This class manages the sequencing of tile requests across multiple threads. More...
#include <ossimMultiThreadSequencer.h>
Classes | |
class | ossimGetTileCallback |
Private class for getTile job callbacks. More... | |
class | ossimGetTileJob |
Private class representing a getTile job. More... | |
ossimMultiThreadSequencer (ossimImageSource *inputSource=NULL, ossim_uint32 num_threads=0, ossimObject *owner=NULL) | |
virtual | ~ossimMultiThreadSequencer () |
virtual void | setToStartOfSequence () |
Overrides base class implementation. More... | |
virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 resLevel=0) |
Overrides base class in order to implement multi-threaded tile requests. More... | |
void | setNumberOfThreads (ossim_uint32 num_threads) |
Specifies number of thread to support. More... | |
ossim_uint32 | getNumberOfThreads () const |
Fetches the number of threads being used. Useful when this object decides the quantity. More... | |
ossim_uint32 | maxCacheSize () const |
Accessed for performance logging. More... | |
bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
void | setUseSharedHandlers (bool use_shared_handlers) |
void | setCacheTileSize (ossim_uint32 cache_tile_size) |
void | setUseCache (bool use_cache) |
double | handlerGetTileT () |
ossimImageSourceSequencer (ossimImageSource *inputSource=NULL, ossimObject *owner=NULL) | |
virtual | ~ossimImageSourceSequencer () |
ossim_int64 | getNumberOfTiles () const |
ossim_int64 | getNumberOfTilesHorizontal () const |
ossim_int64 | getNumberOfTilesVertical () const |
virtual void | initialize () |
virtual void | setAreaOfInterest (const ossimIrect &areaOfInterest) |
const ossimIrect & | getAreaOfInterest () const |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
virtual bool | getNextTileStream (std::ostream &bos) |
virtual bool | getTileOrigin (ossim_int64 id, ossimIpt &origin) const |
bool | getTileRect (ossim_int64 tile_id, ossimIrect &rect) const |
Establishes a tile rect given tile ID. More... | |
virtual ossimRefPtr< ossimImageData > | getTile (ossim_int64 id, ossim_uint32 resLevel=0) |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfInputBands () const |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual void | slaveProcessTiles () |
virtual bool | isMaster () const |
virtual ossimIpt | getTileSize () const |
virtual void | setTileSize (const ossimIpt &tileSize) |
virtual void | setTileSize (ossim_int32 width, ossim_int32 height) |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
void | setCreateHistogram (bool create_histogram) |
void | getBinInformation (ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossimScalarType stype) const |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | propertyEvent (ossimPropertyEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
virtual void | refreshEvent (ossimRefreshEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
Public Attributes | |
ossim_uint32 | d_maxCacheUsed |
ossim_uint32 | d_cacheEmptyCount |
double | d_idleTime1 |
double | d_idleTime2 |
double | d_idleTime3 |
double | d_idleTime4 |
double | d_idleTime5 |
double | d_idleTime6 |
double | d_jobGetTileT |
bool | d_useSharedHandlers |
ossim_uint32 | d_cacheTileSize |
bool | d_useCache |
Protected Types | |
typedef std::map< ossim_uint32, ossimRefPtr< ossimImageData > > | TileCache |
void | initJobs () |
Queues up the optimum amount of jobs given the availability of thread chains and space in the output tile cache. More... | |
void | setTileInCache (ossim_uint32 tile_id, ossimImageData *tile, ossim_uint32 chain_id, double dt) |
Access method to tile cache with scope lock to avoid multiple threads writing to the cache simultaneously. More... | |
void | nextJob (ossim_uint32 chain_id) |
Method to job queue with scope lock to avoid multiple threads modifying the queue simultaneously. More... | |
void | print (ostringstream &msg) const |
For debug – thread-safe console output. More... | |
virtual void | updateTileDimensions () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Friends | |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
Note that multi- threading can only be achieved through the use of getNextTile() method for sequencing. Conventional getTiles will not be multi-threaded.
Definition at line 26 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 75 of file ossimMultiThreadSequencer.h.
ossimMultiThreadSequencer::ossimMultiThreadSequencer | ( | ossimImageSource * | inputSource = NULL , |
ossim_uint32 | num_threads = 0 , |
ossimObject * | owner = NULL |
Definition at line 80 of file ossimMultiThreadSequencer.cpp.
< Same as base class' theInputConnection
Definition at line 135 of file ossimMultiThreadSequencer.cpp.
References m_callback, m_inputChain, and m_jobMtQueue.
The output tile should be available in the tile cache, otherwise, method waits until it becomes available.
Reimplemented from ossimImageSourceSequencer.
Definition at line 231 of file ossimMultiThreadSequencer.cpp.
