ossimPointCloudImageHandler.cpp
Go to the documentation of this file.
1 //**************************************************************************************************
2 //
3 // OSSIM (http://trac.osgeo.org/ossim/)
4 //
5 // License: LGPL -- See LICENSE.txt file in the top level directory for more details.
6 //
7 //**************************************************************************************************
8 // $Id$
9
14 #include <ossim/base/ossimCommon.h>
17 #include <ossim/base/ossimTrace.h>
18 #include <ossim/base/ossimIpt.h>
19 #include <ossim/base/ossimDpt.h>
20 #include <ossim/base/ossimGpt.h>
24 #include <ossim/base/ossimDatum.h>
29
30 RTTI_DEF1(ossimPointCloudImageHandler, "ossimPointCloudImageHandler", ossimImageHandler);
31
32 static ossimTrace traceDebug("ossimPointCloudImageHandler:debug");
33 static const char* GSD_FACTOR_KW = "gsd_factor";
34 static const char* COMPONENT_KW = "component";
35
36 // The member m_activeComponent should be one of the following strings. This is set either in a
37 // state KWL or by a call to setProperty(<"active_component", <string> >)
38 static const char* INTENSITY_KW = "INTENSITY";
39 static const char* HIGHEST_KW = "HIGHEST";
40 static const char* LOWEST_KW = "LOWEST";
41 static const char* RETURNS_KW = "RETURNS";
42 static const char* RGB_KW = "RGB";
43
45  ossim_uint32 numBands)
46 : m_numSamples (1)
47 {
48  m_bucket = new ossim_float32[numBands];
49  for (ossim_uint32 i=0; i<numBands; i++)
50  m_bucket[i] = init_value[i];
51 }
52
53
55  const ossim_float32& G,
56  const ossim_float32& B)
57 : m_numSamples (1)
58 {
59  m_bucket = new ossim_float32[3];
60  m_bucket[0] = R;
61  m_bucket[1] = G;
62  m_bucket[2] = B;
63
64 }
65
66
68 : m_numSamples (1)
69 {
70  m_bucket = new ossim_float32[1];
71  m_bucket[0] = init_value;
72 }
73
74
76 {
77  delete [] m_bucket;
78 }
79
80
83  m_maxPixel(1.0),
84  m_minPixel(0.0),
85  m_gsd(),
86  m_gsdFactor (1.0),
87  m_tile(0),
88  m_mutex(),
90 {
91  //---
92  // Nan out as can be set in several places, i.e. setProperty,
93  // loadState and initProjection.
94  //---
95  m_gsd.makeNan();
96
97  m_componentNames.emplace_back(INTENSITY_KW);
98  m_componentNames.emplace_back(HIGHEST_KW);
99  m_componentNames.emplace_back(LOWEST_KW);
100  m_componentNames.emplace_back(RETURNS_KW);
101  m_componentNames.emplace_back(RGB_KW);
102 }
103
105 {
106  close();
107 }
108
110 {
111  close();
112
113  // Need to utilize the Point Cloud handler registry to open the PC file:
115  if (!m_pch.valid())
116  return false;
117
120
121  // Needed here after open to make sure that min/max pixels are set for active component/entry
123
124  return true;
125 }
126
128 {
129  close();
130
131  // Need to utilize the Point Cloud handler registry to open the PC file:
132  m_pch = pch;
133  if (!m_pch.valid())
134  return false;
135
138
139  // Needed here after open to make sure that min/max pixels are set for active component/entry
141
142  return true;
143 }
144
146 {
147  if (isOpen())
148  {
149  m_pch->close();
150  m_tile = 0;
152  }
153 }
154
156 {
157  if (!isOpen())
158  return 0;
159
160  if (theGeometry.valid())
161  return theGeometry;
162
163  // Check for external geom (i.e., a *.geom file)
165  if (theGeometry.valid())
166  return theGeometry;
167
169  ossimString epsgCode ("EPSG:4326");
170  ossimMapProjection* proj = dynamic_cast<ossimMapProjection*>( // NOLINT
172  if (!proj)
173  return 0;
174  theGeometry->setProjection(proj);
175
176  // Need to establish image bounds and optimal GSD given ground rect. Use this switch to also
177  // initialize the UL tiepoint of image projection:
178  ossimGrect bounds;
179  m_pch->getBounds(bounds);
180  proj->setOrigin(bounds.ul());
181  proj->setUlTiePoints(bounds.ul());
182
183  // The GSD depends on the point density on the ground. count all final returns and
184  // assume they are evenly distributed over the bounding ground rect. Note that this can have
185  // up to a sqrt(2)X error if the collection was taken in a cardinal-diagonal direction.
