Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimDtedTileSource Class Reference
#include <ossimDtedTileSource.h>
Inheritance diagram for ossimDtedTileSource:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Types
enum  { DATA_RECORD_OFFSET_TO_POST = 8, DATA_RECORD_CHECKSUM_SIZE = 4, POST_SIZE = 2, NULL_PIXEL = -32767 }
 ossimDtedTileSource ()
virtual bool open ()
 Returns true if "theImageFile" can be opened and is a valid adrg file. More...
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
 Method to get a tile. More...
 Returns the number of bands in the image. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
 Returns the number of samples in the image. More...
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
 Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More...
 Returns the output pixel type of the tile source. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
virtual bool isOpen () const
void getPostSpacing (ossimDpt &postSpacing) const
 Initializes spacing to the post spacing of the cell. More...
 Gets a property for name. More...
 Adds this class's properties to list. More...
virtual void loadMetaData ()
 Sets the min/max. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual ~ossimDtedTileSource ()
const ossimDtedTileSourceoperator= (const ossimDtedTileSource &rhs)
 ossimDtedTileSource (const ossimDtedTileSource &)
void allocate ()
 Allocated the tiles. More...
bool fillBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile)
 Returns true on success, false on error. More...
void gatherStatistics (bool writeStatsFile)
 Scans for min and max. More...
ossim_sint16 convertSignedMagnitude (ossim_uint16 &s) const
virtual void completeOpen ()
virtual ~ossimReferenced ()
std::shared_ptr< ossim::istreamm_fileStr
std::shared_ptr< ossimDtedInfom_dtedInfo
ossim_uint32 theTileWidth
ossim_uint32 theTileHeight
ossim_uint32 theNumberOfLines
ossim_uint32 theNumberOfSamps
ossim_uint32 theOffsetToFirstDataRecord
ossim_uint32 theDataRecordSize
ossim_sint16 theMinHeight
ossim_sint16 theMaxHeight
ossimDpt thePostSpacing
ossimDtedVol m_vol
ossimDtedHdr m_hdr
ossimDtedUhl m_uhl
ossimDtedDsi m_dsi
ossimDtedAcc m_acc
bool theSwapBytesFlag
 DTED data is always stored as BIG_ENDIAN. More...
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 34 of file ossimDtedTileSource.h.
◆ anonymous enum
anonymous enum
Enumerator
POST_SIZE
NULL_PIXEL
Definition at line 40 of file ossimDtedTileSource.h.
◆ ossimDtedTileSource() [1/2]
ossimDtedTileSource::ossimDtedTileSource ( )
Definition at line 40 of file ossimDtedTileSource.cpp.
References ossim::byteOrder(), ossim::defaultTileSize(), OSSIM_LITTLE_ENDIAN, theSwapBytesFlag, theTileHeight, and theTileWidth.
41  :
43  theTile(0),
44  m_fileStr(0),
45  m_dtedInfo(0),
46  theTileWidth(0),
47  theTileHeight(0),
52  theMinHeight(0),
53  theMaxHeight(0),
54  thePostSpacing(0.0, 0.0),
55  theSwapBytesFlag(false)
56 {
58  {
59  theSwapBytesFlag = true;
60  }
61
62  // Set the tile size to the default.
65  theTileWidth = static_cast<ossim_uint32>(defaultTileSize.x);
66  theTileHeight = static_cast<ossim_uint32>(defaultTileSize.y);
67
68  // Construction not complete. Users should call "open" method.
69 }
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
unsigned int ossim_uint32
ossimImageHandler()
Constructor (default):
std::shared_ptr< ossimDtedInfo > m_dtedInfo
std::shared_ptr< ossim::istream > m_fileStr
◆ ~ossimDtedTileSource()
ossimDtedTileSource::~ossimDtedTileSource ( )
protectedvirtual
Definition at line 71 of file ossimDtedTileSource.cpp.
References close().
72 {
73  close();
74 }
virtual void close()
◆ ossimDtedTileSource() [2/2]
ossimDtedTileSource::ossimDtedTileSource ( const ossimDtedTileSource )
protected
Definition at line 686 of file ossimDtedTileSource.cpp.
