#include <ossimKakaduJp2Writer.h>
ossimKakaduJp2Writer () | |
default constructor More... | |
virtual | ~ossimKakaduJp2Writer () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
Appends this writer image types to list "imageTypeList". More... | |
virtual bool | isOpen () const |
virtual bool | open () |
virtual void | close () |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
saves the state of the object. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
Will set the property whose name matches the argument "property->getName()". More... | |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
Pushes this's names onto the list of property names. More... | |
virtual ossimString | getExtension () const |
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More... | |
virtual bool | getOutputHasInternalOverviews (void) const |
Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More... | |
bool | hasImageType (const ossimString &imageType) const |
bool hasImageType(const ossimString& imageType) const More... | |
virtual bool | writeStream () |
Method to write the image to a stream. More... | |
virtual bool | setOutputStream (std::ostream &stream) |
Sets the output stream to write to. More... | |
ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0) | |
The writer will own the sequencer. More... | |
virtual | ~ossimImageFileWriter () |
virtual ossimObject * | getObject () |
virtual const ossimObject * | getObject () const |
virtual void | setTileSize (const ossimIpt &tileSize) |
Sets the output image tiling size if supported by the writer. More... | |
virtual bool | writeEnviHeaderFile () |
Will write an envi header file. More... | |
virtual bool | writeErsHeaderFile () |
Will write an ER Mapper header file. More... | |
virtual bool | writeExternalGeometryFile () |
Will write an external geometry file. More... | |
virtual bool | writeFgdcFile () |
Will write an fgdc file. More... | |
virtual bool | writeHistogramFile () |
Returns true on success, false on error. More... | |
virtual bool | writeJpegWorldFile () |
Will write a jpeg world file. More... | |
virtual bool | writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false) |
Write out an ossim overview file from the source_file. More... | |
virtual bool | writeReadmeFile () |
Will write a readme file. More... | |
virtual bool | writeTiffWorldFile () |
Will write a world file. More... | |
virtual bool | writeWorldFile () |
virtual bool | writeMetaDataFiles () |
Convenience method that calls meta data write methods that are flagged to be called. More... | |
virtual void | setAreaOfInterest (const ossimIrect &inputRect) |
virtual void | changeSequencer (ossimImageSourceSequencer *sequencer) |
Sets the sequencer and connects it to the input of this. More... | |
virtual ossimImageSourceSequencer * | getSequencer () |
virtual void | initialize () |
Initialize method. More... | |
virtual bool | execute () |
Calls: writeFile() writeMetaDataFiles() More... | |
virtual bool | setOutputStream (ossimRefPtr< ossimOStream > stream) |
virtual ossimRefPtr< ossimOStream > | getOutputStream () const |
Method to return the stream attached to output. More... | |
virtual void | setPercentComplete (double percentComplete) |
virtual void | setOutputImageType (ossim_int32 type) |
virtual void | setOutputImageType (const ossimString &type) |
virtual ossim_int32 | getOutputImageType () const |
virtual ossimString | getOutputImageTypeString () const |
virtual void | setOutputName (const ossimString &outputName) |
virtual void | setFilename (const ossimFilename &file) |
virtual const ossimFilename & | getFilename () const |
virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual bool | getWriteImageFlag () const |
Control flags... More... | |
virtual bool | getWriteHistogramFlag () const |
virtual bool | getWriteOverviewFlag () const |
virtual bool | getScaleToEightBitFlag () const |
virtual bool | getWriteEnviHeaderFlag () const |
virtual bool | getWriteErsHeaderFlag () const |
virtual bool | getWriteExternalGeometryFlag () const |
virtual bool | getWriteFgdcFlag () const |
virtual bool | getWriteJpegWorldFileFlag () const |
virtual bool | getWriteReadmeFlag () const |
virtual bool | getWriteTiffWorldFileFlag () const |
virtual bool | getWriteWorldFileFlag () const |
virtual void | setWriteImageFlag (bool flag) |
virtual void | setWriteOverviewFlag (bool flag) |
virtual void | setWriteHistogramFlag (bool flag) |
virtual void | setScaleToEightBitFlag (bool flag) |
virtual void | setWriteEnviHeaderFlag (bool flag) |
virtual void | setWriteErsHeaderFlag (bool flag) |
virtual void | setWriteExternalGeometryFlag (bool flag) |
virtual void | setWriteFgdcFlag (bool flag) |
virtual void | setWriteJpegWorldFile (bool flag) |
virtual void | setWriteReadme (bool flag) |
virtual void | setWriteTiffWorldFile (bool flag) |
virtual void | setWriteWorldFile (bool flag) |
virtual ossim_uint16 | getOverviewCompressType () const |
virtual ossim_int32 | getOverviewJpegCompressQuality () const |
virtual void | setOverviewCompressType (ossim_uint16 type) |
virtual void | setOverviewJpegCompressQuality (ossim_int32 quality) |
virtual bool | addListener (ossimListener *listener) |
Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More... | |
virtual bool | removeListener (ossimListener *listener) |
Overrides base "removeListener". More... | |
virtual void | setPixelType (ossimPixelType type) |
If "point" the coordinate tie points are relative to the center of the pixel. More... | |
virtual void | setPixelType (const ossimString &type) |
virtual ossimPixelType | getPixelType () const |
virtual void | getPixelTypeString (ossimString &type) const |
ossimImageWriter (ossimObject *owner=NULL) | |
ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed) | |
virtual | ~ossimImageWriter () |
virtual bool | setViewingRect (const ossimIrect &aRect) |
virtual ossimIrect | getAreaOfInterest () const |
ossimOutputSource (ossimObject *owner=NULL) | |
ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimOutputSource () |
virtual bool | open (const ossimString &outputName) |
virtual const ossimString & | getOutputName () |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimProcessInterface () | |
virtual | ~ossimProcessInterface () |
virtual void | abort () |
bool | needsAborting () const |
bool | isAbortRequested () const |
bool | isAborted () const |
bool | isExecuting () const |
ossimProcessStatus | getProcessStatus () const |
virtual void | setProcessStatus (ossimProcessStatus processStatus) |
virtual double | getPercentComplete () const |
virtual ossimListenerManager * | getManager () |
void | enableEvents () |
void | disableEvents () |
void | setCurrentMessage (const ossimString &message) |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
virtual void | refreshEvent (ossimRefreshEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
virtual bool | writeFile () |
Writes the file to disk or a stream. More... | |
bool | writeWorldFile (const ossimFilename &file) |
Common world file writer method. More... | |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Private Member Functions | |
bool | writeGeotiffBox (ossimKakaduCompressor *compressor) |
Writes geotiff box if input has good geometry. More... | |
bool | writeGmlBox (ossimKakaduCompressor *compressor) |
Writes GML box if input has good geometry. More... | |
Private Attributes | |
ossimKakaduCompressor * | m_compressor |
std::ostream * | m_outputStream |
bool | m_ownsStreamFlag |
Definition at line 24 of file ossimKakaduJp2Writer.h.
