Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimArcInfoGridWriter Class Reference
#include <ossimArcInfoGridWriter.h>
Inheritance diagram for ossimArcInfoGridWriter:
ossimImageFileWriter ossimImageWriter ossimProcessInterface ossimConnectableObjectListener ossimOutputSource ossimListener ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimArcInfoGridWriter ()
virtual ~ossimArcInfoGridWriter ()
 ossimArcInfoGridWriter (ossimImageSource *inputSource, const ossimFilename &filename)
virtual bool isOpen () const
virtual bool open ()
virtual void close ()
virtual ossimString getExtension () const
 Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More...
- Public Member Functions inherited from ossimImageFileWriter
 ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
 The writer will own the sequencer. More...
virtual ~ossimImageFileWriter ()
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const =0
 void getImageTypeList(std::vector<ossimString>& imageTypeList)const More...
virtual bool getOutputHasInternalOverviews (void) const
 Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More...
virtual bool hasImageType (const ossimString &imageType) const
 bool hasImageType(const ossimString& imageType) const More...
virtual void setTileSize (const ossimIpt &tileSize)
 Sets the output image tiling size if supported by the writer. More...
virtual bool writeEnviHeaderFile ()
 Will write an envi header file. More...
virtual bool writeErsHeaderFile ()
 Will write an ER Mapper header file. More...
virtual bool writeExternalGeometryFile ()
 Will write an external geometry file. More...
virtual bool writeFgdcFile ()
 Will write an fgdc file. More...
virtual bool writeHistogramFile ()
 Returns true on success, false on error. More...
virtual bool writeJpegWorldFile ()
 Will write a jpeg world file. More...
virtual bool writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false)
 Write out an ossim overview file from the source_file. More...
virtual bool writeReadmeFile ()
 Will write a readme file. More...
virtual bool writeTiffWorldFile ()
 Will write a world file. More...
virtual bool writeWorldFile ()
virtual bool writeMetaDataFiles ()
 Convenience method that calls meta data write methods that are flagged to be called. More...
virtual void setAreaOfInterest (const ossimIrect &inputRect)
virtual void changeSequencer (ossimImageSourceSequencer *sequencer)
 Sets the sequencer and connects it to the input of this. More...
virtual ossimImageSourceSequencergetSequencer ()
virtual void initialize ()
 Initialize method. More...
virtual bool execute ()
 Calls: writeFile() writeMetaDataFiles() More...
virtual bool writeStream ()
 Method to write the image to a stream. More...
virtual bool setOutputStream (ossimRefPtr< ossimOStream > stream)
 Sets the output stream to write to. More...
virtual bool setOutputStream (std::ostream &str)
 tmp drb More...
virtual ossimRefPtr< ossimOStreamgetOutputStream () const
 Method to return the stream attached to output. More...
virtual void setOutputImageType (ossim_int32 type)
virtual void setOutputImageType (const ossimString &type)
virtual ossim_int32 getOutputImageType () const
virtual ossimString getOutputImageTypeString () const
virtual void setOutputName (const ossimString &outputName)
virtual void setFilename (const ossimFilename &file)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool getWriteImageFlag () const
 Control flags... More...
virtual bool getWriteHistogramFlag () const
virtual bool getWriteOverviewFlag () const
virtual bool getScaleToEightBitFlag () const
virtual bool getWriteEnviHeaderFlag () const
virtual bool getWriteErsHeaderFlag () const
virtual bool getWriteExternalGeometryFlag () const
virtual bool getWriteFgdcFlag () const
virtual bool getWriteJpegWorldFileFlag () const
virtual bool getWriteReadmeFlag () const
virtual bool getWriteTiffWorldFileFlag () const
virtual bool getWriteWorldFileFlag () const
virtual void setWriteImageFlag (bool flag)
virtual void setWriteOverviewFlag (bool flag)
virtual void setWriteHistogramFlag (bool flag)
virtual void setScaleToEightBitFlag (bool flag)
virtual void setWriteEnviHeaderFlag (bool flag)
virtual void setWriteErsHeaderFlag (bool flag)
virtual void setWriteExternalGeometryFlag (bool flag)
virtual void setWriteFgdcFlag (bool flag)
virtual void setWriteJpegWorldFile (bool flag)
virtual void setWriteReadme (bool flag)
virtual void setWriteTiffWorldFile (bool flag)
virtual void setWriteWorldFile (bool flag)
virtual ossim_uint16 getOverviewCompressType () const
virtual ossim_int32 getOverviewJpegCompressQuality () const
virtual void setOverviewCompressType (ossim_uint16 type)
virtual void setOverviewJpegCompressQuality (ossim_int32 quality)
 Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More...
