#include <ossimUpsProjection.h>
ossimUpsProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
virtual ossimObject * | dup () const |
void | setDefaults () |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual void | update () |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
double | getFalseEasting () const |
double | getFalseNorthing () const |
void | setHemisphere (char hemisphere) |
virtual bool | operator== (const ossimProjection &projection) const |
Returns TRUE if principal parameters are within epsilon tolerance. More... | |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
long | Set_UPS_Parameters (double a, double f) |
void | Get_UPS_Parameters (double *a, double *f) const |
long | Convert_Geodetic_To_UPS (double Latitude, double Longitude, char *Hemisphere, double *Easting, double *Northing) const |
long | Convert_UPS_To_Geodetic (char Hemisphere, double Easting, double Northing, double *Latitude, double *Longitude) const |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
Protected Attributes | |
char | theHemisphere |
double | UPS_a |
double | UPS_f |
double | UPS_Origin_Latitude |
double | UPS_Origin_Longitude |
double | false_easting |
double | false_northing |
double | UPS_Easting |
double | UPS_Northing |
double | UPS_False_Easting |
double | UPS_False_Northing |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 15 of file ossimUpsProjection.h.
ossimUpsProjection::ossimUpsProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 33 of file ossimUpsProjection.cpp.
References setDefaults(), and update().
protected |
The function Convert_Geodetic_To_UPS converts geodetic (latitude and longitude) coordinates to UPS (hemisphere, easting, and northing) coordinates, according to the current ellipsoid parameters. If any errors occur, the error code(s) are returned by the function, otherwide UPS_NO_ERROR is returned.
Latitude : Latitude in radians (input) Longitude : Longitude in radians (input) Hemisphere : Hemisphere either 'N' or 'S' (output) Easting : Easting/X in meters (output) Northing : Northing/Y in meters (output)
Definition at line 197 of file ossimUpsProjection.cpp.
References Convert_Geodetic_To_Polar_Stereographic(), false_easting, false_northing, Set_Polar_Stereographic_Parameters(), UPS_a, UPS_Easting, UPS_f, UPS_False_Easting, UPS_False_Northing, UPS_NO_ERROR, UPS_Northing, UPS_Origin_Latitude, and UPS_Origin_Longitude.
Referenced by forward().
protected |
The function Convert_UPS_To_Geodetic converts UPS (hemisphere, easting, and northing) coordinates to geodetic (latitude and longitude) coordinates according to the current ellipsoid parameters. If any errors occur, the error code(s) are returned by the function, otherwise UPS_NO_ERROR is returned.
Hemisphere : Hemisphere either 'N' or 'S' (input) Easting : Easting/X in meters (input) Northing : Northing/Y in meters (input) Latitude : Latitude in radians (output) Longitude : Longitude in radians (output)
Definition at line 271 of file ossimUpsProjection.cpp.
References Convert_Polar_Stereographic_To_Geodetic(), MAX_ORIGIN_LAT, Set_Polar_Stereographic_Parameters(), UPS_a, UPS_f, UPS_False_Easting, UPS_False_Northing, UPS_NO_ERROR, UPS_Origin_Latitude, and UPS_Origin_Longitude.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 21 of file ossimUpsProjection.h.
Definition at line 85 of file ossimUpsProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_UPS(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), ossimMapProjection::theDatum, and theHemisphere.
protected |
The function Get_UPS_Parameters returns the current ellipsoid parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output)
Definition at line 180 of file ossimUpsProjection.cpp.
inlinevirtual |
Definition at line 43 of file ossimUpsProjection.h.
inlinevirtual |
Definition at line 44 of file ossimUpsProjection.h.
Definition at line 71 of file ossimUpsProjection.cpp.
References Convert_UPS_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, theHemisphere, ossimDpt::x, and ossimDpt::y.
Definition at line 133 of file ossimUpsProjection.cpp.
References ossimMapProjection::loadState(), and setDefaults().
Definition at line 333 of file ossimUpsProjection.cpp.
References theHemisphere.
Definition at line 123 of file ossimUpsProjection.cpp.
References ossimMapProjection::saveState().
protected |
The function SET_UPS_PARAMETERS receives the ellipsoid parameters and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise UPS_NO_ERROR is returned.
a : Semi-major axis of ellipsoid in meters (input) f : Flattening of ellipsoid (input)
Definition at line 147 of file ossimUpsProjection.cpp.
References UPS_a, UPS_f, and UPS_NO_ERROR.
Referenced by update().
void ossimUpsProjection::setDefaults | ( | ) |
Definition at line 42 of file ossimUpsProjection.cpp.
References DEG_PER_RAD, false_easting, false_northing, FLT_EPSILON, ossimGpt::latd(), MAX_ORIGIN_LAT, theHemisphere, ossimMapProjection::theOrigin, UPS_Easting, UPS_False_Easting, UPS_False_Northing, UPS_Northing, UPS_Origin_Latitude, and UPS_Origin_Longitude.
Referenced by loadState(), and ossimUpsProjection().
void ossimUpsProjection::setHemisphere | ( | char | hemisphere | ) |
Definition at line 108 of file ossimUpsProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), Set_UPS_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::update(), UPS_False_Easting, UPS_False_Northing, ossimDpt::x, and ossimDpt::y.
Referenced by ossimUpsProjection(), and setHemisphere().
mutableprotected |
Definition at line 60 of file ossimUpsProjection.h.
Referenced by Convert_Geodetic_To_UPS(), and setDefaults().
mutableprotected |
Definition at line 61 of file ossimUpsProjection.h.
mutableprotected |
Definition at line 52 of file ossimUpsProjection.h.
Referenced by forward(), inverse(), operator==(), setDefaults(), and setHemisphere().
mutableprotected |
Definition at line 56 of file ossimUpsProjection.h.
Referenced by Convert_Geodetic_To_UPS(), Convert_UPS_To_Geodetic(), Get_UPS_Parameters(), and Set_UPS_Parameters().
mutableprotected |
Definition at line 62 of file ossimUpsProjection.h.
mutableprotected |
Definition at line 57 of file ossimUpsProjection.h.
protected |
Definition at line 64 of file ossimUpsProjection.h.
Referenced by Convert_Geodetic_To_UPS(), Convert_UPS_To_Geodetic(), setDefaults(), and update().
protected |
Definition at line 65 of file ossimUpsProjection.h.
mutableprotected |
Definition at line 63 of file ossimUpsProjection.h.
mutableprotected |
Definition at line 58 of file ossimUpsProjection.h.
Referenced by Convert_Geodetic_To_UPS(), Convert_UPS_To_Geodetic(), and setDefaults().
mutableprotected |
Definition at line 59 of file ossimUpsProjection.h.
