#include <ossimJpipProjectionFactory.h>
virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
takes a filename. More... | |
virtual ossimProjection * | createProjection (const ossimString &name) const |
virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
Take a keywordlist. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimJpipProjectionFactory * | instance () |
ossimJpipProjectionFactory () | |
ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
This method takes the filename and tries to find an external ".geom" file. More... | |
virtual | ~ossimReferenced () |
Protected Attributes | |
TYPE_DATA | |
Definition at line 5 of file ossimJpipProjectionFactory.h.
protected |
Definition at line 10 of file ossimJpipProjectionFactory.cpp.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 73 of file ossimJpipProjectionFactory.cpp.
Creates and object given a keyword list.
Definition at line 78 of file ossimJpipProjectionFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 20 of file ossimJpipProjectionFactory.cpp.
References ossimString::c_str(), ossimInfoFactoryRegistry::create(), ossimProjectionFactoryRegistry::createProjection(), ossimString::downcase(), ossimFilename::ext(), ossimProjectionFactoryRegistry::instance(), ossimInfoFactoryRegistry::instance(), and ossimString::toString().
METHOD: create() Attempts to create an instance of the projection specified by name. Returns successfully constructed projection or NULL.
Definition at line 50 of file ossimJpipProjectionFactory.cpp.
Take a keywordlist.
Definition at line 55 of file ossimJpipProjectionFactory.cpp.
References ossimString::c_str(), ossimProjectionFactoryRegistry::createProjection(), ossimKeywordlist::getNumberOfSubstringKeys(), and ossimProjectionFactoryRegistry::instance().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 84 of file ossimJpipProjectionFactory.cpp.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 14 of file ossimJpipProjectionFactory.cpp.
Referenced by ossimSharedLibraryInitialize().
protected |
Definition at line 42 of file ossimJpipProjectionFactory.h.