186  // Also use this point loop to latch the ground quad vertices vertices.
187  ossim_uint32 numPulses = m_pch->getNumPoints(); // count of final returns
188  if (numPulses == 0)
189  {
190  // Not yet determined. Set GSD to NAN and expect it will be set later:
191  m_gsd.makeNan();
192  }
193  else if (m_gsd.hasNans())
194  {
195  ossimDpt delta (bounds.widthMeters(), bounds.heightMeters());
196  ossim_float64 gsd = sqrt(delta.x * delta.y / numPulses) * m_gsdFactor;
197  setGSD(gsd); // also recomputes the image size
198  }
199
200  return theGeometry;
201 }
202
204  ossim_uint32 resLevel)
205 {
206  if (!m_tile.valid())
207  initTile();
208
209  // Image rectangle must be set prior to calling getTile.
210  m_tile->setImageRectangle(tile_rect);
211  if (!getTile(m_tile.get(), resLevel))
212  {
214  m_tile->makeBlank();
215  }
216
217  return m_tile;
218 }
219
221 {
222  // check for all systems go and valid args:
223  if (!m_pch.valid() || !result || (result->getScalarType() != OSSIM_FLOAT32)
224  || (result->getDataObjectStatus() == OSSIM_NULL) || m_gsd.hasNans())
225  {
226  return false;
227  }
228
229  // Overviews achieved with GSD setting. This may be too slow.
230  ossimDpt gsd (m_gsd);
231  if (resLevel > 0)
232  getGSD(gsd, resLevel);
233
234  // Establish the ground and image rects for this tile:
235  const ossimIrect img_tile_rect = result->getImageRectangle();
236  const ossimIpt tile_offset (img_tile_rect.ul());
237  const ossim_uint32 tile_width = img_tile_rect.width();
238  const ossim_uint32 tile_height = img_tile_rect.height();
239  const ossim_uint32 tile_size = img_tile_rect.area();
240
241  ossimGpt gnd_ul, gnd_lr;
242  ossimDpt dpt_ul (img_tile_rect.ul().x - 0.5, img_tile_rect.ul().y - 0.5);
243  ossimDpt dpt_lr (img_tile_rect.lr().x + 0.5, img_tile_rect.lr().y + 0.5);
244  theGeometry->rnToWorld(dpt_ul, resLevel, gnd_ul);
245  theGeometry->rnToWorld(dpt_lr, resLevel, gnd_lr);
246  const ossimGrect gnd_rect (gnd_ul, gnd_lr);
247
248  // Create array of buckets to store accumulated point data.
