Classes | Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimGeoPdfReader Class Reference
#include <ossimGeoPdfReader.h>
Inheritance diagram for ossimGeoPdfReader:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Classes
struct  ossimFrameEntryData
 ossimGeoPdfReader ()
 default construtor More...
virtual ~ossimGeoPdfReader ()
 virtural destructor More...
 Returns short name. More...
 Returns long name. More...
 Returns class name. More...
 Method to grab a tile(rectangle) from image. More...
 Method to get a tile. More...
 Returns the number of bands in the image. More...
 Returns the output pixel type of the tile source. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Gets number of lines for res level. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Gets the number of samples for res level. More...
virtual bool open ()
 Open method. More...
virtual bool isOpen () const
 Method to test for open file stream. More...
virtual void closeEntry ()
 Method to close current entry. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
std::vector< ossimFrameEntryDatagetIntersectingEntries (const ossimIrect &rect)
 It is important to note that each frame is organized into an easting northing type orientation. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
ossimProjectiongetGeoProjection ()
ossimProjectiongetVPGeoProjection ()
ossimProjectiongetLGIDictGeoProjection ()
ossimProjectiongetProjectionFromStr (ossimString projContents)
ossimDrect computeBoundingRect (ossimRefPtr< ossimImageGeometry > geoImage)
void setPodofoInfo (PoDoFo::PdfObject *object)
void setPodofoRefInfo (PoDoFo::PdfObject *object)
void setPodofoArrayInfo (PoDoFo::PdfObject *object)
void setPodofoDictInfo (PoDoFo::PdfObject *object)
void parseTileStructure (std::vector< ossimString > tileInfo)
void setPodofoImageInfo ()
void buildFrameEntryArray ()
void buildTileInfo (ossimString tileInfo)
void resetCacheBuffer (ossimFrameEntryData entry)
template<class T >
void fillTile (T, const ossimIrect &clip_rect, ossimImageData *tile)
Private Attributes
ossimIrect m_imageRect
ossim_uint32 m_numberOfBands
 Has sub image offset. More...
ossim_uint32 m_numberOfLines
ossim_uint32 m_numberOfSamples
ossim_int32 m_numOfFramesVertical
ossim_int32 m_numOfFramesHorizontal
ossim_int32 m_currentRow
ossim_int32 m_currentCol
std::map< ossim_int32, ossim_int32m_frameWidthVector
std::map< ossim_int32, ossim_int32m_frameHeightVector
ossimScalarType m_scalarType
std::map< ossimString, ossimString, ossimStringLtstrm_podofoProjInfo
std::map< ossim_int32, std::pair< ossim_int32, ossim_int32 > > m_podofoTileInfo
std::map< ossim_int32, PoDoFo::PdfObject * > m_podofoImageObjs
PoDoFo::PdfMemDocument * m_pdfMemDocument
bool m_isLGIDict
bool m_isJpeg
std::vector< ossimGeoPdfVectorPageNode * > m_pageVector
ossimRefPtr< ossimImageDatam_cacheTile
ossimIpt m_cacheSize
ossimAppFixedTileCache::ossimAppFixedCacheId m_cacheId
std::vector< std::vector< std::vector< PoDoFo::PdfObject * > > > m_frameEntryArray
Additional Inherited Members
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 42 of file ossimGeoPdfReader.h.
◆ ossimGeoPdfReader()
ossimGeoPdfReader::ossimGeoPdfReader ( )
default construtor
Definition at line 136 of file ossimGeoPdfReader.cpp.
137  : ossimImageHandler(),
139  m_numberOfBands(0),
140  m_numberOfLines(0),
144  m_currentRow(-1),
145  m_currentCol(-1),
149  m_tile(0),
150  m_pdfMemDocument(NULL),
151  m_isLGIDict(false),
152  m_isJpeg(true),
153  m_pageVector(0),
154  m_cacheTile(0),
155  m_cacheSize(0),
156  m_cacheId(-1),
158 {
159 }
std::map< ossim_int32, ossim_int32 > m_frameWidthVector
#define OSSIM_INT_NAN
std::map< ossim_int32, ossim_int32 > m_frameHeightVector
ossimRefPtr< ossimImageData > m_cacheTile
ossimImageHandler()
Constructor (default):
8 bit unsigned integer
ossimRefPtr< ossimImageData > m_tile
◆ ~ossimGeoPdfReader()
ossimGeoPdfReader::~ossimGeoPdfReader ( )
virtual
virtural destructor
Definition at line 161 of file ossimGeoPdfReader.cpp.
References closeEntry().
162 {
163  closeEntry();
164 }
virtual void closeEntry()
Member Function Documentation
◆ buildFrameEntryArray()
void ossimGeoPdfReader::buildFrameEntryArray ( )
private
Definition at line 1255 of file ossimGeoPdfReader.cpp.
References m_frameEntryArray, m_frameHeightVector, m_frameWidthVector, m_imageRect, m_numberOfBands, m_numberOfLines, m_numberOfSamples, m_numOfFramesHorizontal, m_numOfFramesVertical, m_podofoImageObjs, m_podofoTileInfo, and size.
1256 {
1257  m_frameWidthVector.clear();
1258  m_frameHeightVector.clear();
1259  ossim_int32 row = 0;
1260  ossim_int32 col = 0;
1261  if (m_podofoImageObjs.size() > 0 && m_podofoTileInfo.size() > 0)
1262  {
1263  //Podofo libary may skip some objects when reading file which cause the count of objects
1264  //different between tile info and image info. need offset to correct it.
1265  std::map<ossim_int32, std::pair<ossim_int32, ossim_int32> >::iterator itTileEnd;
1266  itTileEnd = m_podofoTileInfo.end();
1267  itTileEnd--;
1268
1269  std::map<ossim_int32, PoDoFo::PdfObject*>::iterator itObjeEnd;
1270  itObjeEnd = m_podofoImageObjs.end();
1271  itObjeEnd--;
1272
1273  ossim_int32 indexOffset = itTileEnd->first - itObjeEnd->first;
1274
1275  std::map<ossim_int32, std::pair<ossim_int32, ossim_int32> >::iterator it = m_podofoTileInfo.begin();
1276  //get number of vertical frames and number of horizontal frames
1277  while (it != m_podofoTileInfo.end())
1278  {
1279  ossim_int32 index = it->first;
1280  if (indexOffset > 0)
1281  {
1282  index = index - indexOffset;
1283  }
1284  std::map<ossim_int32, PoDoFo::PdfObject*>::iterator itObj = m_podofoImageObjs.find(index);
1285  if (itObj != m_podofoImageObjs.end())
1286  {
1287  row = it->second.first;
1288  col = it->second.second;
1289  if (m_numOfFramesHorizontal <= col)
1290  {
1292  }
1293  if (m_numOfFramesVertical <= row)
1294  {
1295  m_numOfFramesVertical = row;
1296  }
1297  }
1298  it++;
1299  }
1300
1301  //set up array size
1304
1306  for(ossim_uint32 index = 0; index < m_frameEntryArray.size(); index++)
1307  {
1309  }
1310
1311  //build array
1312  it = m_podofoTileInfo.begin();
1313  std::vector<PoDoFo::PdfObject*> tmpObjVector;
1314  while (it != m_podofoTileInfo.end())
1315  {
1316  ossim_int32 index = it->first;
1317  if (indexOffset > 0)
1318  {
1319  index = index - indexOffset;
1320  }
1321  std::map<ossim_int32, PoDoFo::PdfObject*>::iterator itObj = m_podofoImageObjs.find(index);
1322  if (itObj != m_podofoImageObjs.end())
1323  {
1324  ossim_int32 rowCount = it->second.first;
1325  ossim_int32 colCount = it->second.second;
1326  m_frameEntryArray[rowCount][colCount].push_back(itObj->second);
1327  }
1328  it++;
1329  }
1330
1331  //calculate lines and samples
1332  for (row = 0; row < m_numOfFramesVertical; ++row)
1333  {
1334  PoDoFo::PdfObject* tmpObj = m_frameEntryArray[row][0][0];
1335  PoDoFo::PdfImage image(tmpObj);
1336  int height = image.GetHeight();
1337  m_frameHeightVector[row] = height;
1338  }
1339
1340  for (col = 0; col < m_numOfFramesHorizontal; ++col)
1341  {
1342  PoDoFo::PdfObject* tmpObj = m_frameEntryArray[0][col][0];
1343  PoDoFo::PdfImage image(tmpObj);
1344  int width = image.GetWidth();
1345  m_frameWidthVector[col] = width;
1346  }
1347
1348  std::map<ossim_int32, ossim_int32>::iterator itWidth = m_frameWidthVector.begin();
1349  while (itWidth != m_frameWidthVector.end())
1350  {
1351  m_numberOfSamples = m_numberOfSamples + itWidth->second;
1352  itWidth++;
1353  }
1354
1355  std::map<ossim_int32, ossim_int32>::iterator itHeight = m_frameHeightVector.begin();
1356  while (itHeight != m_frameHeightVector.end())
1357  {
1358  m_numberOfLines = m_numberOfLines + itHeight->second;
1359  itHeight++;
1360  }
1362
1363  //get the number of bands
1364  if (m_frameEntryArray[0][0].size() > 2)
1365  {
1367  }
1368  else
1369  {
1370  PoDoFo::PdfObject* tmpObject = m_frameEntryArray[0][0][0];
1371  PoDoFo::PdfMemStream* pStream = dynamic_cast<PoDoFo::PdfMemStream*>(tmpObject->GetStream());
1372  pStream->Uncompress();
1373  ossim_int32 length = pStream->GetLength();
1375  }
1376  }
1377 }
yy_size_t size
unsigned int ossim_uint32
int ossim_int32
◆ buildTileInfo()
void ossimGeoPdfReader::buildTileInfo ( ossimString  tileInfo)
private
Definition at line 424 of file ossimGeoPdfReader.cpp.
References m_podofoTileInfo, and ossimString::split().
Referenced by parseTileStructure().
425 {
426  std::vector<ossimString> tmpKeyValue = tileInfo.split(" ");
427
428  if (tmpKeyValue.size() > 1)
429  {
430  std::vector<ossimString> layerNameVector = tmpKeyValue[0].split("_");
431  ossim_int32 col = layerNameVector[layerNameVector.size()-2].toInt();
432  ossim_int32 row = layerNameVector[layerNameVector.size()-1].toInt();
433  std::pair<ossim_int32, ossim_int32> tileRowCol;
434  tileRowCol = make_pair(row, col);
435  ossim_int32 tileIndex = tmpKeyValue[1].toInt();
436
437  m_podofoTileInfo[tileIndex] = tileRowCol;
438  }
439 }
int ossim_int32
◆ closeEntry()
void ossimGeoPdfReader::closeEntry ( )
virtual
Note
There is a bool kdu_compressed_source::close() and a void ossimImageHandler::close(); hence, a new close to avoid conflicting return types.
