ossimH5Reader.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: David Burken
8 //
9 // Description: OSSIM HDF5 Reader.
10 //
11 //----------------------------------------------------------------------------
12 // $Id
13
14 #ifndef ossimH5Reader_HEADER
15 #define ossimH5Reader_HEADER 1
16
18 #include <ossim/base/ossimIrect.h>
19 #include <ossim/base/ossimRefPtr.h>
23 #include "ossimH5ImageDataset.h"
24
25 #include <mutex>
26 #include <vector>
27
28 // Forward class declarations:
29 namespace H5
30 {
31  class DataSet;
32  class H5File;
33 }
34
36 {
37 public:
38
41
43  virtual ~ossimH5ImageHandler();
44
46  virtual ossimString getShortName() const;
47
49  virtual ossimString getLongName() const;
50
52  virtual ossimString getClassName() const;
53
60  ossim_uint32 resLevel=0);
73  virtual bool getTile(ossimImageData* result, ossim_uint32 resLevel=0);
74
79  virtual ossim_uint32 getNumberOfInputBands() const;
80
86  virtual ossim_uint32 getNumberOfOutputBands()const;
87
92  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
93
98  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
99
104  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const;
105
110  virtual bool saveState(ossimKeywordlist& kwl,
111  const char* prefix=0)const;
112
117  virtual bool loadState(const ossimKeywordlist& kwl,
118  const char* prefix=0);
119
123  virtual ossimScalarType getOutputScalarType() const;
124
131  virtual ossim_uint32 getImageTileWidth() const;
132
139  virtual ossim_uint32 getImageTileHeight() const;
140
141  bool isOpen()const;
142
144  virtual void close();
145
149  virtual ossim_uint32 getNumberOfEntries()const;
150
163  virtual void getEntryNames(std::vector<ossimString>& entryNames) const;
164
170  virtual void getEntryList(std::vector<ossim_uint32>& entryList) const;
171
172  virtual bool setCurrentEntry(ossim_uint32 entryIdx);
173
177  virtual ossim_uint32 getCurrentEntry() const;
178
185
187  virtual double getNullPixelValue(ossim_uint32 band=0)const;
188
198  virtual void setProperty(ossimRefPtr<ossimProperty> property);
199
204  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name) const;
205
210  virtual void getPropertyNames(std::vector<ossimString>& propertyNames) const;
211
224  virtual void addMetadata( ossimKeywordlist* kwl,
225  const std::string& prefix ) const;
226
227 protected:
228
231
241  ossimRefPtr<ossimProjection> processCoarseGridProjection(
242  H5::DataSet& latDataSet,
243  H5::DataSet& lonDataSet,
244  const ossimIrect& validRect ) const;
245
253  bool getLatLonDatasetNames( H5::H5File* h5File,
254  std::string& latName,
255  std::string& lonName ) const;
262  bool getLatLonDatasets( H5::H5File* h5File,
263  H5::DataSet& latDataSet,
264  H5::DataSet& lonDataSet ) const;
265
266  bool getDataSetRect( std::string& name, std::string& lonName ) const;
267
272  virtual bool open();
273
275  void allocate();
276
281  void addImageDatasetEntries(const std::vector<std::string>& names);
282
286  bool isNppMission( H5::H5File* h5File ) const;
287
288  H5::H5File* m_h5File;
289  std::vector<ossimH5ImageDataset> m_entries;
293  std::mutex m_mutex;
294
295 TYPE_DATA
296 };
297
298 #endif /* #ifndef ossimH5Reader_HEADER */
virtual bool open()=0
Pure virtual open.
virtual void getEntryNames(std::vector< ossimString > &entryNames) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Definition: ossimObject.cpp:64
Definition: ossimObject.cpp:48
virtual bool isOpen() const =0
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
Definition: ossimObject.cpp:53
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossim_uint32 getNumberOfEntries() const
#define OSSIM_PLUGINS_DLL
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
virtual void addMetadata(ossimKeywordlist *kwl, const std::string &prefix) const =0
Pure virtual addMetadata method.
ossimRefPtr< ossimImageData > m_tile
ossim_uint32 m_currentEntry
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
H5::H5File * m_h5File
ossimRefPtr< ossimProjection > m_projection
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
std::vector< ossimH5ImageDataset > m_entries