687 {
688 }
Member Function Documentation
◆ allocate()
void ossimDtedTileSource::allocate ( )
protected
Definition at line 356 of file ossimDtedTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
357 {
358  //---
359  // Set up the tiles. Note the blank tile will not get initialized to save
360  // memory. This includes setting the min and max pixel value gathered
361  // from the statistics.
362  //---
364  if(theTile.valid())
365  {
366  theTile->initialize();
367  }
368
369  if (traceDebug())
370  {
372  << "DEBUG:"
373  << "\ntheTile:\n" << *theTile << "\n";
374  }
375 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual void initialize()
Initialize the data buffer.
◆ close()
void ossimDtedTileSource::close ( )
virtual
Definition at line 242 of file ossimDtedTileSource.cpp.
References m_fileStr.
Referenced by ~ossimDtedTileSource().
243 {
244  m_fileStr.reset();
245 }
◆ convertSignedMagnitude()
ossim_sint16 ossimDtedTileSource::convertSignedMagnitude ( ossim_uint16 s) const
inlineprotected
Definition at line 246 of file ossimDtedTileSource.h.
References theSwapBytesFlag.
Referenced by fillBuffer().
247 {
248  // DATA_VALUE_MASK 0x7fff = 0111 1111 1111 1111
249  // DATA_SIGN_MASK 0x8000 = 1000 0000 0000 0000
250
251  // First check to see if the bytes need swapped.
252  s = (theSwapBytesFlag ? ( ((s&0x00ff) << 8) | ((s&0xff00) >> 8) ) : s);
253
254  // If the sign bit is set, mask it out then multiply by negative one.
255  if (s & 0x8000)
256  {
257  return (static_cast<ossim_sint16>(s & 0x7fff) * -1);
258  }
259
260  return static_cast<ossim_sint16>(s);
261 }
signed short ossim_sint16
◆ fillBuffer()
bool ossimDtedTileSource::fillBuffer ( const ossimIrect tile_rect,
const ossimIrect clip_rect,
ossimImageData tile
protected
Definition at line 167 of file ossimDtedTileSource.cpp.
References convertSignedMagnitude(), DATA_RECORD_OFFSET_TO_POST, ossimImageData::getBuf(), ossimImageData::getWidth(), ossimIrect::lr(), m_fileStr, POST_SIZE, theDataRecordSize, theNumberOfLines, theOffsetToFirstDataRecord, ossimIrect::ul(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
170 {
171  //***
172  // NOTE:
173  // Elevation posts are organized positive line up.
174  // The "tile_rect" and "clip_rect" is organized positive line down.
175  //***
176
177  const ossim_int32 TILE_WIDTH = tile->getWidth();
178
179  //***
180  // Position the file pointer to the first record needed.
181  // Posts are organized positive line up so we're going to start at
182  // the lower left side of the cell so all reads are going forward in
183  // the file.
184  //***
185  ossim_int32 seek_position = theOffsetToFirstDataRecord +
186  (clip_rect.ul().x * theDataRecordSize);
187  seek_position += DATA_RECORD_OFFSET_TO_POST +
188  (theNumberOfLines - 1 - clip_rect.lr().y) * 2;
189
190  //***
191  // Get a pointer positioned at the first valid pixel in
192  // the tile. Tiles are organized positive line down.
193  //***
194  ossim_sint16* d = static_cast<ossim_sint16*>(tile->getBuf());
195
196  // Loop in the longitude or sample direction.
197  for (ossim_int32 samp = clip_rect.ul().x; samp <= clip_rect.lr().x; samp++)
198  {
199  ossim_int32 d_offset = (clip_rect.lr().y - tile_rect.ul().y) *
200  TILE_WIDTH +
201  (samp - tile_rect.ul().x);
202
203  m_fileStr->seekg(seek_position, ios::beg); // Seek to the first post.
204
205  for (ossim_int32 line = clip_rect.lr().y; line >= clip_rect.ul().y; line--)
206  {
207  // Grab all the post needed from the column.
208  ossim_uint16 temp;
209  ossim_sint16 s;
210  m_fileStr->read((char*)&temp, POST_SIZE);
211  s = convertSignedMagnitude(temp);
212  d[d_offset] = s;
213  d_offset -= TILE_WIDTH;
214  }
215  seek_position += theDataRecordSize;
216  }
217
218  tile->validate();
219
220  return true;
221 }
const ossimIpt & ul() const
Definition: ossimIrect.h:274
unsigned short ossim_uint16
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
ossim_sint16 convertSignedMagnitude(ossim_uint16 &s) const
int ossim_int32
◆ gatherStatistics()
void ossimDtedTileSource::gatherStatistics ( bool  writeStatsFile)
protected
Parameters
writeStatsFileIf true and statistics file does not exists it will write one; else, no file will be written.