249  ossim_uint32 numBands = result->getNumberOfBands();
250  if (numBands > getNumberOfInputBands())
251  {
252  // This should never happen;
254  << "ossimPointCloudImageHandler::getTile() ERROR: \n"
255  << "More bands were requested than was available from the point cloud source. Returning "
256  << "blank tile." << endl;
257  result->makeBlank();
258  return false;
259  }
260  std::map<ossim_int32, PcrBucket*> accumulator;
261
262  // initialize a point block with desired fields as requested in the reader properties
263  ossimPointBlock pointBlock (this);
264  pointBlock.setFieldCode(componentToFieldCode());
265  m_pch->rewind();
266
267  ossimDpt ipt;
268  ossimGpt pos;
269
270 #define USE_GETBLOCK
271 #ifdef USE_GETBLOCK
272  m_pch->getBlock(gnd_rect, pointBlock);
273  for (ossim_uint32 id=0; id<pointBlock.size(); ++id)
274  {
275  pos = pointBlock[id]->getPosition();
276  theGeometry->worldToRn(pos, resLevel, ipt);
277  ipt.x = ossim::round<double,double>(ipt.x) - tile_offset.x;
278  ipt.y = ossim::round<double,double>(ipt.y) - tile_offset.y;
279
280  ossim_int32 bucketIndex = ipt.y*tile_width + ipt.x;
281  if ((bucketIndex >= 0) && (bucketIndex < (ossim_int32)tile_size))
282  addSample(accumulator, bucketIndex, pointBlock[id]);
283  }
284
285 #else // using getFileBlock
286  ossim_uint32 numPoints = m_pch->getNumPoints();
289
290  // Loop to read all point blocks:
291  do
292  {
293  pointBlock.clear();
294  m_pch->getNextFileBlock(pointBlock, numPoints);
295  //m_pch->normalizeBlock(pointBlock);
296
297  for (ossim_uint32 id=0; id<pointBlock.size(); ++id)
298  {
299  // Check that each point in read block is inside the ROI before accumulating it:
300  pos = pointBlock[id]->getPosition();
301  if (gnd_rect.pointWithin(pos))
302  {
303  theGeometry->worldToRn(pos, resLevel, ipt);
304  ipt.x = ossim::round<double,double>(ipt.x) - tile_offset.x;
305  ipt.y = ossim::round<double,double>(ipt.y) - tile_offset.y;
306
307  ossim_int32 bucketIndex = ipt.y*tile_width + ipt.x;
308  if ((bucketIndex >= 0) && (bucketIndex < (ossim_int32)tile_size))
309  addSample(accumulator, bucketIndex, pointBlock[id]);
310  }
311  }
312  } while (pointBlock.size() == numPoints);
313 #endif
314
315  // Finished accumulating, need to normalize and fill the tile.
316  // We must always blank out the tile as we may not have a point for every pixel.
317  normalize(accumulator);
318  auto buf = new ossim_float32*[numBands];
319  std::map<ossim_int32, PcrBucket*>::iterator accum_iter;
321  result->setNullPix(null_pixel);
322  for (ossim_uint32 band = 0; band < numBands; band++)
323  {
324  ossim_uint32 index = 0;
325  buf[band] = result->getFloatBuf(band);
326  for (ossim_uint32 y = 0; y < tile_height; y++)
327  {
328  for (ossim_uint32 x = 0; x < tile_width; x++)
329  {
330  accum_iter = accumulator.find(index);
331  if (accum_iter != accumulator.end())
332  buf[band][index] = accum_iter->second->m_bucket[band];
333  else
334  buf[band][index] = null_pixel;
335  ++index;
336  }
337  }
338  }
339
340  delete [] buf;
341  buf = 0;
342
343  auto pcr_iter = accumulator.begin();
344  while (pcr_iter != accumulator.end())
345  {
346  delete pcr_iter->second;
347  pcr_iter++;
348  }
349
350  result->validate();
351  return true;
352 }
353
354 void ossimPointCloudImageHandler::addSample(std::map<ossim_int32, PcrBucket*>& accumulator,
355  ossim_int32 index,
356  const ossimPointRecord* sample)
357 {
358  if (sample == 0)
359  return;
360
