45 static const std::string AOI_GEO_RECT_KW =
"aoi_geo_rect";
46 static const std::string AOI_MAP_RECT_KW =
"aoi_map_rect";
47 static const std::string AOI_GEO_CENTER_KW =
"aoi_geo_center";
48 static const std::string AOI_SIZE_METERS_KW =
"aoi_size_meters";
49 static const std::string AOI_SIZE_PIXELS_KW =
"aoi_size_pixels";
50 static const std::string CLIP_POLY_LAT_LON_KW =
"clip_poly_lat_lon";
51 static const std::string LUT_FILE_KW =
"lut_file";
52 static const std::string GSD_KW =
"gsd";
53 static const std::string OUTPUT_RADIOMETRY_KW =
"output_radiometry";
54 static const std::string READER_PROPERTY_KW =
"reader_property";
55 static const std::string SNAP_TIE_TO_ORIGIN_KW =
"snap_tie_to_origin";
56 static const std::string SRS_KW =
"srs";
57 static const std::string TILE_SIZE_KW =
"tile_size";
58 static const std::string TRUE_KW =
"true";
59 static const std::string WRITER_KW =
"writer";
60 static const std::string WRITER_PROPERTY_KW =
"writer_property";
63 : m_projIsIdentity(false),
70 : m_projIsIdentity(false),
104 std::string tempString1;
106 std::string tempString2;
108 std::string tempString3;
110 std::string tempString4;
116 vector<ossimString> paramList;
122 if ( ap.
read(
"--load-options", stringParam1))
131 if ( ap.
read(
"--aoi-geo-bbox", stringParam1, stringParam2, stringParam3, stringParam4))
134 ostr<<tempString1<<
" "<<tempString2<<
" "<<tempString3<<
" "<<tempString4<<ends;
138 if ( ap.
read(
"--aoi-geo-center", stringParam1, stringParam2))
141 ostr<<tempString1<<
" "<<tempString2<<ends;
145 if ( ap.
read(
"--aoi-map-bbox", stringParam1, stringParam2, stringParam3, stringParam4))
148 ostr<<tempString1<<
" "<<tempString2<<
" "<<tempString3<<
152 if ( ap.
read(
"--aoi-size-meters", stringParam1, stringParam2))
155 ostr<<tempString1<<
159 if ( ap.
read(
"--aoi-size-pixels", stringParam1, stringParam2))
162 ostr<<tempString1<<
166 if (ap.
read(
"-b", stringParam1) || ap.
read(
"--bands", stringParam1))
169 if( ap.
read(
"--central-meridian", stringParam1) )
172 if( ap.
read(
"--color-table", stringParam1) || ap.
read(
"--lut", stringParam1) )
175 if ( ap.
read(
"-e", stringParam1) || ap.
read(
"--entry", stringParam1) )
178 if (ap.
read(
"--dem", paramList))
189 if( ap.
read(
"--gsd", stringParam1) )
192 if ( ap.
read(
"--hemisphere", stringParam1) )
195 vector<ossimString> imageFnames;
196 if (ap.
read(
"--image", imageFnames) || ap.
read(
"-i", imageFnames))
198 if (imageFnames.size() == 1)
200 else for(
ossim_uint32 idx=0; idx<imageFnames.size(); ++idx)
208 if( ap.
read(
"--origin-latitude", stringParam1) )
211 if(ap.
read(
"--output-file", stringParam1) || ap.
read(
"-o", stringParam1))
214 if(ap.
read(
"--output-radiometry", stringParam1))
217 if( ap.
read(
"--projection", stringParam1) )
220 while (ap.
read(
"--reader-prop", stringParam1))
223 key << READER_PROPERTY_KW << readerPropIdx;
228 if ( ap.
read(
"--snap-tie-to-origin") )
231 if( ap.
read(
"--srs", stringParam1) )
239 if( ap.
read(
"--tile-size", stringParam1) )
242 if( ap.
read(
"-w", stringParam1) || ap.
read(
"--writer", stringParam1) )
245 while (ap.
read(
"--writer-prop", stringParam1))
248 key << WRITER_PROPERTY_KW << writerPropIdx;
253 if( ap.
read(
"--zone", stringParam1) )
263 bool dumpKwl =
false;
264 if ( ap.
read(
"--dump-options") )
267 if ( ap.
argc() >= 2 )
285 while ( pos < (ap.
argc()-1) )
289 m_kwl.
add( key.str().c_str(), ap[pos] );
312 xmsg<<
"ossimChipProcUtil:"<<__LINE__<<
" Error encountered writing options file to <"<<f<<
335 getScalarTypeFromString(
m_kwl.