 Overrides base "removeListener". More...
virtual void setPixelType (ossimPixelType type)
 If "point" the coordinate tie points are relative to the center of the pixel. More...
virtual void setPixelType (const ossimString &type)
virtual ossimPixelType getPixelType () const
virtual void getPixelTypeString (ossimString &type) const
- Public Member Functions inherited from ossimImageWriter
 ossimImageWriter (ossimObject *owner=NULL)
 ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed)
virtual ~ossimImageWriter ()
virtual bool setViewingRect (const ossimIrect &aRect)
virtual ossimIrect getAreaOfInterest () const
- Public Member Functions inherited from ossimOutputSource
 ossimOutputSource (ossimObject *owner=NULL)
 ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true)
virtual ~ossimOutputSource ()
virtual bool open (const ossimString &outputName)
virtual const ossimStringgetOutputName ()
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual bool writeFile ()
 Write out the file. More...
virtual bool writeBinaryAigHeader ()
virtual bool writeBinaryAigBounds ()
virtual bool writeBinaryAigStats ()
Private Attributes
ossimIpt theOutputTileSize
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
- Protected Member Functions inherited from ossimImageFileWriter
bool writeWorldFile (const ossimFilename &file)
 Common world file writer method. More...
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimImageFileWriter
ossimRefPtr< ossimImageSourceSequencertheInputConnection
ossimRefPtr< ossimViewControllertheViewController
ossimListenertheProgressListener
ossimFilename theFilename
ossimString theOutputImageType
bool theWriteImageFlag
bool theWriteOverviewFlag
bool theWriteHistogramFlag
bool theScaleToEightBitFlag
ossim_uint16 theOverviewCompressType
ossim_int32 theOverviewJpegCompressQuality
bool theWriteEnviHeaderFlag
 External meta data writer flags. More...
bool theWriteErsHeaderFlag
bool theWriteExternalGeometryFlag
bool theWriteFgdcFlag
bool theWriteJpegWorldFileFlag
bool theWriteReadmeFlag
bool theWriteTiffWorldFileFlag
bool theWriteWorldFileFlag
bool theAutoCreateDirectoryFlag
ossimUnitType theLinearUnits
 If not a geographic projection this allows the user to set the linear units of the output tag to be: More...
ossimPixelType thePixelType
 OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1. More...
- Protected Attributes inherited from ossimImageWriter
ossimIrect theAreaOfInterest
- Protected Attributes inherited from ossimOutputSource
ossimString theOutputName
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
Definition at line 20 of file ossimArcInfoGridWriter.h.
◆ ossimArcInfoGridWriter() [1/2]
ossimArcInfoGridWriter::ossimArcInfoGridWriter ( )
Definition at line 45 of file ossimArcInfoGridWriter.cpp.
47  theOutputTileSize(256, 4)
48 {
49 }
ossimImageFileWriter(const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
◆ ~ossimArcInfoGridWriter()
ossimArcInfoGridWriter::~ossimArcInfoGridWriter ( )
virtual
Definition at line 60 of file ossimArcInfoGridWriter.cpp.
References close().
61 {
62  close();
63 }
◆ ossimArcInfoGridWriter() [2/2]
ossimArcInfoGridWriter::ossimArcInfoGridWriter ( ossimImageSource inputSource,
const ossimFilename filename
Definition at line 51 of file ossimArcInfoGridWriter.cpp.
53  :ossimImageFileWriter(filename, inputSource)
54 {
55 }
Member Function Documentation
◆ close()
void ossimArcInfoGridWriter::close ( )
virtual
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 236 of file ossimArcInfoGridWriter.cpp.
Referenced by ~ossimArcInfoGridWriter().
237 {
238 }
◆ getExtension()
ossimString ossimArcInfoGridWriter::getExtension ( ) const
virtual
Parameters
imageTypestring representing image type.
Returns
the 3-letter string extension.
Reimplemented from ossimImageFileWriter.
Definition at line 371 of file ossimArcInfoGridWriter.cpp.