361  //cout << "sample: "<<*sample<<endl;//TODO: REMOVE DEBUG
362
363  // Search map for exisiting point in that location:
364  auto iter = accumulator.find(index);
365  if (iter == accumulator.end())
366  {
367  // First hit. Initialize location with current sample:
369  {
370  accumulator[index] = new PcrBucket(sample->getField(ossimPointRecord::Intensity));
371  }
372  else if (m_activeComponent == RGB)
373  {
374  ossim_float32 color[3];
375  color[0] = sample->getField(ossimPointRecord::Red);
376  color[1] = sample->getField(ossimPointRecord::Green);
377  color[2] = sample->getField(ossimPointRecord::Blue);
378  accumulator[index] = new PcrBucket(color, 3);
379  }
380  else if ((m_activeComponent == LOWEST) || (m_activeComponent == HIGHEST))
381  accumulator[index] = new PcrBucket(sample->getPosition().hgt);
382  else if (m_activeComponent == RETURNS)
383  accumulator[index] = new PcrBucket(sample->getField(ossimPointRecord::NumberOfReturns));
384  }
385  else
386  {
387  // Not the first hit at this location, accumulate:
388  // First hit. Initialize location with current sample:
390  {
391  iter->second->m_bucket[0] += sample->getField(ossimPointRecord::Intensity);
392  }
393  else if (m_activeComponent == RGB)
394  {
395  iter->second->m_bucket[0] += sample->getField(ossimPointRecord::Red);
396  iter->second->m_bucket[1] += sample->getField(ossimPointRecord::Green);
397  iter->second->m_bucket[2] += sample->getField(ossimPointRecord::Blue);
398  }
399  else if ((m_activeComponent == HIGHEST) &&
400  (sample->getPosition().hgt > iter->second->m_bucket[0]))
401  iter->second->m_bucket[0] = sample->getPosition().hgt;
402  else if ((m_activeComponent == LOWEST) &&
403  (sample->getPosition().hgt < iter->second->m_bucket[0]))
404  iter->second->m_bucket[0] = sample->getPosition().hgt;
405  else if (m_activeComponent == RETURNS)
406  iter->second->m_bucket[0] += sample->getField(ossimPointRecord::NumberOfReturns);
407
408  iter->second->m_numSamples++;
409  }
410 }
411
412 void ossimPointCloudImageHandler::normalize(std::map<ossim_int32, PcrBucket*>& accumulator)
413 {
414  // highest and lowest elevations latch extremes, no mean is computed but needs to be normalized
417  return;
418
419  int numBands = 1;
420  if (m_activeComponent == RGB)
421  numBands = 3;
422
423  auto iter = accumulator.begin();
424  ossim_float32 avg;
425  while (iter != accumulator.end())
426  {
427  for (int i=0; i<numBands; i++)
428  {
429  avg = iter->second->m_bucket[i] / iter->second->m_numSamples;
430  iter->second->m_bucket[i] = avg;
431  }
432  iter++;
433  }
434 }
435
437 {
438  ossim_uint32 numBands = 0;
439  if (m_pch.valid())
440  {
442  numBands = 1;
443  else if (m_activeComponent == RGB)
444  numBands = 3;
445  else if ((m_activeComponent == LOWEST) || (m_activeComponent == HIGHEST))
446  numBands = 1;
447  else if (m_activeComponent == RETURNS)
448  numBands = 1;
449  }
450  return numBands;
451 }
452
454 {
455  ossim_uint32 result = 0;
456  if (isOpen() && theGeometry.valid())
457  {
458  ossimIpt image_size(theGeometry->getImageSize());
459  result = image_size.line;
460  if (resLevel)
461  result = (result >> resLevel);
462  }
463  return result;
464 }
465
467 {
468  ossim_uint32 result = 0;
469  if (isOpen() && theGeometry.valid())
470  {
471  ossimIpt image_size(theGeometry->getImageSize());
472  result = image_size.samp;
473  if (resLevel)
474  result = (result >> resLevel);
475  }
476  return result;
477 }
478
480 {
481  return getTileWidth();
482 }
483
485 {