findKey( OUTPUT_RADIOMETRY_KW ) );
360 if (!lutFile.
empty())
364 errMsg<<
"ERROR ossimChipProcUtil ["<<__LINE__<<
"] Color table <"<<lutFile
365 <<
"> does not exists: "<<ends;
403 xmsg <<
"Null pointer encountered for m_procChain!";
409 xmsg <<
"Image size is NaN!";
424 throw ossimException(
"Unable to initialize writer for execution" );
435 xmsg <<
"Writer Process aborted!";
482 if (!geo_bounding_grect.
hasNans())
485 "provided. Using full AOI."<<endl;
574 entryIndex = globalEntryValue;
581 errMsg<<
"ERROR: ossimChipProcUtil ["<<__LINE__<<
"] Could not open <"<<f<<
">"<<ends;
586 std::vector<ossim_uint32> bandList(0);
588 if ( bandList.size() )
601 if (!chain->
open(fname))
604 errMsg<<
"] Could not open <"<<fname<<
">"<<ends;
614 errMsg <<
" ERROR: ossimChipProcUtil ["<<__LINE__<<
"] Entry " << entry_index <<
" out of range!" << std::endl;
624 chain->
add(remapper.
get());
635 std::vector<ossimGpt> points;
637 if(points.size() >= 3)
669 cout<<key.str()<<endl;
678 errMsg <<
"ossimChipProcUtil ["<<__LINE__<<
"] Could not open DEM file: <" << f <<
690 static const char* MODULE =
"ossimChipProcUtil::createOutputProjection()";
697 << MODULE <<
" WARNING:" 699 <<
" keywords are set!" 701 <<
"\noutput_projection: " << op
702 <<
"\nTaking " << srs <<
" over " << op <<
"\n";
712 if ( (op ==
"geo") || (srs.
contains(
"4326")))
720 throw ossimException(
"ossimChipProcUtil::createOutputProjection() -- Bad EPSG code passed.");
722 else if (op ==
"geo-scaled")
727 else if ( ( op ==
"input" ) || (op ==
"identity") || (op ==
"none") )
730 else if ( (op ==
"utm") || (op ==
"ossimutmprojection") )
778 output_proj = output_utm.
get();
818 bool setZone =
false;
823 if ( (zone > 0 ) && ( zone < 61 ) )
830 bool setHemisphere =
false;
835 if ( ( h ==
"N" ) || ( h ==
"NORTH" ) || ( h ==
"S" ) || ( h ==
"SOUTH" ) )
838 setHemisphere =
true;
842 if ( !setZone || !setHemisphere )
849 if ( !setHemisphere )
875 std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx =
m_imgLayers.begin();
883 gsd.
y = gsd.
x = gsd.
mean();
895 std::vector<ossimFilename>::iterator demFile =
m_demSources.begin();
899 if (geom.
open(*demFile))
903 gsd.
y = gsd.
x = gsd.
mean();
967 if ( (imageSize.
x > 0)&& (imageSize.
y > 0 ) )
976 double dlat = sizeMeters.
y/metersPerDegree.y/2.0;
977 double dlon = sizeMeters.
x/metersPerDegree.x/2.0;
987 double dlat = sizeMeters.
988 double dlon = sizeMeters.
1000 vector<ossimString> substrings = lookup.
split(
1001 if (substrings.size() != 4)
1004 errMsg <<
"] Incorrect number of values specified for " 1015 if ( minLatF > maxLatF )
1026 ossimGpt lrgpt (minLatF , maxLonF);
1030 if ( (imageSize.
x > 0) && (imageSize.
y > 0) )
1034 if (mapProj.
valid())
1037 gsd.
x = std::fabs( maxLonF - minLonF ) / imageSize.
x;
1038 gsd.
y = std::fabs( maxLatF - minLatF ) / imageSize.
y;
1048 if (mapProj.
valid())
1052 vector<ossimString> substrings = lookup.
split(
true);
1053 if (substrings.size() != 4)
1056 errMsg <<
"] Incorrect number of values specified for " 1087 if ( (imageSize.
y > 0) )
1091 if (mapProj.
valid())
1094 gsd.
x = std::fabs( maxX - minX ) / imageSize.
x;
1095 gsd.
y = std::fabs( maxY - minY ) / imageSize.
y;
1125 bool snapToTP =
false;
1138 bool found_spec =
false;
1140 if ( lookup.
size() )
1143 if ( (gpt.
lat < -90) || (gpt.
lat > 90.0) )
1145 std::string errMsg =
"origin latitude range error! Valid range: -90 to 90";
1153 if ( lookup.
size() )
1156 if ( (gpt.