Definition at line 536 of file ossimDtedTileSource.cpp.
Referenced by loadMetaData().
537 {
538  // Scan the cell and gather the statistics...
539  if ( traceDebug() )
540  {
542  << "ossimDtedTileSource::gatherStatistics() scanning for min/max"
543  << "\nThis may take a while...\n";
544  }
545
546  // Start off with the min and max pegged.
547  theMinHeight = 32767;
548  theMaxHeight = -32767;
549
550  // Put the file pointer at the start of the first elevation post.
551  m_fileStr->seekg(theOffsetToFirstDataRecord, ios::beg);
552
553  //---
554  // Loop through all records and scan for lowest min and highest max.
555  // Each record contains a row of latitude points for a given longitude.
556  // There are eight bytes in front of the post and four checksum bytes at
557  // the end so ignore them.
558  //---
559  for (ossim_uint32 i=0; i<theNumberOfSamps; i++) // longitude direction
560  {
561  m_fileStr->seekg(DATA_RECORD_OFFSET_TO_POST, ios::cur);
562
563  for (ossim_uint32 j=0; j<theNumberOfLines; j++) // latitude direction
564  {
565  ossim_uint16 temp;
566  ossim_sint16 s;
567  m_fileStr->read((char*)&temp, POST_SIZE);
568  s = convertSignedMagnitude(temp);
569  if (s < theMinHeight && s != NULL_PIXEL) theMinHeight = s;
570  if (s > theMaxHeight) theMaxHeight = s;
571  }
572
573  m_fileStr->seekg(DATA_RECORD_CHECKSUM_SIZE, ios::cur);
574  }
575
576  if ( writeStatsFile )
577  {
578  // Add the stats to the keyword list.
579  ossimKeywordlist kwl;
582
583  // Write out the statistics file.
585  f.setExtension("statistics");
586  kwl.write( f.c_str() );
587  }
588
589  if (traceDebug())
590  {
592  << "ossimDtedTileSource::gatherStatistics DEBUG:"
593  << "\ntheMinHeight: " << theMinHeight
594  << "\ntheMaxHeight: " << theMaxHeight
595  << "\n";
596  }
597 }
static const char * MIN_VALUE_KW
static const char * MAX_VALUE_KW
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
ossimFilename fileNoExtension() const
const char * c_str() const
Definition: ossimString.h:396
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimDtedTileSource::getImageGeometry ( )
virtual
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Definition at line 402 of file ossimDtedTileSource.cpp.
References ossimDatum::ellipsoid(), ossimRefPtr< T >::get(), ossimImageHandler::initImageParameters(), ossimDatumFactory::instance(), ossimDtedUhl::latInterval(), ossimDtedUhl::latOrigin(), ossimDtedUhl::lonInterval(), ossimDtedUhl::lonOrigin(), m_uhl, ossimDtedUhl::numLatPoints(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), ossimImageGeometry::setProjection(), ossimMapProjection::setUlTiePoints(), ossimImageHandler::theGeometry, ossimRefPtr< T >::valid(), and ossimDatumFactory::wgs84().
403 {
404  if ( theGeometry.valid() )
405  return theGeometry;
406
407  // Compute the projection tie point (UL corner of dted cell). The UHL supplies the SW (LL) corner
408  // coordinates, so need to compute the UL lat from the cell spacing:
409  const ossimDatum* datum = ossimDatumFactory::instance()->wgs84();
410  ossim_float64 ul_lat = m_uhl.latOrigin() + (m_uhl.latInterval() * (m_uhl.numLatPoints()-1.0));
411  ossim_float64 ul_lon = m_uhl.lonOrigin();
412  ossimGpt tie(ul_lat, ul_lon, 0.0, datum);
413
414  //---
415  // This code is backed out as it affects the corner.