486  return getTileHeight();
487 }
488
490 {
491  ossimIpt ipt;
493  return ipt.x;
494 }
495
497 {
498  ossimIpt ipt;
500  return ipt.y;
501 }
502
504 {
505  return OSSIM_FLOAT32;
506 }
507
508 void ossimPointCloudImageHandler::getEntryList(std::vector<ossim_uint32>& entryList) const
509 {
510  entryList.clear();
511  for (ossim_uint32 i = 0; i < m_componentNames.size(); i++)
512  {
513  entryList.emplace_back(i);
514  }
515 }
516
517 void ossimPointCloudImageHandler::getEntryNames(std::vector<ossimString>& entryNames) const
518 {
519  entryNames = m_componentNames;
520 }
521
523 {
525 }
526
528 {
529  if (entryIdx >= NUM_COMPONENTS)
530  return false;
531
532  m_activeComponent = (Components) entryIdx;
533  if (m_pch.valid() && m_pch->getMinPoint() && m_pch->getMaxPoint())
534  {
536  {
539  }
540  else if (m_activeComponent == RGB)
541  {
544  }
545  else if ((m_activeComponent == LOWEST) || (m_activeComponent == HIGHEST))
546  {
549  }
550  else if (m_activeComponent == RETURNS)
551  {
552  m_minPixel = 0;
554  }
555  }
556
557  return true;
558 }
559
561 {
562  return ossimString("Point Cloud Image Handler");
563 }
564
566 {
567  return ossimString("ossim point cloud to image renderer");
568 }
569
571 {
572  return m_minPixel;
573 }
574
576 {
577  return m_maxPixel;
578 }
579
581 {
583 }
584
586 {
587  // Can support any number of rlevels.
588  ossim_uint32 result = 1;
589  const ossim_uint32 STOP_DIMENSION = 16;
590  ossim_uint32 largestImageDimension =
592  while (largestImageDimension > STOP_DIMENSION)
593  {
594  largestImageDimension /= 2;
595  ++result;
596  }
597  return result;
598 }
599
601 {
602  const ossim_uint32 BANDS = getNumberOfOutputBands();
603
605
606  for (ossim_uint32 band = 0; band < BANDS; ++band)
607  {
608  m_tile->setMinPix(getMinPixelValue(band), band);
609  m_tile->setMaxPix(getMaxPixelValue(band), band);
610  m_tile->setNullPix(getNullPixelValue(band), band);
611  }
612
613  m_tile->initialize();
614 }
615
617 {
618  // std::pow(2.0, 0) returns 1.
619  ossim_float64 d = std::pow(2.0, static_cast<double>(resLevel));
620  gsd.x = m_gsd.x * d;
621  gsd.y = m_gsd.y * d;
622 }
623
625 {
626  if (ossim::isnan(gsd) || (gsd<=0.0) || !theGeometry.valid())
627  return;
628
629  m_gsd = ossimDpt(gsd, gsd);
630  m_gsdFactor = 1.0; // resets after GSD adjusted
631
633  if (!proj)
634  return;
635
636  proj->setMetersPerPixel(m_gsd);
637
638  ossimGrect bounds;
639  m_pch->getBounds(bounds);
640
641  ossimDpt ipt_ul, ipt_lr;
642  theGeometry->worldToLocal(bounds.ul(), ipt_ul);
643  theGeometry->worldToLocal(bounds.lr(), ipt_lr);
644  ossimIpt image_size;
645  image_size.x = ossim::round<ossim_int32,double>(ipt_lr.x - ipt_ul.x) + 1;
646  image_size.y = ossim::round<ossim_int32,double>(ipt_lr.y - ipt_ul.y) + 1;
647
648  theGeometry->setImageSize(image_size);
649 }
650
651 bool ossimPointCloudImageHandler::saveState(ossimKeywordlist& kwl, const char* prefix) const
652 {
653  static const char MODULE[] = "ossimPointCloudImageHandler::saveState()";
654
655  ossimImageHandler::saveState(kwl, prefix);
657  {
659  << " ERROR detected in keyword list! State not saved." << std::endl;
660  return false;
661  }
662
663  kwl.add(prefix, ossimKeywordNames::ENTRY_KW, (int) m_activeComponent, true);
665
666  return true;
667 }
668
669 bool ossimPointCloudImageHandler::loadState(const ossimKeywordlist& kwl, const char* prefix)
670 {
671  static const char MODULE[] = "ossimPointCloudImageHandler::loadState()";
672  theDecimationFactors.clear();