Definition at line 674 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::close(), m_cacheTile, m_frameEntryArray, m_frameHeightVector, m_frameWidthVector, m_pageVector, m_pdfMemDocument, m_podofoImageObjs, m_podofoProjInfo, m_podofoTileInfo, and m_tile.
Referenced by ~ossimGeoPdfReader().
675 {
676  m_tile = 0;
677  m_cacheTile = 0;
678  m_podofoProjInfo.clear();
679  m_podofoTileInfo.clear();
680  m_frameWidthVector.clear();
681  m_frameHeightVector.clear();
682
683  if (m_pdfMemDocument)
684  {
685  std::map<int, PoDoFo::PdfObject*>::iterator it = m_podofoImageObjs.begin();
686  while (it != m_podofoImageObjs.end())
687  {
688  m_pdfMemDocument->FreeObjectMemory(it->second);
689  it++;
690  }
691  }
692  m_podofoImageObjs.clear();
693
694  if (m_frameEntryArray.size() > 0)
695  {
696  for (ossim_uint32 i = 0; i < m_frameEntryArray.size(); i++)
697  {
698  std::vector< std::vector<PoDoFo::PdfObject*> > tmpVector = m_frameEntryArray[i];
699  for (ossim_uint32 j = 0; j < tmpVector.size(); j++)
700  {
701  std::vector<PoDoFo::PdfObject*> tmpVector1 = tmpVector[j];
702  for (ossim_uint32 k = 0; k < tmpVector1.size(); k++)
703  {
704  m_pdfMemDocument->FreeObjectMemory(tmpVector1[k]);
705  }
706  }
707  }
708  }
709  m_frameEntryArray.clear();
710
711  if (m_pdfMemDocument != NULL)
712  {
713  delete m_pdfMemDocument;
714  m_pdfMemDocument = 0;
715  }
716
717  for(ossim_uint32 i = 0; i < m_pageVector.size(); ++i)
718  {
719  if(m_pageVector[i])
720  {
721  delete m_pageVector[i];
722  }
723  }
724  m_pageVector.clear();
725
727 }
virtual void close()
std::map< ossimString, ossimString, ossimStringLtstr > m_podofoProjInfo
◆ computeBoundingRect()
ossimDrect ossimGeoPdfReader::computeBoundingRect ( ossimRefPtr< ossimImageGeometry geoImage)
private
Definition at line 441 of file ossimGeoPdfReader.cpp.
References ossimString::contains(), ossimString::empty(), ossimMapProjection::forward(), ossimImageGeometry::getProjection(), getValueFromMap(), ossimProjection::inverse(), ossimMapProjection::isGeographic(), ossimDrect::ll(), ossimDrect::lr(), m_isLGIDict, m_numberOfLines, m_numberOfSamples, m_podofoProjInfo, OSSIM_RIGHT_HANDED, ossimString::push_back(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlEastingNorthing(), ossimMapProjection::setUlTiePoints(), ossimString::split(), ossimString::substitute(), ossimString::toString(), ossimString::trim(), ossimDrect::ul(), ossimDrect::ur(), ossimImageGeometry::worldToLocal(), ossimDpt::x, and ossimDpt::y.
442 {
443  // ossim_uint32 entry = 0;
444  ossimKeywordlist kwl;
445  ossimString pfx = "image";
446  pfx += ossimString::toString(0);
447  pfx += ".";
448
449  double ll_lat = 0.0;
450  double ll_lon = 0.0;
451  double lr_lat = 0.0;
452  double lr_lon = 0.0;
453  double ul_lat = 0.0;
454  double ul_lon = 0.0;
455  double ur_lat = 0.0;
456  double ur_lon = 0.0;
457  ossimDrect rect2(ossimDpt(0,0), ossimDpt(0,0),ossimDpt(0,0),ossimDpt(0,0));
458
459  ossimProjection* proj = geoImage->getProjection();
460  if (m_isLGIDict)
461  {
462  ossimString bBoxStr = getValueFromMap(m_podofoProjInfo, "Registration");
463  std::vector<ossimString> tmpVector = bBoxStr.split(")");
464  std::vector<ossimString> tmpVector1;
465  for (ossim_uint32 i = 0; i < tmpVector.size(); i++)
466  {
467  ossimString tmpStr = tmpVector[i];
468  if (tmpStr.contains("(") || tmpStr.contains(")"))
469  {
470  tmpStr = tmpStr.substitute("[", "", true).trim();
471  tmpStr = tmpStr.substitute("]", "", true).trim();
472  tmpStr = tmpStr.substitute("(", "", true).trim();
473  tmpStr = tmpStr.substitute(")", "", true).trim();
474  tmpVector1.push_back(tmpStr);
475  }
476  }
477
478  if (tmpVector1.size() == 8)
479  {
480  ll_lon = tmpVector1[2].toDouble();
481  ll_lat = tmpVector1[3].toDouble();
482  ur_lon = tmpVector1[6].toDouble();
483  ur_lat = tmpVector1[7].toDouble();
484
485  lr_lon = tmpVector1[6].toDouble();
486  lr_lat = tmpVector1[3].toDouble();
487  ul_lon = tmpVector1[2].toDouble();
488  ul_lat = tmpVector1[7].toDouble();
489  }
490  else if (tmpVector1.size() == 16)
491  {
492  ll_lon = tmpVector1[2].toDouble();
493  ll_lat = tmpVector1[3].toDouble();
494  lr_lon = tmpVector1[6].toDouble();
495  lr_lat = tmpVector1[7].toDouble();
496
497  ur_lon = tmpVector1[10].toDouble();
498  ur_lat = tmpVector1[11].toDouble();
499  ul_lon = tmpVector1[14].toDouble();
500  ul_lat = tmpVector1[15].toDouble();
501  }
502  }
503  else
504  {
505  std::vector<ossimString> tmpVector;
506  ossimString coodStr = getValueFromMap(m_podofoProjInfo, "GPTS");
507  if (!coodStr.empty())
508  {
509  std::vector<ossimString> coodVector = coodStr.split(" ");
510
511  for (ossim_uint32 i = 0; i < coodVector.size(); i++)
512  {
513  ossimString tmp = coodVector[i].trim();
514  if (!tmp.empty() && tmp.contains("[") == false && tmp.contains("]") == false)
515  {
516  tmpVector.push_back(tmp);
517  }
518  }
519
520  ll_lat = tmpVector[0].toDouble();
521  ll_lon = tmpVector[1].toDouble();
522  lr_lat = tmpVector[2].toDouble();
523  lr_lon = tmpVector[3].toDouble();
524  ur_lat = tmpVector[4].toDouble();
525  ur_lon = tmpVector[5].toDouble();
526  ul_lat = tmpVector[6].toDouble();
527  ul_lon = tmpVector[7].toDouble();
528  }
529  }
530
531  if(proj)
532  {
533  ossimMapProjection* mapProj = dynamic_cast<ossimMapProjection*>(proj);
534
535  ossimDrect rect(ossimDpt(ul_lon, ul_lat),
536  ossimDpt(ur_lon, ur_lat),
537  ossimDpt(lr_lon, lr_lat),
538  ossimDpt(ll_lon, ll_lat), OSSIM_RIGHT_HANDED);
539
540  std::vector<ossimGpt> points;
541  if (mapProj->isGeographic())
542  {
543  ossimGpt g1(ul_lat, ul_lon);
544  ossimGpt g2(ur_lat, ur_lon);
545  ossimGpt g3(lr_lat, lr_lon);
546  ossimGpt g4(ll_lat, ll_lon);
547
548  points.push_back(g1);
549  points.push_back(g2);
550  points.push_back(g3);
551  points.push_back(g4);
552  ossimGpt tie(ul_lat, ul_lon);
553  mapProj->setUlTiePoints(tie);
554  if (m_numberOfLines != 0 && m_numberOfSamples != 0)
555  {
556  ossim_float64 scaleLat = (ul_lat - lr_lat)/m_numberOfLines;
557  ossim_float64 scaleLon = (lr_lon - ul_lon)/m_numberOfSamples;
558
559  ossimDpt gsd(fabs(scaleLon), fabs(scaleLat));
560  mapProj->setDecimalDegreesPerPixel(gsd);
561  }
562  }
563  else if (!mapProj->isGeographic() && m_isLGIDict == false)
564  {
565  ossimGpt g1(ul_lat, ul_lon);
566  ossimGpt g2(ur_lat, ur_lon);
567  ossimGpt g3(lr_lat, lr_lon);
568  ossimGpt g4(ll_lat, ll_lon);
569
570  points.push_back(g1);
571  points.push_back(g2);
572  points.push_back(g3);
573  points.push_back(g4);
574
575  if (m_numberOfLines != 0 && m_numberOfSamples != 0)
576  {
577  ossimDpt ulEn = mapProj->forward(g1);
578  ossimDpt lrEn = mapProj->forward(g3);
579
580  mapProj->setUlEastingNorthing(ulEn);
581
582  ossim_float64 scaleLat = (ulEn.y - lrEn.y)/m_numberOfLines;
583  ossim_float64 scaleLon = (lrEn.x - ulEn.x)/m_numberOfSamples;
584
585  ossimDpt gsd(fabs(scaleLon), fabs(scaleLat));
586  mapProj->setMetersPerPixel(gsd);
587  }
588  }
589  else
590  {
591  ossimGpt g1 = proj->inverse(rect.ul());
592  ossimGpt g2 = proj->inverse(rect.ur());
593  ossimGpt g3 = proj->inverse(rect.lr());
594  ossimGpt g4 = proj->inverse(rect.ll());
595
596  points.push_back(g1);
597  points.push_back(g2);
598  points.push_back(g3);
599  points.push_back(g4);
600
601  ossimDpt tie(ul_lon, ul_lat);
602  if (mapProj)
603  {
604  mapProj->setUlTiePoints(tie);
605  if (m_numberOfLines != 0 && m_numberOfSamples != 0)
606  {
607  ossim_float64 scaleLat = (ul_lat - lr_lat)/m_numberOfLines;
608  ossim_float64 scaleLon = (ur_lon - ll_lon)/m_numberOfSamples;
609  ossimDpt gsd(fabs(scaleLon), fabs(scaleLat));
610  mapProj->setMetersPerPixel(gsd);
611  }
612  }
613  }
614
615  std::vector<ossimDpt> rectTmp;
616  rectTmp.resize(4);
617
618  for(std::vector<ossimGpt>::size_type index=0; index < 4; ++index)
619  {
620  geoImage->worldToLocal(points[(int)index], rectTmp[(int)index]);
621  }
622
623  rect2 = ossimDrect(rectTmp);
624
625  }
626  return rect2;
627 }
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
double y
Definition: ossimDpt.h:165
bool contains(char aChar) const
Definition: ossimString.h:58
virtual ossimGpt inverse(const ossimDpt &pp) const
Numeric to string methods.
virtual bool isGeographic() const
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
virtual void setMetersPerPixel(const ossimDpt &gsd)
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
double ossim_float64
virtual void setUlEastingNorthing(const ossimDpt &ulEastingNorthing)
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
ossimString getValueFromMap(std::map< ossimString, ossimString, ossimStringLtstr > info, ossimString key)
virtual ossimDpt forward(const ossimGpt &worldPoint) const =0
double x
Definition: ossimDpt.h:164
bool empty() const
Definition: ossimString.h:411
virtual void setUlTiePoints(const ossimGpt &gpt)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
◆ fillTile()
template<class T >
void ossimGeoPdfReader::fillTile ( ,
const ossimIrect clip_rect,
ossimImageData tile
private
Note
this method assumes that setImageRectangle has been called on theTile.
