ossimBlendMosaic.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 //*************************************************************************
8 // $Id: ossimBlendMosaic.cpp 20696 2012-03-19 12:36:40Z dburken $
9
14
15 RTTI_DEF1(ossimBlendMosaic, "ossimBlendMosaic", ossimImageMosaic)
16
18  : ossimImageMosaic(),
19  theNormResult(NULL)
20 {
21 }
22
24  : ossimImageMosaic(inputSources),
25  theNormResult(NULL)
26 {
27  initialize();
28 }
29
31 {
32 }
33
35 {
37
38  allocate();
39
40  // only allocate this space if we have to
41  if(hasDifferentInputs())
42  {
43  theNormResult = new ossimImageData(this,
47  }
48
49  if(theWeights.size() < theInputObjectList.size())
50  {
51  for(ossim_uint32 index =(ossim_uint32)theWeights.size();
52  index < theInputObjectList.size();
53  ++index)
54  {
55  theWeights.push_back(1.0);
56  }
57  }
58 }
59
61  const ossimIrect& tileRect,
62  ossim_uint32 resLevel)
63 {
64  // ossimIpt origin = tileRect.ul();
65  if(!isSourceEnabled())
66  {
67  return ossimImageMosaic::getTile(tileRect, resLevel);
68  }
69
71  if(!theTile.get())
72  {
73  // try to initialize
74  initialize();
75
76  // if we still don't have a buffer
77  // then we will leave
78  if(!theTile.get())
79  {
80  return theTile;
81  }
82  }
83
84  if(size == 0)
85  {
87  }
88  if(size == 1)
89  {
90  return ossimImageMosaic::getTile(tileRect, resLevel);
91  }
92
93  theTile->setImageRectangle(tileRect);
94  theTile->makeBlank();
95  if(theNormResult.valid())
96  {
99  }
100
101  switch(theTile->getScalarType())
102  {
103  case OSSIM_UINT8:
104  {
105  if(!hasDifferentInputs())
106  {
107  return combine(static_cast<ossim_uint8>(0), tileRect, resLevel);
108  }
109  else
110  {
111  return combineNorm(static_cast<ossim_uint8>(0), tileRect,
112  resLevel);
113  }
114  }
115  case OSSIM_SINT8:
116  {
117  if(!hasDifferentInputs())
118  {
119  return combine(static_cast<ossim_sint8>(0), tileRect, resLevel);
120  }
121  else
122  {
123  return combineNorm(static_cast<ossim_sint8>(0), tileRect,
124  resLevel);
125  }
126  }
127  case OSSIM_FLOAT32:
129  {
130  if(!hasDifferentInputs())
131  {
132  return combine(static_cast<float>(0), tileRect, resLevel);
133  }
134  else
135  {
136  return combineNorm(static_cast<float>(0), tileRect, resLevel);
137  }
138  }
139  case OSSIM_UINT16:
140  case OSSIM_USHORT11:
141  case OSSIM_USHORT12:
142  case OSSIM_USHORT13:
143  case OSSIM_USHORT14:
144  case OSSIM_USHORT15:
145  {
146  if(!hasDifferentInputs())
147  {
148  return combine(static_cast<ossim_uint16>(0), tileRect, resLevel);
149  }
150  else
151  {
152  return combineNorm(static_cast<ossim_uint16>(0), tileRect,
153  resLevel);
154  }
155  }
156  case OSSIM_SINT16:
157  {
158  if(!hasDifferentInputs())
159  {
160  return combine(static_cast<ossim_sint16>(0), tileRect, resLevel);
161  }
162  else
163  {
164  return combineNorm(static_cast<ossim_sint16>(0), tileRect,
165  resLevel);
166  }
167  }
168  case OSSIM_SINT32:
169  {
170  if(!hasDifferentInputs())
171  {
172  return combine(static_cast<ossim_sint32>(0), tileRect, resLevel);
173  }
174  else
175  {
176  return combineNorm(static_cast<ossim_sint32>(0), tileRect,
177  resLevel);
178  }
179  }
180  case OSSIM_UINT32:
181  {
182  if(!hasDifferentInputs())
183  {
184  return combine(static_cast<ossim_uint32>(0), tileRect, resLevel);
185  }
186  else
187  {
188  return combineNorm(static_cast<ossim_uint32>(0), tileRect,
189  resLevel);
190  }
191  }
192  case OSSIM_FLOAT64:
194  {
195  if(!hasDifferentInputs())
196  {
197  return combine(static_cast<double>(0), tileRect, resLevel);
198  }
199  else
200  {
201  return combineNorm(static_cast<double>(0), tileRect, resLevel);
202  }
203  }
205  default:
206  {
208  << "ossimBlendMosaic::getTile NOTICE:\n"
209  << "Scalar type = " << theTile->getScalarType()
210  << " Not supported by ossimImageMosaic" << endl;
211  }
212  }
213
214  return ossimRefPtr<ossimImageData>();
215 }
216
218  T,
219  const ossimIrect& tileRect,
220  ossim_uint32 resLevel)
221 {
222  ossimRefPtr<ossimImageData> currentImageData=NULL;
223  ossim_uint32 band;
224  double currentWeight = 1.0;
225  double previousWeight = 1.0;
226  // double sumOfWeights = 1;
227  long offset = 0;
228  long row = 0;
229  long col = 0;
230  ossim_uint32 layerIdx = 0;
231  currentImageData = getNextTile(layerIdx, 0, tileRect, resLevel);
232
233  if(!currentImageData.get()) // if we don't have one then return theTile
234  {
235  return theTile;
236  }
237
238  T** srcBands = new T*[theLargestNumberOfInputBands];
239  T** destBands = new T*[theLargestNumberOfInputBands];
240  T* nullPix = new T[theTile->getNumberOfBands()];
241
242  previousWeight = theWeights[layerIdx];
243  // // now get the previous weight and then combine the two into one.