673  if(traceDebug())
674  ossimNotify(ossimNotifyLevel_DEBUG)<< MODULE << " DEBUG: entered ..."<< std::endl;
675
676  ossimImageHandler::loadState(kwl, prefix);
678  {
680  << "WARNING: error detected in keyword list! State not load." << std::endl;
681  return false;
682  }
683
685  ossimString value = kwl.find(prefix, ossimKeywordNames::ENTRY_KW);
686  if (!value.empty())
687  {
688  ossim_uint32 i = value.toUInt32();
689  if (i < NUM_COMPONENTS)
691  }
692
693  value = kwl.find(prefix, ossimKeywordNames::METERS_PER_PIXEL_KW);
694  if (!value.empty())
695  setGSD(value.toDouble());
696
697  // The rest of the state is established by opening the file:
698  bool good_open = open();
699
700  return good_open;
701 }
702
703 void ossimPointCloudImageHandler::getValidImageVertices(std::vector<ossimIpt>& validVertices,
704  ossimVertexOrdering ordering,
705  ossim_uint32 resLevel) const
706 {
707  validVertices.clear();
708  if (!m_pch.valid())
709  return;
710  int divisor = 1;
711  if (resLevel)
712  divisor = resLevel<<1;
713
714  // Transform the world coords for the four vertices into image vertices:
715  ossimDpt r0Pt;
716  ossimGrect bounds;
717  m_pch->getBounds(bounds);
718  theGeometry->worldToLocal(bounds.ul(), r0Pt);
719  validVertices.emplace_back(r0Pt);
720  theGeometry->worldToLocal(bounds.ur(), r0Pt);
721  validVertices.emplace_back(r0Pt);
722  theGeometry->worldToLocal(bounds.lr(), r0Pt);
723  validVertices.emplace_back(r0Pt);
724  theGeometry->worldToLocal(bounds.ll(), r0Pt);
725  validVertices.emplace_back(r0Pt);
726
727  if (ordering == OSSIM_COUNTERCLOCKWISE_ORDER)
728  {
729  for (int i=3; i>=0; i--)
730  validVertices.emplace_back(validVertices[i]/divisor);
731  validVertices.erase(validVertices.begin(), validVertices.begin()+4);
732  }
733 }
734
736 {
737  if (!property.valid())
738  return;
739
740  ossimString s;
741  property->valueToString(s);
742  if (s.empty())
743  return;
744
745  // The user should select either explicit GSD or relative GSD factor, never both:
746  if ( property->getName() == ossimKeywordNames::METERS_PER_PIXEL_KW )
747  {
748  ossim_float64 gsd = s.toFloat64();
749  if (!ossim::isnan(gsd))
750  setGSD(gsd);
751  }
752  else if ( property->getName() == GSD_FACTOR_KW )
753  {
754  m_gsdFactor = s.toDouble();
756  {
757  if (!m_gsd.hasNans())
759  }
760  else
761  m_gsdFactor = 1.0;
762  }
763  else if ( property->getName() == ossimKeywordNames::ENTRY_KW )
764  {
766  }
767  else if ( property->getName() == COMPONENT_KW )
768  {
769  for (int i=0; i<NUM_COMPONENTS; i++)
770  {
771  if (s.upcase() == m_componentNames[i])
772  {
774  break;
775  }
776  }
777  }
778  else
779  {
781  }
782 }
783
785 {
788  {
790  prop = new ossimStringProperty(name, value);
791  }
792  else if ( name == GSD_FACTOR_KW )
793  {
795  }
796  else if ( name == ossimKeywordNames::ENTRY_KW )
797  {
799  }
800  else if ( name == COMPONENT_KW )
801  {
803  }
804  else
805  {
806  prop = ossimImageHandler::getProperty(name);
807  }
808  return prop;
809 }
810
812 {
813  ossim_uint32 field_code = 0;
814  switch (m_activeComponent)
815  {
816  case INTENSITY:
817  field_code = ossimPointRecord::Intensity;
818  break;
819  case RETURNS:
821  break;
822  case RGB:
824  break;
825  default:
826  break;
827  }
828  return field_code;
829 }
830
831
ossim_uint32 x
void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering, ossim_uint32 resLevel) const override
ordering specifies how the vertices should be arranged.
