Public Member Functions | Protected Member Functions | Protected Attributes | Friends | List of all members
ossimHdf5ImageHandler Class Reference
This is the base class for all imagery using HDF5 as the file format. More...
#include <ossimHdf5ImageHandler.h>
Inheritance diagram for ossimHdf5ImageHandler:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimViirsHandler ossimViirsHandler
 ossimHdf5ImageHandler ()
 default constructor More...
virtual ~ossimHdf5ImageHandler ()
 virtual destructor More...
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
 Method to get a tile. More...
 Returns the number of bands in the image. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
 Returns the number of samples in the image. More...
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
 Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More...
 Returns the output pixel type of the tile source. More...
virtual bool isOpen () const
virtual void close ()
 Close method. More...
virtual void loadMetaData ()
ossimRefPtr< ossimHdf5ImageDatasetgetCurrentDataset ()
 Set propterty method. More...
 Get propterty method. More...
 Get propterty names. More...
virtual bool open ()
 The derived class needs to initialize the raster dataset names m_renderableNames in their constructor, for this method to work. More...
const std::vector< ossimString > & getRenderableSetNames ()
void addRenderable (const ossimString &datasetName)
 Adds the dataset name, either the full HDF5 path or the simple object name, to the list of renderable datasets. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
void allocate ()
 Allocates the tile. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
std::vector< ossimStringm_renderableNames
ossimRefPtr< ossimHdf5m_hdf5
std::vector< ossimRefPtr< ossimHdf5ImageDataset > > m_entries
ossim_uint32 m_currentEntry
std::mutex m_mutex
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Friends
class ossimHdf5ImageDataset
Additional Inherited Members
Detailed Description
HDF5 is unique in that it represents a variety of subformats for raster and projection information. The derived classes will need to specify the group and dataset names where the needed data lives.
Definition at line 26 of file ossimHdf5ImageHandler.h.
◆ ossimHdf5ImageHandler()
ossimHdf5ImageHandler::ossimHdf5ImageHandler ( )
default constructor
Definition at line 50 of file ossimHdf5ImageHandler.cpp.
52  m_entries(),
53  m_currentEntry(0),
54  m_tile(0),
55  m_mutex()
56 {
57 }
ossimRefPtr< ossimImageData > m_tile
ossimImageHandler()
Constructor (default):
◆ ~ossimHdf5ImageHandler()
ossimHdf5ImageHandler::~ossimHdf5ImageHandler ( )
virtual
virtual destructor
Definition at line 59 of file ossimHdf5ImageHandler.cpp.
References close(), and isOpen().
60 {
61  if (isOpen())
62  {
63  close();
64  }
65 }
virtual void close()
Close method.
virtual bool isOpen() const
Member Function Documentation
◆ addRenderable()
void ossimHdf5ImageHandler::addRenderable ( const ossimString datasetName)
inline
Definition at line 212 of file ossimHdf5ImageHandler.h.
Referenced by ossimHdf5Tool::loadImageFiles().
212 { m_renderableNames.push_back(datasetName); }
std::vector< ossimString > m_renderableNames
◆ allocate()
void ossimHdf5ImageHandler::allocate ( )
protected
Allocates the tile.
Definition at line 67 of file ossimHdf5ImageHandler.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_mutex, and m_tile.
Referenced by getTile().
68 {
69  m_mutex.lock();
71  m_tile->initialize();
72  m_mutex.unlock();
73 }
virtual void initialize()
Initialize the data buffer.
◆ close()
void ossimHdf5ImageHandler::close ( )
virtual
Close method.
Definition at line 425 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::close(), m_entries, m_hdf5, m_tile, and ossimRefPtr< T >::valid().
Referenced by ~ossimHdf5ImageHandler().
426 {
427  // Close the datasets.
428  m_entries.clear();
429
430  // Then the file.
431  if ( m_hdf5.valid() )
432  m_hdf5 = 0;
433
434  // ossimRefPtr so assign to 0(unreferencing) will handle memory.
