Public Member Functions | Static Public Attributes | Protected Attributes | List of all members
ossimSpaceImagingGeom Class Reference
#include <ossimSpaceImagingGeom.h>
 ossimSpaceImagingGeom (const ossimFilename &file, const char *prefix=0)
 ossimSpaceImagingGeom ()
void setGeometry (const ossimFilename &file)
void setGeometry (const ossimKeywordlist &kwl)
void exportToOssim (ossimKeywordlist &kwl, const char *prefix=0) const
ossimString spaceImagingToOssimKeyword (const ossimString &spaceImagingKeyword) const
ossimString spaceImagingToOssimValue (const ossimString &spaceImagingKeyword, const ossimString &spaceImagingValue) const
ossimString getBandName () const
ossimFilename getFilename () const
ossimString getProducer () const
static const char * SIG_PRODUCER_KW = "Producer"
static const char * SIG_PROJECT_NAME_KW = "Project Name"
static const char * SIG_FILENAME_KW = "Filename"
static const char * SIG_BAND_KW = "Band"
static const char * SIG_BITS_PER_PIXEL_KW = "Bits/Pixel"
static const char * SIG_NUMBER_OF_BANDS_KW = "Number of Bands"
static const char * SIG_DATUM_KW = "Datum"
static const char * SIG_PROJECTION_KW = "Projection"
static const char * SIG_SELECTED_PROJECTION_KW = "Selected Projection"
static const char * SIG_ZONE_KW = "Zone"
static const char * SIG_UL_EASTING_KW = "UL Map X (Easting)"
static const char * SIG_UL_NORTHING_KW = "UL Map Y (Northing)"
static const char * SIG_PIXEL_SIZE_X_KW = "Pixel Size X"
static const char * SIG_PIXEL_SIZE_Y_KW = "Pixel Size Y"
static const char * SIG_COLUMNS_KW = "Columns"
static const char * SIG_ROWS_KW = "Rows"
ossimKeywordlist theSpaceImagingGeometry
ossimString thePrefix
Detailed Description
Definition at line 19 of file ossimSpaceImagingGeom.h.
◆ ossimSpaceImagingGeom() [1/2]
ossimSpaceImagingGeom::ossimSpaceImagingGeom ( const ossimFilename file,
const char *  prefix = 0
Definition at line 38 of file ossimSpaceImagingGeom.cpp.
40 {
41  setGeometry(file);
42  thePrefix = prefix;
43 }
void setGeometry(const ossimFilename &file)
◆ ossimSpaceImagingGeom() [2/2]
ossimSpaceImagingGeom::ossimSpaceImagingGeom ( )
Definition at line 34 of file ossimSpaceImagingGeom.cpp.
35 {
36 }
Member Function Documentation
◆ exportToOssim()
void ossimSpaceImagingGeom::exportToOssim ( ossimKeywordlist kwl,
) const
Definition at line 59 of file ossimSpaceImagingGeom.cpp.
References ossimKeywordlist::add(), and ossimString::c_str().
Referenced by ossimMapProjectionFactory::createProjection().
61 {
63  ossimKeywordlist::KeywordMap::const_iterator node = geomMap.begin();
64
65  while(node != geomMap.end())
66  {
67  ossimString keyword = spaceImagingToOssimKeyword((*node).first);
68  ossimString value = spaceImagingToOssimValue((*node).first,
69  (*node).second);
70  if(keyword != "")
71  {
72  kwl.add(prefix,
73  keyword.c_str(),
74  value.c_str(),
75  true);
76  }
77  ++node;
78  }
79 }
ossimString spaceImagingToOssimValue(const ossimString &spaceImagingKeyword, const ossimString &spaceImagingValue) const
std::map< std::string, std::string > KeywordMap
ossimString spaceImagingToOssimKeyword(const ossimString &spaceImagingKeyword) const
const ossimKeywordlist::KeywordMap & getMap() const
const char * c_str() const
Definition: ossimString.h:396
◆ getBandName()
ossimString ossimSpaceImagingGeom::getBandName ( ) const
Definition at line 258 of file ossimSpaceImagingGeom.cpp.