Definition at line 829 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), getClassName(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimIrect::intersects(), ossimIrect::ll(), ossimImageData::loadTile(), m_cacheTile, m_isJpeg, ossimErrorCodes::OSSIM_ERROR, OSSIM_NULL, ossimSetError(), ossimIrect::ul(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
832 {
833  if (m_isJpeg == true)
834  {
835  tile->loadTile(m_cacheTile.get());
836  }
837  else
838  {
839  const ossimIrect img_rect = tile->getImageRectangle();
841  if (!img_rect.intersects(src_rect) )
842  {
843  return; // Nothing to do here.
844  }
845
846  // Check the clip rect.
847  if (!clip_rect.completely_within(img_rect))
848  {
849  return;
850  }
851
852  ossimIrect clipRect = clip_rect.clipToRect(src_rect);
853  void* src = (void*)m_cacheTile->getBuf();
854  if (!src)
855  {
856  // Set the error...
859  "%s File %s line %d\nNULL pointer passed to method!");
860  return;
861  }
862
863  // Check the status and allocate memory if needed.
864  if (tile->getDataObjectStatus() == OSSIM_NULL)
865  {
866  tile->initialize();
867  }
868
869  // Get the width of the buffers.
870  ossim_uint32 num_bands = tile->getNumberOfBands();
871  ossim_uint32 s_width = src_rect.width();
872  ossim_uint32 d_width = tile->getWidth();
873  ossim_uint32 s_band_offset = s_width * src_rect.height();
874
875  const T* s = static_cast<const T*>(src);
876
877  ossim_uint32 destinationOffset = (clipRect.ul().y - img_rect.ul().y) * d_width +
878  (clipRect.ul().x - img_rect.ul().x);
879
880  ossim_uint32 destinationIndex = destinationOffset;
881
882  ossim_uint32 clipHeight = clipRect.height();
883  ossim_uint32 clipWidth = clipRect.width();
884
885  ossim_uint32 sourceOffset = (src_rect.ll().y - clipRect.ul().y) * s_width +
886  (clipRect.ul().x - src_rect.ul().x);
887  ossim_uint32 sourceIndex = sourceOffset;
888
889  // Copy the data.
890  for (ossim_uint32 band=0; band<num_bands; band++)
891  {
892  T* destinationBand = static_cast<T*>(tile->getBuf(band));
893  destinationIndex = destinationOffset;
894  sourceIndex = sourceOffset + s_band_offset*band;
895
896  for (ossim_uint32 line = 0; line < clipHeight; ++line)
897  {
898  for (ossim_uint32 sample = 0; sample < clipWidth; ++sample)
899  {
900  destinationBand[destinationIndex + sample]
901  = s[sourceIndex+sample];
902  }
903  sourceIndex -= s_width;
904  destinationIndex += d_width;
905  }
906  }
907  }
908  tile->validate();
909 }
OSSIMDLLEXPORT void ossimSetError(const char *className, ossim_int32 error, const char *fmtString=0,...)
ossim_uint32 height() const
Definition: ossimIrect.h:487
const ossimIpt & ul() const
Definition: ossimIrect.h:274
static const ossimErrorCode OSSIM_ERROR
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
const ossimIpt & ll() const
Definition: ossimIrect.h:277
virtual void initialize()
Initialize the data buffer.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual ossimIrect getImageRectangle() const
virtual ossimString getClassName() const
Returns class name.
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
◆ getClassName()
ossimString ossimGeoPdfReader::getClassName ( ) const
virtual
Returns class name.
Returns
"ossimGeoPdfReader"
Definition at line 239 of file ossimGeoPdfReader.cpp.
Referenced by fillTile().
240 {
241  return ossimString("ossimGeoPdfReader");
242 }
◆ getEntryList()
void ossimGeoPdfReader::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
virtual
Parameters
entryListThis is the list to initialize with entry indexes.
Note
This implementation returns puts one entry "0" in the list.
Definition at line 734 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::getEntryList(), getNumberOfEntries(), and m_pageVector.
735 {
736  if (m_pageVector.size() > 0)
737  {
738  for (ossim_uint32 i = 0; i < getNumberOfEntries(); i++)
739  {
740  entryList.push_back(i);
741  }
742  }
743  else
744  {
746  }
747 }
virtual ossim_uint32 getNumberOfEntries() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
◆ getGeoProjection()
ossimProjection * ossimGeoPdfReader::getGeoProjection ( )
private
Definition at line 991 of file ossimGeoPdfReader.cpp.
References getLGIDictGeoProjection(), getVPGeoProjection(), and m_isLGIDict.
992 {
993  if (m_isLGIDict)
994  {
995  return getLGIDictGeoProjection();
996  }
997  else
998  {
999  return getVPGeoProjection();
1000  }
1001  return NULL;
1002 }
ossimProjection * getLGIDictGeoProjection()
ossimProjection * getVPGeoProjection()
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimGeoPdfReader::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 936 of file ossimGeoPdfReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
937 {
938  if ( !theGeometry )
939  {
940  // Check for external geom:
942
943  if ( !theGeometry.valid() )
944  {
945  // Internnal geom:
947
948  if ( !theGeometry.valid() )
949  {
951  }
952
953  // Check for set projection.
954  if ( !theGeometry->getProjection() )
955  {
956  // Try factories for projection.
958  }
959  }
960
961  // Set image things the geometry object should know about.
963  }
964  return theGeometry;
965 }
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
bool valid() const
Definition: ossimRefPtr.h:75
virtual bool extendGeometry(ossimImageHandler *handler) const
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
◆ getImageTileHeight()
ossim_uint32 ossimGeoPdfReader::getImageTileHeight ( ) const
virtual
Note: this is not the same as the ossimImageSource::getTileHeight which returns the output tile height which can be different than the internal image tile height on disk.
Implements ossimImageHandler.
Definition at line 926 of file ossimGeoPdfReader.cpp.
927 {
928  return 0;
929 }
◆ getImageTileWidth()
ossim_uint32 ossimGeoPdfReader::getImageTileWidth ( ) const
virtual
Definition at line 921 of file ossimGeoPdfReader.cpp.
922 {
923  return 0;
924 }
◆ getInternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimGeoPdfReader::getInternalImageGeometry ( ) const
virtual
Parameters
Methodto get geometry.
Definition at line 967 of file ossimGeoPdfReader.cpp.
References m_pageVector.
Referenced by getImageGeometry().
968 {
970  if (m_pageVector.size() > 0)
971  {
972  geom = m_pageVector[0]->m_geoImage;
973  }
974  return geom;
975 }
◆ getIntersectingEntries()
std::vector< ossimGeoPdfReader::ossimFrameEntryData > ossimGeoPdfReader::getIntersectingEntries ( const ossimIrect rect)
protected
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
Parameters
rectthe current region to render.
Returns
The list of entry data objects found for this rect.
Definition at line 1379 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimImageHandler::getImageRectangle(), ossimIrect::intersects(), isOpen(), ossimIrect::lr(), m_frameEntryArray, m_frameHeightVector, m_frameWidthVector, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
1380 {
1381  std::vector<ossimFrameEntryData> result;
1382
1383  // make sure we have the Toc entry to render
1384  if(!isOpen()) return result;
1385
1386  ossimIrect imageRect = getImageRectangle();
1387  if(rect.intersects(imageRect))
1388  {
1389  ossimIrect clipRect = rect.clipToRect(imageRect);
1390  ossimIrect frameRect(clipRect.ul().x/m_frameWidthVector[0],
1391  clipRect.ul().y/m_frameHeightVector[0],
1392  clipRect.lr().x/m_frameWidthVector[0],
1393  clipRect.lr().y/m_frameHeightVector[0]);
1394
1395  for(ossim_int32 row = frameRect.ul().y; row <= frameRect.lr().y; ++row)
1396  {
1397  for(ossim_int32 col = frameRect.ul().x; col <= frameRect.lr().x; ++col)
1398  {
1399  ossim_int32 pixelRow = 0;
1400  ossim_int32 pixelCol = 0;
1401  for (ossim_int32 iRow = 0; iRow < row; ++iRow)
1402  {
1403  pixelRow = pixelRow + m_frameHeightVector[iRow];
1404  }
1405  for (ossim_int32 iCol = 0; iCol < col; ++iCol)
1406  {
1407  pixelCol = pixelCol + m_frameWidthVector[iCol];
1408  }
1409  std::vector<PoDoFo::PdfObject*> tempEntry = m_frameEntryArray[row][col];
1410  if(tempEntry.size() > 0)
1411  {
1412  result.push_back(ossimFrameEntryData(row,
1413  col,
1414  pixelRow,
1415  pixelCol,
1416  tempEntry));
1417  }
1418  }
1419  }
1420  }
1421
1422  return result;
1423 }
virtual bool isOpen() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
ossim_int32 y
ossim_int32 x
int ossim_int32
◆ getLGIDictGeoProjection()
ossimProjection * ossimGeoPdfReader::getLGIDictGeoProjection ( )
private
Definition at line 1023 of file ossimGeoPdfReader.cpp.
References ossimString::empty(), getProjectionFromStr(), getValueFromMap(), and m_podofoProjInfo.
Referenced by getGeoProjection().
1024 {
1025  ossimProjection* proj = NULL;
1026  ossimString projContents = getValueFromMap(m_podofoProjInfo, "Projection");
1027  if (!projContents.empty())
1028  {
1029  proj = getProjectionFromStr(projContents);
1030  }
1031  return proj;
1032 }
ossimProjection * getProjectionFromStr(ossimString projContents)
bool empty() const
◆ getLongName()
ossimString ossimGeoPdfReader::getLongName ( ) const
virtual
Returns long name.
Returns
"ossim mrsid reader"
Definition at line 234 of file ossimGeoPdfReader.cpp.