435  m_tile = 0;
436
438 }
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimHdf5 > m_hdf5
◆ getClassName()
ossimString ossimHdf5ImageHandler::getClassName ( ) const
virtual
Returns
"ossimH5Reader"
Definition at line 387 of file ossimHdf5ImageHandler.cpp.
388 {
389  return ossimString("ossimHdf5ImageHandler");
390 }
◆ getCurrentDataset()
ossimRefPtr< ossimHdf5ImageDataset > ossimHdf5ImageHandler::getCurrentDataset ( )
Definition at line 499 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry, and m_entries.
500 {
501  if ( m_currentEntry >= m_entries.size() )
502  return 0;
503
504  return m_entries[m_currentEntry];
505 }
◆ getCurrentEntry()
ossim_uint32 ossimHdf5ImageHandler::getCurrentEntry ( ) const
virtual
Returns
The current entry number.
Definition at line 494 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry.
495 {
496  return m_currentEntry;
497 }
◆ getEntryList()
void ossimHdf5ImageHandler::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
virtual
Parameters
entryListThis is the list to initialize with entry indexes.
Note
This implementation returns puts one entry "0" in the list.
Definition at line 454 of file ossimHdf5ImageHandler.cpp.
References m_entries.
455 {
456  const ossim_uint32 SIZE = m_entries.size();
457  entryList.resize( SIZE );
458  for ( ossim_uint32 i = 0; i < SIZE; ++i )
459  {
460  entryList[i] = i;
461  }
462 }
unsigned int ossim_uint32
◆ getEntryNames()
void ossimHdf5ImageHandler::getEntryNames ( std::vector< ossimString > &  entryNames) const
virtual
Get the name of entry as a string.
Example given from HDF5 file:
entry_name: /All_Data/VIIRS-IMG-GTM-EDR-GEO_All/QF1_VIIRSGTMGEO
Parameters
entryIdxZero based entry index. If out of range name will be cleared.
nameInitialized by this.
Definition at line 445 of file ossimHdf5ImageHandler.cpp.
446 {
447  entryNames.clear();
448  for (ossim_uint32 i=0; i<m_entries.size(); ++i )
449  {
450  entryNames.push_back(m_entries[i]->getName());
451  }
452 }
◆ getImageRectangle()
ossimIrect ossimHdf5ImageHandler::getImageRectangle ( ossim_uint32  reduced_res_level = 0) const
virtual
Note that rrds 0 is the highest resolution rrds.
Definition at line 195 of file ossimHdf5ImageHandler.cpp.
References getNumberOfLines(), and getNumberOfSamples().
196 {
197  return ossimIrect(0,
198  0,
199  getNumberOfSamples(reduced_res_level) - 1,
200  getNumberOfLines(reduced_res_level) - 1);
201 }
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
◆ getImageTileHeight()
ossim_uint32 ossimHdf5ImageHandler::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 372 of file ossimHdf5ImageHandler.cpp.
373 {
374  return 0; // Not tiled format.
375 }
◆ getImageTileWidth()
ossim_uint32 ossimHdf5ImageHandler::getImageTileWidth ( ) const
virtual
Definition at line 367 of file ossimHdf5ImageHandler.cpp.
368 {
369  return 0; // Not tiled format.
370 }
◆ getLongName()
ossimString ossimHdf5ImageHandler::getLongName ( ) const
virtual
Returns
"ossim hdf5"
Definition at line 382 of file ossimHdf5ImageHandler.cpp.
383 {
384  return ossimString("ossim hdf5 reader");
385 }
◆ getMaxPixelValue()
double ossimHdf5ImageHandler::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 512 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getMaxPixelValue(), m_currentEntry, and m_entries.
