#include <ossimCcfTileSource.h>
ossimCcfTileSource () | |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual bool | open () |
virtual void | close () |
Deletes the overview and clears the valid image vertices. More... | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossim_uint32 | getNumberOfInputBands () const |
Returns the number of bands in the image. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossim_uint32 | getNumberOfLines (ossim_uint32 reduced_res_level=0) const |
Returns the number of lines in the image. More... | |
virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 reduced_res_level=0) const |
Returns the number of samples in the image. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Returns the number of reduced resolution data sets (rrds). More... | |
virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
bool | setOutputBandList (const vector< ossim_uint32 > &outputBandList) |
Set the output band list. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual ossimScalarType | getOutputScalarType () const |
Returns the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the width of the output tile. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the height of the output tile. More... | |
virtual ossim_uint32 | getImageTileWidth () const |
Returns the tile width of the image or 0 if the image is not tiled. More... | |
virtual ossim_uint32 | getImageTileHeight () const |
virtual bool | isOpen () const |
Derived classes must implement this method to be concrete. More... | |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
Gets a property for matching name. More... | |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
Gets a list of property names available. More... | |
ossimImageHandler () | |
Constructor (default): More... | |
virtual | ~ossimImageHandler () |
Destructor: Derived classes should implement. More... | |
virtual void | initialize () |
initialize Does nothing in this class. More... | |
virtual bool | openOverview () |
Searches for an overview. More... | |
virtual bool | openOverview (const ossimFilename &overview_file) |
Calls closeOverview(), then attempts to open the overview_file. More... | |
virtual void | closeOverview () |
If theOverview is initialized it will be deleted and set to NULL. More... | |
virtual const ossimImageHandler * | getOverview () const |
virtual bool | hasOverviews () const |
virtual ossimFilename | createDefaultOverviewFilename () const |
virtual ossimFilename | createDefaultGeometryFilename () const |
virtual ossimFilename | createDefaultMetadataFilename () const |
virtual ossimFilename | createDefaultHistogramFilename () const |
virtual ossimFilename | createDefaultValidVerticesFilename () const |
virtual bool | writeValidImageVertices (const std::vector< ossimIpt > &vertices, const ossimFilename &file=ossimFilename("")) |
Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices". More... | |
virtual bool | openValidVertices (const ossimFilename &vertices_file) |
Opens the valid image vertices file and sets theValidImageVerticesFile variable. More... | |
virtual bool | openValidVertices () |
Creates vertices file name based on image, then tries to open. More... | |
virtual bool | open (const ossimFilename &imageFile, ossim_uint32 entryIndex) |
Opens the image file. More... | |
virtual bool | open (const ossimFilename &imageFile) |
virtual bool | open (std::shared_ptr< ossim::ImageHandlerState > state) |
virtual bool | buildHistogram (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histogram for image file. More... | |
virtual bool | buildAllHistograms (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histograms for all image entries. More... | |
virtual bool | buildOverview (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for theImageFile. More... | |
virtual bool | buildAllOverviews (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for all image entries. More... | |
virtual bool | buildOverview (const ossimFilename &filename, ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build an over file for filename. More... | |
ossimRefPtr< ossimMultiResLevelHistogram > | getImageHistogram () const |
Fetches the current entry image's histogram. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if non defined. More... | |
virtual void | setImageGeometry (ossimImageGeometry *geom) |
Sets the image geometry object. More... | |
virtual void | saveImageGeometry () const |
Saves the image geometry to a file that will be made based on the image file name. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