235 {
236  return ossimString("ossim geopdf reader");
237 }
◆ getNumberOfEntries()
ossim_uint32 ossimGeoPdfReader::getNumberOfEntries ( ) const
virtual
Returns
The number of entries (images) in the image file.
Definition at line 729 of file ossimGeoPdfReader.cpp.
Referenced by getEntryList().
730 {
731  return (ossim_uint32)m_pageVector.size();
732 }
◆ getNumberOfInputBands()
ossim_uint32 ossimGeoPdfReader::getNumberOfInputBands ( ) const
virtual
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 911 of file ossimGeoPdfReader.cpp.
References m_numberOfBands.
912 {
913  return m_numberOfBands;
914 }
◆ getNumberOfLines()
ossim_uint32 ossimGeoPdfReader::getNumberOfLines ( ossim_uint32  resLevel = 0) const
virtual
Parameters
resLevelReduced resolution level to return lines of. Default = 0
Returns
The number of lines for specified reduced resolution level.
Definition at line 244 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::getNumberOfLines(), m_numberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
246 {
247  if (resLevel == 0)
248  {
249  return m_numberOfLines;
250  }
251  else if ( theOverview.valid() )
252  {
253  return theOverview->getNumberOfLines(resLevel);
254  }
255
256  return 0;
257 }
bool valid() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
ossimRefPtr< ossimImageHandler > theOverview
◆ getNumberOfOutputBands()
ossim_uint32 ossimGeoPdfReader::getNumberOfOutputBands ( ) const
virtual
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 916 of file ossimGeoPdfReader.cpp.
917 {
918  return m_numberOfBands;
919 }
◆ getNumberOfSamples()
ossim_uint32 ossimGeoPdfReader::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
virtual
Parameters
resLevelReduced resolution level to return samples of. Default = 0
Returns
The number of samples for specified reduced resolution level.
Definition at line 259 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_numberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
261 {
262  if (resLevel == 0)
263  {
264  return m_numberOfSamples;
265  }
266  else if ( theOverview.valid() )
267  {
268  return theOverview->getNumberOfSamples(resLevel);
269  }
270
271  return 0;
272 }
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimGeoPdfReader::getOutputScalarType ( ) const
virtual
Definition at line 931 of file ossimGeoPdfReader.cpp.
References m_scalarType.
932 {
933  return m_scalarType;
934 }
◆ getProjectionFromStr()
ossimProjection * ossimGeoPdfReader::getProjectionFromStr ( ossimString  projContents)
private
Definition at line 1425 of file ossimGeoPdfReader.cpp.
References ossimString::contains(), ossimString::empty(), getValueFromMap(), ossimString::split(), ossimString::substitute(), and ossimString::trim().
Referenced by getLGIDictGeoProjection().
1426 {
1427  std::vector<ossimString> tmpVector = projContents.split("\n");
1428  std::map<ossimString, ossimString, ossimStringLtstr> projectionMap;
1429
1430  for (ossim_uint32 i = 0; i < tmpVector.size(); i++)
1431  {
1432  ossimString tmpStr = tmpVector[i];
1433  if (tmpStr.contains("/"))
1434  {
1435  std::vector<ossimString> tmpKeyValue = tmpStr.split(" ");
1436  ossimString key;
1437  ossimString valueStr;
1438  for (ossim_uint32 j = 0; j < tmpKeyValue.size(); j++)
1439  {
1440  if (tmpKeyValue[j].contains("/"))
1441  {
1442  key = tmpKeyValue[j].substitute("/", "", true).trim();
1443  }
1444  else
1445  {
1446  valueStr = tmpKeyValue[j].substitute(")", "", true).trim();
1447  valueStr = valueStr.substitute("(", "", true).trim();
1448  }
1449  }
1450  if (!key.empty() && !valueStr.empty())
1451  {
1452  projectionMap[key] = valueStr;
1453  }
1454  }
1455  }
1456
1457  ossimString projCode = getValueFromMap(projectionMap, "ProjectionType");
1458  ossimString datumCode = getValueFromMap(projectionMap, "Datum");
1459
1460  ossimString originLatitudeStr = getValueFromMap(projectionMap, originLatKey);
1461  ossimString centralMeridianStr = getValueFromMap(projectionMap, centralMeridianKey);
1462  ossimString standardParallelOneStr = getValueFromMap(projectionMap, standardParallelOneKey);
1463  ossimString standardParallelTwoStr = getValueFromMap(projectionMap, standardParallelTwoKey);
1464  ossimString falseEastingStr = getValueFromMap(projectionMap, falseEastingKey);
1465  ossimString falseNorthingStr = getValueFromMap(projectionMap, falseNorthingKey);
1466  ossimString scaleFactorStr = getValueFromMap(projectionMap, scaleFactorKey);
1467
1468  if (projCode == "GEODETIC" || projCode == "GEOGRAPHIC")
1469  {
1470  ossimString codeName = "EPSG:4326";
1471  if (datumCode == "WD")
1472  {
1473  codeName = "EPSG:4322";
1474  }
1476  return proj;
1477  }
1478  else if (projCode == "UT")
1479  {
1480  ossimString zoneStr = getValueFromMap(projectionMap, zoneKey);
1481  ossimString hemisphereStr = getValueFromMap(projectionMap, hemisphereKey);
1482  ossimUtmProjection* utm = new ossimUtmProjection(zoneStr.toInt32());
1483  if (!datumCode.empty())
1484  {
1485  utm->setDatum(ossimDatumFactory::instance()->create(datumCode));
1486  }
1487
1488  if (!zoneStr.empty())
1489  {
1490  utm->setZone(zoneStr.toInt32());
1491  }
1492
1493  if (!hemisphereStr.empty())
1494  {
1495  utm->setHemisphere(*hemisphereStr.c_str());
1496  }
1497
1498  return utm;
1499  }
1500  else if (projCode == "UP")
1501  {
1502  ossimString hemiStr = getValueFromMap(projectionMap, hemisphereKey);
1504
1505  if (!datumCode.empty())
1506  {
1507  ups->setDatum(ossimDatumFactory::instance()->create(datumCode));
1508  }
1509
1510  if (!hemiStr.empty())
1511  {
1512  ups->setHemisphere(*hemiStr.c_str());
1513  }
1514
1515  return ups;
1516  }
1517  else if (projCode == "SPCS")
1518  {
1519  ossimString zoneStr = getValueFromMap(projectionMap, zoneKey);
1520
1521  ossimString spcsCode;
1522  if (datumCode.upcase().contains("NAR"))
1523  {
1524  spcsCode = ossimString("NAD83_" + projCode + "_" + zoneStr);
1525  }
1526  else if (datumCode.upcase().contains("NAS"))
1527  {
1528  spcsCode = ossimString("NAD83_SPAF_" + zoneStr);
1529  }
1530
1531  // State plane projections are represented in the EPSG database. Search for corresponding proj
1532  // by name. Name needs to be exact match as found in the EPSG database files:
1534  if (stateProj)
1535  {
1536  return stateProj;
1537  }
1538  }
1539  else if (projCode == "AC")
1540  {
1541  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1542
1544
1545  if (!datumCode.empty())
1546  {
1547  albers->setDatum(ossimDatumFactory::instance()->create(datumCode));
1548  }
1549
1550  if (!origin.isNan())
1551  {
1552  albers->setOrigin(origin);
1553  }
1554
1555  if (!standardParallelOneStr.empty())
1556  {
1557  albers->setStandardParallel1(standardParallelOneStr.toDouble());
1558  }
1559
1560  if (!standardParallelTwoStr.empty())
1561  {
1562  albers->setStandardParallel2(standardParallelTwoStr.toDouble());
1563  }
1564
1565  if (!falseEastingStr.empty())
1566  {
1567  albers->setFalseEasting(falseEastingStr.toDouble());
1568  }
1569
1570  if (!falseNorthingStr.empty())
1571  {
1572  albers->setFalseNorthing(falseNorthingStr.toDouble());
1573  }
1574
1575  return albers;
1576  }
1577  else if (projCode == "AL")
1578  {
1580
1581  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1582
1583  if (!datumCode.empty())
1584  {
1585  azimEqud->setDatum(ossimDatumFactory::instance()->create(datumCode));
1586  }
1587
1588  if (!origin.isNan())
1589  {
1590  azimEqud->setOrigin(origin);
1591  }
1592
1593  if (!falseEastingStr.empty())
1594  {
1595  azimEqud->setFalseEasting(falseEastingStr.toDouble());
1596  }
1597
1598  if (!falseNorthingStr.empty())
1599  {
1600  azimEqud->setFalseNorthing(falseNorthingStr.toDouble());
1601  }
1602
1603  return azimEqud;
1604  }
1605  else if (projCode == "BF")
1606  {
1608
1609  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1610
1611  if (!datumCode.empty())
1612  {
1613  bonne->setDatum(ossimDatumFactory::instance()->create(datumCode));
1614  }
1615
1616  if (!origin.isNan())
1617  {
1618  bonne->setOrigin(origin);
1619  }
1620
1621  if (!falseEastingStr.empty())
1622  {
1623  bonne->setFalseEasting(falseEastingStr.toDouble());
1624  }
1625
1626  if (!falseNorthingStr.empty())
1627  {
1628  bonne->setFalseNorthing(falseNorthingStr.toDouble());
1629  }
1630
1631  return bonne;
1632  }
1633  else if (projCode == "CS")
1634  {
1636
1637  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1638
1639  if (!datumCode.empty())
1640  {
1641  cassin->setDatum(ossimDatumFactory::instance()->create(datumCode));
1642  }
1643
1644  if (!origin.isNan())
1645  {
1646  cassin->setOrigin(origin);
1647  }
1648
1649  if (!falseEastingStr.empty())
1650  {
1651  cassin->setFalseEasting(falseEastingStr.toDouble());
1652  }
1653
1654  if (!falseNorthingStr.empty())
1655  {
1656  cassin->setFalseNorthing(falseNorthingStr.toDouble());
1657  }
1658
1659  return cassin;
1660  }
1661  else if (projCode == "LI")
1662  {
1664
1665  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1666
1667  if (!datumCode.empty())
1668  {
1669  cyeq->setDatum(ossimDatumFactory::instance()->create(datumCode));
1670  }
1671
1672  if (!origin.isNan())
1673  {
1674  cyeq->setOrigin(origin);
1675  }
1676
1677  if (!falseEastingStr.empty())
1678  {
1679  cyeq->setFalseEasting(falseEastingStr.toDouble());
1680  }
1681
1682  if (!falseNorthingStr.empty())
1683  {
1684  cyeq->setFalseNorthing(falseNorthingStr.toDouble());
1685  }
1686
1687  return cyeq;
1688  }
1689  else if (projCode == "EF")
1690  {
1692
1693  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1694
1695  if (!datumCode.empty())
1696  {
1697  ecker4->setDatum(ossimDatumFactory::instance()->create(datumCode));
1698  }
1699
1700  if (!origin.isNan())
1701  {
1702  ecker4->setOrigin(origin);
1703  }
1704
1705  if (!falseEastingStr.empty())
1706  {
1707  ecker4->setFalseEasting(falseEastingStr.toDouble());
1708  }
1709
1710  if (!falseNorthingStr.empty())
1711  {
1712  ecker4->setFalseNorthing(falseNorthingStr.toDouble());
1713  }
1714
1715  return ecker4;
1716  }
1717  else if (projCode == "ED")
1718  {
1720
1721  if (!datumCode.empty())
