Factory for Kakadu based image writers. More...
#include <ossimKakaduWriterFactory.h>
virtual | ~ossimKakaduWriterFactory () |
virtual destructor More... | |
virtual ossimImageFileWriter * | createWriterFromExtension (const ossimString &fileExtension) const |
Creates a writer from extension like "ntf". More... | |
virtual ossimImageFileWriter * | createWriter (const ossimKeywordlist &kwl, const char *prefix=0) const |
Create that takes a keyword list and prefix. More... | |
virtual ossimImageFileWriter * | createWriter (const ossimString &typeName) const |
createWriter that takes a class name (ossimKakaduWriter) More... | |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
Creates and object given a keyword list. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
createObject that takes a class name (ossimKakaduWriter) More... | |
virtual void | getExtensions (std::vector< ossimString > &extList) const |
Adds "ntf" to list. More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Adds "ossimKakaduWriter" to list. More... | |
virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
Adds "ossim_kakada_nitf_j2k" to writer list. More... | |
virtual void | getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const |
virtual void | getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const |
virtual | ~ossimImageWriterFactoryBase () |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimKakaduWriterFactory * | instance () |
static method to return instance (the only one) of this class. More... | |
ossimKakaduWriterFactory () | |
hidden from use default constructor More... | |
ossimKakaduWriterFactory (const ossimKakaduWriterFactory &) | |
hidden from use copy constructor More... | |
void | operator= (const ossimKakaduWriterFactory &) |
virtual | ~ossimReferenced () |
typedef std::vector< ossimRefPtr< ossimImageFileWriter > > | ImageFileWriterList |
Definition at line 23 of file ossimKakaduWriterFactory.h.
protected |
Definition at line 164 of file ossimKakaduWriterFactory.cpp.
protected |
Definition at line 166 of file ossimKakaduWriterFactory.cpp.
kwl | The keyword list. |
prefix | the keyword list prefix. |
Implements ossimObjectFactory.
Definition at line 106 of file ossimKakaduWriterFactory.cpp.
References createWriter().
typeName | Should be "ossimKakaduReader". |
Definition at line 112 of file ossimKakaduWriterFactory.cpp.
Implements ossimImageWriterFactoryBase.
Definition at line 55 of file ossimKakaduWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
Definition at line 74 of file ossimKakaduWriterFactory.cpp.
References ossimImageFileWriter::hasImageType(), and ossimRefPtr< T >::release().
fileExtension | "ntf" |
Definition at line 34 of file ossimKakaduWriterFactory.cpp.
Adds "ntf" to list.
extList | List to add to. |
Definition at line 118 of file ossimKakaduWriterFactory.cpp.
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 155 of file ossimKakaduWriterFactory.cpp.
Definition at line 140 of file ossimKakaduWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
imageTypeList | List to append to. |
Definition at line 134 of file ossimKakaduWriterFactory.cpp.
typeList | List to add to. |
Definition at line 125 of file ossimKakaduWriterFactory.cpp.
static |
Definition at line 28 of file ossimKakaduWriterFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
protected |
Definition at line 168 of file ossimKakaduWriterFactory.cpp.
