36 static const ossimTrace traceDebug(
"ossimArcInfoGridWriter:debug");
39 "ossimArcInfoGridWriter",
47 theOutputTileSize(256, 4)
67 const char* MODULE =
"ossimArcInfoGridWriter::writeFile";
105 ios::out|ios::binary);
107 ios::out|ios::binary);
110 if(indexFileStream&&dataFileStream)
131 aigIndexHeader.
theFileSize += (4*totalNumberOfTiles);
137 (tileSizeInShorts*totalNumberOfTiles) +
146 CLOG <<
"AIG INDEX HEADER = \n" << aigIndexHeader << std::endl;
147 CLOG <<
"AIG DATA FILE HEADER\n" 152 while(currentTile.
valid())
154 currentTile = filter->
applyCast(currentTile);
156 if(!currentTile->
getBuf())
161 tileOffsetShorts = dataFileStream.tellp()/2;
166 endian.swap(tileOffsetShorts);
167 endian.swap(tileSizeShorts);
168 endian.swap(tileSizeShorts16);
174 indexFileStream.write((
char*)(&tileOffsetShorts), 4);
175 indexFileStream.write((
char*)(&tileSizeShorts), 4);
176 dataFileStream.write((
char*)(&tileSizeShorts16),
178 dataFileStream.write((
char*)(currentTile->
getBuf()),
193 const char* prefix)
const 228 <<
"ossimArcInfoGridWriter::open(): Directory " 243 const char* MODULE =
"ossimArcInfoGridWriter::writeBinaryAigHeader";
275 <<
"ossimArcInfoGridWriter::writeBinaryAigHeader: " 276 <<
"unknown scalar type" << std::endl;
292 out.open(file.
c_str(), ios::out|ios::binary);
298 CLOG <<
"AIG_HEADER = \n" << aigHeader << std::endl;
309 const char* MODULE =
"ossimArcInfoGridWriter::writeBinaryAigBounds";
317 aigBounds.
ll_x = -.5;
318 aigBounds.
ll_y = -.5;
328 out.open(file.
334 CLOG <<
"AIG BOUNDS =\n" <<aigBounds << std::endl;
360 out.open(file.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual void setToStartOfSequence()
bool writeStream(std::ostream &out)
ossim_int64 getNumberOfTiles() const
ossim_uint32 height() const
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
ossimIrect theAreaOfInterest
Pure virtual base class for image file writers.
virtual bool isOpen() const
virtual void initialize()
Initialize the data buffer.
virtual ossimString getExtension() const
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
ossimFilename theFilename
This will return the bounding rect of the source.
virtual void setOutputScalarType(ossimScalarType scalarType)
Sets the output scalar type.
virtual bool writeBinaryAigBounds()
virtual bool writeBinaryAigHeader()
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
RTTI_DEF1(ossimArcInfoGridWriter, "ossimArcInfoGridWriter", ossimImageFileWriter)
ossim_uint32 width() const
ossimIpt theOutputTileSize
virtual bool writeBinaryAigStats()
ossim_int64 getNumberOfTilesHorizontal() const
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ~ossimArcInfoGridWriter()
virtual bool writeFile()
Write out the file.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
const ossimIrect & getAreaOfInterest() const
std::basic_ofstream< char > ofstream
Class for char output file streams.
ossimRefPtr< ossimImageData > applyCast(ossimRefPtr< ossimImageData > input)
virtual void setTileSize(const ossimIpt &tileSize)
ossimFilename path() const
ossim_int64 getNumberOfTilesVertical() const