lon < -180.0) || (gpt.
lon > 180.0) )
1158 std::string errMsg =
"central meridian range error! Valid range: -180 to 180";
1173 vector<ossimString> substrings = lookup.
split(
1174 if (substrings.size() != 2)
1177 errMsg <<
"] Incorrect number of values specified for " 1181 gpt.
lat = substrings[0].toDouble();
1182 gpt.
lon = substrings[1].toDouble();
1190 vector<ossimString> substrings = lookup.
split(
1191 if (substrings.size() != 4)
1194 errMsg <<
"] Incorrect number of values specified for " 1202 gpt.
lat = 0.5*(minLatF + maxLatF);
1203 gpt.
lon = 0.5*(minLonF + maxLonF);
1216 std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chain =
1219 geom = (*chain)->getImageGeometry();
1237 std::vector<ossimFilename>::iterator dem_file =
1241 if (!geom->
open(*dem_file))
1244 <<
"ossimHLZUtil::initialize ERR: Cannot open DEM file <" << *dem_file <<
"> " 1245 "as image handler. Ignoring entry for bounding box computation.\n" << std::endl;
1261 else if (!bbox_dems.
hasNans())
1277 halfDpp = halfDpp/2.0;
1308 std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx =
1311 viewVisitor.reset();
1312 eventVisitor.reset();
1313 (*chainIdx)->accept(viewVisitor);
1314 (*chainIdx)->accept(eventVisitor);
1316 if (resampler.
valid())
1337 std::vector<ossimString> splitArray;
1338 value.
split(splitArray,
1339 if(splitArray.size() == 2)
1352 std::vector<ossim_uint32>& bandList )
const 1366 std::vector<ossimString> band_list(0);
1368 if ( band_list.size() )
1370 std::vector<ossimString>::const_iterator i = band_list.begin();
1371 while ( i != band_list.end() )
1376 bandList.push_back( band - 1 );
1400 vector<ossimFilename>::iterator fname_iter =
1406 xmsg<<
" Cannot open DEM file at <"<<*fname_iter<<
1415 elevChains.push_back(connectable);
1419 if (elevChains.size() == 1)
1433 if ( layerCount == 1 )
1435 combiner = layers[0].
get();
1437 else if (layerCount > 1)
1440 std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx = layers.begin();
1441 while ( chainIdx != layers.end() )
1455 if ( lookup.
size() )
1458 if ( !writer.
valid() )
1461 errMsg <<
"] ERROR creating writer for <"<<lookup<<
">" 1471 if ( !writer.
valid() )
1474 errMsg <<
"] ERROR creating writer from extension <" 1490 if ( lookup.
size() )
1492 std::vector<ossimString> splitArray;
1493 lookup.
split(splitArray,
1494 if(splitArray.size() == 2)
1506 if ( lookup.
size() )
1510 if ( (tileSize.
x % 16) == 0 )
1512 tileSize.
y = tileSize.
x;
1533 au->
addCommandLineOption(
"--aoi-geo-bbox",
"<min-lat> <min-lon> <max-lat> <max-lon>\nSpecify a comma-separated list for the lower-left and upper-right corners of the scene rect in decimal degrees.");
1534 au->
"--aoi-geo-center",
"<lat> <lon>\nCenter of AOI in decimal degrees.");
1535 au->
"--aoi-map-bbox",
"<min-x> <min-y> <max-x> <max-y>\nSpecify a space-separated list for the upper-left and lower-right corners of the scene rect in decimal degrees.");
1537 au->
"<dx> <dy>,\nSize of AOI in output product pixels.");
1539 au->
"-b or --bands <n,n...>",
"Use the specified bands in given order: e.g. \"3,2,1\" will select bands 3, 2 and 1 of the input image.\nNote: it is 1 based" );
1540 au->
"<lon>\nNote if set this will be used for the central meridian of the projection. This can be used to lock the utm zone.");
1541 au->
"--color-table | --lut",
"<color-table.kwl>\nKeyword list containing color table for color-relief option.");
1542 au->
"--deg-per-pixel",
"<dpp_xy> | <dpp_x> <dpp_y>\nSpecifies an override for degrees per pixel. Takes either a single value applied equally to x and y directions, or two values applied correspondingly to x then y. This option takes precedence over the \"--meters\" option.");
1543 au->
"--dem",
"<file1>[,<file2>...]\n Input DEM file(s) (comma-separated) to process.");
1544 au->
"--dump-options",
"The current state of the utility (after the entire command line is parsed) is written to the file $PWD/<utility>.kwl, where <utility> is the name of the operation being performed. See \"--load-options\".");
1545 au->
"-e or --entry",
"<entry> For multi image handlers which entry do you wish to extract. For list of entries use: \"ossim-info -i <your_image>\" ");
1548 au->
"--hemisphere",
"<hemisphere>\nSpecify a projection hemisphere if supported. E.g. UTM projection. This will lock the hemisphere even if input scene center is the other hemisphere. Valid values for UTM are \"N\" and \"S\"");
1549 au->
"--image | -i",
"<file1>[, <file2>...] Input image file(s) (comma-separated) to process.");
1550 au->
"--load-options",