372 {
373  return ossimString("aig");
374 }
◆ isOpen()
bool ossimArcInfoGridWriter::isOpen ( ) const
virtual
◆ loadState()
bool ossimArcInfoGridWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 198 of file ossimArcInfoGridWriter.cpp.
References ossimImageFileWriter::loadState().
200 {
201
202  return ossimImageFileWriter::loadState(kwl, prefix);
203 }
◆ open()
bool ossimArcInfoGridWriter::open ( )
virtual
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 210 of file ossimArcInfoGridWriter.cpp.
References ossimFilename::exists(), ossimFilename::isDir(), ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::path(), and ossimImageFileWriter::theFilename.
Referenced by writeFile().
211 {
212  if(theFilename.isDir()&&
214  {
215  return true;
216  }
217  else
218  {
220  if(theFilename.isDir()&&
222  {
223  return true;
224  }
225  else
226  {
228  << "ossimArcInfoGridWriter::open(): Directory "
229  << theFilename << " doesn't exist" << std::endl;
230  }
231
232  }
233  return false;
234 }
bool isDir() const
bool exists() const
ossimFilename path() const
◆ saveState()
bool ossimArcInfoGridWriter::saveState ( ossimKeywordlist kwl,
) const
virtual
saves the state of the object.
Definition at line 192 of file ossimArcInfoGridWriter.cpp.
References ossimImageFileWriter::saveState().
194 {
195  return ossimImageFileWriter::saveState(kwl, prefix);
196 }
◆ writeBinaryAigBounds()
bool ossimArcInfoGridWriter::writeBinaryAigBounds ( )
privatevirtual
Definition at line 307 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimImageSourceSequencer::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::height(), isOpen(), ossimAigBounds::ll_x, ossimAigBounds::ll_y, ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, ossimAigBounds::ur_x, ossimAigBounds::ur_y, and ossimIrect::width().
308 {
309  const char* MODULE = "ossimArcInfoGridWriter::writeBinaryAigBounds";
310  ossimAigBounds aigBounds;
311
312
313  // setup bounds
315  if(!bounds.hasNans())
316  {
317  aigBounds.ll_x = -.5;
318  aigBounds.ll_y = -.5;
319  aigBounds.ur_x = bounds.width()-.5;
320  aigBounds.ur_y = bounds.height()-.5;
321
322  //
323  ossimFilename file=ossimFilename(theFilename+"/"+"dblbnd.adf");
324
325  if(isOpen())
326  {
327  std::ofstream out;
328  out.open(file.c_str(), ios::out|ios::binary);
329
330  if(out)
331  {
332  if(traceDebug())
333  {
334  CLOG << "AIG BOUNDS =\n" <<aigBounds << std::endl;
335  }
336  return aigBounds.writeStream(out);
337  }
338  }
339  }
340
341  return false;
342 }
#define CLOG
Definition: ossimTrace.h:23
bool writeStream(std::ostream &out)
ossim_uint32 height() const
Definition: ossimIrect.h:487
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
This will return the bounding rect of the source.
ossim_uint32 width() const
Definition: ossimIrect.h:500
const char * c_str() const
Definition: ossimString.h:396
bool hasNans() const
Definition: ossimIrect.h:337
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ writeBinaryAigHeader()
bool ossimArcInfoGridWriter::writeBinaryAigHeader ( )
privatevirtual
Definition at line 241 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimImageSourceSequencer::getNumberOfTilesHorizontal(), ossimImageSourceSequencer::getNumberOfTilesVertical(), ossimImageSourceSequencer::getOutputScalarType(), ossimImageSourceSequencer::getTileHeight(), ossimImageSourceSequencer::getTileWidth(), isOpen(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimAigHeader::setFloatCoverage(), ossimImageFileWriter::theFilename, ossimAigHeader::theHeightOfTileInPixels, ossimImageFileWriter::theInputConnection, ossimAigHeader::theNumberOfTilesPerColumn, ossimAigHeader::theNumberOfTilesPerRow, and ossimAigHeader::theWidthOfTileInPixels.
