vector< std::vector< PoDoFo::PdfObject * > > > m_frameEntryArray
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
ossim_uint32 m_numberOfSamples
virtual ossimString getClassName() const
ossim_uint32 m_numberOfBands
Has sub image offset.
ossimAppFixedTileCache::ossimAppFixedCacheId m_cacheId
virtual ossimString getShortName() const
std::map< ossim_int32, PoDoFo::PdfObject * > m_podofoImageObjs
virtual bool isOpen() const =0
std::vector< PoDoFo::PdfObject * > theFrameEntry
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
ossimFrameEntryData(ossim_int32 row, ossim_int32 col, ossim_int32 pixelRow, ossim_int32 pixelCol, std::vector< PoDoFo::PdfObject *> entry)
virtual ossimString getLongName() const
std::map< ossim_int32, ossim_int32 > m_frameHeightVector
virtual ossim_uint32 getNumberOfEntries() const
#define OSSIM_PLUGINS_DLL
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
std::map< ossim_int32, std::pair< ossim_int32, ossim_int32 > > m_podofoTileInfo
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossim_int32 ossimAppFixedCacheId
ossimRefPtr< ossimImageData > m_cacheTile
std::vector< ossimGeoPdfVectorPageNode * > m_pageVector
virtual ossim_uint32 getImageTileWidth() const =0
std::map< ossimString, ossimString, ossimStringLtstr > m_podofoProjInfo
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_int32 m_numOfFramesVertical
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
ossim_uint32 m_numberOfLines
ossim_int32 m_numOfFramesHorizontal
ossimRefPtr< ossimImageData > m_tile