"[<filename>]\nThe contents of <filename> (keyword-value pairs) are loaded as command options. The command-line options take precedence. See \"--load-options\" and \"--write-template\" options.");
1551 au->
"--output-file | -o",
"<filename>\nThe product output file name. The format is dictated by the extension.");
1552 au->
"<latidude_in_decimal_degrees>\nNote if set this will be used for the origin latitude of the projection. Setting this to something other than 0.0 with a geographic projection creates a scaled geographic projection.");
1553 au->
"<R>\nSpecifies the desired product's pixel radiometry type. Possible values for <R> are: U8, U11, U16, S16, F32. Note this overrides the deprecated option \"scale-to-8-bit\".");
1554 au->
"--projection",
"<output_projection> Valid projections: geo, geo-scaled, input or utm\ngeo = Equidistant Cylindrical, origin latitude = 0.0\ngeo-scaled = Equidistant Cylindrical, origin latitude = image center\ninput Use first images projection. Must be a map projecion.\nutm = Universal Tranverse Mercator\nIf input and multiple sources the projection of the first image will be used.\nIf utm the zone will be set from the scene center of first image.\nNOTE: --srs takes precedence over this option.");
1555 au->
"--reader-prop",
"<string>Adds a property to send to the reader. format is name=value");
1556 au->
"--scale-to-8-bit",
"Scales the output to unsigned eight bits per band. This option has been deprecated by the newer \"--output-radiometry\" option.");
1557 au->
"--snap-tie-to-origin",
"Snaps tie point to projection origin so that (tie-origin)/gsd come out on an even integer boundary.");
1558 au->
"--srs",
"<src_code>\nSpecify a spatial reference system(srs) code for the output projection. Example: --srs EPSG:4326");
1559 au->
"-t or --thumbnail",
"<max_dimension>\nSpecify a thumbnail resolution.\nScale will be adjusted so the maximum dimension = argument given.");
1560 au->
"--tile-size",
"<size_in_pixels>\nSets the output tile size if supported by writer. Notes: This sets both dimensions. Must be a multiple of 16, e.g. 1024.");
1561 au->
"-w or --writer",
"<writer>\nSpecifies the output writer. Default uses output file extension to determine writer. For valid output writer types use: \"ossim-info --writers\"\n");
1562 au->
"--writer-prop",
"<writer-property>\nPasses a name=value pair to the writer for setting it's property. Any number of these can appear on the line.");
1563 au->
"--write-template",
"<filename>\nWrites a keywrd list template to the filename specified.");
1564 au->
"--zone",
"<zone>\nSpecify a projection zone if supported. E.g. UTM projection. This will lock the zone even if input scene center is in another zone. Valid values for UTM are \"1\" to \"60\"");
void getBoundingGroundRect(ossimGrect &bounding_grect) const
void setRectangle(const ossimIrect &rect)
virtual double getMeanSpacingMeters() const
Returns the mean post spacing (in meters) for the highest resolution DEM in the list or NaN if no DEM...
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
virtual ossimObject * dup() const =0
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
double mean() const
Returns the average of x and y.
static const char * PROJECTION_KW
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Within the image chain will pass the head of the list.
static ossimString upcase(const ossimString &aString)
ossim_uint32 numberOf(const char *str) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
static const char * OUTPUT_FILE_KW
const ossimIpt & getImageSize() const
static const char * CENTRAL_MERIDIAN_KW
bool addFile(const char *file)
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
ossimRefPtr< const ossimImageHandler > getImageHandler() const
static const ossimErrorCode OSSIM_OK
void addResampler()
Adds a resampler (a.k.a.
virtual bool addListener(ossimListener *listener)
Overrides base "addListener" this will capture the pointer and then call the base class "addListener"...
void addOptions(ossimArgumentParser &parser)
const ossimMapProjection * getAsMapProjection() const
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
const ossimDpt & ul() const
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
bool contains(char aChar) const
bool hasKey(const std::string &key) const
Checks for key in map.
virtual void initialize()
virtual void propagateEventToOutputs(ossimEvent &event)
static ossimImageWriterFactoryRegistry * instance()
void addList(const ossimKeywordlist &src, bool overwrite=true)
Visitor to update view and then propagate property event to outputs.