513 {
514  if ( m_currentEntry >= m_entries.size() )
515  {
516  if(m_entries[m_currentEntry]->isMaxPixelSet())
517  {
518  return m_entries[m_currentEntry]->getMaxPixelValue(band);
519  }
520  }
522 }
◆ getMinPixelValue()
double ossimHdf5ImageHandler::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 524 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getMinPixelValue(), m_currentEntry, and m_entries.
525 {
526  if ( m_currentEntry >= m_entries.size() )
527  {
528  if(m_entries[m_currentEntry]->isMinPixelSet())
529  {
530  return m_entries[m_currentEntry]->getMinPixelValue(band);
531  }
532  }
534 }
◆ getNullPixelValue()
double ossimHdf5ImageHandler::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Returns
Null pixel value.
Reimplemented in ossimViirsHandler, and ossimViirsHandler.
Definition at line 507 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getNullPixelValue().
Referenced by getTile(), ossimHdf5ImageDataset::getTileBuf(), and ossimHdf5ImageDataset::scanForMinMax().
508 {
510 }
◆ getNumberOfEntries()
ossim_uint32 ossimHdf5ImageHandler::getNumberOfEntries ( ) const
virtual
Returns
The number of entries (images) in the image file.
Definition at line 440 of file ossimHdf5ImageHandler.cpp.
441 {
442  return (ossim_uint32)m_entries.size();
443 }
◆ getNumberOfInputBands()
ossim_uint32 ossimHdf5ImageHandler::getNumberOfInputBands ( ) const
virtual
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 392 of file ossimHdf5ImageHandler.cpp.
Referenced by getNumberOfOutputBands(), and getTile().
393 {
394  ossim_uint32 result = 1;
395
396  if ( m_currentEntry < m_entries.size() )
397  result = m_entries[m_currentEntry]->getNumberOfBands();
398
399  return result;
400 }
◆ getNumberOfLines()
ossim_uint32 ossimHdf5ImageHandler::getNumberOfLines ( ossim_uint32  reduced_res_level = 0) const
virtual
Definition at line 335 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getNumberOfLines(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
336 {
337  ossim_uint32 r = 0;
338  if (reduced_res_level == 0)
339  {
340  if (m_currentEntry < m_entries.size())
342  }
343  else if ( theOverview.valid() )
344  {
345  r = theOverview->getNumberOfLines(reduced_res_level);
346  }
347
348  return r;
349 }
bool valid() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
ossimRefPtr< ossimImageHandler > theOverview
◆ getNumberOfOutputBands()
ossim_uint32 ossimHdf5ImageHandler::getNumberOfOutputBands ( ) const
virtual
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 402 of file ossimHdf5ImageHandler.cpp.
References getNumberOfInputBands().
403 {
404  // Currently not band selectable.
405  return getNumberOfInputBands();
406 }
virtual ossim_uint32 getNumberOfInputBands() const
◆ getNumberOfSamples()
ossim_uint32 ossimHdf5ImageHandler::getNumberOfSamples ( ossim_uint32  reduced_res_level = 0) const
virtual
Definition at line 351 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getNumberOfSamples(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
352 {
353  ossim_uint32 r = 0;
354  if (reduced_res_level == 0)
355  {
356  if (m_currentEntry < m_entries.size())
358  }
359  else if ( theOverview.valid() )
360  {
361  r = theOverview->getNumberOfSamples(reduced_res_level);
362  }
363
364  return r;
365 }
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimHdf5ImageHandler::getOutputScalarType ( ) const
virtual
Definition at line 408 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry, m_entries, and OSSIM_SCALAR_UNKNOWN.
409 {
411
412  if ( m_currentEntry < m_entries.size() )
413  {
414  result = m_entries[m_currentEntry]->getScalarType();
415  }
416
417  return result;
418 }
ossimScalarType
◆ getProperty()
ossimRefPtr< ossimProperty > ossimHdf5ImageHandler::getProperty ( const ossimString name) const
virtual
Overrides ossimImageHandler::getProperty.
Parameters
nameProperty name to get.