References ossimString::find().
259 {
261 }
◆ getFilename()
ossimFilename ossimSpaceImagingGeom::getFilename ( ) const
Definition at line 263 of file ossimSpaceImagingGeom.cpp.
264 {
266 }
◆ getProducer()
ossimString ossimSpaceImagingGeom::getProducer ( ) const
Definition at line 268 of file ossimSpaceImagingGeom.cpp.
269 {
271 }
◆ setGeometry() [1/2]
void ossimSpaceImagingGeom::setGeometry ( const ossimFilename file)
Definition at line 45 of file ossimSpaceImagingGeom.cpp.
References ossimString::c_str().
46 {
48
50 }
bool addFile(const char *file)
◆ setGeometry() [2/2]
void ossimSpaceImagingGeom::setGeometry ( const ossimKeywordlist kwl)
Definition at line 52 of file ossimSpaceImagingGeom.cpp.
53 {
55
57 }
◆ spaceImagingToOssimKeyword()
ossimString ossimSpaceImagingGeom::spaceImagingToOssimKeyword ( const ossimString spaceImagingKeyword) const
Definition at line 81 of file ossimSpaceImagingGeom.cpp.
References ossimKeywordNames::DATUM_KW, ossimKeywordNames::METERS_PER_PIXEL_X_KW, ossimKeywordNames::METERS_PER_PIXEL_Y_KW, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::TIE_POINT_EASTING_KW, ossimKeywordNames::TIE_POINT_NORTHING_KW, ossimKeywordNames::TYPE_KW, and ossimKeywordNames::ZONE_KW.
82 {
83  if(spaceImagingKeyword == SIG_NUMBER_OF_BANDS_KW)
84  {
86  }
87  else if(spaceImagingKeyword == SIG_DATUM_KW)
88  {
90  }
91  else if((spaceImagingKeyword == SIG_PROJECTION_KW)||
92  (spaceImagingKeyword == SIG_SELECTED_PROJECTION_KW))
93  {
95  }
96  else if(spaceImagingKeyword == SIG_ZONE_KW)
97  {
99  }
100  else if(spaceImagingKeyword == SIG_UL_EASTING_KW)
101  {
103  }
104  else if(spaceImagingKeyword == SIG_UL_NORTHING_KW)
105  {
107  }
108  else if(spaceImagingKeyword == SIG_PIXEL_SIZE_X_KW)
109  {
111  }
112  else if(spaceImagingKeyword == SIG_PIXEL_SIZE_Y_KW)
113  {
115  }
116  else if(spaceImagingKeyword == SIG_COLUMNS_KW)
117  {
119  }
120  else if(spaceImagingKeyword == SIG_ROWS_KW)
121  {
123  }
124
125  return ossimString("");
126 }
static const char * DATUM_KW
static const char * NUMBER_LINES_KW
static const char * METERS_PER_PIXEL_Y_KW
static const char * TYPE_KW
static const char * TIE_POINT_NORTHING_KW
static const char * ZONE_KW
static const char * TIE_POINT_EASTING_KW
static const char * NUMBER_BANDS_KW
static const char * METERS_PER_PIXEL_X_KW
static const char * NUMBER_SAMPLES_KW
◆ spaceImagingToOssimValue()
ossimString ossimSpaceImagingGeom::spaceImagingToOssimValue ( const ossimString spaceImagingKeyword,
const ossimString spaceImagingValue
) const
Definition at line 128 of file ossimSpaceImagingGeom.cpp.
References ossimString::c_str(), ossimString::find(), ossimNotify(), ossimNotifyLevel_WARN, ossimString::trim(), and ossimString::upcase().