Numeric to string methods.
virtual void setTileSize(const ossimIpt &tileSize)
Sets the output image tiling size if supported by the writer.
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
ossim_float64 hgt
Height in meters above the ellipsiod.
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
ossim_uint32 toUInt32() const
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
ossimDpt getDegreesPerPixel() const
Returns the resolution of this image in degrees/pixel.
ossimApplicationUsage * getApplicationUsage()
void setImageSize(const ossimIpt &size)
An image mosaic is a simple combiner that will just do a simple mosaic.
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
virtual ossimGpt inverse(const ossimDpt &projectedPoint) const =0
void getCellsForBounds(const std::string &connectionString, const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0)
Gets a list of elevation cells needed to cover bounding box.
void setBandSelection(const std::vector< ossim_uint32 > &bandList)
method to set band selector.
Single image chain class.
virtual void setMetersPerPixel(const ossimDpt &gsd)
void expandToInclude(const ossimGpt &gpt)
Expands existing rect to accommodate argument point.
This call is passed to the head of the list.
ossim_int32 toInt32() const
void reportRemainingOptionsAsUnrecognized(ossimErrorSeverity severity=OSSIM_BENIGN)
for each remaining option report it as an unrecongnized.
bool open(const ossimFilename &image)
Shortcut way of getting to an image's geometry when access to pixels is not needed.
void setCutType(ossimRectangleCutType cutType)
static const char * ZONE_KW
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
bool errors(ossimErrorSeverity severity=OSSIM_BENIGN) const
virtual void setOutputScalarType(ossimScalarType scalarType)
Sets the output scalar type.
OSSIM_DLL void toVector(std::vector< ossimDpt > &result, const ossimString &stringOfPoints)
Will take a string list separated by spaces and convert to a vector of ossimDpts. ...
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
std::string::size_type size() const
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
ossimGrect clipToRect(const ossimGrect &rect) const
void setLut(const ossimFilename &file)
Set lookup table(lut) method.
unsigned int ossim_uint32
const char * chars() const
For backward compatibility.
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
ossim_float64 toFloat64() const
const ossimGpt & ul() const
bool loadElevationPath(const ossimFilename &path, bool set_as_first=false)
Adds a new elevation file (or multiple files if path is a directory) to the collection.
virtual bool add(ossimConnectableObject *source)
Will return true or false if an image source was added to the chain.
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
bool getBoolKeywordValue(bool &rtn_val, const char *keyword, const char *prefix=0) const
[OLK, Aug/2008] Sets the boolean <rtn_val> depending on value associated with keyword for values = (y...
static const char * BANDS_KW
ossimRefPtr< ossimCacheTileSource > addCache()
Adds a new cache to the current end of the chain.
ossimGpt midPoint() const
void setZone(const ossimGpt &ground)
static ossimProjectionFactoryRegistry * instance()
static const char * ORIGIN_LATITUDE_KW
static const char * ENTRY_KW
Will pass this call to the head of the list.
virtual void setFilename(const ossimFilename &file)
void snapTiePointToOrigin()
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossimErrorCode getErrorStatus() const
virtual void setAreaOfInterest(const ossimIrect &inputRect)
static const char * HEMISPHERE_KW
bool open(const ossimFilename &file, bool openOverview=true)
open method that takes an image file.
ossim_int32 getZone() const
static ossimInit * instance()
ossimImageFileWriter * createWriter(const ossimFilename &filename) const
virtual void setUlTiePoints(const ossimGpt &gpt)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossimDpt metersPerDegree() const
ossimRefPtr< const ossimImageRenderer > getImageRenderer() const
ossimString & gsub(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false)
Substitutes searchKey string with replacementValue and returns a reference to *this.
char getHemisphere() const
static const char * IMAGE_FILE_KW
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
virtual bool removeListener(ossimListener *listener)
Overrides base "removeListener".
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
void setElevationLookupFlag(bool flag)
static const char * ELEVATION_SOURCE_KW
const ossimDpt & lr() const
const ossimGpt & lr() const
int & argc()
return the argument count.
void setHemisphere(const ossimGpt &ground)
void setExpandEnvVarsFlag(bool flag)
virtual bool setView(ossimObject *baseObject)
virtual bool execute()
Calls: writeFile() writeMetaDataFiles()
void addGeoPolyCutterPolygon(const vector< ossimGpt > &polygon)
void writeErrorMessages(std::ostream &output, ossimErrorSeverity sevrity=OSSIM_BENIGN)
write out error messages at an above specified .
const std::string & string() const
