Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimH5ReaderFactory Class Reference
Factory for Hdf image reader. More...
#include <ossimH5ReaderFactory.h>
Inheritance diagram for ossimH5ReaderFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimH5ReaderFactory ()
 virtual destructor More...
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
 open that takes a file name. More...
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
 open that takes a keyword list and prefix. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimH5Reader) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list and prefix. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds ossimH5Reader to the typeList. More...
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
 Method to add supported extension to the list, like "hdf". More...
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
 Open method that takes a stream. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
 Open overview that takes a file name. More...
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
virtual void getImageHandlersBySuffix (ImageHandlerList &result, const ossimString &ext) const
virtual void getImageHandlersByMimeType (ImageHandlerList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimH5ReaderFactoryinstance ()
 static method to return instance (the only one) of this class. More...
bool hasExcludedExtension (const ossimFilename &file) const
 Method to weed out extensions that this plugin knows it does not support. More...
 hidden from use default constructor More...
 ossimH5ReaderFactory (const ossimH5ReaderFactory &)
 hidden from use copy constructor More...
void operator= (const ossimH5ReaderFactory &)
virtual ~ossimReferenced ()
static ossimH5ReaderFactorytheInstance = 0
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
Detailed Description
Definition at line 23 of file ossimH5ReaderFactory.h.
◆ ~ossimH5ReaderFactory()
ossimH5ReaderFactory::~ossimH5ReaderFactory ( )
virtual
virtual destructor
Definition at line 31 of file ossimH5ReaderFactory.cpp.
References theInstance.
32 {
33  theInstance = 0;
34 }
static ossimH5ReaderFactory * theInstance
◆ ossimH5ReaderFactory() [1/2]
ossimH5ReaderFactory::ossimH5ReaderFactory ( )
protected
Definition at line 155 of file ossimH5ReaderFactory.cpp.
Referenced by instance().
155 {}
◆ ossimH5ReaderFactory() [2/2]
ossimH5ReaderFactory::ossimH5ReaderFactory ( const ossimH5ReaderFactory )
protected
Definition at line 157 of file ossimH5ReaderFactory.cpp.
157 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimH5ReaderFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimH5Reader".
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 109 of file ossimH5ReaderFactory.cpp.
References ossimRefPtr< T >::release().
111 {
112  ossimRefPtr<ossimObject> result = 0;
113  if(typeName == "ossimH5Reader")
114  {
115  result = new ossimHdf5ImageHandler;
116  }
117
118  return result.release();
119 }
This is the base class for all imagery using HDF5 as the file format.
T * release()
Definition: ossimRefPtr.h:93
◆ createObject() [2/2]
ossimObject * ossimH5ReaderFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image handler on success, NULL on failure.
Definition at line 121 of file ossimH5ReaderFactory.cpp.
References open().
124 {
125  return this->open(kwl, prefix);
126 }
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
◆ getSupportedExtensions()
void ossimH5ReaderFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Parameters
extensionListThe list to add to.
Implements ossimImageHandlerFactoryBase.
Definition at line 134 of file ossimH5ReaderFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
136 {
137  extensionList.push_back(ossimString("h5"));
138  extensionList.push_back(ossimString("he5"));
139  extensionList.push_back(ossimString("hdf5"));
140 }
◆ getTypeNameList()
void ossimH5ReaderFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 128 of file ossimH5ReaderFactory.cpp.
130 {
131  typeList.push_back(ossimString("ossimH5Reader"));
132 }
◆ hasExcludedExtension()
bool ossimH5ReaderFactory::hasExcludedExtension ( const ossimFilename file) const
protected
This is to avoid a costly open on say a tiff or jpeg that is not handled by this plugin.
Returns
true if extension, false if not.
Definition at line 142 of file ossimH5ReaderFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
144 {
145  bool result = true;
146  ossimString ext = file.ext().downcase();
147  //only include the file with those extension and exclude any other files
148  if ( (ext == "h5") || (ext == "hdf5") || (ext == "he5") )
149  {
150  result = false;
151  }
152  return result;
153 }
ossimString ext() const
◆ instance()
ossimH5ReaderFactory * ossimH5ReaderFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 36 of file ossimH5ReaderFactory.cpp.
References ossimH5ReaderFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
37 {
38  if(!theInstance)
39  {
41  }
42  return theInstance;
43 }
◆ open() [1/2]
ossimImageHandler * ossimH5ReaderFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Parameters
fileThe file to open.
openOverviewIf true image handler will attempt to open overview. default = true
Returns
Definition at line 45 of file ossimH5ReaderFactory.cpp.
Referenced by createObject().
47 {
48  if(traceDebug())
49  {
51  << "ossimH5ReaderFactory::open(filename) DEBUG: entered..."
52  << "\ntrying ossimH5Reader"
53  << std::endl;
54  }
55
57
58  if ( hasExcludedExtension(fileName) == false )
59  {
60  if (reader == 0) //try hdf5 reader
61  {
62  // cout << "Calling ossimH5Reader ***********************" << endl;
63  reader = new ossimHdf5ImageHandler;
65  if(reader->open(fileName) == false)
66  {
67  reader = 0;
68  }
69  }
70  }
71
72  if(traceDebug())
73  {
75  << "ossimH5ReaderFactory::open(filename) DEBUG: leaving..."
76  << std::endl;
77  }
78
79  return reader.release();
80 }
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
bool hasExcludedExtension(const ossimFilename &file) const
T * release()
◆ open() [2/2]
ossimImageHandler * ossimH5ReaderFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
Definition at line 82 of file ossimH5ReaderFactory.cpp.
84 {
85  if(traceDebug())
86  {
88  << "ossimH5ReaderFactory::open(kwl, prefix) DEBUG: entered..."
89  << "Trying ossimKakaduNitfReader"
90  << std::endl;
91  }
92
94  if(reader->loadState(kwl, prefix) == false)
95  {
96  reader = 0;
97  }
98
99  if(traceDebug())
100  {
102  << "ossimH5ReaderFactory::open(kwl, prefix) DEBUG: leaving..."
103  << std::endl;
104  }
105
106  return reader.release();
107 }
T * release()
◆ operator=()
void ossimH5ReaderFactory::operator= ( const ossimH5ReaderFactory )
protected
Definition at line 159 of file ossimH5ReaderFactory.cpp.
159 {}
Member Data Documentation
◆ theInstance
ossimH5ReaderFactory * ossimH5ReaderFactory::theInstance = 0
staticprotected
Definition at line 106 of file ossimH5ReaderFactory.h.
Referenced by instance(), and ~ossimH5ReaderFactory().