131 {
132  const char* value = theSpaceImagingGeometry.find(thePrefix.c_str(),
133  spaceImagingKeyword.c_str());
134
135  if(!value) return ossimString("");
136
137  if(spaceImagingKeyword == SIG_DATUM_KW)
138  {
139  // better to have a lut for this. For now I'll put it
140  // here. As the list gets larger let's move it to a
141  // lut then.
142  ossimString datum = value;
143  datum = datum.trim().upcase();
144
145  if( datum == "WGS84")
146  {
147  return ossimString("WGE");
148  }
149  }
150  else if((spaceImagingKeyword == SIG_PROJECTION_KW)||
151  (spaceImagingKeyword == SIG_SELECTED_PROJECTION_KW))
152  {
153  ossimString proj = value;
154  proj = proj.trim().upcase();
155
156  if(proj == "UNIVERSAL TRANSVERSE MERCATOR")
157  {
158  return ossimString("ossimUtmProjection");
159  }
160  else
161  {
162  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimSpaceImagingGeom::spaceImagingToOssimValue: Projection " << value << " doesn't have a converter yet!" << endl
163  << "Please add it" << endl;
164  }
165  }
166  else if(spaceImagingKeyword == SIG_UL_EASTING_KW)
167  {
168  ossimString easting = value;
169  easting = easting.trim();
170
171  ostringstream os;
172  os << easting;
173
174  ossimString eastingValue;
175  ossimString eastingUnits;
176
177  istringstream is(os.str());
178  is >> eastingValue >> eastingUnits;
179
180  eastingUnits = eastingUnits.trim().upcase();
181  if(eastingUnits!= "METERS")
182  {
183  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimSpaceImagingGeom::spaceImagingToOssimValue: units " << eastingUnits << " not supported yet!" << endl;
184  }
185
186  return eastingValue;
187  }
188  else if(spaceImagingKeyword == SIG_UL_NORTHING_KW)
189  {
190  ossimString northing = value;
191  northing = northing.trim();
192
193  ostringstream os;
194  os << northing;
195
196  ossimString northingValue;
197  ossimString northingUnits;
198
199  istringstream is(os.str());
200  is >> northingValue >> northingUnits;
201
202  northingUnits = northingUnits.trim().upcase();
203  if(northingUnits!= "METERS")
204  {
205  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimSpaceImagingGeom::spaceImagingToOssimValue: units " << northingUnits << " not supported yet!" << endl;
206  }
207
208  return northingValue;
209  }
210  else if(spaceImagingKeyword == SIG_PIXEL_SIZE_X_KW)
211  {
212  ossimString gsd = value;
213  gsd = gsd.trim();
214
215  ostringstream os;
216  os << gsd;
217
218  ossimString gsdValue;
219  ossimString gsdUnits;
220
221  istringstream is(os.str());
222  is >> gsdValue >> gsdUnits;
223
224  gsdUnits = gsdUnits.trim().upcase();
225  if(gsdUnits!= "METERS")
226  {
227  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimSpaceImagingGeom::spaceImagingToOssimValue: units " << gsdUnits << " not supported yet!" << endl;
228  }
229
230  return gsdValue;
231  }
232  else if(spaceImagingKeyword == SIG_PIXEL_SIZE_Y_KW)
233  {
234  ossimString gsd = value;
235  gsd = gsd.trim();
236
237  ostringstream os;
238  os << gsd;
239
240  ossimString gsdValue;
241  ossimString gsdUnits;
242
243  istringstream is(os.str());
244  is >> gsdValue >> gsdUnits;
245
246  gsdUnits = gsdUnits.trim().upcase();
247  if(gsdUnits!= "METERS")
248  {
249  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimSpaceImagingGeom::spaceImagingToOssimValue: units " << gsdUnits << " not supported yet!" << endl;
250  }
251
252  return gsdValue;
253  }
254
255  return ossimString(value);
256 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
Member Data Documentation
◆ SIG_BAND_KW
const char * ossimSpaceImagingGeom::SIG_BAND_KW = "Band"
static
Definition at line 43 of file ossimSpaceImagingGeom.h.