1722  {
1723  ecker6->setDatum(ossimDatumFactory::instance()->create(datumCode));
1724  }
1725
1726  if (!centralMeridianStr.empty())
1727  {
1728  ecker6->setCentralMeridian(centralMeridianStr.toDouble());
1729  }
1730
1731  if (!falseEastingStr.empty())
1732  {
1733  ecker6->setFalseEasting(falseEastingStr.toDouble());
1734  }
1735
1736  if (!falseNorthingStr.empty())
1737  {
1738  ecker6->setFalseNorthing(falseNorthingStr.toDouble());
1739  }
1740
1741  return ecker6;
1742  }
1743  else if (projCode == "GN")
1744  {
1746
1747  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1748
1749  if (!datumCode.empty())
1750  {
1751  gnomon->setDatum(ossimDatumFactory::instance()->create(datumCode));
1752  }
1753
1754  if (!origin.isNan())
1755  {
1756  gnomon->setOrigin(origin);
1757  }
1758
1759  if (!falseEastingStr.empty())
1760  {
1761  gnomon->setFalseEasting(falseEastingStr.toDouble());
1762  }
1763
1764  if (!falseNorthingStr.empty())
1765  {
1766  gnomon->setFalseNorthing(falseNorthingStr.toDouble());
1767  }
1768
1769  return gnomon;
1770  }
1771  else if (projCode == "LE")
1772  {
1773  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1774
1776
1777  if (!datumCode.empty())
1778  {
1779  lamber->setDatum(ossimDatumFactory::instance()->create(datumCode));
1780  }
1781
1782  if (!origin.isNan())
1783  {
1784  lamber->setOrigin(origin);
1785  }
1786
1787  if (!standardParallelOneStr.empty())
1788  {
1789  lamber->setStandardParallel1(standardParallelOneStr.toDouble());
1790  }
1791
1792  if (!standardParallelTwoStr.empty())
1793  {
1794  lamber->setStandardParallel2(standardParallelTwoStr.toDouble());
1795  }
1796
1797  if (!falseEastingStr.empty())
1798  {
1799  lamber->setFalseEasting(falseEastingStr.toDouble());
1800  }
1801
1802  if (!falseNorthingStr.empty())
1803  {
1804  lamber->setFalseNorthing(falseNorthingStr.toDouble());
1805  }
1806
1807  return lamber;
1808  }
1809  else if (projCode == "MC")
1810  {
1812
1813  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1814
1815  if (!datumCode.empty())
1816  {
1817  mercator->setDatum(ossimDatumFactory::instance()->create(datumCode));
1818  }
1819
1820  if (!origin.isNan())
1821  {
1822  mercator->setOrigin(origin);
1823  }
1824
1825  if (!scaleFactorStr.empty())
1826  {
1827  mercator->setScaleFactor(scaleFactorStr.toDouble());
1828  }
1829
1830  if (!falseEastingStr.empty())
1831  {
1832  mercator->setFalseEasting(falseEastingStr.toDouble());
1833  }
1834
1835  if (!falseNorthingStr.empty())
1836  {
1837  mercator->setFalseNorthing(falseNorthingStr.toDouble());
1838  }
1839
1840  return mercator;
1841  }
1842  else if (projCode == "MH")
1843  {
1845
1846  if (!datumCode.empty())
1847  {
1848  miller->setDatum(ossimDatumFactory::instance()->create(datumCode));
1849  }
1850
1851  if (!centralMeridianStr.empty())
1852  {
1853  miller->setCentralMeridian(centralMeridianStr.toDouble());
1854  }
1855
1856  if (!falseEastingStr.empty())
1857  {
1858  miller->setFalseEasting(falseEastingStr.toDouble());
1859  }
1860
1861  if (!falseNorthingStr.empty())
1862  {
1863  miller->setFalseNorthing(falseNorthingStr.toDouble());
1864  }
1865
1866  return miller;
1867  }
1868  else if (projCode == "MP")
1869  {
1871
1872  if (!datumCode.empty())
1873  {
1874  mollweid->setDatum(ossimDatumFactory::instance()->create(datumCode));
1875  }
1876
1877  if (!centralMeridianStr.empty())
1878  {
1879  mollweid->setCentralMeridian(centralMeridianStr.toDouble());
1880  }
1881
1882  if (!falseEastingStr.empty())
1883  {
1884  mollweid->setFalseEasting(falseEastingStr.toDouble());
1885  }
1886
1887  if (!falseNorthingStr.empty())
1888  {
1889  mollweid->setFalseNorthing(falseNorthingStr.toDouble());
1890  }
1891
1892  return mollweid;
1893  }
1894  else if (projCode == "NT")
1895  {
1897  if (!datumCode.empty())
1898  {
1899  newzealand->setDatum(ossimDatumFactory::instance()->create(datumCode));
1900  }
1901  return newzealand;
1902  }
1903  else if (projCode == "OC")
1904  {
1905  ossimString latOne = getValueFromMap(projectionMap, latitudeOneKey);
1906  ossimString lonOne = getValueFromMap(projectionMap, longitudeOneKey);
1907  ossimString latTwo = getValueFromMap(projectionMap, latitudeTwoKey);
1908  ossimString lonTwo = getValueFromMap(projectionMap, longitudeTwoKey);
1909
1911
1912  ossimGpt origin1(latOne.toDouble(), lonOne.toDouble());
1913  ossimGpt origin2(latTwo.toDouble(), lonTwo.toDouble());
1914
1915  if (!datumCode.empty())
1916  {
1917  oblique->setDatum(ossimDatumFactory::instance()->create(datumCode));
1918  }
1919
1920  if (!origin1.isNan())
1921  {
1922  oblique->setCentralPoint1(origin1);
1923  }
1924
1925  if (!origin2.isNan())
1926  {
1927  oblique->setCentralPoint2(origin2);
1928  }
1929
1930  if (!scaleFactorStr.empty())
1931  {
1932  oblique->setScaleFactor(scaleFactorStr.toDouble());
1933  }
1934
1935  if (!falseEastingStr.empty())
1936  {
1937  oblique->setFalseEasting(falseEastingStr.toDouble());
1938  }
1939
1940  if (!falseNorthingStr.empty())
1941  {
1942  oblique->setFalseNorthing(falseNorthingStr.toDouble());
1943  }
1944
1945  return oblique;
1946  }
1947  else if (projCode == "PG")
1948  {
1949  ossimString originLat = getValueFromMap(projectionMap, "LatitudeTrueScale");
1950  ossimString originLon = getValueFromMap(projectionMap, "LongitudeDownFromPole");
1951  ossimGpt origin(originLat.toDouble(), originLon.toDouble());
1952
1954
1955  if (!datumCode.empty())
1956  {
1957  polar->setDatum(ossimDatumFactory::instance()->create(datumCode));
1958  }
1959
1960  if (!origin.isNan())
1961  {
1962  polar->setOrigin(origin);
1963  }
1964
1965  if (!falseEastingStr.empty())
1966  {
1967  polar->setFalseEasting(falseEastingStr.toDouble());
1968  }
1969
1970  if (!falseNorthingStr.empty())
1971  {
1972  polar->setFalseNorthing(falseNorthingStr.toDouble());
1973  }
1974
1975  return polar;
1976  }
1977  else if (projCode == "PH")
1978  {
1980
1981  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
1982
1983  if (!datumCode.empty())
1984  {
1985  polyconic->setDatum(ossimDatumFactory::instance()->create(datumCode));
1986  }
1987
1988  if (!origin.isNan())
1989  {
1990  polyconic->setOrigin(origin);
1991  }
1992
1993  if (!falseEastingStr.empty())
1994  {
1995  polyconic->setFalseEasting(falseEastingStr.toDouble());
1996  }
1997
1998  if (!falseNorthingStr.empty())
1999  {
2000  polyconic->setFalseNorthing(falseNorthingStr.toDouble());
2001  }
2002
2003  return polyconic;
2004  }
2005  else if (projCode == "SA")
2006  {
2008
2009  if (!datumCode.empty())
2010  {
2011  sinusoidal->setDatum(ossimDatumFactory::instance()->create(datumCode));
2012  }
2013
2014  if (!centralMeridianStr.empty())
2015  {
2016  sinusoidal->setCentralMeridian(centralMeridianStr.toDouble());
2017  }
2018
2019  if (!falseEastingStr.empty())
2020  {
2021  sinusoidal->setFalseEasting(falseEastingStr.toDouble());
2022  }
2023
2024  if (!falseNorthingStr.empty())
2025  {
2026  sinusoidal->setFalseNorthing(falseNorthingStr.toDouble());
2027  }
2028
2029  return sinusoidal;
2030  }
2031  else if (projCode == "SD")
2032  {
2034
2035  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
2036
2037  if (!datumCode.empty())
2038  {
2039  stereo->setDatum(ossimDatumFactory::instance()->create(datumCode));
2040  }
2041
2042  if (!origin.isNan())
2043  {
2044  stereo->setOrigin(origin);
2045  }
2046
2047  if (!falseEastingStr.empty())
2048  {
2049  stereo->setFalseEasting(falseEastingStr.toDouble());
2050  }
2051
2052  if (!falseNorthingStr.empty())
2053  {
2054  stereo->setFalseNorthing(falseNorthingStr.toDouble());
2055  }
2056
2057  return stereo;
2058  }
2059  else if (projCode == "TC")
2060  {
2062
2063  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
2064
2065  if (!datumCode.empty())
2066  {
2067  trans->setDatum(ossimDatumFactory::instance()->create(datumCode));
2068  }
2069
2070  if (!origin.isNan())
2071  {
2072  trans->setOrigin(origin);
2073  }
2074
2075  if (!scaleFactorStr.empty())
2076  {
2077  trans->setScaleFactor(scaleFactorStr.toDouble());
2078  }
2079
2080  if (!falseEastingStr.empty())
2081  {
2082  trans->setFalseEasting(falseEastingStr.toDouble());
2083  }
2084
2085  if (!falseNorthingStr.empty())
2086  {
2087  trans->setFalseNorthing(falseNorthingStr.toDouble());
2088  }
2089
2090  return trans;
2091  }
2092  else if (projCode == "TX")
2093  {
2095
2096  ossimGpt origin(originLatitudeStr.toDouble(), centralMeridianStr.toDouble());
2097
2098  if (!datumCode.empty())
2099  {
2100  transCyl->setDatum(ossimDatumFactory::instance()->create(datumCode));
2101  }
2102
2103  if (!origin.isNan())
2104  {
2105  transCyl->setOrigin(origin);
2106  }
2107
2108  if (!scaleFactorStr.empty())
2109  {
2110  transCyl->setScaleFactor(scaleFactorStr.toDouble());
2111  }
2112
2113  if (!falseEastingStr.empty())
2114  {
2115  transCyl->setFalseEasting(falseEastingStr.toDouble());
2116  }
2117
2118  if (!falseNorthingStr.empty())
2119  {
2120  transCyl->setFalseNorthing(falseNorthingStr.toDouble());
2121  }
2122
2123  return transCyl;
2124  }
2125  else if (projCode == "VA")
2126  {
2128
2129  if (!datumCode.empty())
2130  {
2131  vander->setDatum(ossimDatumFactory::instance()->create(datumCode));
2132  }
2133
2134  if (!centralMeridianStr.empty())
2135  {
2136  vander->setCentralMeridian(centralMeridianStr.toDouble());
2137  }
2138
2139  if (!falseEastingStr.empty())
2140  {
2141  vander->setFalseEasting(falseEastingStr.toDouble());
2142  }
2143
2144  if (!falseNorthingStr.empty())
2145  {
2146  vander->setFalseNorthing(falseNorthingStr.toDouble());
2147  }
2148
2149  return vander;
2150  }
2151  else
2152  {
2153  if (traceDebug())
2154  {
2156  << "ossimGeoPdfReader: No projection information. \n"
2157  << std::endl;
2158  }
2159  }
2160
2161  return NULL;
2162 }
void setFalseEasting(double falseEasting)
void setFalseNorthing(double falseNorthing)
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
void setCentralMeridian(double centralMeridian)
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
ossim_int32 toInt32() const
Albers Equal Area Conic Projection.