Definition at line 560 of file ossimHdf5ImageHandler.cpp.
References ossimString::string().
561 {
563  if ( name.string() == LAYER_KW )
564  {
565  if ( m_currentEntry < m_entries.size() )
566  {
567  ossimString value = m_entries[m_currentEntry]->getName();
568  prop = new ossimStringProperty(name, value);
569  }
570  }
571  else
572  {
573  prop = ossimImageHandler::getProperty(name);
574  }
575  return prop;
576 }
const std::string & string() const
Definition: ossimString.h:414
◆ getPropertyNames()
void ossimHdf5ImageHandler::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Overrides ossimImageHandler::getPropertyNames.
Parameters
propertyNamesArray to initialize.
Definition at line 578 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getPropertyNames().
579 {
580  propertyNames.push_back( ossimString("layer") );
582 }
◆ getRenderableSetNames()
const std::vector<ossimString>& ossimHdf5ImageHandler::getRenderableSetNames ( )
inline
Definition at line 208 of file ossimHdf5ImageHandler.h.
Referenced by ossimHdf5PluginHandlerFactory::getSupportedRenderableNames().
208 { return m_renderableNames; }
◆ getShortName()
ossimString ossimHdf5ImageHandler::getShortName ( ) const
virtual
Returns
"hdf5"
Definition at line 377 of file ossimHdf5ImageHandler.cpp.
378 {
379  return ossimString("ossim_hdf5_reader");
380 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimHdf5ImageHandler::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Satisfies pure virtual from TileSource class.
Definition at line 75 of file ossimHdf5ImageHandler.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_mutex, m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
77 {
78  if ( m_tile.valid() == false ) // First time through.
79  {
80  allocate();
81  }
82
83  if (m_tile.valid())
84  {
85  // Image rectangle must be set prior to calling getTile.
86  m_mutex.lock();
88  m_mutex.unlock();
89
90  if ( getTile( m_tile.get(), resLevel ) == false )
91  {
92  m_mutex.lock();
94  {
95  m_tile->makeBlank();
96  }
97  m_mutex.unlock();
98  }
99  }
100
101  return m_tile;
102 }
void allocate()
Allocates the tile.
bool valid() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
virtual void makeBlank()
◆ getTile() [2/2]
bool ossimHdf5ImageHandler::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 104 of file ossimHdf5ImageHandler.cpp.
References ossimIrect::area(), ossimIrect::clipToRect(), ossimIrect::completely_within(), getImageRectangle(), ossimImageData::getImageRectangle(), getNullPixelValue(), ossimImageData::getNumberOfBands(), getNumberOfInputBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossim_hdf5::getScalarType(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::loadBand(), m_currentEntry, m_entries, m_mutex, ossimImageData::makeBlank(), OSSIM_FLOAT32, ossimReferenced::ref(), ossim::scalarSizeInBytes(), status, ossimReferenced::unref(), and ossimImageData::validate().
105 {
106  bool status = false;
107
108  m_mutex.lock();
109
110  //---
111  // Not open, this tile source bypassed, or invalid res level,
112  // return a blank tile.
113  //---
114  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
115  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
116  {
117  result->ref(); // Increment ref count.
118
119  //---
120  // Check for overview tile. Some overviews can contain r0 so always
121  // call even if resLevel is 0. Method returns true on success, false
122  // on error.
123  //---
124  status = getOverviewTile(resLevel, result);
125
126  if (!status) // Did not get an overview tile.
127  {
128  status = true;
129
130  ossimIrect tile_rect = result->getImageRectangle();
131
132  if ( ! tile_rect.completely_within(getImageRectangle(0)) )
133  {
134  // We won't fill totally so make blank first.
135  result->makeBlank();
136  }
137
138  if (getImageRectangle(0).intersects(tile_rect))
139  {
140  // Make a clip rect.
141  ossimIrect clipRect = tile_rect.clipToRect(getImageRectangle(0));
142
143  if (tile_rect.completely_within( clipRect) == false)
144  {
145  // Not filling whole tile so blank it out first.