416  // E.g.: image0.ur_lon: -88.999999999995
417  // Should be -89.0
418  // Used ossimImageGeometry::::getMetersPerPixel for a center of the image gsd. (drb)
419  //
420  // We also need to define an origin for the projection as the center of the cell for proper GSD
421  // calculation (OLK 01/11: Used to set origin at 0,0 causing incorrect meters GSD to be
422  // computed)
423  // ossim_float64 mid_lat = m_uhl.latOrigin() + (m_uhl.latInterval()*m_uhl.numLatPoints()/2.0);
424  // ossim_float64 mid_lon = m_uhl.lonOrigin() + (m_uhl.lonInterval()*m_uhl.numLonLines()/2.0);
425  // ossimGpt origin (mid_lat, mid_lon, 0.0, datum);
426  //---
427  ossimGpt origin (0.0, 0.0, 0.0, datum);
428
429  // Make an Equidistant Cylindrical projection.
431  new ossimEquDistCylProjection(*(datum->ellipsoid()));
432
433  // Set the scale:
434  eq->setOrigin(origin);
435  eq->setUlTiePoints(tie);
437  eq->setDecimalDegreesPerPixel(gsd);
438
439  // Give it to the geometry object.
440  ossimRefPtr<ossimProjection> proj = eq.get();
441
442  // Make the geometry:
444
445  // Set the projection.
446  theGeometry->setProjection( proj.get() );
447
448  // Set image things the geometry object should know about.
450
451  return theGeometry;
452 }
double latOrigin() const
ossimRefPtr< ossimImageGeometry > theGeometry
double latInterval() const
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
ossim_int32 numLatPoints() const
double ossim_float64
virtual const ossimEllipsoid * ellipsoid() const
Definition: ossimDatum.h:60
static ossimDatumFactory * instance()
virtual void setOrigin(const ossimGpt &origin)
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
double lonOrigin() const
virtual void setUlTiePoints(const ossimGpt &gpt)
const ossimDatum * wgs84() const
double lonInterval() const
◆ getImageRectangle()
ossimIrect ossimDtedTileSource::getImageRectangle ( ossim_uint32  reduced_res_level = 0) const
virtual
Note that rrds 0 is the highest resolution rrds.
Definition at line 229 of file ossimDtedTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
230 {
231  return ossimIrect(0,
232  0,
233  getNumberOfSamples(reduced_res_level) - 1,
234  getNumberOfLines(reduced_res_level) - 1);
235 }
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
◆ getImageTileHeight()
ossim_uint32 ossimDtedTileSource::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 604 of file ossimDtedTileSource.cpp.
605 {
606  return 0;
607 }
◆ getImageTileWidth()
ossim_uint32 ossimDtedTileSource::getImageTileWidth ( ) const
virtual
Definition at line 599 of file ossimDtedTileSource.cpp.
600 {
601  return 0;
602 }
◆ getLongName()
ossimString ossimDtedTileSource::getLongName ( ) const
virtual
Definition at line 81 of file ossimDtedTileSource.cpp.
82 {
83  return ossimString("dted reader");
84 }
◆ getMaxPixelValue()
double ossimDtedTileSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 631 of file ossimDtedTileSource.cpp.
References ossimImageMetaData::getMaxPix(), ossimImageMetaData::getNumberOfBands(), theMaxHeight, and ossimImageHandler::theMetaData.
632 {
634  {
635  return theMetaData.getMaxPix(band);
636  }
637  return theMaxHeight;
638 }
double getMaxPix(ossim_uint32 band) const
ossim_uint32 getNumberOfBands() const
ossimImageMetaData theMetaData
◆ getMinPixelValue()
double ossimDtedTileSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 622 of file ossimDtedTileSource.cpp.
References ossimImageMetaData::getMinPix(), ossimImageMetaData::getNumberOfBands(), ossimImageHandler::theMetaData, and theMinHeight.
623 {
625  {
626  return theMetaData.getMinPix(band);
627  }
628  return theMinHeight;
629 }
double getMinPix(ossim_uint32 band) const
◆ getNullPixelValue()
double ossimDtedTileSource::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 614 of file ossimDtedTileSource.cpp.
References ossimImageMetaData::getNullPix(), ossimImageMetaData::getNumberOfBands(), and ossimImageHandler::theMetaData.