References ossim::Block::block(), d_cacheEmptyCount, d_debugEnabled, d_idleTime1, d_idleTime2, d_idleTime3, d_t1, d_timedBlocksDt, d_timeMetricsEnabled, ossimTimer::instance(), m_cacheMutex, m_getTileBlock, m_inputChain, m_nextJobBlock, m_nextTileID, m_tileCache, m_totalNumberOfTiles, print(), ossim::Block::release(), ossim::Block::reset(), setToStartOfSequence(), ossimImageSourceSequencer::theCurrentTileNumber, ossimTimer::time_s(), and ossimRefPtr< T >::valid().
inline |
Definition at line 48 of file ossimMultiThreadSequencer.h.
Referenced by ossimIgen::outputProduct().
double ossimMultiThreadSequencer::handlerGetTileT | ( | ) |
Definition at line 465 of file ossimMultiThreadSequencer.cpp.
References ossimImageHandlerMtAdaptor::d_getTileT, m_inputChain, ossimImageChainMtAdaptor::m_sharedHandlers, and ossimRefPtr< T >::valid().
protected |
Definition at line 475 of file ossimMultiThreadSequencer.cpp.
References ossimKeywordlist::find(), ossimImageSourceSequencer::loadState(), setCacheTileSize(), setNumberOfThreads(), setUseCache(), setUseSharedHandlers(), status, ossimString::toBool(), and ossimString::toUInt32().
inline |
Definition at line 51 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 401 of file ossimMultiThreadSequencer.cpp.
References ossim::Block::block(), d_debugEnabled, d_idleTime5, d_idleTime6, d_t1, d_timedBlocksDt, d_timeMetricsEnabled, ossimTimer::instance(), m_cacheMutex, m_callback, m_jobMtQueue, m_jobMutex, m_maxCacheSize, m_nextJobBlock, m_nextTileID, m_tileCache, m_totalNumberOfTiles, print(), ossim::Block::reset(), and ossimTimer::time_s().
Referenced by ossimMultiThreadSequencer::ossimGetTileJob::run().
protected |
Definition at line 460 of file ossimMultiThreadSequencer.cpp.
References d_printMutex.
Referenced by getNextTile(), nextJob(), ossimMultiThreadSequencer::ossimGetTileJob::run(), setTileInCache(), and setToStartOfSequence().
void ossimMultiThreadSequencer::setCacheTileSize | ( | ossim_uint32 | cache_tile_size | ) |
Definition at line 353 of file ossimMultiThreadSequencer.cpp.
References d_cacheTileSize, m_inputChain, ossimImageChainMtAdaptor::setCacheTileSize(), and ossimRefPtr< T >::valid().
Referenced by loadState().
void ossimMultiThreadSequencer::setNumberOfThreads | ( | ossim_uint32 | num_threads | ) |
Default behavior (if this method is never called) is to query the system for number of cores available.
Definition at line 331 of file ossimMultiThreadSequencer.cpp.
References m_inputChain, m_jobMtQueue, m_maxCacheSize, m_maxTileCacheFactor, m_nextTileID, m_numThreads, ossimImageChainMtAdaptor::setNumberOfThreads(), and ossimRefPtr< T >::valid().
protected |
NOTE: chain_id being passed only for debug. To be removed.
Definition at line 373 of file ossimMultiThreadSequencer.cpp.
References d_debugEnabled, d_idleTime4, d_jobGetTileT, d_maxCacheUsed, d_t1, d_timeMetricsEnabled, ossimTimer::instance(), m_cacheMutex, m_tileCache, print(), and ossimTimer::time_s().
This call initiates the multi-threaded getTile jobs for the first N tiles.
The base class should have successfully assigned its input:
Definition at line 145 of file ossimMultiThreadSequencer.cpp.
References ossimImageChain::add(), d_cacheTileSize, d_debugEnabled, d_useCache, d_useSharedHandlers, ossimConnectableObject::disconnectAllOutputs(), ossim::getNumberOfThreads(), m_callback, m_inputChain, m_jobMtQueue, m_maxCacheSize, m_maxTileCacheFactor, m_nextTileID, m_numThreads, m_totalNumberOfTiles, print(), ossimImageChainMtAdaptor::setCacheTileSize(), ossimImageChainMtAdaptor::setNumberOfThreads(), ossimImageChainMtAdaptor::setUseCache(), ossimImageChainMtAdaptor::setUseSharedHandlers(), ossimImageSourceSequencer::theCurrentTileNumber, ossimImageSourceSequencer::theInputConnection, ossimImageSourceSequencer::theNumberOfTilesHorizontal, ossimImageSourceSequencer::theNumberOfTilesVertical, and ossimRefPtr< T >::valid().