146  result->makeBlank();
147  }
148
149  // Create buffer to hold the clip rect for a single band.
150  ossim_uint32 clipRectSizeInBytes = clipRect.area() *
152  vector<char> dataBuffer(clipRectSizeInBytes);
153
154  // Get the data.
155  for (ossim_uint32 band = 0; band < getNumberOfInputBands(); ++band)
156  {
157  // Hdf5 file to buffer:
158  m_entries[m_currentEntry]->getTileBuf(&dataBuffer.front(), clipRect, band);
159 #if 0
160  // Scan and fix non-standard null value:
162  {
163  const ossim_float32 NP = getNullPixelValue(band);
164  const ossim_uint32 COUNT = clipRect.area();
165  ossim_float32* float_buffer = (ossim_float32*)&dataBuffer.front();
166  for ( ossim_uint32 i = 0; i < COUNT; ++i )
167  {
168  if ( float_buffer[i] < -999.0 )
169  float_buffer[i] = NP;
170  }
171  }
172 #endif
173  // Buffer to tile:
174  result->loadBand((void*)&dataBuffer.front(), clipRect, band);
175  }
176
177  // Validate the tile, i.e. full, partial, empty.
178  result->validate();
179  }
180  else // No intersection...
181  {
182  result->makeBlank();
183  }
184  }
185
186  result->unref(); // Decrement ref count.
187  }
188
189  m_mutex.unlock();
190
191  return status;
192 }
virtual void loadBand(const void *src, const ossimIrect &src_rect, ossim_uint32 band)
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in...
float ossim_float32
ossimScalarType getScalarType(const H5::DataSet *dataset)
32 bit floating point
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
virtual ossimIrect getImageRectangle() const
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
return status
ossim_uint32 area() const
Definition: ossimIrect.h:396
◆ isOpen()
bool ossimHdf5ImageHandler::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 420 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry, m_entries, m_hdf5, and ossimRefPtr< T >::valid().
Referenced by ossimViirsHandler::getImageGeometry(), getTile(), setCurrentEntry(), and ~ossimHdf5ImageHandler().
421 {
422  return ( m_hdf5.valid() && m_entries.size() && (m_currentEntry < m_entries.size()));
423 }
bool valid() const
◆ loadMetaData()
void ossimHdf5ImageHandler::loadMetaData ( )
virtual
There is an external file with an omd extension.
this file contains additional information about the image such as the null pixel, min and max values. For general raster it will contain much more than that.
Definition at line 220 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::loadMetaData(), and m_tile.
221 {
222  m_tile = 0;
224 }
virtual void loadMetaData()
◆ loadState()
bool ossimHdf5ImageHandler::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 209 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::loadState(), and open().
211 {
212  if (ossimImageHandler::loadState(kwl, prefix))
213  {
214  return open();
215  }
216
217  return false;
218 }
virtual bool open()
The derived class needs to initialize the raster dataset names m_renderableNames in their constructor...
◆ open()
bool ossimHdf5ImageHandler::open ( )
virtual
This should be implemented by the derived HDF5-format readers defined in plugins.
Returns
Definition at line 226 of file ossimHdf5ImageHandler.cpp.
Referenced by ossimHdf5Tool::loadImageFiles(), and loadState().
227 {
228  static const char* M = "ossimHdf5ImageHandler::open(filename) -- ";
229  if(traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG) << M <<" Entering..." << std::endl;
230
231  // Start with a clean slate.
232  if (isOpen())
233  {
234  close();
235  }
236
237  // Check for empty filename.