244  // let's assign the bands
245  for(band = 0; band < theLargestNumberOfInputBands; ++band)
246  {
247  destBands[band] = static_cast<T*>(theTile->getBuf(band));
248  nullPix[band] = static_cast<T>(theTile->getNullPix(band));
249  }
250  while(currentImageData.get())
251  {
252  ossimDataObjectStatus currentStatus =
253  currentImageData->getDataObjectStatus();
254
255  // set the current weight for the current tile.
256  currentWeight = theWeights[layerIdx];
257
258  // sumOfWeights = previousWeight+currentWeight;
259  if( (currentStatus != OSSIM_EMPTY) &&
260  (currentStatus != OSSIM_NULL))
261  {
262  long h = (long)currentImageData->getHeight();
263  long w = (long)currentImageData->getWidth();
264  offset = 0;
265  ossim_uint32 minNumberOfBands = currentImageData->getNumberOfBands();
266
267  // let's assign the bands
268  for(band = 0; band < minNumberOfBands; ++band)
269  {
270  srcBands[band] = static_cast<T*>(currentImageData->getBuf(band));
271  }
272  for(;band < theLargestNumberOfInputBands; ++band)
273  {
274  srcBands[band] = srcBands[minNumberOfBands - 1];
275  }
276
277  if(currentStatus == OSSIM_PARTIAL)
278  {
279  for(row = 0; row < h; ++row)
280  {
281  for(col = 0; col < w; ++col)
282  {
283  if(!currentImageData->isNull(offset))
284  {
285  for(band = 0; band < theLargestNumberOfInputBands; ++band)
286  {
287  if(destBands[band][offset] != nullPix[band])
288  {
289 // destBands[band][offset] = static_cast<T>((destBands[band][offset]*(1.0-currentWeight) +
290 // srcBands[band][offset]*currentWeight));
291  destBands[band][offset] = static_cast<T>((destBands[band][offset]*previousWeight +
292  srcBands[band][offset]*currentWeight)/(previousWeight+currentWeight));
293  }
294  else
295  {
296  destBands[band][offset] = srcBands[band][offset];
297  }
298  }
299  }
300  ++offset;
301  }
302  }
303  }
304  else
305  {
306  for(row = 0; row < h; ++row)
307  {
308  for(col = 0; col < w; ++col)
309  {
310  for(band = 0; band < theLargestNumberOfInputBands; ++band)
311  {
312  if(destBands[band][offset] != nullPix[band])
313  {
314  destBands[band][offset] = static_cast<T>((destBands[band][offset]*previousWeight+
315  srcBands[band][offset]*currentWeight)/(previousWeight + currentWeight));
316  }
317  else
318  {
319  destBands[band][offset] = srcBands[band][offset];
320  }
321  }
322  ++offset;
323  }
324  }
325  }
326  }
327  currentImageData = getNextTile(layerIdx, tileRect, resLevel);
328  previousWeight = (previousWeight+currentWeight)/2.0;
329  }
330  delete [] srcBands;
331  delete [] destBands;
332  delete [] nullPix;
333  theTile->validate();
334
335  return theTile;
336 }
337
339  T, const ossimIrect& tileRect, ossim_uint32 resLevel)
340 {
341  ossimRefPtr<ossimImageData> currentImageData=NULL;
342  ossim_uint32 band;
343  double currentWeight = 1.0;
344  double previousWeight = 1.0;
345  // double sumOfWeights = 1;
346  long offset = 0;
347  long row = 0;
348  long col = 0;
349  ossim_uint32 layerIdx = 0;
350  currentImageData = getNextNormTile(layerIdx, 0, tileRect, resLevel);
351
352  if(!currentImageData.get()) // if we don't have one then return theTile
353  {
354  return theTile;
355  }
357  float** srcBands = new float*[theLargestNumberOfInputBands];
358  float** destBands = new float*[theLargestNumberOfInputBands];
359  float* nullPix = new float[theTile->getNumberOfBands()];
360
361  previousWeight = theWeights[layerIdx];
362  // // now get the previous weight and then combine the two into one.