615 {
617  {
618  return theMetaData.getNullPix(0);
619  }
620  return -32767.0;
621 }
double getNullPix(ossim_uint32 band) const
◆ getNumberOfInputBands()
ossim_uint32 ossimDtedTileSource::getNumberOfInputBands ( ) const
virtual
Satisfies pure virtual requirement from ImageHandler class.
Implements ossimImageSource.
Definition at line 609 of file ossimDtedTileSource.cpp.
Referenced by getNumberOfOutputBands().
610 {
611  return 1;
612 }
◆ getNumberOfLines()
ossim_uint32 ossimDtedTileSource::getNumberOfLines ( ossim_uint32  reduced_res_level = 0) const
virtual
Definition at line 469 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), theNumberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
470 {
471  if (reduced_res_level == 0)
472  {
473  return theNumberOfLines;
474  }
475  else if (theOverview.valid())
476  {
477  return theOverview->getNumberOfLines(reduced_res_level);
478  }
479
480  return 0;
481 }
bool valid() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
ossimRefPtr< ossimImageHandler > theOverview
◆ getNumberOfOutputBands()
ossim_uint32 ossimDtedTileSource::getNumberOfOutputBands ( ) const
virtual
Definition at line 223 of file ossimDtedTileSource.cpp.
References getNumberOfInputBands().
224 {
225  return getNumberOfInputBands();
226 }
virtual ossim_uint32 getNumberOfInputBands() const
◆ getNumberOfSamples()
ossim_uint32 ossimDtedTileSource::getNumberOfSamples ( ossim_uint32  reduced_res_level = 0) const
virtual
Definition at line 483 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), theNumberOfSamps, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
484 {
485  if (reduced_res_level == 0)
486  {
487  return theNumberOfSamps;
488  }
489  else if (theOverview.valid())
490  {
491  return theOverview->getNumberOfSamples(reduced_res_level);
492  }
493
494  return 0;
495 }
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimDtedTileSource::getOutputScalarType ( ) const
virtual
Definition at line 454 of file ossimDtedTileSource.cpp.
References OSSIM_SSHORT16.
455 {
456  return OSSIM_SSHORT16; // Always signed 16 bit.
457 }
16 bit signed integer
◆ getPostSpacing()
void ossimDtedTileSource::getPostSpacing ( ossimDpt postSpacing) const
Parameters
postSpacingossimDpt to initialize with spacing where postspacing.x = longitude interval and postspacing.y = latitude interval.
Definition at line 640 of file ossimDtedTileSource.cpp.
References thePostSpacing, ossimDpt::x, and ossimDpt::y.
641 {
642  postSpacing.x = thePostSpacing.x;
643  postSpacing.y = thePostSpacing.y;
644 }
double y
Definition: ossimDpt.h:165
double x
Definition: ossimDpt.h:164
◆ getProperty()
ossimRefPtr< ossimProperty > ossimDtedTileSource::getProperty ( const ossimString name) const
virtual
Parameters
nameProperty name to get.
Returns
ossimRefPtr<ossimProperty> Note that this can be empty if property for name was not found.
Definition at line 646 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getProperty(), m_dtedInfo, and ossimRefPtr< T >::valid().
648 {
649  // look in base class.
651
652  if (result.valid() == false)
653  {
654 // ossimDtedInfo info;
655 // std::string connectionString = theImageFile.c_str();
656  if (m_dtedInfo)
657  {
658  result = m_dtedInfo->getProperty(name);
659  }
660  }
661
662  return result;
663 }
bool valid() const
◆ getPropertyNames()
void ossimDtedTileSource::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNameslist to append to.
Definition at line 665 of file ossimDtedTileSource.cpp.
References ossimImageHandler::getPropertyNames(), and m_dtedInfo.
667 {
669
670  if (m_dtedInfo)
671  {
672  m_dtedInfo->getPropertyNames(propertyNames);
673  }
674 // ossimDtedInfo info;
675 // if (info.open(theImageFile))
676 // {
677 // info.getPropertyNames(propertyNames);
678 // }
679 }
◆ getShortName()
ossimString ossimDtedTileSource::getShortName ( ) const
virtual
Definition at line 76 of file ossimDtedTileSource.cpp.
77 {
78  return ossimString("dted");
79 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimDtedTileSource::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 86 of file ossimDtedTileSource.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
88 {
89  if (!theTile.valid())
90  {
91  allocate(); // First getTile call or after changeTileSize.