void setScaleFactor(double scaleFactor)
double toDouble() const
static ossimDatumFactory * instance()
void setZone(const ossimGpt &ground)
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
STUB. Not implemented.
void setHemisphere(char hemisphere)
virtual void setDatum(const ossimDatum *datum)
Sets theDatum to datum.
void setHemisphere(const ossimGpt &ground)
static ossimEpsgProjectionFactory * instance()
Implements singleton pattern.
◆ getShortName()
ossimString ossimGeoPdfReader::getShortName ( ) const
virtual
Returns short name.
Returns
"ossim_mrsid_reader"
Definition at line 229 of file ossimGeoPdfReader.cpp.
230 {
231  return ossimString("ossim_geopdf_reader");
232 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimGeoPdfReader::getTile ( const ossimIrect rect,
virtual
Parameters
rectThe zero based rectangle to grab.
resLevelThe reduced resolution level to grab from.
Returns
The ref pointer with the image data pointer.
Definition at line 749 of file ossimGeoPdfReader.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
751 {
752  if (m_tile.valid())
753  {
754  // Image rectangle must be set prior to calling getTile.
755  m_tile->setImageRectangle(rect);
756
757  if ( getTile( m_tile.get(), resLevel ) == false )
758  {
760  {
761  m_tile->makeBlank();
762  }
763  }
764  }
765
766  return m_tile;
767 }
bool valid() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
virtual void makeBlank()
◆ getTile() [2/2]
bool ossimGeoPdfReader::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 769 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillTile(), ossimImageData::getImageRectangle(), ossimImageHandler::getImageRectangle(), getIntersectingEntries(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), m_currentRow, ossimImageData::makeBlank(), ossimReferenced::ref(), resetCacheBuffer(), status, and ossimReferenced::unref().
771 {
772  bool status = false;
773
774  //---
775  // Not open, this tile source bypassed, or invalid res level,
776  // return a blank tile.
777  //---
778  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
779  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
780  {
781  result->ref(); // Increment ref count.
782
783  //---
784  // Check for overview tile. Some overviews can contain r0 so always
785  // call even if resLevel is 0. Method returns true on success, false
786  // on error.
787  //---
788  status = getOverviewTile(resLevel, result);
789
790  if (!status) // Did not get an overview tile.
791  {
792  status = true;
793
794  ossimIrect tile_rect = result->getImageRectangle();
795
796  if (getImageRectangle().intersects(tile_rect))
797  {
798  // Make a clip rect.
799  ossimIrect clip_rect = tile_rect.clipToRect(getImageRectangle());
800
801  std::vector<ossimFrameEntryData> frames = getIntersectingEntries(clip_rect);
802
803  if (!tile_rect.completely_within(getImageRectangle()) )
804  {
805  result->makeBlank();
806  }
807
808  for(ossim_uint32 idx = 0; idx < frames.size(); ++idx)
809  {
810  resetCacheBuffer(frames[idx]);
811  m_currentRow = frames[idx].theRow;
812
813  fillTile(ossim_uint8(0), clip_rect, result);
814  }
815  }
816  else // No intersection...
817  {
818  result->makeBlank();
819  }
820  }
821
822  result->unref(); // Decrement ref count.
823  }
824
825  return status;
826 }
void resetCacheBuffer(ossimFrameEntryData entry)
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
std::vector< ossimFrameEntryData > getIntersectingEntries(const ossimIrect &rect)
It is important to note that each frame is organized into an easting northing type orientation...
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
return status
unsigned char ossim_uint8
void fillTile(T, const ossimIrect &clip_rect, ossimImageData *tile)
◆ getVPGeoProjection()
ossimProjection * ossimGeoPdfReader::getVPGeoProjection ( )
private
Definition at line 1004 of file ossimGeoPdfReader.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimEpsgProjectionFactory::createProjection(), ossimString::empty(), getValueFromMap(), ossimEpsgProjectionFactory::instance(), m_podofoProjInfo, ossimKeywordNames::PCS_CODE_KW, and ossimString::toString().
1005 {
1006  ossimKeywordlist kwl;
1007  ossimString pfx = "image";
1008  pfx += ossimString::toString(0);
1009  pfx += ".";
1010
1011  ossimProjection* proj = NULL;
1012
1013  ossimString projCode = getValueFromMap(m_podofoProjInfo, "EPSG");
1014  if (!projCode.empty())
1015  {
1016  kwl.add(pfx.c_str(), ossimKeywordNames::PCS_CODE_KW, projCode, true);
1017  projCode = ossimString("EPSG:") + projCode;
1019  }
1020  return proj;
1021 }
static const char * PCS_CODE_KW
bool empty() const
◆ isOpen()
bool ossimGeoPdfReader::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 660 of file ossimGeoPdfReader.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimImageHandler::theImageFile.
Referenced by getIntersectingEntries(), and getTile().
661 {
663
664  if(ext == "pdf")
665  {
666  return true;
667  }
668  else
669  {
670  return false;
671  }
672 }
ossimString ext() const
◆ loadState()
bool ossimGeoPdfReader::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 977 of file ossimGeoPdfReader.cpp.
References ossimKeywordlist::find(), ossimImageHandler::loadState(), open(), and ossimKeywordNames::TYPE_KW.
978 {
979  bool result = false;
980  ossimString type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
981  if( (type == "ossimGeoPdfReader") || (type == "ossimImageHandler") )
982  {
983  if ( ossimImageHandler::loadState(kwl, prefix) )
984  {
985  result = open();
986  }
987  }
988  return result;
989 }
static const char * TYPE_KW
virtual bool open()
Open method.
◆ open()
bool ossimGeoPdfReader::open ( )
virtual
Open method.
Returns
Definition at line 274 of file ossimGeoPdfReader.cpp.
Referenced by loadState().
275 {
276  static const char MODULE[] = "ossimGeoPdfReader::open";
277
278  if (traceDebug())
279  {
281  << MODULE << " entered...\n"
282  << "image: " << theImageFile << "\n";
283  }
284
285  bool result = false;
286  closeEntry();
287
288  if ( theImageFile.size() )
289  {
290  PoDoFo::PdfError::EnableDebug(false);//do not print out debug info
291
292  try
293  {
294  m_pdfMemDocument = new PoDoFo::PdfMemDocument(theImageFile.c_str());
295  }
296  catch (...)
297  {
298  return false;
299  }
300
301  if (m_pdfMemDocument != NULL)
302  {
303  int count = m_pdfMemDocument->GetPageCount();
304  for(int i = 0; i < count; ++i)
305  {
306  PoDoFo::PdfPage* pdfPage = m_pdfMemDocument->GetPage(i);
307  if( pdfPage )
308  {
309  PoDoFo::PdfObject* pdfObject = pdfPage->GetObject();
310  PoDoFo::PdfObject* geoPdfObject = NULL;
311  if( pdfObject->GetDictionary().HasKey(PoDoFo::PdfName("LGIDict") ) )
312  {
313  geoPdfObject = pdfObject->GetDictionary().GetKey(PoDoFo::PdfName("LGIDict"));
314  m_isLGIDict = true;
315  }
316  else if (pdfObject->GetDictionary().HasKey(PoDoFo::PdfName("VP") ))
317  {
318  geoPdfObject = pdfObject->GetDictionary().GetKey(PoDoFo::PdfName("VP"));
319  }
320
321  if (geoPdfObject)
322  {
323  std::string imagInfo; //try to get tile structure information
324  geoPdfObject->ToString(imagInfo);
325  ossimString imagInfoStr = imagInfo;
326
327  if (imagInfoStr.downcase().contains("tile") == false)//if not, try to get tile structure info from source object
328  {
329  PoDoFo::PdfObject* pSource = pdfPage->GetResources();
330  pSource->ToString(imagInfo);
331  imagInfoStr = imagInfo;
332  }
333  std::vector<ossimString> imageInfoVector;
334  imageInfoVector.push_back(imagInfoStr);
335  parseTileStructure(imageInfoVector);
338  setPodofoInfo(geoPdfObject);
339  }
340  else
341  {
342  continue;
343  }
344
345  // Create the geometry.
347  geoImage->setProjection(getGeoProjection());
349
350  // Create the node.
352  node->setGeoImage(geoImage);
353  node->setBoundingBox(computeBoundingRect(geoImage));
354
355  // Add to array.