242 {
243  const char* MODULE = "ossimArcInfoGridWriter::writeBinaryAigHeader";
244  ossimAigHeader aigHeader;
245
246  ossimFilename file=ossimFilename(theFilename+"/"+"hdr.adf");
247
248  if(isOpen())
249  {
251  {
252  case OSSIM_UCHAR:
253  case OSSIM_SSHORT16:
254  case OSSIM_USHORT11:
255  case OSSIM_USHORT12:
256  case OSSIM_USHORT13:
257  case OSSIM_USHORT14:
258  case OSSIM_USHORT15:
259  case OSSIM_USHORT16:
260 // {
261 // aigHeader.setIntCoverage();
262 // break;
263 // }
264  case OSSIM_DOUBLE:
265  case OSSIM_FLOAT:
268  {
269  aigHeader.setFloatCoverage();
270  break;
271  }
272  default:
273  {
275  << "ossimArcInfoGridWriter::writeBinaryAigHeader: "
276  << "unknown scalar type" << std::endl;
277  }
278  }
279
280  // need to set pixel size
281  //
282
283  // code goes here
284
285  // now setting number of tiles per row
290
291  std::ofstream out;
292  out.open(file.c_str(), ios::out|ios::binary);
293
294  if(out)
295  {
296  if(traceDebug())
297  {
298  CLOG << "AIG_HEADER = \n" << aigHeader << std::endl;
299  }
300  return aigHeader.writeStream(out);
301  }
302  }
303
304  return false;
305 }
#define CLOG
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
int theNumberOfTilesPerColumn
int theNumberOfTilesPerRow
ossim_int64 getNumberOfTilesHorizontal() const
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
void setFloatCoverage()
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
ossim_int64 getNumberOfTilesVertical() const
8 bit unsigned iteger
◆ writeBinaryAigStats()
bool ossimArcInfoGridWriter::writeBinaryAigStats ( )
privatevirtual
Definition at line 344 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimImageSourceSequencer::getMaxPixelValue(), ossimImageSourceSequencer::getMinPixelValue(), isOpen(), ossimImageFileWriter::theFilename, ossimImageFileWriter::theInputConnection, ossimAigStatistics::theMax, ossimAigStatistics::theMean, ossimAigStatistics::theMin, and ossimAigStatistics::writeStream().
345 {
346  ossimAigStatistics aigStats;
347
348
349  // setup bounds
352  aigStats.theMean = (aigStats.theMax-aigStats.theMin)/2.0;
353
354  //
355  ossimFilename file=ossimFilename(theFilename+"/"+"sta.adf");
356
357  if(isOpen())
358  {
359  std::ofstream out;
360  out.open(file.c_str(), ios::out|ios::binary);
361
362  if(out)
363  {
364  return aigStats.writeStream(out);
365  }
366  }
367
368  return false;
369 }
◆ writeFile()
bool ossimArcInfoGridWriter::writeFile ( )
privatevirtual
Write out the file.
Returns
Implements ossimImageFileWriter.
Definition at line 65 of file ossimArcInfoGridWriter.cpp.
References ossimString::c_str(), ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimImageSourceSequencer::getAreaOfInterest(), ossimImageSourceSequencer::getNextTile(), ossimImageSourceSequencer::getNumberOfTiles(), ossimImageSourceSequencer::getTileHeight(), ossimImageSourceSequencer::getTileWidth(), ossimIrect::hasNans(), ossimCastTileSourceFilter::initialize(), ossimImageSourceSequencer::initialize(), open(), OSSIM_FLOAT, ossimNotify(), ossimNotifyLevel_NOTICE, ossimImageSourceSequencer::setAreaOfInterest(), ossimCastTileSourceFilter::setOutputScalarType(), ossimImageSourceSequencer::setTileSize(), ossimImageSourceSequencer::setToStartOfSequence(), ossimImageWriter::theAreaOfInterest, ossimImageFileWriter::theFilename, ossimAigDataFileHeader::theFileSize, ossimAigIndexFileHeader::theFileSize, ossimImageFileWriter::theInputConnection, theOutputTileSize, ossimAigDataFileHeader::theTileSize, tileNumber, writeBinaryAigBounds(), writeBinaryAigHeader(), writeBinaryAigStats(), ossimAigDataFileHeader::writeStream(), and ossimAigIndexFileHeader::writeStream().