92  if (!theTile.valid())
93  {
94  return ossimRefPtr<ossimImageData>(); // Throw exception???
95  }
96  }
97
98  // Image rectangle must be set prior to calling getTile.
99  theTile->setImageRectangle(tile_rect);
100
101  if ( getTile( theTile.get(), resLevel ) == false )
102  {
104  {
105  theTile->makeBlank();
106  }
107  }
108
109  return theTile;
110 }
bool valid() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
virtual void makeBlank()
void allocate()
◆ getTile() [2/2]
bool ossimDtedTileSource::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 112 of file ossimDtedTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillBuffer(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), ossimReferenced::ref(), status, and ossimReferenced::unref().
114 {
115  bool status = false;
116
117  //---
118  // Not open, this tile source bypassed, or invalid res level,
119  // return a blank tile.
120  //---
121  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
122  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
123  {
124  result->ref(); // Increment ref count.
125
126  //---
127  // Check for overview tile. Some overviews can contain r0 so always
128  // call even if resLevel is 0. Method returns true on success, false
129  // on error.
130  //---
131  status = getOverviewTile(resLevel, result);
132
133  if ( !status ) // Did not get an overview tile.
134  {
135  ossimIrect image_rect = getImageRectangle(resLevel);
136
137  ossimIrect tile_rect = result->getImageRectangle();
138
139  //---
140  // See if any point of the requested tile is in the image.
141  //---
142  if ( tile_rect.intersects(image_rect) )
143  {
144  ossimIrect clip_rect = tile_rect.clipToRect(image_rect);
145
146  if ( !tile_rect.completely_within(clip_rect) )
147  {
148  // Start with a blank tile.
149  result->makeBlank();
150  }
151
152  // Load the tile buffer with data from the dted cell.
153  status = fillBuffer(tile_rect, clip_rect, result);
154
155  } // End of if ( tile_rect.intersects(image_rect) )
156  }
157
158  result->unref(); // Decrement ref count.
159  }
160
161  return status;
162 }
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
bool fillBuffer(const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile)
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
virtual ossimIrect getImageRectangle() const
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
return status
virtual bool isOpen() const
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in...
◆ getTileHeight()
ossim_uint32 ossimDtedTileSource::getTileHeight ( ) const
virtual
Definition at line 464 of file ossimDtedTileSource.cpp.
References theTileHeight.
465 {
466  return theTileHeight;
467 }
◆ getTileWidth()
ossim_uint32 ossimDtedTileSource::getTileWidth ( ) const
virtual
Definition at line 459 of file ossimDtedTileSource.cpp.
References theTileWidth.
460 {
461  return theTileWidth;
462 }
◆ isOpen()
bool ossimDtedTileSource::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 237 of file ossimDtedTileSource.cpp.
238 {
239  return (m_fileStr!=0);
240 }
◆ loadMetaData()
void ossimDtedTileSource::loadMetaData ( )
virtual
Sets the min/max.
looks for an omd or statistics file for min/max. If not found calls gatherStatistics method. Overrides ossimImageHandler::loadMetaData called by completeOpen.
Definition at line 497 of file ossimDtedTileSource.cpp.
References ossimKeywordlist::addFile(), ossimFilename::exists(), ossimFilename::fileNoExtension(), ossimKeywordlist::find(), gatherStatistics(), ossimKeywordNames::MAX_VALUE_KW, ossimKeywordNames::MIN_VALUE_KW, ossimFilename::setExtension(), ossimImageHandler::theImageFile, theMaxHeight, and theMinHeight.
498 {
499  ossimKeywordlist kwl;
500  const char* min_str = 0;
501  const char* max_str = 0;
502
504
505  // Check for omd file.
506  f.setExtension("omd");
507  if ( f.exists() )
508  {
509  kwl.addFile(f);
510  min_str = kwl.find("band1.min_value");
511  max_str = kwl.find("band1.max_value");
512  }
513
514  if ( !min_str || !max_str )
515  {
516  f.setExtension("statistics");
517  if ( f.exists() )
518  {
519  kwl.addFile(f);
520  min_str = kwl.find(ossimKeywordNames::MIN_VALUE_KW);
521  max_str = kwl.find(ossimKeywordNames::MAX_VALUE_KW);
522  }
523  }
524
525  if ( min_str || max_str )
526  {
527  theMinHeight = atoi(min_str);
528  theMaxHeight = atoi(max_str);
529  }
530  else
531  {
532  gatherStatistics(false);
533  }
534 }
bool addFile(const char *file)
void gatherStatistics(bool writeStatsFile)
bool exists() const
◆ loadState()
bool ossimDtedTileSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 384 of file ossimDtedTileSource.cpp.
