Public Member Functions | Protected Member Functions | Private Attributes | Friends | List of all members
ossimMultiThreadSequencer::ossimGetTileJob Class Reference
Private class representing a getTile job. More...
#include <ossimMultiThreadSequencer.h>
Inheritance diagram for ossimMultiThreadSequencer::ossimGetTileJob:
ossimJob
 ossimGetTileJob (ossim_uint32 tile_id, ossim_uint32 chain_id, ossimMultiThreadSequencer &sequencer)
- Public Member Functions inherited from ossimJob
 ossimJob ()
virtual void start ()
 Main entry point to the job. More...
std::shared_ptr< ossimJobgetSharedFromThis ()
 This is a convenience method to get the shared representation of this pointer. More...
std::shared_ptr< const ossimJobgetSharedFromThis () const
void setPercentComplete (double value)
 When the pernet complete is set for the job it will call any callbacks and nofity percentCompleteChanged. More...
void setPriority (double value)
 sets the priority of the job More...
double priority () const
virtual void release ()
 If derived interfaces implement a block this will allow one to release. More...
State state () const
virtual void resetState (int value)
 Will clear out the state and the call setState. More...
virtual void setState (int value, bool on=true)
 Will allow you to set the state of the job. More...
bool isCanceled () const
virtual void cancel ()
 Sets the state if the object as cancelled. More...
virtual void ready ()
 Sets the state if the object as ready. More...
virtual void running ()
 Sets the state if the object as running. More...
virtual void finished ()
 Sets the state if the object as finished. More...
bool isReady () const
bool isStopped () const
bool isFinished () const
bool isRunning () const
void setCallback (std::shared_ptr< ossimJobCallback > callback)
void setName (const ossimString &value)
 Sets the name of a job. More...
const ossimStringname () const
void setId (const ossimString &value)
const ossimStringid () const
void setDescription (const ossimString &value)
const ossimStringdescription () const
std::shared_ptr< ossimJobCallbackcallback ()
virtual void run ()
 Abstract method and must be overriden by the base class. More...
Private Attributes
ossim_uint32 m_tileID
ossim_uint32 m_chainID
ossimMultiThreadSequencerm_sequencer
bool t_launchNewJob
Friends
class ossimMultiThreadSequencer
Additional Inherited Members
- Public Types inherited from ossimJob
enum  State {
  ossimJob_NONE = 0, ossimJob_READY = 1, ossimJob_RUNNING = 2, ossimJob_CANCEL = 4,
  ossimJob_FINISHED = 8, ossimJob_ALL = (ossimJob_READY|ossimJob_RUNNING|ossimJob_CANCEL|ossimJob_FINISHED)
This is a Bit vector. More...
typedef std::list< std::shared_ptr< ossimJob > > List
- Protected Attributes inherited from ossimJob
std::mutex m_jobMutex
ossimString m_name
ossimString m_description
ossimString m_id
State m_state
double m_priority
std::shared_ptr< ossimJobCallbackm_callback
Detailed Description
Definition at line 78 of file ossimMultiThreadSequencer.h.
◆ ossimGetTileJob()
ossimMultiThreadSequencer::ossimGetTileJob::ossimGetTileJob ( ossim_uint32  tile_id,
ossimMultiThreadSequencer sequencer
inline
Member Function Documentation
◆ run()
void ossimMultiThreadSequencer::ossimGetTileJob::run ( )
protectedvirtual
The base ossimJob will call run from the start method after setting some variables.
Implements ossimJob.
Definition at line 27 of file ossimMultiThreadSequencer.cpp.
References ossimMultiThreadSequencer::d_debugEnabled, ossimImageData::dup(), ossimJob::finished(), ossimImageChainMtAdaptor::getClone(), ossimImageSource::getTile(), ossimImageSourceSequencer::getTileRect(), ossimTimer::instance(), m_chainID, ossimMultiThreadSequencer::m_getTileBlock, ossimMultiThreadSequencer::m_inputChain, m_sequencer, m_tileID, ossimMultiThreadSequencer::nextJob(), ossimMultiThreadSequencer::print(), ossim::Block::release(), ossimJob::running(), ossimImageData::setImageRectangle(), ossimMultiThreadSequencer::setTileInCache(), t_launchNewJob, ossimImageSourceSequencer::theBlankTile, ossimTimer::time_s(), and ossimRefPtr< T >::valid().