363  // let's assign the bands
364  for(band = 0; band < theLargestNumberOfInputBands; ++band)
365  {
366  destBands[band] = static_cast<float*>(theNormResult->getBuf(band));
367  nullPix[band] = static_cast<float>(theNormResult->getNullPix(band));
368  }
369  while(currentImageData.get())
370  {
371  ossimDataObjectStatus currentStatus = currentImageData->getDataObjectStatus();
372
373  // set the current weight for the current tile.
374  currentWeight = theWeights[layerIdx];
375
376  // sumOfWeights = previousWeight+currentWeight;
377  if( (currentStatus != OSSIM_EMPTY) &&
378  (currentStatus != OSSIM_NULL))
379  {
380  long h = (long)currentImageData->getHeight();
381  long w = (long)currentImageData->getWidth();
382  offset = 0;
383  ossim_uint32 minNumberOfBands = currentImageData->getNumberOfBands();
384
385  // let's assign the bands
386  for(band = 0; band < minNumberOfBands; ++band)
387  {
388  srcBands[band] = static_cast<float*>(currentImageData->getBuf(band));
389  }
390  for(;band < theLargestNumberOfInputBands; ++band)
391  {
392  srcBands[band] = srcBands[minNumberOfBands - 1];
393  }
394
395  if(currentStatus == OSSIM_PARTIAL)
396  {
397  for(row = 0; row < h; ++row)
398  {
399  for(col = 0; col < w; ++col)
400  {
401  if(!currentImageData->isNull(offset))
402  {
403  for(band = 0; band < theLargestNumberOfInputBands; ++band)
404  {
405  if(destBands[band][offset] != nullPix[band])
406  {
407  destBands[band][offset] = static_cast<float>((destBands[band][offset]*previousWeight +
408  srcBands[band][offset]*currentWeight)/(previousWeight+currentWeight));
409  }
410  else
411  {
412  destBands[band][offset] = srcBands[band][offset];
413  }
414  }
415  }
416  ++offset;
417  }
418  }
419  }
420  else
421  {
422  for(row = 0; row < h; ++row)
423  {
424  for(col = 0; col < w; ++col)
425  {
426  for(band = 0; band < theLargestNumberOfInputBands; ++band)
427  {
428  if(destBands[band][offset] != nullPix[band])
429  {
430  destBands[band][offset] = static_cast<float>((destBands[band][offset]*previousWeight+
431  srcBands[band][offset]*currentWeight)/(previousWeight + currentWeight));
432  }
433  else
434  {
435  destBands[band][offset] = srcBands[band][offset];
436  }
437  }
438  ++offset;
439  }
440  }
441  }
442  }
443  currentImageData = getNextNormTile(layerIdx, tileRect, resLevel);
444  previousWeight = (previousWeight+currentWeight)/2.0;
445  }
448  delete [] srcBands;
449  delete [] destBands;
450  delete [] nullPix;
451  theTile->validate();
452
453  return theTile;
454 }
455
457  const char* prefix)const
458 {
459  bool result = ossimImageMosaic::saveState(kwl, prefix);
460
461  ossimString copyPrefix = prefix;
462  for(ossim_uint32 index = 0; index < theWeights.size(); ++index)
463  {
464  ossimString weightStr = ossimString("weight") +
465  ossimString::toString(index);
466  kwl.add(copyPrefix.c_str(),
467  weightStr.c_str(),
468  theWeights[index],
469  true);
470  }
471
472  return result;
473 }
474
476  const char* prefix)
477 {
478  bool result = ossimImageMosaic::loadState(kwl, prefix);
479  ossim_uint32 count = 0;
480  theWeights.clear();
481  if(result)
482  {
483  ossimString copyPrefix = prefix;
484  ossimString regExpression = ossimString("^(") + copyPrefix + "weight[0-9]+)";
485  ossim_uint32 result = kwl.getNumberOfSubstringKeys(regExpression);
486
487  ossim_uint32 numberOfMatches = 0;
488  while(numberOfMatches < result)
489  {
490  ossimString value = ossimString("weight") + ossimString::toString(count);
491
492  const char* lookup = kwl.find(copyPrefix.c_str(),
493  value.c_str());
494
495  if(lookup)
496  {
497  ++numberOfMatches;
498  theWeights.push_back(ossimString(lookup).toDouble());
499  }
500
501  ++count;
502  }
503  }
504
505  return result;
506 }
507
508
510 {
511  if(numberOfWeights > theWeights.size())
512  {
513  ossim_uint32 length = numberOfWeights - (ossim_uint32) theWeights.size();
514  for(ossim_uint32 index= 0; index < length; ++ index)