References ossimImageHandler::loadState(), ossimImageHandler::open(), and ossimImageHandler::theImageFile.
386 {
387  if (ossimImageHandler::loadState(kwl, prefix))
388  {
390  {
391  return true;
392  }
393  }
394
395  return false;
396 }
virtual bool open()=0
Pure virtual open.
◆ open()
bool ossimDtedTileSource::open ( )
virtual
Definition at line 247 of file ossimDtedTileSource.cpp.
248 {
249  static const char MODULE[] = "ossimDtedTileSource::open";
250
251  if (traceDebug())
252  {
253  CLOG << "DEBUG:"
254  << "\nAttempting to parse file: " << theImageFile.c_str()
255  << endl;
256  }
257  std::shared_ptr<ossim::istream> str = ossim::StreamFactoryRegistry::instance()->
258  createIstream( theImageFile.c_str(), std::ios_base::in|std::ios_base::binary);
259
260  // Open up the file for reading.
261  if (!str)
262  {
264
265  if(traceDebug())
266  {
267  ossimNotify(ossimNotifyLevel_WARN) << MODULE << " ERROR!"
268  << "\nCould not open file: " << theImageFile.c_str()
269  << "\nReturning..." << endl;
270  CLOG << "returning with error..." << endl;
271  }
272  return false;
273  }
274
275  if(!str)
276  {
277  if (traceDebug())
278  {
279  CLOG << "DEBUG:"
280  << "\nCannot open: " << theImageFile.c_str()
281  << endl;
282  }
283  str.reset();
284  return false;
285  }
286  std::string connectionString = theImageFile.c_str();
287  m_dtedInfo = std::make_shared<ossimDtedInfo>();
288  if(!m_dtedInfo->open(str, connectionString))
289  {
290  close();
291  return false;
292  }
293  m_fileStr = str;
294  m_fileStr->clear();
295  m_fileStr->seekg(0);
296
297  m_vol.parse(*str);
298  m_hdr.parse(*str);
299  m_uhl.parse(*str);
300  m_dsi.parse(*str);
301  m_acc.parse(*str);
302
303  //***
304  // Check for errors. Must have uhl, dsi and acc records. vol and hdr
305  // are for magnetic tape only; hence, may or may not be there.
306  //***
310  {
311  if (traceDebug())
312  {
313  CLOG << "DEBUG:"
314  << "\nError parsing file: " << theImageFile.c_str()
315  << "\nPossibly not a dted file.\n";
316  }
317
318  str.reset();
319  return false;
320  }
321  m_fileStr = str;
322
323  // Get the cell specific info needed for later.
330  (theNumberOfLines * sizeof(ossim_sint16)) +
332
333  //---
334  // Note:
335  // Complete open calls loadMetaData which we have overriden to check for
336  // dot omd or dot statistics file. If not there it will call
337  // gatherStatistics which will scan the file for min/max values.
338  //---
339  completeOpen();
340
341  if (traceDebug())
342  {
343  CLOG << "DEBUG:"
344  << "\nNull pix: " << getNullPixelValue(0)
345  << "\nMin pix: " << getMinPixelValue(0)
346  << "\nMax pix: " << getMaxPixelValue(0)
347  << "\ntheNumberOfLines: " << theNumberOfLines
348  << "\ntheNumberOfSamps: " << theNumberOfSamps
349  << "\ntheOffsetToFirstDataRecord: " << theOffsetToFirstDataRecord
350  << "\ntheDataRecordSize: " << theDataRecordSize << "\n";
351  }
352
353  return true;
354 }
ossim_int32 stopOffset() const
#define CLOG
Definition: ossimTrace.h:23
double y
static const ossimErrorCode OSSIM_ERROR
static StreamFactoryRegistry * instance()
void parse(std::istream &in)
virtual void completeOpen()
Will complete the opening process.
virtual ossimErrorCode getErrorStatus() const
double x
ossim_int32 numLonLines() const
◆ operator=()
const ossimDtedTileSource & ossimDtedTileSource::operator= ( const ossimDtedTileSource rhs)
protected
Definition at line 681 of file ossimDtedTileSource.cpp.