66 {
67  const char* MODULE = "ossimArcInfoGridWriter::writeFile";
69  {
70  return false;
71  }
72
76  filter->initialize();
77
78  open();
79
80  // make sure we have a region of interest
82  {
85  }
86  else
87  {
89  }
90
91  if(theAreaOfInterest.hasNans()) return false;
92
95
96  bool result = writeBinaryAigHeader()&&
99  if(result)
100  {
101  ossimFilename indexFile=ossimFilename(theFilename+"/"+"w001001x.adf");
102  ossimFilename dataFile=ossimFilename(theFilename+"/"+"w001001.adf");
103
104  std::ofstream indexFileStream(indexFile.c_str(),
105  ios::out|ios::binary);
106  std::ofstream dataFileStream(dataFile.c_str(),
107  ios::out|ios::binary);
108  ossimEndian endian;
109
110  if(indexFileStream&&dataFileStream)
111  {
112  ossimAigIndexFileHeader aigIndexHeader;
113  ossimAigDataFileHeader aigDataFileHeader;
114
115  ossimRefPtr<ossimImageData> currentTile =
117  long tileNumber = 0;
118  long totalNumberOfTiles = theInputConnection->getNumberOfTiles();
119  ossim_int32 tileOffsetShorts = 0;
120  ossim_int32 tileSizeShorts = 0;
121
123  << "Tile height = " << theInputConnection->getTileHeight()
124  << std::endl
125  << "Tile width = " << theInputConnection->getTileWidth()
126  << std::endl;
127  ossim_int32 tileSizeInShorts = 2*(theInputConnection->getTileHeight()*
129  // Note: this is in shorts
130  //
131  aigIndexHeader.theFileSize += (4*totalNumberOfTiles);
132
133  // Note this is in shorts
134  //
135
136  aigDataFileHeader.theFileSize = 50+
137  (tileSizeInShorts*totalNumberOfTiles) +
138  totalNumberOfTiles;
139  aigDataFileHeader.theTileSize = tileSizeInShorts;
140
141  aigIndexHeader.writeStream(indexFileStream);
142  aigDataFileHeader.writeStream(dataFileStream);
143
144  if(traceDebug())
145  {
146  CLOG << "AIG INDEX HEADER = \n" << aigIndexHeader << std::endl;
147  CLOG << "AIG DATA FILE HEADER\n"
148  << "file size = " << aigDataFileHeader.theFileSize
149  << std::endl;
150  }
151
152  while(currentTile.valid())
153  {
154  currentTile = filter->applyCast(currentTile);
155
156  if(!currentTile->getBuf())
157  {
158  currentTile->initialize();
159  }
160
161  tileOffsetShorts = dataFileStream.tellp()/2;
162  tileSizeShorts = 2*currentTile->getHeight()*currentTile->getWidth();
163  ossim_int16 tileSizeShorts16 = 2*currentTile->getHeight()*currentTile->getWidth();
164  if(endian.getSystemEndianType() == OSSIM_LITTLE_ENDIAN)
165  {
166  endian.swap(tileOffsetShorts);
167  endian.swap(tileSizeShorts);
168  endian.swap(tileSizeShorts16);
169  endian.swap((ossim_float32*)currentTile->getBuf(),
170  currentTile->getWidth()*
171  currentTile->getHeight());
172  }
173
174  indexFileStream.write((char*)(&tileOffsetShorts), 4);
175  indexFileStream.write((char*)(&tileSizeShorts), 4);
176  dataFileStream.write((char*)(&tileSizeShorts16),
177  2);
178  dataFileStream.write((char*)(currentTile->getBuf()),
179  currentTile->getWidth()*currentTile->getHeight()*4);
180
181  currentTile = theInputConnection->getNextTile();
182  ++tileNumber;
183  }
184  }
185  }
186
187  close();
188  filter = 0;
189  return result;
190 }
#define CLOG
ossim_uint32 tileNumber
bool valid() const
Definition: ossimRefPtr.h:75
float ossim_float32
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
virtual void initialize()
Initialize the data buffer.
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
virtual void setOutputScalarType(ossimScalarType scalarType)
Sets the output scalar type.
bool writeStream(std::ostream &out) const
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
short ossim_int16
const ossimIrect & getAreaOfInterest() const
ossimRefPtr< ossimImageData > applyCast(ossimRefPtr< ossimImageData > input)
virtual void setTileSize(const ossimIpt &tileSize)
int ossim_int32
Member Data Documentation
◆ theOutputTileSize
ossimIpt ossimArcInfoGridWriter::theOutputTileSize
private
Definition at line 63 of file ossimArcInfoGridWriter.h.
