Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimPngWriterFactory Class Reference
Factory for PNG image writer. More...
#include <ossimPngWriterFactory.h>
Inheritance diagram for ossimPngWriterFactory:
ossimImageWriterFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimPngWriterFactory ()
 virtual destructor More...
virtual ossimImageFileWritercreateWriterFromExtension (const ossimString &fileExtension) const
 Creates a writer from extension like "png". More...
virtual ossimImageFileWritercreateWriter (const ossimKeywordlist &kwl, const char *prefix=0) const
 Create that takes a keyword list and prefix. More...
virtual ossimImageFileWritercreateWriter (const ossimString &typeName) const
 createWriter that takes a class name (ossimPngWriter) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimPngWriter) More...
virtual void getExtensions (std::vector< ossimString > &extList) const
 Adds "png" to list. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds "ossimPngWriter" to list. More...
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 Adds "ossim_png" to writer list. More...
virtual void getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const
virtual void getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimImageWriterFactoryBase
virtual ~ossimImageWriterFactoryBase ()
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimPngWriterFactoryinstance ()
 static method to return instance (the only one) of this class. More...
 hidden from use default constructor More...
 ossimPngWriterFactory (const ossimPngWriterFactory &)
 hidden from use copy constructor More...
void operator= (const ossimPngWriterFactory &)
virtual ~ossimReferenced ()
static ossimPngWriterFactorytheInstance = 0
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageWriterFactoryBase
typedef std::vector< ossimRefPtr< ossimImageFileWriter > > ImageFileWriterList
Detailed Description
Definition at line 20 of file ossimPngWriterFactory.h.
◆ ~ossimPngWriterFactory()
ossimPngWriterFactory::~ossimPngWriterFactory ( )
virtual
virtual destructor
Definition at line 23 of file ossimPngWriterFactory.cpp.
References theInstance.
24 {
25  theInstance = 0;
26 }
static ossimPngWriterFactory * theInstance
◆ ossimPngWriterFactory() [1/2]
ossimPngWriterFactory::ossimPngWriterFactory ( )
protected
Definition at line 138 of file ossimPngWriterFactory.cpp.
Referenced by instance().
138 {}
◆ ossimPngWriterFactory() [2/2]
ossimPngWriterFactory::ossimPngWriterFactory ( const ossimPngWriterFactory )
protected
Definition at line 140 of file ossimPngWriterFactory.cpp.
140 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimPngWriterFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 88 of file ossimPngWriterFactory.cpp.
References createWriter().
90 {
91  return createWriter(kwl, prefix);
92 }
virtual ossimImageFileWriter * createWriter(const ossimKeywordlist &kwl, const char *prefix=0) const
◆ createObject() [2/2]
ossimObject * ossimPngWriterFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimPngReader".
Returns
Definition at line 94 of file ossimPngWriterFactory.cpp.
96 {
97  return createWriter(typeName);
98 }
◆ createWriter() [1/2]
ossimImageFileWriter * ossimPngWriterFactory::createWriter ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
pointer to image handler on success, NULL on failure.
Implements ossimImageWriterFactoryBase.
Definition at line 49 of file ossimPngWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
51 {
53  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
54  if (type)
55  {
56  writer = createWriter(ossimString(type));
57  if ( writer.valid() )
58  {
59  if (writer->loadState(kwl, prefix) == false)
60  {
61  writer = 0;
62  }
63  }
64  }
65  return writer.release();
66 }
bool valid() const
Definition: ossimRefPtr.h:75
static const char * TYPE_KW
T * release()
Definition: ossimRefPtr.h:93
◆ createWriter() [2/2]
ossimImageFileWriter * ossimPngWriterFactory::createWriter ( const ossimString typeName) const
virtual
Parameters
Returns
Definition at line 68 of file ossimPngWriterFactory.cpp.
References ossimImageFileWriter::hasImageType(), and ossimRefPtr< T >::release().
70 {
72  if (typeName == "ossimPngWriter")
73  {
74  writer = new ossimPngWriter;
75  }
76  else
77  {
78  // See if the type name is supported by the writer.
79  writer = new ossimPngWriter;
80  if ( writer->hasImageType(typeName) == false )
81  {
82  writer = 0;
83  }
84  }
85  return writer.release();
86 }
T * release()
virtual bool hasImageType(const ossimString &imageType) const
bool hasImageType(const ossimString& imageType) const
◆ createWriterFromExtension()
ossimImageFileWriter * ossimPngWriterFactory::createWriterFromExtension ( const ossimString fileExtension) const
virtual
Parameters
fileExtension"png"
Definition at line 37 of file ossimPngWriterFactory.cpp.
References ossimRefPtr< T >::release().
39 {
40  ossimRefPtr<ossimPngWriter> writer = 0;
41  if ( (fileExtension == "png") || (fileExtension == ".png") )
42  {
43  writer = new ossimPngWriter;
44  }
45  return writer.release();
46 }
T * release()
◆ getExtensions()
void ossimPngWriterFactory::getExtensions ( std::vector< ossimString > &  extList) const
virtual
Adds "png" to list.
Parameters
extListList to add to.
Definition at line 100 of file ossimPngWriterFactory.cpp.
102 {
103  result.push_back("png");
104 }
◆ getImageFileWritersByMimeType()
void ossimPngWriterFactory::getImageFileWritersByMimeType ( ossimImageWriterFactoryBase::ImageFileWriterList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 128 of file ossimPngWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
130 {
131  ossimString testMime = mimeType.downcase();
132  if(testMime == "image/png")
133  {
134  result.push_back(new ossimPngWriter);
135  }
136 }
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ getImageFileWritersBySuffix()
void ossimPngWriterFactory::getImageFileWritersBySuffix ( ossimImageWriterFactoryBase::ImageFileWriterList result,
const ossimString ext
) const
virtual
Definition at line 118 of file ossimPngWriterFactory.cpp.
120 {
121  ossimString testExt = ext.downcase();
122  if(testExt == "png")
123  {
124  result.push_back(new ossimPngWriter);
125  }
126 }
◆ getImageTypeList()
void ossimPngWriterFactory::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Parameters
imageTypeListList to append to.
Definition at line 111 of file ossimPngWriterFactory.cpp.
References ossimPngWriter::getImageTypeList().
112 {
114  writer->getImageTypeList(imageTypeList);
115  writer = 0;
116 }
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const
void getImageTypeList(std::vector<ossimString>& imageTypeList)const
◆ getTypeNameList()
void ossimPngWriterFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 106 of file ossimPngWriterFactory.cpp.
107 {
108  typeList.push_back(ossimString("ossimPngWriter"));
109 }
◆ instance()
ossimPngWriterFactory * ossimPngWriterFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 28 of file ossimPngWriterFactory.cpp.
References ossimPngWriterFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize().
29 {
30  if(!theInstance)
31  {
33  }
34  return theInstance;
35 }
◆ operator=()
void ossimPngWriterFactory::operator= ( const ossimPngWriterFactory )
protected
Definition at line 142 of file ossimPngWriterFactory.cpp.
142 {}
Member Data Documentation
◆ theInstance
ossimPngWriterFactory * ossimPngWriterFactory::theInstance = 0
staticprotected
Definition at line 107 of file ossimPngWriterFactory.h.
Referenced by instance(), and ~ossimPngWriterFactory().