ossimKakaduJp2Writer::ossimKakaduJp2Writer | ( | ) |
default constructor
Definition at line 55 of file ossimKakaduJp2Writer.cpp.
Definition at line 78 of file ossimKakaduJp2Writer.cpp.
References close(), and m_compressor.
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 386 of file ossimKakaduJp2Writer.cpp.
References m_outputStream, and m_ownsStreamFlag.
Referenced by open(), and ~ossimKakaduJp2Writer().
Definition at line 100 of file ossimKakaduJp2Writer.cpp.
imageType | string representing image type. |
Reimplemented from ossimImageFileWriter.
Definition at line 405 of file ossimKakaduJp2Writer.cpp.
imageTypeList | stl::vector<ossimString> list to append to. |
Implements ossimImageFileWriter.
Definition at line 400 of file ossimKakaduJp2Writer.cpp.
References getShortName().
Definition at line 95 of file ossimKakaduJp2Writer.cpp.
Definition at line 410 of file ossimKakaduJp2Writer.cpp.
name | Name of property to return. |
Definition at line 438 of file ossimKakaduJp2Writer.cpp.
References ossimKakaduCompressor::getProperty(), ossimImageFileWriter::getProperty(), and m_compressor.
propertyNames | array to add this's property names to. |
Definition at line 451 of file ossimKakaduJp2Writer.cpp.
References ossimKakaduCompressor::getPropertyNames(), ossimImageFileWriter::getPropertyNames(), and m_compressor.
Definition at line 90 of file ossimKakaduJp2Writer.cpp.
Referenced by getImageTypeList(), and hasImageType().
Definition at line 415 of file ossimKakaduJp2Writer.cpp.
Definition at line 346 of file ossimKakaduJp2Writer.cpp.
References m_outputStream.
Definition at line 338 of file ossimKakaduJp2Writer.cpp.
References ossimKakaduCompressor::loadState(), ossimImageFileWriter::loadState(), and m_compressor.
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 351 of file ossimKakaduJp2Writer.cpp.
References ossimString::c_str(), close(), m_outputStream, m_ownsStreamFlag, ossimString::size(), and ossimImageFileWriter::theFilename.
Definition at line 330 of file ossimKakaduJp2Writer.cpp.
References m_compressor, ossimKakaduCompressor::saveState(), and ossimImageFileWriter::saveState().
The stream will not be closed/deleted by this object.
output | The stream to write to. |
Definition at line 459 of file ossimKakaduJp2Writer.cpp.
property | Object containing property to set. |
Definition at line 426 of file ossimKakaduJp2Writer.cpp.
References m_compressor, ossimKakaduCompressor::setProperty(), ossimImageFileWriter::setProperty(), and ossimRefPtr< T >::valid().
protectedvirtual |
Definition at line 105 of file ossimKakaduJp2Writer.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimErrorCodes::OSSIM_OK, ossimImageSourceSequencer::setTileSize(), ossimImageFileWriter::theInputConnection, and ossimRefPtr< T >::valid().
private |
compressor | Writes to this. |
Definition at line 283 of file ossimKakaduJp2Writer.cpp.
References ossimFilename::fileNoExtension(), ossimRefPtr< T >::get(), ossimImageSourceSequencer::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageFileWriter::getPixelType(), ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and ossimKakaduCompressor::writeGeotiffBox().
private |
Definition at line 310 of file ossimKakaduJp2Writer.cpp.
References ossimRefPtr< T >::get(), ossimImageSourceSequencer::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageFileWriter::theInputConnection, ossimRefPtr< T >::valid(), and ossimKakaduCompressor::writeGmlBox().
Definition at line 145 of file ossimKakaduJp2Writer.cpp.
private |
Definition at line 151 of file ossimKakaduJp2Writer.h.
Referenced by getProperty(), getPropertyNames(), loadState(), saveState(), setProperty(), and ~ossimKakaduJp2Writer().
private |
Definition at line 152 of file ossimKakaduJp2Writer.h.
Referenced by close(), isOpen(), open(), and setOutputStream().
private |
Definition at line 153 of file ossimKakaduJp2Writer.h.
Referenced by close(), open(), and setOutputStream().