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossim_uint32 getNumPoints() const =0
Returns the total number of points in the dataset (not just the block returned in getPoints) ...
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
ossimFilename theImageFile
ossimRefPtr< ossimProperty > getProperty(const ossimString &name) const override
const ossimIpt & getImageSize() const
ossimRefPtr< ossimPointCloudHandler > m_pch
void getEntryNames(std::vector< ossimString > &entryNames) const override
ossimRefPtr< ossimImageData > m_tile
ossim_uint32 y
bool valid() const
Definition: ossimRefPtr.h:75
std::vector< ossimDpt > theDecimationFactors
ossimScalarType getOutputScalarType() const override
float ossim_float32
ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const override
Gets samples.
ossim_float32 getField(FIELD_CODES fc) const
Return the float value of the requested field.
double y
Definition: ossimDpt.h:165
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
ossim_uint32 height() const
Definition: ossimIrect.h:487
bool loadState(const ossimKeywordlist &kwl, const char *prefix) override
Class used for rendering point cloud data into a raster tile.
Numeric to string methods.
bool setPointCloudHandler(ossimPointCloudHandler *pch)
Permits backdoor for setting the input point cloud handler object.
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const override
Gets lines.
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual void getBounds(ossimGrect &bounds) const
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
static const ossimErrorCode OSSIM_ERROR
ossim_uint32 toUInt32() const
double getNullPixelValue(ossim_uint32 band) const override
32 bit floating point
ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0) override
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
void setImageSize(const ossimIpt &size)
void getGSD(ossimDpt &gsd, ossim_uint32 resLevel) const
Get the GSD for resLevel.
std::vector< ossimString > m_componentNames
virtual bool isOpen() const
is open method.
virtual void initialize()
Initialize the data buffer.
virtual void setMetersPerPixel(const ossimDpt &gsd)
virtual void clear()
Resets any storage to empty.
virtual ossimPointCloudHandler * open(const ossimFilename &fileName) const
ossim_float64 widthMeters() const
Returns the width of a rectangle in meters using the center lat for scaling EW direction.
Definition: ossimGrect.cpp:292
ossim_uint32 getTileHeight() const override
ossimRefPtr< ossimImageGeometry > getImageGeometry() override
Returns the image geometry object associated with this tile source or NULL if non defined...
double ossim_float64
bool pointWithin(const ossimGpt &gpt, bool considerHgt=false) const
METHOD: pointWithin(ossimGpt)
Definition: ossimGrect.h:232
virtual void setNullPix(ossim_float64 null_pix)
ossim_uint32 getNumberOfInputBands() const override
Gets bands.
static ossim_uint32 DEFAULT_BLOCK_SIZE
void addSample(std::map< ossim_int32, PcrBucket *> &accumulator, ossim_int32 index, const ossimPointRecord *sample)
ossim_uint32 getNumberOfDecimationLevels() const override
ossimVertexOrdering
void setGSD(const ossim_float64 &gsd)
Sets m_gsd data member and projection if projection is set.