356  m_pageVector.push_back(node);
357
358  m_pdfMemDocument->FreeObjectMemory(pdfObject);
359  }
360
361  } // Matches: for(int i = 0; i < count; ++i)
362
363  if ( m_pageVector.size() )
364  {
365  result = true;
366  }
367  }
368
370  m_tile->initialize();
373
376
379
380  completeOpen();
381
382  if (result == false)
383  {
384  closeEntry();
385  }
386
387  } // Matches: if ( theImageFile.size() )
388
389  return result;
390 }
virtual void deleteCache(ossimAppFixedCacheId cacheId)
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
ossimDrect computeBoundingRect(ossimRefPtr< ossimImageGeometry > geoImage)
void setImageSize(const ossimIpt &size)
static ossimAppFixedTileCache * instance(ossim_uint32 maxSize=0)
virtual ossimObject * dup() const
void setBoundingBox(const ossimDrect &bounds)
std::string::size_type size() const
Definition: ossimString.h:405
void parseTileStructure(std::vector< ossimString > tileInfo)
virtual void completeOpen()
Will complete the opening process.
ossim_int32 y
void setPodofoInfo(PoDoFo::PdfObject *object)
void setGeoImage(ossimRefPtr< ossimImageGeometry > image)
ossim_int32 x
ossimAppFixedCacheId newTileCache(const ossimIrect &tileBoundaryRect, const ossimIpt &tileSize=ossimIpt(0, 0))
ossimProjection * getGeoProjection()
◆ parseTileStructure()
void ossimGeoPdfReader::parseTileStructure ( std::vector< ossimString tileInfo)
private
Definition at line 392 of file ossimGeoPdfReader.cpp.
References buildTileInfo(), ossimString::contains(), ossimString::downcase(), and m_podofoTileInfo.
Referenced by setPodofoImageInfo().
393 {
394  m_podofoTileInfo.clear();
395  std::vector<ossimString> tileInfoVector;
396  for (ossim_uint32 index = 0; index < tileInfo.size(); ++index)
397  {
398  std::vector<ossimString> tmpVector = tileInfo[index].split("\n");
399  for (ossim_uint32 i = 0; i < tmpVector.size(); i++)
400  {
401  ossimString tmpStr = tmpVector[i];
402  if (tmpStr.downcase().contains("layer_"))
403  {
404  buildTileInfo(tmpStr);
405  }
406  else if (tmpStr.downcase().contains("tile"))
407  {
408  tileInfoVector.push_back(tmpStr);
409  }
410  }
411  }
412
413  if (m_podofoTileInfo.size() == 0)//does not layer information, try tile information
414  {
415  for (ossim_uint32 index = 0; index < tileInfoVector.size(); ++index)
416  {
417  buildTileInfo(tileInfoVector[index]);
418  }
419  }
420
421  tileInfoVector.clear();
422 }
void buildTileInfo(ossimString tileInfo)
◆ resetCacheBuffer()
void ossimGeoPdfReader::resetCacheBuffer ( ossimFrameEntryData  entry)
private
Definition at line 166 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimImageData::loadBand(), ossimImageData::loadTile(), m_cacheSize, m_cacheTile, m_frameHeightVector, m_frameWidthVector, m_numberOfBands, ossimImageData::makeBlank(), OSSIM_BIP, ossimImageData::setImageRectangle(), ossimGeoPdfReader::ossimFrameEntryData::theCol, ossimGeoPdfReader::ossimFrameEntryData::theFrameEntry, ossimGeoPdfReader::ossimFrameEntryData::thePixelCol, ossimGeoPdfReader::ossimFrameEntryData::thePixelRow, ossimGeoPdfReader::ossimFrameEntryData::theRow, ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
167 {
168  ossim_int32 row = entry.theRow;
169  ossim_int32 col = entry.theCol;
170  ossim_int32 width = m_frameWidthVector[col];
171  ossim_int32 height = m_frameHeightVector[row];
172  ossim_int32 pixelRow = entry.thePixelRow;
173  ossim_int32 pixelCol = entry.thePixelCol;
174
175  ossimIrect imageRect(pixelCol, pixelRow, pixelCol+width-1, pixelRow+height-1);
176
177  ossimIrect cacheRect(pixelCol, pixelRow, pixelCol+m_cacheSize.x-1, pixelRow+m_cacheSize.y-1);
178
179  ossimIrect clipRect = cacheRect.clipToRect(imageRect);
180
181  m_cacheTile->setImageRectangle(clipRect);
182
183  if (!cacheRect.completely_within(imageRect))
184  {
186  }
187
189
190  void* lineBuffer = 0;
191  std::vector<PoDoFo::PdfObject*> imageObjects = entry.theFrameEntry;
192  if (imageObjects.size() == 1)
193  {
194  PoDoFo::PdfMemStream* pStream = dynamic_cast<PoDoFo::PdfMemStream*>(imageObjects[0]->GetStream());
195  pStream->Uncompress();
196  PoDoFo::pdf_long length = pStream->GetLength();
197  pStream->GetCopy((char**)&lineBuffer, &length);
198  if (lineBuffer)
199  {
200  m_cacheTile->loadTile(lineBuffer, imageRect, clipRect, OSSIM_BIP);
201  delete [] (char*)lineBuffer;
202  lineBuffer = 0;
203  }
204  }
205  else
206  {
207  for (ossim_uint32 band = 0; band < m_numberOfBands; ++band)
208  {
209  PoDoFo::PdfMemStream* pStream = dynamic_cast<PoDoFo::PdfMemStream*>(imageObjects[band]->GetStream());
210  pStream->Uncompress();
211  PoDoFo::pdf_long length = pStream->GetLength();
212  pStream->GetCopy((char**)&lineBuffer, &length);
213
214  if (lineBuffer)
215  {
216  m_cacheTile->loadBand(lineBuffer, imageRect,clipRect, band);
217  delete [] (char*)lineBuffer;
218  lineBuffer = 0;
219  }
220  }
221  }
222  if (lineBuffer != NULL)
223  {
224  delete [] (char*)lineBuffer;
225  lineBuffer = 0;
226  }
227 }
virtual void loadBand(const void *src, const ossimIrect &src_rect, ossim_uint32 band)
ossim_uint32 m_numberOfBands
Has sub image offset.
ossim_int32 y
ossim_int32 x
int ossim_int32
◆ saveState()
bool ossimGeoPdfReader::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 645 of file ossimGeoPdfReader.cpp.
References m_pageVector, ossimImageGeometry::saveState(), ossimImageHandler::saveState(), and ossimRefPtr< T >::valid().
647 {
648  for (ossim_uint32 i = 0; i < m_pageVector.size(); i++)
649  {
650  ossimRefPtr<ossimImageGeometry> imageGeometry = m_pageVector[i]->m_geoImage;
651  if(imageGeometry.valid())
652  {
653  imageGeometry->saveState(kwl, prefix);
654  }
655  }
656
657  return ossimImageHandler::saveState(kwl, prefix);
658 }
bool valid() const
std::vector< ossimGeoPdfVectorPageNode * > m_pageVector
Saves the transform (if any) and projection (if any) states to the KWL.
◆ setCurrentEntry()
bool ossimGeoPdfReader::setCurrentEntry ( ossim_uint32  entryIdx)
virtual
Parameters
entryIdxEntry number to select.
Note
The implementation does nothing. Derived classes that handle multiple images should override.
Returns
true if it was able to set the current entry and false otherwise.
Definition at line 629 of file ossimGeoPdfReader.cpp.
References m_imageRect, m_pageVector, ossimIrect::makeNan(), ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
630 {
631  if (m_pageVector.size() > entryIdx)
632  {
633  theGeometry = 0;
635  theGeometry = m_pageVector[entryIdx]->m_geoImage;
636  m_imageRect = m_pageVector[entryIdx]->m_boundingRect;
637  if (theGeometry.valid())
638  {
639  return true;
640  }
641  }
642  return false;
643 }
bool valid() const
void makeNan()
Definition: ossimIrect.h:329
◆ setPodofoArrayInfo()
void ossimGeoPdfReader::setPodofoArrayInfo ( PoDoFo::PdfObject *  object)
private
Definition at line 1051 of file ossimGeoPdfReader.cpp.
References setPodofoDictInfo(), and setPodofoRefInfo().
Referenced by setPodofoInfo().
1052 {
1053  PoDoFo::PdfArray arrayObj = object->GetArray();
1054  for (ossim_uint32 i = 0; i < arrayObj.size(); i++)
1055  {
1056  PoDoFo::PdfObject objTmp = arrayObj[i];
1057  if (objTmp.IsDictionary())
1058  {
1059  setPodofoDictInfo(&objTmp);
1060  }
1061  else if (objTmp.IsReference())
1062  {
1063  setPodofoRefInfo(&objTmp);
1064  }
1065  }
1066 }
void setPodofoDictInfo(PoDoFo::PdfObject *object)
void setPodofoRefInfo(PoDoFo::PdfObject *object)
◆ setPodofoDictInfo()
void ossimGeoPdfReader::setPodofoDictInfo ( PoDoFo::PdfObject *  object)
private
Definition at line 1082 of file ossimGeoPdfReader.cpp.
References m_podofoProjInfo, and setPodofoRefInfo().
Referenced by setPodofoArrayInfo(), setPodofoInfo(), and setPodofoRefInfo().
1083 {
1084  std::string valueStr;
1085  PoDoFo::PdfDictionary pdfDictionary = object->GetDictionary();
1086  PoDoFo::TKeyMap keyMap = pdfDictionary.GetKeys();
1087  PoDoFo::TKeyMap::iterator it = keyMap.begin();
1088  while (it != keyMap.end())
1089  {
1090  ossimString refName = ossimString(it->first.GetName());
1091  PoDoFo::PdfObject* refObj = it->second;
1092  if (refObj->IsReference())
1093  {
1094  setPodofoRefInfo(refObj);
1095  }
1096  else
1097  {
1098  refObj->ToString(valueStr);
1099  if (valueStr != "")
1100  {
1101  m_podofoProjInfo[refName] = valueStr;
1102  }
1103  }
1104  it++;
1105  }
1106 }
◆ setPodofoImageInfo()
void ossimGeoPdfReader::setPodofoImageInfo ( )
private
Definition at line 1108 of file ossimGeoPdfReader.cpp.
References ossimString::contains(), ossimString::downcase(), m_isJpeg, m_pdfMemDocument, m_podofoImageObjs, m_podofoTileInfo, parseTileStructure(), and ossimString::push_back().