Returns zero-based bounding rectangle of the image. More... | |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
This returns all decimation for all levels. More... | |
virtual ossim_uint32 | getNumberOfReducedResSets () const |
This method is obsolete. More... | |
virtual void | setFilename (const ossimFilename &filename) |
Sets the filename. More... | |
virtual const ossimFilename & | getFilename () const |
Returns the filename. More... | |
virtual bool | isValidRLevel (ossim_uint32 resLevel) const |
Determines if the passed in reslution level is valid. More... | |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
Connection rule. More... | |
virtual void | getValidImageVertices (vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual bool | isBandSelector () const |
Indicates whether or not the image handler can control output band selection via the setOutputBandList method. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &band_list) |
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled. More... | |
virtual bool | setOutputToInputBandList () |
If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity. More... | |
virtual bool | isIdentityBandList (const std::vector< ossim_uint32 > &bandList) const |
Convenience method to see if band list is identity. More... | |
virtual bool | isImageTiled () const |
Indicates whether or not the image is tiled internally. More... | |
virtual bool | hasMetaData () const |
virtual ossimRefPtr< ossimNBandLutDataObject > | getLut () const |
virtual bool | hasLut () const |
virtual void | loadMetaData () |
There is an external file with an omd extension. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Retuns the min pixel value. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual void | setMinPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set min pixel value. More... | |
virtual void | setMaxPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set max pixel value. More... | |
virtual void | setNullPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set null pixel value. More... | |
virtual ossim_uint32 | getCurrentEntry () const |
virtual ossim_uint32 | getNumberOfEntries () const |
virtual void | getEntryName (ossim_uint32 entryIdx, std::string &name) const |
Get the name of entry as a string. More... | |
virtual void | getEntryList (std::vector< ossim_uint32 > &entryList) const |
virtual void | getEntryNames (std::vector< ossimString > &entryNames) const |
bool | useEntryIndex () const |
Convenience method to determine if entry index should be used for support files, e.g. More... | |
ossimFilename | getOverviewFile () const |
virtual bool | setCurrentEntry (ossim_uint32 entryIdx) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
ossimFilename | getFilenameWithThisExtension (const ossimString &ext, bool set_e0_prefix=false) const |
Returns the image file with extension set using supplentary directory for dirname if set. More... | |
void | getFilenameWithThisExt (const ossimString &ext, ossimFilename &f) const |
ossim_uint32 | getStartingResLevel () const |
void | setStartingResLevel (ossim_uint32 level) |
bool | getOpenOverviewFlag () const |
void | setOpenOverviewFlag (bool flag) |
Sets theOpenOverviewFlag. More... | |
virtual void | setSupplementaryDirectory (const ossimFilename &dir) |
Sets the supplementary directory. More... | |
virtual const ossimFilename & | getSupplementaryDirectory () const |
Returns the supplementary directory. More... | |
const ossimString & | getImageID () const |
Fetches the image ID. More... | |
void | setImageID (const ossimString &id) |
Sets the image ID in case it is externally generated. More... | |
ossimPixelType | getPixelType () const |
Returns the raster pixel alignment type. More... | |
virtual bool | getRgbBandList (std::vector< ossim_uint32 > &bandList) const |
Convenience method to get the zero based rgb output band list. More... | |
template<class T > | |
std::shared_ptr< T > | getStateAs () |
std::shared_ptr< const T > | getStateAs () const |
std::shared_ptr< ossim::ImageHandlerState > | getState () |
std::shared_ptr< const ossim::ImageHandlerState > | getState () const |
void | setState (std::shared_ptr< ossim::ImageHandlerState > state) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
virtual | ~ossimCcfTileSource () |
void | initVerticesFromHeader () |
ossimCcfTileSource (const ossimCcfTileSource &source) | |
ossimCcfTileSource & | operator= (const ossimCcfTileSource &source) |
bool | fillBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, const ossimIrect &image_rect, ossim_uint32 reduced_res_level, ossimImageData *tile) |