◆ SIG_BITS_PER_PIXEL_KW
const char * ossimSpaceImagingGeom::SIG_BITS_PER_PIXEL_KW = "Bits/Pixel"
static
Definition at line 44 of file ossimSpaceImagingGeom.h.
◆ SIG_COLUMNS_KW
const char * ossimSpaceImagingGeom::SIG_COLUMNS_KW = "Columns"
static
Definition at line 54 of file ossimSpaceImagingGeom.h.
◆ SIG_DATUM_KW
const char * ossimSpaceImagingGeom::SIG_DATUM_KW = "Datum"
static
Definition at line 46 of file ossimSpaceImagingGeom.h.
◆ SIG_FILENAME_KW
const char * ossimSpaceImagingGeom::SIG_FILENAME_KW = "Filename"
static
Definition at line 42 of file ossimSpaceImagingGeom.h.
◆ SIG_NUMBER_OF_BANDS_KW
const char * ossimSpaceImagingGeom::SIG_NUMBER_OF_BANDS_KW = "Number of Bands"
static
Definition at line 45 of file ossimSpaceImagingGeom.h.
◆ SIG_PIXEL_SIZE_X_KW
const char * ossimSpaceImagingGeom::SIG_PIXEL_SIZE_X_KW = "Pixel Size X"
static
Definition at line 52 of file ossimSpaceImagingGeom.h.
◆ SIG_PIXEL_SIZE_Y_KW
const char * ossimSpaceImagingGeom::SIG_PIXEL_SIZE_Y_KW = "Pixel Size Y"
static
Definition at line 53 of file ossimSpaceImagingGeom.h.
◆ SIG_PRODUCER_KW
const char * ossimSpaceImagingGeom::SIG_PRODUCER_KW = "Producer"
static
Definition at line 40 of file ossimSpaceImagingGeom.h.
◆ SIG_PROJECT_NAME_KW
const char * ossimSpaceImagingGeom::SIG_PROJECT_NAME_KW = "Project Name"
static
Definition at line 41 of file ossimSpaceImagingGeom.h.
◆ SIG_PROJECTION_KW
const char * ossimSpaceImagingGeom::SIG_PROJECTION_KW = "Projection"
static
Definition at line 47 of file ossimSpaceImagingGeom.h.
◆ SIG_ROWS_KW
const char * ossimSpaceImagingGeom::SIG_ROWS_KW = "Rows"
static
Definition at line 55 of file ossimSpaceImagingGeom.h.
◆ SIG_SELECTED_PROJECTION_KW
const char * ossimSpaceImagingGeom::SIG_SELECTED_PROJECTION_KW = "Selected Projection"
static
Definition at line 48 of file ossimSpaceImagingGeom.h.
◆ SIG_UL_EASTING_KW
const char * ossimSpaceImagingGeom::SIG_UL_EASTING_KW = "UL Map X (Easting)"
static
Definition at line 50 of file ossimSpaceImagingGeom.h.
◆ SIG_UL_NORTHING_KW
const char * ossimSpaceImagingGeom::SIG_UL_NORTHING_KW = "UL Map Y (Northing)"
static
Definition at line 51 of file ossimSpaceImagingGeom.h.
◆ SIG_ZONE_KW
const char * ossimSpaceImagingGeom::SIG_ZONE_KW = "Zone"
static
Definition at line 49 of file ossimSpaceImagingGeom.h.
◆ thePrefix
ossimString ossimSpaceImagingGeom::thePrefix
protected
Definition at line 59 of file ossimSpaceImagingGeom.h.
◆ theSpaceImagingGeometry
ossimKeywordlist ossimSpaceImagingGeom::theSpaceImagingGeometry
protected
Definition at line 58 of file ossimSpaceImagingGeom.h.