1109 {
1110  PoDoFo::PdfObject* pObj = NULL;
1111  m_podofoImageObjs.clear();
1112  std::vector<ossimString> tmpForm;
1113  int count = 1;
1114  int rowCount = 0;
1115  bool isDctDecode = false;
1116  PoDoFo::TCIVecObjects it = m_pdfMemDocument->GetObjects().begin();
1117  while( it != m_pdfMemDocument->GetObjects().end() )
1118  {
1119  if ((*it)->IsDictionary())
1120  {
1121  pObj = (*it)->GetDictionary().GetKey( PoDoFo::PdfName::KeyType );
1122  if( pObj && pObj->IsName() && ( pObj->GetName().GetName() == "XObject" ))
1123  {
1124  pObj = (*it)->GetDictionary().GetKey( PoDoFo::PdfName::KeySubtype );
1125  if( pObj && pObj->IsName() && ( pObj->GetName().GetName() == "Form" ))
1126  {
1127  std::string imageTileInfo;
1128  (*it)->ToString(imageTileInfo);
1129  ossimString imageTileInfoStr = imageTileInfo;
1130  if (imageTileInfoStr.downcase().contains("tile"))
1131  {
1132  tmpForm.push_back(imageTileInfoStr);
1133  }
1134  }
1135  else if( pObj && pObj->IsName() && ( pObj->GetName().GetName() == "Image" ))
1136  {
1137  pObj = (*it)->GetDictionary().GetKey( PoDoFo::PdfName::KeyFilter );
1138  if( pObj->IsName() && ( pObj->GetName().GetName() == "DCTDecode" ))
1139  {
1140  m_podofoImageObjs[count] = (*it);
1141  isDctDecode = true;
1142  }
1143  else if( pObj->IsArray() && pObj->GetArray().GetSize() == 1 &&
1144  pObj->GetArray()[0].IsName() && (pObj->GetArray()[0].GetName().GetName() == "DCTDecode"))
1145  {
1146  m_podofoImageObjs[count] = (*it);
1147  isDctDecode = true;
1148  }
1149  else if (pObj->IsName() && (pObj->GetName().GetName() == "FlateDecode") )
1150  {
1151  if (isDctDecode == false)
1152  {
1153  std::pair<ossim_int32, ossim_int32> tileRowCol;
1154  tileRowCol = make_pair(rowCount, 0);
1155  m_podofoTileInfo[count] = tileRowCol;
1156  m_podofoImageObjs[count] = (*it);
1157  m_isJpeg = false;
1158  }
1159  rowCount++;
1160  }
1161  }
1162  }
1163  }
1164  ++it;
1165  ++count;
1166  }
1167
1168  if (m_isJpeg == false)
1169  {
1170  std::map<ossim_int32, ossim_int32> widthMap;
1171  std::map<ossim_int32, PoDoFo::PdfObject*>::iterator it = m_podofoImageObjs.begin();
1172  while (it != m_podofoImageObjs.end())
1173  {
1174  PoDoFo::PdfObject* tmpObj = it->second;
1175  PoDoFo::PdfImage image(tmpObj);
1176  int width = image.GetWidth();
1177  widthMap[it->first] = width;
1178  it++;
1179  }
1180
1181  std::map<ossim_int32, ossim_int32>::iterator itWidth = widthMap.begin();
1182  ossim_int32 firstId = itWidth->first;
1183  ossim_int32 firstWidth = itWidth->second;
1184  widthMap.erase(itWidth);
1185
1186  itWidth = widthMap.end();
1187  itWidth--;
1188  ossim_int32 lastId = itWidth->first;
1189  ossim_int32 lastWidth = itWidth->second;
1190
1191  itWidth = widthMap.begin();
1192  ossim_int32 invalidId = 0;
1193  while (itWidth != widthMap.end())
1194  {
1195  ossim_int32 tmpWidth = itWidth->second;
1196  ossim_int32 tmpId = itWidth->first;
1197  if (firstWidth == tmpWidth)
1198  {
1199  invalidId = lastId;
1200  }
1201  else if ( lastWidth == tmpWidth )
1202  {
1203  invalidId = firstId;
1204  }
1205  else
1206  {
1207  invalidId = tmpId;
1208  }
1209  break;
1210  itWidth++;
1211  }
1212
1213  it = m_podofoImageObjs.find(invalidId);
1214  if (it != m_podofoImageObjs.end())
1215  {
1216  m_podofoImageObjs.erase(it);
1217  }
1218
1219  std::map<ossim_int32, std::pair<ossim_int32, ossim_int32> >::iterator itTile = m_podofoTileInfo.find(invalidId);
1220  if (itTile != m_podofoTileInfo.end())
1221  {
1222  m_podofoTileInfo.erase(itTile);
1223  }
1224
1225  if (invalidId == firstId)
1226  {
1227  itTile = m_podofoTileInfo.begin();
1228  while (itTile != m_podofoTileInfo.end())
1229  {
1230  ossim_int32 index = itTile->first;
1231  ossim_int32 tileRow = itTile->second.first;
1232  if (tileRow > 0)
1233  {
1234  std::pair<ossim_int32, ossim_int32> tileRowCol;
1235  tileRowCol = make_pair(tileRow-1, 0);
1236  m_podofoTileInfo[index] = tileRowCol;
1237  }
1238  else
1239  {
1240  break;
1241  }
1242  itTile++;
1243  }
1244  }
1245  widthMap.clear();
1246  }
1247
1248  if (tmpForm.size() > 0 && m_podofoTileInfo.size() == 0)
1249  {
1250  parseTileStructure(tmpForm);
1251  }
1252  tmpForm.clear();
1253 }
PoDoFo::PdfMemDocument * m_pdfMemDocument
std::map< ossim_int32, PoDoFo::PdfObject * > m_podofoImageObjs
std::map< ossim_int32, std::pair< ossim_int32, ossim_int32 > > m_podofoTileInfo
int ossim_int32
◆ setPodofoInfo()
void ossimGeoPdfReader::setPodofoInfo ( PoDoFo::PdfObject *  object)
private
Definition at line 1034 of file ossimGeoPdfReader.cpp.
References m_podofoProjInfo, setPodofoArrayInfo(), setPodofoDictInfo(), and setPodofoRefInfo().
1035 {
1036  m_podofoProjInfo.clear();
1037  if (object->IsReference())
1038  {
1039  setPodofoRefInfo(object);
1040  }
1041  else if (object->IsDictionary())
1042  {
1043  setPodofoDictInfo(object);
1044  }
1045  else if (object->IsArray())
1046  {
1047  setPodofoArrayInfo(object);
1048  }
1049 }
void setPodofoArrayInfo(PoDoFo::PdfObject *object)
std::map< ossimString, ossimString, ossimStringLtstr > m_podofoProjInfo
◆ setPodofoRefInfo()
void ossimGeoPdfReader::setPodofoRefInfo ( PoDoFo::PdfObject *  object)
private
Definition at line 1068 of file ossimGeoPdfReader.cpp.
References m_pdfMemDocument, and setPodofoDictInfo().
Referenced by setPodofoArrayInfo(), setPodofoDictInfo(), and setPodofoInfo().
1069 {
1070  PoDoFo::PdfReference pdfReference = object->GetReference();
1071  PoDoFo::PdfVecObjects objVector = m_pdfMemDocument->GetObjects();
1072  if (pdfReference.IsIndirect())
1073  {
1074  PoDoFo::PdfObject* refObj = objVector.GetObject(pdfReference);
1075  if (refObj->IsDictionary())
1076  {
1077  setPodofoDictInfo(refObj);
1078  }
1079  }
1080 }
Member Data Documentation
◆ m_cacheId
ossimAppFixedTileCache::ossimAppFixedCacheId ossimGeoPdfReader::m_cacheId
private
Definition at line 323 of file ossimGeoPdfReader.h.
◆ m_cacheSize
ossimIpt ossimGeoPdfReader::m_cacheSize
private
Definition at line 322 of file ossimGeoPdfReader.h.
Referenced by resetCacheBuffer().
◆ m_cacheTile
ossimRefPtr<ossimImageData> ossimGeoPdfReader::m_cacheTile
private
Definition at line 321 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), fillTile(), and resetCacheBuffer().
◆ m_currentCol
ossim_int32 ossimGeoPdfReader::m_currentCol
private
Definition at line 305 of file ossimGeoPdfReader.h.
◆ m_currentRow
ossim_int32 ossimGeoPdfReader::m_currentRow
private
Definition at line 304 of file ossimGeoPdfReader.h.
◆ m_frameEntryArray
std::vector<std::vector< std::vector<PoDoFo::PdfObject*> > > ossimGeoPdfReader::m_frameEntryArray
private
Definition at line 324 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), closeEntry(), and getIntersectingEntries().
◆ m_frameHeightVector
std::map<ossim_int32, ossim_int32> ossimGeoPdfReader::m_frameHeightVector
private
◆ m_frameWidthVector
std::map<ossim_int32, ossim_int32> ossimGeoPdfReader::m_frameWidthVector
private
◆ m_imageRect
ossimIrect ossimGeoPdfReader::m_imageRect
private
Definition at line 298 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), and setCurrentEntry().
◆ m_isJpeg
bool ossimGeoPdfReader::m_isJpeg
private
Definition at line 318 of file ossimGeoPdfReader.h.
Referenced by fillTile(), and setPodofoImageInfo().
◆ m_isLGIDict
bool ossimGeoPdfReader::m_isLGIDict
private
Definition at line 317 of file ossimGeoPdfReader.h.
Referenced by computeBoundingRect(), and getGeoProjection().
◆ m_numberOfBands
ossim_uint32 ossimGeoPdfReader::m_numberOfBands
private
Definition at line 299 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), getNumberOfInputBands(), getNumberOfOutputBands(), and resetCacheBuffer().
◆ m_numberOfLines
ossim_uint32 ossimGeoPdfReader::m_numberOfLines
private
◆ m_numberOfSamples
ossim_uint32 ossimGeoPdfReader::m_numberOfSamples
private
◆ m_numOfFramesHorizontal
ossim_int32 ossimGeoPdfReader::m_numOfFramesHorizontal
private
Definition at line 303 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray().
◆ m_numOfFramesVertical
ossim_int32 ossimGeoPdfReader::m_numOfFramesVertical
private
Definition at line 302 of file ossimGeoPdfReader.h.
◆ m_pageVector
std::vector<ossimGeoPdfVectorPageNode*> ossimGeoPdfReader::m_pageVector
private
◆ m_pdfMemDocument
PoDoFo::PdfMemDocument* ossimGeoPdfReader::m_pdfMemDocument
private
Definition at line 316 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), setPodofoImageInfo(), and setPodofoRefInfo().
◆ m_podofoImageObjs
std::map<ossim_int32, PoDoFo::PdfObject*> ossimGeoPdfReader::m_podofoImageObjs
private
Definition at line 315 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), closeEntry(), and setPodofoImageInfo().
◆ m_podofoProjInfo
std::map<ossimString, ossimString, ossimStringLtstr> ossimGeoPdfReader::m_podofoProjInfo
private
◆ m_podofoTileInfo
std::map<ossim_int32, std::pair<ossim_int32, ossim_int32> > ossimGeoPdfReader::m_podofoTileInfo
private
◆ m_scalarType
ossimScalarType ossimGeoPdfReader::m_scalarType
private
Definition at line 308 of file ossimGeoPdfReader.h.
Referenced by getOutputScalarType().
◆ m_tile
ossimRefPtr<ossimImageData> ossimGeoPdfReader::m_tile
private
Definition at line 309 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), and getTile().
