22 #ifndef ossimCcfTileSource_HEADER 23 #define ossimCcfTileSource_HEADER 116 const char* prefix=0)
const;
123 const char* prefix=0);
156 virtual bool isOpen()
const;
170 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
176 void initVerticesFromHeader();
194 bool fillUshortBuffer(
const ossimIrect& tile_rect,
203 bool fillUcharBuffer(
212 void adjustToStartOfChunk(
ossimIpt& pt)
const;
217 void adjustToStartOfChip(
ossimIpt& pt)
const;
virtual bool open()=0
Pure virtual open.
vector< ossim_uint32 > theOutputBandList
std::basic_ifstream< char > ifstream
Class for char input file streams.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
const ossimImageSource & operator=(const ossimImageSource &)
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
virtual void close()
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossim_uint32 getImageTileWidth() const =0
ossim_uint8 * theChipBuffer
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
unsigned char ossim_uint8