28 {
29  running();
31  {
32  ostringstream s1;
33  s1<<"THREAD #"<<m_chainID<<" -- Starting tile/job #"<<m_tileID;
34  m_sequencer.print(s1);
35  }
36
37  // Figure out the rect for this tile. Only process if rect is valid:
38  ossimIrect tileRect;
39  if (m_sequencer.getTileRect(m_tileID, tileRect))
40  {
41  // Perform the getTile and save the result:
44  double dt = ossimTimer::instance()->time_s(); //###
45
46  if (source != NULL)
47  tile = source->getTile(tileRect);
48  if (!tile.valid())
49  {
51  tile->setImageRectangle(tileRect);
52  }
53  dt = ossimTimer::instance()->time_s() - dt; //###
54
55  // Give the sequencer the tile. Execution may pause here while waiting for space to free up
56  // if the cache is full.
58  }
59
60  // Unblock the main thread which might be blocked waiting for jobs to finish:
62
63  // Queue the next job using this job's freed-up image chain:
64  if (t_launchNewJob)
66
67  finished();
68
70  {
71  ostringstream s2;
72  s2<<"THREAD #"<<m_chainID<<" -- Finished tile/job #"<<m_tileID;
73  m_sequencer.print(s2);
74  }
75 }
void nextJob(ossim_uint32 chain_id)
Method to job queue with scope lock to avoid multiple threads modifying the queue simultaneously...
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
bool valid() const
Definition: ossimRefPtr.h:75
void setTileInCache(ossim_uint32 tile_id, ossimImageData *tile, ossim_uint32 chain_id, double dt)
Access method to tile cache with scope lock to avoid multiple threads writing to the cache simultaneo...
bool getTileRect(ossim_int64 tile_id, ossimIrect &rect) const
Establishes a tile rect given tile ID.
void print(ostringstream &msg) const
For debug – thread-safe console output.
ossimRefPtr< ossimImageChainMtAdaptor > m_inputChain
Same as base class&#39; theInputConnection.
virtual ossimObject * dup() const
void release()
Releases the threads and will not return until all threads are released.
Definition: Block.cpp:66
static ossimTimer * instance()
Definition: ossimTimer.cpp:19
double time_s() const
Get elapsed time in seconds.
Definition: ossimTimer.h:33
virtual void finished()
Definition: ossimJob.h:316
ossimImageSource * getClone(ossim_uint32 index)
Returns pointer to a specific clone image chain, or NULL if index exceeds the max available...
ossimRefPtr< ossimImageData > theBlankTile
virtual void running()
Definition: ossimJob.h:308
◆ ossimMultiThreadSequencer
friend class ossimMultiThreadSequencer
friend
Definition at line 95 of file ossimMultiThreadSequencer.h.
Member Data Documentation
◆ m_chainID
ossim_uint32 ossimMultiThreadSequencer::ossimGetTileJob::m_chainID
private
Definition at line 91 of file ossimMultiThreadSequencer.h.
Referenced by run().
◆ m_sequencer
ossimMultiThreadSequencer& ossimMultiThreadSequencer::ossimGetTileJob::m_sequencer
private
Definition at line 92 of file ossimMultiThreadSequencer.h.
◆ m_tileID
ossim_uint32 ossimMultiThreadSequencer::ossimGetTileJob::m_tileID
private
Definition at line 90 of file ossimMultiThreadSequencer.h.
◆ t_launchNewJob
bool ossimMultiThreadSequencer::ossimGetTileJob::t_launchNewJob
private
Definition at line 94 of file ossimMultiThreadSequencer.h.