Referenced by getNextTile().
void ossimMultiThreadSequencer::setUseCache | ( | bool | use_cache | ) |
Definition at line 361 of file ossimMultiThreadSequencer.cpp.
References d_useCache, m_inputChain, ossimImageChainMtAdaptor::setUseCache(), and ossimRefPtr< T >::valid().
void ossimMultiThreadSequencer::setUseSharedHandlers | ( | bool | use_shared_handlers | ) |
Definition at line 345 of file ossimMultiThreadSequencer.cpp.
References d_useSharedHandlers, m_inputChain, ossimImageChainMtAdaptor::setUseSharedHandlers(), and ossimRefPtr< T >::valid().
friend |
Definition at line 97 of file ossimMultiThreadSequencer.h.
ossim_uint32 ossimMultiThreadSequencer::d_cacheEmptyCount |
Definition at line 59 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), and ossimIgen::outputProduct().
ossim_uint32 ossimMultiThreadSequencer::d_cacheTileSize |
Definition at line 69 of file ossimMultiThreadSequencer.h.
Referenced by setCacheTileSize(), and setToStartOfSequence().
protected |
Definition at line 144 of file ossimMultiThreadSequencer.h.
double ossimMultiThreadSequencer::d_idleTime1 |
Definition at line 60 of file ossimMultiThreadSequencer.h.
double ossimMultiThreadSequencer::d_idleTime2 |
Definition at line 61 of file ossimMultiThreadSequencer.h.
double ossimMultiThreadSequencer::d_idleTime3 |
Definition at line 62 of file ossimMultiThreadSequencer.h.
double ossimMultiThreadSequencer::d_idleTime4 |
Definition at line 63 of file ossimMultiThreadSequencer.h.
Referenced by setTileInCache().
double ossimMultiThreadSequencer::d_idleTime5 |
Definition at line 64 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), and ossimIgen::outputProduct().
double ossimMultiThreadSequencer::d_idleTime6 |
Definition at line 65 of file ossimMultiThreadSequencer.h.
Referenced by nextJob().
double ossimMultiThreadSequencer::d_jobGetTileT |
Definition at line 66 of file ossimMultiThreadSequencer.h.
Referenced by ossimIgen::outputProduct(), and setTileInCache().
ossim_uint32 ossimMultiThreadSequencer::d_maxCacheUsed |
Definition at line 58 of file ossimMultiThreadSequencer.h.
mutableprotected |
Definition at line 142 of file ossimMultiThreadSequencer.h.
Referenced by print().
protected |
Definition at line 147 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), nextJob(), and setTileInCache().
protected |
Definition at line 145 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), and nextJob().
protected |
Definition at line 146 of file ossimMultiThreadSequencer.h.
mutableprotected |
Definition at line 143 of file ossimMultiThreadSequencer.h.
bool ossimMultiThreadSequencer::d_useCache |
Definition at line 70 of file ossimMultiThreadSequencer.h.
Referenced by setToStartOfSequence(), and setUseCache().
bool ossimMultiThreadSequencer::d_useSharedHandlers |
Definition at line 68 of file ossimMultiThreadSequencer.h.
Referenced by setToStartOfSequence(), and setUseSharedHandlers().
mutableprotected |
Definition at line 135 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 130 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), setToStartOfSequence(), and ~ossimMultiThreadSequencer().
protected |
Definition at line 138 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), and ossimMultiThreadSequencer::ossimGetTileJob::run().
protected |
Same as base class' theInputConnection.
Definition at line 127 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), handlerGetTileT(), ossimMultiThreadSequencer::ossimGetTileJob::run(), setCacheTileSize(), setNumberOfThreads(), setToStartOfSequence(), setUseCache(), setUseSharedHandlers(), and ~ossimMultiThreadSequencer().
protected |
Definition at line 128 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), setNumberOfThreads(), setToStartOfSequence(), and ~ossimMultiThreadSequencer().
mutableprotected |
Definition at line 136 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 133 of file ossimMultiThreadSequencer.h.
Referenced by nextJob(), setNumberOfThreads(), and setToStartOfSequence().
protected |
Definition at line 134 of file ossimMultiThreadSequencer.h.
Referenced by setNumberOfThreads(), and setToStartOfSequence().
protected |
Definition at line 139 of file ossimMultiThreadSequencer.h.
protected |
ID of next tile to be threaded, different from base class' theCurrentTileNumber.
Definition at line 131 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), nextJob(), setNumberOfThreads(), and setToStartOfSequence().
protected |
Definition at line 129 of file ossimMultiThreadSequencer.h.
protected |
Saves tiles output by threaded jobs.
Definition at line 132 of file ossimMultiThreadSequencer.h.
protected |
Definition at line 137 of file ossimMultiThreadSequencer.h.
Referenced by getNextTile(), nextJob(), and setToStartOfSequence().
