9 #ifndef ossimHdf5ImageHandler_HEADER 10 #define ossimHdf5ImageHandler_HEADER 1 104 const char* prefix=0)
const;
111 const char* prefix=0);
134 virtual bool isOpen()
const;
137 virtual void close();
156 virtual void getEntryNames(std::vector<ossimString>& entryNames)
const;
163 virtual void getEntryList(std::vector<ossim_uint32>& entryList)
const;
200 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
220 std::vector<ossimRefPtr<ossimHdf5ImageDataset> >
m_entries;
virtual bool open()=0
Pure virtual open.
void addRenderable(const ossimString &datasetName)
Adds the dataset name, either the full HDF5 path or the simple object name, to the list of renderable...
ossimRefPtr< ossimImageData > m_tile
std::vector< ossimRefPtr< ossimHdf5ImageDataset > > m_entries
virtual void getEntryNames(std::vector< ossimString > &entryNames) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
This is the base class for all imagery using HDF5 as the file format.
virtual ossimString getClassName() const
Class encapsulates a HDF5 Data set that can be loaded as an image.
ossimRefPtr< ossimHdf5 > m_hdf5
virtual ossimString getShortName() const
virtual bool isOpen() const =0
Retuns the min pixel value.
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
const std::vector< ossimString > & getRenderableSetNames()
virtual ossim_uint32 getCurrentEntry() const
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossim_uint32 getNumberOfEntries() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
ossim_uint32 m_currentEntry
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual void loadMetaData()
There is an external file with an omd extension.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
std::vector< ossimString > m_renderableNames