Returns true on success, false on error. More... | |
bool | fillUshortBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, const ossimIrect &image_rect, ossim_uint32 reduced_res_level, ossimImageData *tile) |
bool | fillUcharBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, const ossimIrect &image_rect, ossim_uint32 reduced_res_level, ossimImageData *tile) |
void | adjustToStartOfChunk (ossimIpt &pt) const |
Adjust point to even 256 boundary. More... | |
void | adjustToStartOfChip (ossimIpt &pt) const |
Adjust point to even 32 boundary. More... | |
bool | isEcgGeom (const ossimFilename &filename) const |
virtual ossimRefPtr< ossimImageGeometry > | getExternalImageGeometry () const |
virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () const |
virtual bool | getOverviewTile (ossim_uint32 resLevel, ossimImageData *result) |
Method to get an overview tile. More... | |
bool | initVertices (const char *file) |
Opens file and attempts to initialize the valid image vertices. More... | |
virtual void | completeOpen () |
Will complete the opening process. More... | |
void | initImageParameters (ossimImageGeometry *geom) const |
Convenience method to set things needed in the image geometry from the image handler. More... | |
virtual void | establishDecimationFactors () |
Virtual method determines the decimation factors at each resolution level. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &inBandList, std::vector< ossim_uint32 > &outBandList) |
Convenience method to set output band list. More... | |
void | getFilenameWithNoExtension (ossimFilename &f) const |
Get filename with no extension, using supplentary directory for dirname if set. More... | |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimImageHandlerOverviewCompressionType { OSSIM_OVERVIEW_COMPRESSION_NONE = 0, OSSIM_OVERVIEW_COMPRESSION_JPEG, OSSIM_OVERVIEW_COMPRESSION_LZW, OSSIM_OVERVIEW_COMPRESSION_DEFLATE, OSSIM_OVERVIEW_COMPRESSION_PACKBITS } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
Definition at line 32 of file ossimCcfTileSource.h.
ossimCcfTileSource::ossimCcfTileSource | ( | ) |
Definition at line 46 of file ossimCcfTileSource.cpp.
protectedvirtual |
Definition at line 57 of file ossimCcfTileSource.cpp.
References close().
protected |
protected |
Assumes 0,0 origin.
Definition at line 901 of file ossimCcfTileSource.cpp.
References ossimIpt::x, and ossimIpt::y.
protected |
Assumes 0,0 origin.
Definition at line 895 of file ossimCcfTileSource.cpp.
Referenced by fillUcharBuffer(), and fillUshortBuffer().
Definition at line 739 of file ossimCcfTileSource.cpp.
References theChipBuffer, theFileStr, and theTile.
Referenced by ~ossimCcfTileSource().
protected |
Definition at line 146 of file ossimCcfTileSource.cpp.
References fillUcharBuffer(), fillUshortBuffer(), ossimErrorCodes::OSSIM_ERROR, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimCcfHead::pixelType(), status, theCcfHead, and ossimErrorStatusInterface::theErrorStatus.
Referenced by getTile().
protected |
Definition at line 193 of file ossimCcfTileSource.cpp.
References adjustToStartOfChunk(), ossimCcfHead::bytesPerChip(), ossimCcfHead::bytesPerChunk(), ossimCcfHead::chipSizePerBand(), ossimCcfHead::chunksInSampleDir(), ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getSizePerBand(), ossimImageData::getWidth(), ossimIrect::intersects(), isOpen(), ossimCcfHead::lineChipsPerChunk(), ossimCcfHead::linesPerChip(), ossimIrect::lr(), ossimCcfHead::numberOfBands(), ossimErrorCodes::OSSIM_ERROR, ossimCcfHead::sampleChipsPerChunk(), ossimCcfHead::samplesPerChip(), ossimCcfHead::startOfData(), theCcfHead, theChipBuffer, ossimErrorStatusInterface::theErrorStatus, theFileStr, ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by fillBuffer().
protected |
Definition at line 384 of file ossimCcfTileSource.cpp.
References adjustToStartOfChunk(), ossimCcfHead::bytesPerChip(), ossimCcfHead::bytesPerChunk(), ossimCcfHead::chipSizePerBand(), ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getSizePerBand(), ossimImageData::getWidth(), ossimIrect::intersects(), ossimCcfHead::lineChipsPerChunk(), ossimCcfHead::linesPerChip(), ossimIrect::lr(), ossimCcfHead::numberOfBands(), ossimErrorCodes::OSSIM_ERROR, OSSIM_LITTLE_ENDIAN, ossimCcfHead::sampleChipsPerChunk(), ossimCcfHead::samplesPerChip(), ossimCcfHead::startOfData(), theByteOrder, theCcfHead, theChipBuffer, ossimErrorStatusInterface::theErrorStatus, theFileStr, ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Note that rrds 0 is the highest resolution rrds.