515  {
516  theWeights.push_back(1.0);
517  }
518  }
519  else if(numberOfWeights < theWeights.size())
520  {
521  // copy the list
522  vector<double> temp(theWeights.begin(),
523  theWeights.begin()+numberOfWeights);
524  // now shrink
525  theWeights = temp;
526  }
527 }
528
530 {
531  for(ossim_uint32 index = 0; index < theWeights.size(); ++index)
532  {
533  theWeights[index] = value;
534  }
535 }
536
538 {
539  double sumWeights=0.0;
540  ossim_uint32 index = 0;
541  for(index = 0; index < theWeights.size(); ++index)
542  {
543  sumWeights+=theWeights[index];
544  }
545  if(sumWeights > 0.0)
546  {
547  for(index = 0; index < theWeights.size(); ++index)
548  {
549  theWeights[index] /= sumWeights;
550  }
551  }
552 }
553
554 void ossimBlendMosaic::findMinMax(double& minValue, double& maxValue)const
555 {
556  if(theWeights.size() > 0)
557  {
558  minValue = maxValue = theWeights[0];
559
560  for(ossim_uint32 index = 1; index < theWeights.size(); ++index)
561  {
562  minValue = minValue < theWeights[index]?minValue:theWeights[index];
563  maxValue = maxValue > theWeights[index]?maxValue:theWeights[index];
564  }
565  }
566 }
567
568 void ossimBlendMosaic::setWeight(ossim_uint32 index, double weight)
569 {
570  if(index < theWeights.size())
571  {
572  theWeights[index] = weight;
573  }
574 }
575
576 void ossimBlendMosaic::setWeights(const std::vector<double>& weights)
577 {
578  theWeights = weights;
579 }
580
581 const vector<double>& ossimBlendMosaic::getWeights()const
582 {
583  return theWeights;
584 }
585
587 {
588  if(index < theWeights.size())
589  {
590  return theWeights[index];
591  }
592  if(theWeights.size())
593  {
594  return theWeights[theWeights.size()-1];
595  }
596  return 0;
597 }
8 bit signed integer
virtual void initialize()
ossimRefPtr< ossimImageData > theNormResult
double getWeight(ossim_uint32 index) const
ossim_uint32 getNumberOfSubstringKeys(const ossimString &regularExpression) const
64 bit floating point
16 bit unsigned integer
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageData > getNextNormTile(ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
ossimRefPtr< ossimImageData > combineNorm(T, const ossimIrect &tileRect, ossim_uint32)
Numeric to string methods.
16 bit signed integer
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
32 bit floating point
void findMinMax(double &minValue, double &maxValue) const
An image mosaic is a simple combiner that will just do a simple mosaic.
32 bit unsigned integer
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
Initialize the data buffer.
void setAllWeightsTo(double value)
bool isNull(ossim_uint32 offset) const
void allocate()
Called on first getTile, will initialize all data needed.
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
ossim_uint32 theLargestNumberOfInputBands
yy_size_t size
vector< double > theWeights
32 bit signed integer
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual void copyNormalizedBufferToTile(ossim_float64 *buf)
Copies buf passed in to tile.
virtual bool hasDifferentInputs() const
void setWeight(ossim_uint32 index, double weight)
virtual void makeBlank()
ConnectableObjectList theInputObjectList
Holds a list of input objects.
void normalizeWeights()
Will find the min and max values and then normalize all weights to be from 0 to 1.
ossimRefPtr< ossimImageData > combine(T, const ossimIrect &tileRect, ossim_uint32)
If our inputs have output of different scalar types then we must normalize so we can blend different ...
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
const char * c_str() const
Definition: ossimString.h:396
void setNumberOfWeights(ossim_uint32 numberOfWeights)
8 bit unsigned integer
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
Definitions for data object status.
void setWeights(const std::vector< double > &weights)
virtual ~ossimBlendMosaic()
const std::vector< double > & getWeights() const