238  if (theImageFile.empty())
239  return false;
240
242  m_hdf5 = new ossimHdf5;
243  if (!m_hdf5->open(theImageFile))
244  {
245  if(traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG) << M <<" Unable to open image Leaving..." << std::endl;
246  m_hdf5 = 0;
247  return false;
248  }
249
250  if(traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG) << M <<" Opened Image..." << std::endl;
251
252  vector<H5::DataSet> datasetList;
253  H5::Group root;
254  m_hdf5->getRoot(root);
255  m_hdf5->getNdimDatasets(root, datasetList, true);
256
257  if ( datasetList.empty() )
258  {
259  return false;
260  m_hdf5->close();
261  m_hdf5 = 0;
262  }
263  // Filter for specified renderable datasets:
264  if (m_renderableNames.size())
265  {
266  std::vector<H5::DataSet>::iterator dataset = datasetList.begin();
267  while (dataset != datasetList.end())
268  {
269  bool found=false;
270  ossimString dsName = dataset->getObjName();
271  std::vector<ossimString>::iterator name = m_renderableNames.begin();
272  while (name != m_renderableNames.end())
273  {
274  if (dsName.contains(*name))
275  {
276  found = true;
277  break;
278  }
279  ++name;
280  }
281  if (!found)
282  datasetList.erase(dataset);
283  else
284  ++dataset;
285  }
286  }
287 #if 0
288  ossimNotify(ossimNotifyLevel_DEBUG)<< "ossimHdf5ImageHandler:"<<__LINE__ << " DEBUG\nDataset names:\n";
289  for ( ossim_uint32 i = 0; i < datasetList.size(); ++i )
290  {
291  ossimNotify(ossimNotifyLevel_DEBUG)<< "dataset[" << i << "]: "
292  << datasetList[i].getObjName() << "\n";
293  }
294 #endif
295  if ( datasetList.empty() )
296  {
297  m_hdf5 = 0;
298  return false;
299  }
300
301  // Add the image dataset entries.
302  std::vector<H5::DataSet>::iterator dataset = datasetList.begin();
303  while (dataset != datasetList.end())
304  {
306  oimgset->initialize(*dataset);
307  m_entries.push_back(oimgset);
308  ++dataset;
309  }
310
311  // Initialize the current entry to be 0:
312  m_currentEntry = 999; // Forces init on change of index
313  setCurrentEntry(0);
314
315  // Establish a common geometry for all entries. TODO: Need to verify if this is a kosher thing
316  // to do. It may be that multiple entries have different geometries associated.
318  if (!theGeometry.valid())
319  return false;
320
321 #if 0 /* Please leave for debug. (drb) */
322  std::vector<ossimHdf5ImageDataset>::const_iterator i = m_entries.begin();
323  while ( i != m_entries.end() )
324  {
325  std::cout << (*i) << endl;
326  ++i;
327  }
328 #endif
329  if(traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG) << M <<" Leaving..." << std::endl;
330
331  return true;
332 }
bool initialize(const H5::DataSet &dataset)
Opens datasetName and initializes all data members on success.
ossimRefPtr< ossimImageGeometry > theGeometry
bool getRoot(H5::Group &root) const
Assigns the root group.
Definition: ossimHdf5.cpp:93
bool valid() const
ossimFilename expand() const
Method to do file name expansion.
bool contains(char aChar) const
Definition: ossimString.h:58
bool open(const ossimFilename &hdf5File)
Opens specified HDF5 file.
Definition: ossimHdf5.cpp:29
bool close()
Closes the file and deletes all pointers.
Definition: ossimHdf5.cpp:72
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
Close method.
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
Low-level OSSIM interface to HDF5 libraries.
Definition: ossimHdf5.h:27
bool empty() const
Definition: ossimString.h:411
static bool getNdimDatasets(H5::Group group, std::vector< H5::DataSet > &datasetList, bool recursive=false)
Assigns list of all multi-dimensional datasets under current active group.
Definition: ossimHdf5.cpp:188
◆ saveState()
bool ossimHdf5ImageHandler::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 203 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::saveState().
