ossimBitMaskTileSource.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: MIT
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Oscar Kramer
8 //
9 //*******************************************************************
10 // $Id: ossimBitMaskTileSource.h 2644 2011-05-26 15:20:11Z oscar.kramer $
11
12 #ifndef ossimBitMaskTileSource_HEADER
13 #define ossimBitMaskTileSource_HEADER
14
17
18 class ossimImageGeometry;
19
20 //*************************************************************************************************
62 //*************************************************************************************************
63
65 {
66 public:
67
69
72  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tile_rect, ossim_uint32 rLevel=0);
73
74  virtual bool isValidRLevel (ossim_uint32 res_level) const;
75  virtual ossim_uint32 getNumberOfLines (ossim_uint32 res_level=0) const;
76  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 res_level=0) const;
77
78  virtual ossim_uint32 getNumberOfInputBands() const { return 1; }
79  virtual ossim_uint32 getNumberOfOutputBands() const { return 1; }
80  virtual ossimScalarType getOutputScalarType() const { return OSSIM_UINT8; }
81  virtual ossim_uint32 getImageTileWidth() const { return 0; }
82  virtual ossim_uint32 getImageTileHeight() const { return 0; }
83
84  virtual bool isOpen() const;
85  virtual bool open();
86  virtual void close();
87
88  virtual double getNullPixelValue(ossim_uint32 /*band=0*/) const { return 0; }
89  virtual double getMinPixelValue (ossim_uint32 /*band=0*/) const { return 0; }
90  virtual double getMaxPixelValue (ossim_uint32 /*band=0*/) const { return 1.0; }
91
95
98
101  void setAssociatedImageHandler(ossimImageHandler* handler);
102
106  void setAssociatedMaskWriter(ossimBitMaskWriter* maskWriter);
107
108 protected:
109  virtual ~ossimBitMaskTileSource();
110
112  bool isSupportedExtension();
113
114  virtual void establishDecimationFactors();
115
117  vector<ossim_uint8*> m_buffers;
118  vector<ossimIpt> m_bufferSizes;
119
123
128
129  TYPE_DATA
130 };
131
132 #endif
133
virtual bool open()=0
Pure virtual open.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual double getNullPixelValue(ossim_uint32) const
ossimRefPtr< ossimImageHandler > m_handler
For backward compatibility with older mask format ("Ming Mask"), provide for associating the mask wit...
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool isOpen() const =0
vector< ossimIpt > m_bufferSizes
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
unsigned int ossim_uint32
This is the image handler for providing mask pixels to an ossimMaskFilter object. ...
Class for computing a mask from an input image source and writing the mask file to disk...
Virtual method determines the decimation factors at each resolution level.
virtual double getMaxPixelValue(ossim_uint32) const
ossimScalarType
ossimRefPtr< ossimImageData > m_tile
This class defines an abstract Handler which all image handlers(loaders) should derive from...
ossimRefPtr< ossimBitMaskWriter > m_maskWriter
This class can be used during overview generation, in which case there will be a simultaneous mask wr...
#define OSSIM_DLL
virtual double getMinPixelValue(ossim_uint32) const
Retuns the min pixel value.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
8 bit unsigned integer
vector< ossim_uint8 * > m_buffers
