ossimWorldFileWriter Class Reference
ossimWorldFileWriter More...
#include <ossimWorldFileWriter.h>
Inheritance diagram for ossimWorldFileWriter:
ossimMetadataFileWriter ossimConnectableObject ossimProcessInterface ossimConnectableObjectListener ossimObject ossimListenerManager ossimPropertyInterface ossimListener ossimReferenced
Public Member Functions
 ossimWorldFileWriter ()
 default constructor More...
 Load state method: More...
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const
 Satisfies pure virtual from ossimMetadataWriter base. More...
virtual bool hasMetadataType (const ossimString &metadataType) const
void setLinearUnits (ossimUnitType units)
 Sets the linear units of the output file to either feet, us_survey_feet, or meters. More...
- Public Member Functions inherited from ossimMetadataFileWriter
 ossimMetadataFileWriter ()
virtual void initialize ()
virtual bool execute ()
virtual void setFilename (const ossimFilename &file)
const ossimFilenamegetFilename () const
virtual void setPixelType (ossimPixelType pixelType)
 Ossim uses a concept of "pixel is point" internally. More...
virtual ossimPixelType getPixelType () const
virtual void setAreaOfInterest (const ossimIrect &areaOfInterest)
 Sets the area of interest to write the meta data for. More...
virtual ossimIrect getAreaOfInterest () const
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimWorldFileWriter ()
virtual bool writeFile ()
 Write out the file. More...
- Protected Member Functions inherited from ossimMetadataFileWriter
virtual ~ossimMetadataFileWriter ()
virtual ~ossimReferenced ()
Protected Attributes
ossimUnitType theUnits
- Protected Attributes inherited from ossimMetadataFileWriter
ossimFilename theFilename
ossimPixelType thePixelType
ossimIrect theAreaOfInterest
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Definition at line 17 of file ossimWorldFileWriter.h.
◆ ossimWorldFileWriter()
ossimWorldFileWriter::ossimWorldFileWriter ( )
default constructor
◆ ~ossimWorldFileWriter()
virtual ossimWorldFileWriter::~ossimWorldFileWriter ( )
protectedvirtual
default constructor
Member Function Documentation
◆ getMetadatatypeList()
virtual void ossimWorldFileWriter::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
virtual
Appends the writers image types to the "metadatatypeList".
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
Appends to the list, does not clear it first.
Implements ossimMetadataFileWriter.
◆ hasMetadataType()
virtual bool ossimWorldFileWriter::hasMetadataType ( const ossimString metadataType) const
virtual
Parameters
imageTypestring representing image type.
Returns
true if "metadataType" is supported by writer.
◆ loadState()
virtual bool ossimWorldFileWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Load state method:
This method call base class ossimMetadataFileWriter::loadState after looking for its keywords.
Parameters
kwlKeyword list to initialize from.
prefixUsually something like: "object1."
Returns
This method will alway return true as it is intended to be used in conjuction with the set methods.
Keywords picked up by loadState:
(linear units must be "feet", "us_survey_feet", or "meters") (If projection is geographic units will always be decimal degrees.)
linear_units: us_survey_feet
Reimplemented from ossimMetadataFileWriter.
◆ setLinearUnits()
void ossimWorldFileWriter::setLinearUnits ( ossimUnitType  units)
If the projection is geographic, the call has no affect.
If units is not feet, us_survey_feet or meters this call has no effect.
Parameters
unitsDesired output units of the world file.
Referenced by ossimImageFileWriter::writeWorldFile().
◆ writeFile()
virtual bool ossimWorldFileWriter::writeFile ( )
protectedvirtual
Write out the file.
Returns
Member Data Documentation
◆ theUnits
ossimUnitType ossimWorldFileWriter::theUnits
protected
Definition at line 84 of file ossimWorldFileWriter.h.
The documentation for this class was generated from the following file:
