18 #ifndef ossimDtedTileSource_HEADER 19 #define ossimDtedTileSource_HEADER 42 DATA_RECORD_OFFSET_TO_POST = 8,
43 DATA_RECORD_CHECKSUM_SIZE = 4,
112 const char* prefix=0)
const;
119 const char* prefix=0);
156 virtual bool isOpen()
const;
164 void getPostSpacing(
ossimDpt& postSpacing)
const;
178 std::vector<ossimString>& propertyNames)
const;
214 void gatherStatistics(
bool writeStatsFile);
257 return (static_cast<ossim_sint16>(s & 0x7fff) * -1);
virtual bool open()=0
Pure virtual open.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
const ossimImageSource & operator=(const ossimImageSource &)
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
bool theSwapBytesFlag
DTED data is always stored as BIG_ENDIAN.
ossim_uint32 theTileWidth
unsigned short ossim_uint16
ossim_uint32 theDataRecordSize
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual bool isOpen() const =0
Retuns the min pixel value.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
signed short ossim_sint16
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
ossim_sint16 theMaxHeight
virtual ossimString getLongName() const
virtual void close()
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
ossim_uint32 theNumberOfSamps
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual void loadMetaData()
There is an external file with an omd extension.
ossim_uint32 theOffsetToFirstDataRecord
std::shared_ptr< ossimDtedInfo > m_dtedInfo
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_sint16 theMinHeight
virtual ossim_uint32 getNumberOfInputBands() const =0
ossim_uint32 theTileHeight
std::shared_ptr< ossim::istream > m_fileStr
ossim_sint16 convertSignedMagnitude(ossim_uint16 &s) const
ossim_uint32 theNumberOfLines