205 {
206  return ossimImageHandler::saveState(kwl, prefix);
207 }
◆ setCurrentEntry()
bool ossimHdf5ImageHandler::setCurrentEntry ( ossim_uint32  entryIdx)
virtual
Parameters
entryIdxEntry number to select.
Note
The implementation does nothing. Derived classes that handle multiple images should override.
Returns
true if it was able to set the current entry and false otherwise.
Definition at line 464 of file ossimHdf5ImageHandler.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), isOpen(), ossimIrect::ll(), ossimIrect::lr(), m_currentEntry, m_entries, m_tile, ossimImageHandler::theOverviewFile, ossimImageHandler::theValidImageVertices, ossimIrect::ul(), and ossimIrect::ur().
465 {
466  bool result = true;
467  if (m_currentEntry != entryIdx)
468  {
469  // Entries always start at zero and increment sequentially..
470  if ( entryIdx < m_entries.size() )
471  {
473  m_currentEntry = entryIdx;
474  m_tile = 0;
475  ossimIrect validRect = m_entries[entryIdx]->getValidImageRect();
476  theValidImageVertices.clear();
477  theValidImageVertices.push_back(validRect.ul());
478  theValidImageVertices.push_back(validRect.ur());
479  theValidImageVertices.push_back(validRect.lr());
480  theValidImageVertices.push_back(validRect.ll());
481
482  if ( isOpen() )
483  completeOpen();
484  }
485  else
486  {
487  result = false; // Entry index out of range.
488  }
489  }
490
491  return result;
492 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
const ossimIpt & ul() const
Definition: ossimIrect.h:274
const ossimIpt & ll() const
Definition: ossimIrect.h:277
vector< ossimIpt > theValidImageVertices
const ossimIpt & lr() const
Definition: ossimIrect.h:276
const ossimIpt & ur() const
Definition: ossimIrect.h:275
virtual void completeOpen()
Will complete the opening process.
◆ setProperty()
void ossimHdf5ImageHandler::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
Parameters
propertyto set.
Definition at line 536 of file ossimHdf5ImageHandler.cpp.
References ossimProperty::getName(), ossimString::string(), and ossimRefPtr< T >::valid().
537 {
538  if ( !property.valid() )
539  return;
540
541  if ( property->getName().string() == LAYER_KW )
542  {
543  ossimString s;
544  property->valueToString(s);
545  ossim_uint32 SIZE = (ossim_uint32)m_entries.size();
546  for ( ossim_uint32 i = 0; i < SIZE; ++i )
547  {
548  if ( m_entries[i]->getName() == s.string() )
549  {
550  setCurrentEntry( i );
551  }
552  }
553  }
554  else
555  {
557  }
558 }
bool valid() const
const ossimString & getName() const
◆ ossimHdf5ImageDataset
friend class ossimHdf5ImageDataset
friend
Definition at line 28 of file ossimHdf5ImageHandler.h.
Member Data Documentation
◆ m_currentEntry
ossim_uint32 ossimHdf5ImageHandler::m_currentEntry
protected
◆ m_entries
std::vector<ossimRefPtr<ossimHdf5ImageDataset> > ossimHdf5ImageHandler::m_entries
protected
◆ m_hdf5
ossimRefPtr<ossimHdf5> ossimHdf5ImageHandler::m_hdf5
protected
◆ m_mutex
std::mutex ossimHdf5ImageHandler::m_mutex
protected
Definition at line 223 of file ossimHdf5ImageHandler.h.
Referenced by allocate(), and getTile().
◆ m_renderableNames
std::vector<ossimString> ossimHdf5ImageHandler::m_renderableNames
protected
Definition at line 218 of file ossimHdf5ImageHandler.h.
Referenced by ossimViirsHandler::ossimViirsHandler().
◆ m_tile
ossimRefPtr<ossimImageData> ossimHdf5ImageHandler::m_tile
protected
Definition at line 222 of file ossimHdf5ImageHandler.h.
Referenced by allocate(), close(), getTile(), loadMetaData(), and setCurrentEntry().