Definition at line 585 of file ossimCcfTileSource.cpp.
References ossimCcfHead::imageRect(), and theCcfHead.
Implements ossimImageHandler.
Definition at line 785 of file ossimCcfTileSource.cpp.
Definition at line 780 of file ossimCcfTileSource.cpp.
Definition at line 844 of file ossimCcfTileSource.cpp.
Note: The full res image is counted as a data set so an image with no reduced resolution data set will have a count of one.
Definition at line 869 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfReducedResSets(), and theCcfHead.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 849 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfBands(), and theCcfHead.
Referenced by getNumberOfOutputBands().
Definition at line 859 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfLines(), and theCcfHead.
Definition at line 854 of file ossimCcfTileSource.cpp.
References getNumberOfInputBands().
Definition at line 864 of file ossimCcfTileSource.cpp.
References ossimCcfHead::numberOfSamples(), and theCcfHead.
Definition at line 759 of file ossimCcfTileSource.cpp.
References ossimCcfHead::pixelType(), and theCcfHead.
name | The name of the property to get. |
Definition at line 879 of file ossimCcfTileSource.cpp.
References ossimImageHandler::getProperty().
propertyNames | The list to push back names to. |
Definition at line 889 of file ossimCcfTileSource.cpp.
References ossimImageHandler::getPropertyNames().
Definition at line 839 of file ossimCcfTileSource.cpp.
Definition at line 62 of file ossimCcfTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 82 of file ossimCcfTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillBuffer(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimCcfHead::imageRect(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), ossimReferenced::ref(), status, theCcfHead, ossimReferenced::unref(), and ossimImageData::validate().
Definition at line 775 of file ossimCcfTileSource.cpp.
References ossimImageData::getHeight(), theTile, and ossimRefPtr< T >::valid().
Definition at line 767 of file ossimCcfTileSource.cpp.
References ossimImageData::getWidth(), theTile, and ossimRefPtr< T >::valid().
protected |
Definition at line 790 of file ossimCcfTileSource.cpp.
References ossimCcfHead::getValidImageVertices(), theCcfHead, and ossimImageHandler::theValidImageVertices.
protected |
Definition at line 817 of file ossimCcfTileSource.cpp.
References ossimString::c_str(), ossimString::downcase(), ossimFilename::exists(), and ossimFilename::setExtension().
Definition at line 874 of file ossimCcfTileSource.cpp.
References theFileStr.
Referenced by fillUcharBuffer(), and getTile().
Definition at line 645 of file ossimCcfTileSource.cpp.
References ossimImageHandler::loadState(), and open().
Definition at line 662 of file ossimCcfTileSource.cpp.
Referenced by loadState().
protected |
Definition at line 635 of file ossimCcfTileSource.cpp.
References ossimImageHandler::saveState().
bool ossimCcfTileSource::setOutputBandList | ( | const vector< ossim_uint32 > & | outputBandList | ) |
Use to set the number and order of output bands. Will set an error if out of range.
Definition at line 593 of file ossimCcfTileSource.cpp.
protected |
Definition at line 226 of file ossimCcfTileSource.h.
Referenced by fillUshortBuffer().
protected |
Definition at line 221 of file ossimCcfTileSource.h.
Referenced by fillBuffer(), fillUcharBuffer(), fillUshortBuffer(), getImageRectangle(), getNumberOfDecimationLevels(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), and initVerticesFromHeader().
protected |
Definition at line 223 of file ossimCcfTileSource.h.
Referenced by close(), fillUcharBuffer(), and fillUshortBuffer().
protected |
Definition at line 224 of file ossimCcfTileSource.h.
Referenced by close(), fillUcharBuffer(), fillUshortBuffer(), and isOpen().
protected |
Definition at line 225 of file ossimCcfTileSource.h.
protected |
Definition at line 222 of file ossimCcfTileSource.h.
Referenced by close(), getTile(), getTileHeight(), and getTileWidth().