ossim_uint32 getImageTileWidth() const override
Gets tile width.
unsigned int ossim_uint32
double toDouble() const
ossim_float64 toFloat64() const
const ossimGpt & ul() const
Definition: ossimGrect.h:252
ossimString getShortName() const override
virtual ossimIrect getImageRectangle() const
double getMaxPixelValue(ossim_uint32 band) const override
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual void close()
void rnToWorld(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimGpt &wpt) const
rnToWorld is a utility method that takes a rn resolution image point and maps it to the world point...
void worldToRn(const ossimGpt &wpt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
worldToRn is a utility method that takes a world point allows one to transform all the way back to an...
bool setCurrentEntry(ossim_uint32 entryIdx) override
ossimGpt ur() const
Definition: ossimGrect.h:257
ossim_uint32 width() const
Definition: ossimIrect.h:500
bool hasNans() const
Definition: ossimDpt.h:67
virtual ossim_uint32 size() const
Returns allocated size.
double getMinPixelValue(ossim_uint32 band) const override
ossimScalarType
virtual const ossimPointRecord * getMaxPoint() const
virtual const ossim_float32 * getFloatBuf() const
void setProperty(ossimRefPtr< ossimProperty > property) override
The reader properties are: – the GSD ("meters_per_pixel") which overrides computed nominal GSD – th...
static ossimPointCloudHandlerRegistry * instance()
static const char * ENTRY_KW
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
ossimString getLongName() const override
virtual void getBlock(const ossimGrect &bounds, ossimPointBlock &block) const
Fetches the block of points inside the block bounds.
virtual void rewind() const
ossim_int32 samp
Definition: ossimIpt.h:141
virtual void setMaxPix(ossim_float64 max_pix)
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossimErrorCode getErrorStatus() const
ossim_int32 y
Definition: ossimIpt.h:142
void getEntryList(std::vector< ossim_uint32 > &entryList) const override
Gets entry list.
bool saveState(ossimKeywordlist &kwl, const char *prefix) const override
ossim_uint32 getTileWidth() const override
static const char * METERS_PER_PIXEL_KW
ossim_uint32 area() const
Definition: ossimIrect.h:396
double x
Definition: ossimDpt.h:164
virtual const ossimPointRecord * getMinPoint() const
Assigns the two points with fields representing the extremes of the dataset.
bool empty() const
Definition: ossimString.h:411
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
STUB. Not implemented.
#define OSSIM_DEFAULT_NULL_PIX_FLOAT
ossim_int32 line
ossim_float64 heightMeters() const
Returns the height of a rectangle in meters.
Definition: ossimGrect.cpp:286
virtual void setUlTiePoints(const ossimGpt &gpt)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
const ossimGpt & getPosition() const
Returns the 3D position vector in the dataset&#39;s coodinate reference system (available from the ossimP...
ossim_int32 x
Base class for all point-cloud file readers.
void setFieldCode(ossim_uint32 code)
Initializes the desired fields to be stored.
void normalize(std::map< ossim_int32, PcrBucket *> &accumulator)
Close method.
virtual void close()=0
Closes the point cloud file(s).
virtual void setMinPix(ossim_float64 min_pix)
const ossimGpt & lr() const
Definition: ossimGrect.h:269
ossim_uint32 getImageTileHeight() const override
Gets tile height.
ossimGpt ll() const
Definition: ossimGrect.h:263
static ossimEpsgProjectionFactory * instance()
Implements singleton pattern.
virtual void getNextFileBlock(ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
void makeNan()
Definition: ossimDpt.h:65
const ossimString & getName() const
ossim_uint32 getCurrentEntry() const override
int ossim_int32
bool isnan(const float &v)
Definition: ossimCommon.h:91
