119 const char *prefix)
const 135 if(lookupSpaceImaging)
255 const char* prefix)
const
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
takes a filename.
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
ossimProjection * createProjectionFromGeometryFile(const ossimFilename &imageFile, ossim_uint32 entryIdx) const
This method takes the filename and tries to find an external ".geom" file.
bool addFile(const char *file)
void setGeometry(const ossimFilename &file)
static ossimMapProjectionFactory * instance()
virtual ossimObject * createObject(const ossimString &typeName) const
static const char * SIG_PRODUCER_KW
static const char * TYPE_KW
#define STATIC_TYPE_NAME(T)
Albers Equal Area Conic Projection.
unsigned int ossim_uint32
static const char * GEOM_FILE_KW
static ossimMapProjectionFactory * theInstance
static ossimProjectionFactoryRegistry * instance()
void exportToOssim(ossimKeywordlist &kwl, const char *prefix=0) const
Special "sensor model" that provides a conventional map projection but with.
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
ossimMapProjectionFactory()