682 {
683  return rhs;
684 }
◆ saveState()
bool ossimDtedTileSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 377 of file ossimDtedTileSource.cpp.
References ossimImageHandler::saveState().
379 {
380  // Currently nothing to do here.
381  return ossimImageHandler::saveState(kwl, prefix);
382 }
Member Data Documentation
◆ m_acc
ossimDtedAcc ossimDtedTileSource::m_acc
protected
Definition at line 236 of file ossimDtedTileSource.h.
◆ m_dsi
ossimDtedDsi ossimDtedTileSource::m_dsi
protected
Definition at line 235 of file ossimDtedTileSource.h.
◆ m_dtedInfo
std::shared_ptr<ossimDtedInfo> ossimDtedTileSource::m_dtedInfo
mutableprotected
Definition at line 220 of file ossimDtedTileSource.h.
Referenced by getProperty(), and getPropertyNames().
◆ m_fileStr
std::shared_ptr<ossim::istream> ossimDtedTileSource::m_fileStr
mutableprotected
Definition at line 219 of file ossimDtedTileSource.h.
Referenced by close(), fillBuffer(), and isOpen().
◆ m_hdr
ossimDtedHdr ossimDtedTileSource::m_hdr
protected
Definition at line 233 of file ossimDtedTileSource.h.
◆ m_uhl
ossimDtedUhl ossimDtedTileSource::m_uhl
protected
Definition at line 234 of file ossimDtedTileSource.h.
Referenced by getImageGeometry().
◆ m_vol
ossimDtedVol ossimDtedTileSource::m_vol
protected
Definition at line 232 of file ossimDtedTileSource.h.
◆ theDataRecordSize
ossim_uint32 ossimDtedTileSource::theDataRecordSize
protected
Definition at line 227 of file ossimDtedTileSource.h.
◆ theMaxHeight
ossim_sint16 ossimDtedTileSource::theMaxHeight
protected
Definition at line 229 of file ossimDtedTileSource.h.
Referenced by getMaxPixelValue(), and loadMetaData().
◆ theMinHeight
ossim_sint16 ossimDtedTileSource::theMinHeight
protected
Definition at line 228 of file ossimDtedTileSource.h.
Referenced by getMinPixelValue(), and loadMetaData().
◆ theNumberOfLines
ossim_uint32 ossimDtedTileSource::theNumberOfLines
protected
Definition at line 224 of file ossimDtedTileSource.h.
Referenced by fillBuffer(), and getNumberOfLines().
◆ theNumberOfSamps
ossim_uint32 ossimDtedTileSource::theNumberOfSamps
protected
Definition at line 225 of file ossimDtedTileSource.h.
Referenced by getNumberOfSamples().
◆ theOffsetToFirstDataRecord
ossim_uint32 ossimDtedTileSource::theOffsetToFirstDataRecord
protected
Definition at line 226 of file ossimDtedTileSource.h.
◆ thePostSpacing
ossimDpt ossimDtedTileSource::thePostSpacing
protected
Definition at line 230 of file ossimDtedTileSource.h.
Referenced by getPostSpacing().
◆ theSwapBytesFlag
bool ossimDtedTileSource::theSwapBytesFlag
protected
This flag indicates that byte swapping is needed (LITTLE_ENDIAN machine).
Definition at line 241 of file ossimDtedTileSource.h.
Referenced by convertSignedMagnitude(), and ossimDtedTileSource().
◆ theTile
ossimRefPtr<ossimImageData> ossimDtedTileSource::theTile
protected
Definition at line 218 of file ossimDtedTileSource.h.
Referenced by allocate(), and getTile().
◆ theTileHeight
ossim_uint32 ossimDtedTileSource::theTileHeight
protected
Definition at line 223 of file ossimDtedTileSource.h.
Referenced by getTileHeight(), and ossimDtedTileSource().
◆ theTileWidth
ossim_uint32 ossimDtedTileSource::theTileWidth
protected
Definition at line 222 of file ossimDtedTileSource.h.
Referenced by getTileWidth(), and ossimDtedTileSource().
