ossimGdalOverviewBuilder.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: David Burken
6 //
7 // Description: OSSIM wrapper for building gdal overviews (tiff or hfa) from
8 // an ossim image source.
9 //
10 //----------------------------------------------------------------------------
11 // $Id: ossimGdalOverviewBuilder.h 15833 2009-10-29 01:41:53Z eshirschorn $
12
13 #ifndef ossimGdalOverviewBuilder_HEADER
14 #define ossimGdalOverviewBuilder_HEADER
15
16 #include <vector>
17
20 #include <ossim/base/ossimRefPtr.h>
23
24 class ossimImageSource;
25 class ossimGdalDataset;
26
32  :
34 {
35 public:
36
39  {
45  };
46
49
51  virtual ~ossimGdalOverviewBuilder();
52
58  bool open(const ossimFilename& file);
59
69  virtual bool execute();
70
77  virtual bool setInputSource(ossimImageHandler* imageSource);
78
84  virtual void setOutputFile(const ossimFilename& file);
85
92  virtual ossimFilename getOutputFile() const;
93
107  virtual bool setOverviewType(const ossimString& type);
108
114  virtual ossimString getOverviewType() const;
115
121  virtual void getTypeNameList(std::vector<ossimString>& typeList)const;
122
126  virtual ossimObject* getObject();
127
131  virtual const ossimObject* getObject() const;
132
136  virtual bool canConnectMyInputTo(ossim_int32 index,
137  const ossimConnectableObject* obj) const;
138
147  virtual void setProperty(ossimRefPtr<ossimProperty> property);
148
154  virtual void getPropertyNames(std::vector<ossimString>& propertyNames)const;
155
160  virtual std::ostream& print(std::ostream& out) const;
161
162 private:
163
164  bool generateHfaStats() const;
165
168
171
175  std::vector<ossim_int32> theLevels; // like 2, 4, 8, 16, 32
177
179  TYPE_DATA
180 };
181
182 #endif /* End if "#ifndef ossimGdalOverviewBuilder_HEADER" */
bool open(const ossimFilename &file)
Open that takes a file name.
virtual bool setOverviewType(const ossimString &type)
Sets the overview output type.
ossimString getExtensionFromType() const
ossimGdalOverviewType theOverviewType
std::vector< ossim_int32 > theLevels
Builds the overviews.
Method to set properties.
virtual bool setInputSource(ossimImageHandler *imageSource)
Sets the input to the builder.
ossimGdalOverviewBuilder Class to build overviews from the GDAL library.
virtual destructor
Method to populate the list of property names.
print method.
Enumerations for the type of GDAL overviews to build.
default constructor
ossimString getGdalResamplingType() const
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual bool canConnectMyInputTo(ossim_int32 index, const ossimConnectableObject *obj) const
ossimGdalDataset This is a gdal data set that wraps an ossim image handler.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual void setOutputFile(const ossimFilename &file)
Sets the output filename.
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Method to populate class supported types.
virtual ossimObject * getObject()
Returns the output.
Gets the overview type.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
int ossim_int32
