#include <ossimH5Reader.h>
ossimH5ImageHandler () | |
default constructor More... | |
virtual | ~ossimH5ImageHandler () |
virtual destructor More... | |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossim_uint32 | getNumberOfInputBands () const |
Returns the number of bands in the image. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossim_uint32 | getNumberOfLines (ossim_uint32 reduced_res_level=0) const |
Returns the number of lines in the image. More... | |
virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 reduced_res_level=0) const |
Returns the number of samples in the image. More... | |
virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual ossimScalarType | getOutputScalarType () const |
Returns the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getImageTileWidth () const |
Returns the tile width of the image or 0 if the image is not tiled. More... | |
virtual ossim_uint32 | getImageTileHeight () const |
bool | isOpen () const |
Derived classes must implement this method to be concrete. More... | |
virtual void | close () |
Close method. More... | |
virtual ossim_uint32 | getNumberOfEntries () const |
virtual void | getEntryNames (std::vector< ossimString > &entryNames) const |
Get the name of entry as a string. More... | |
virtual void | getEntryList (std::vector< ossim_uint32 > &entryList) const |
virtual bool | setCurrentEntry (ossim_uint32 entryIdx) |
virtual ossim_uint32 | getCurrentEntry () const |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if non defined. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
Set propterty method. More... | |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
Get propterty method. More... | |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
Get propterty names. More... | |
virtual void | addMetadata (ossimKeywordlist *kwl, const std::string &prefix) const |
Adds metadata to keyword list. More... | |
ossimImageHandler () | |
Constructor (default): More... | |
virtual | ~ossimImageHandler () |
Destructor: Derived classes should implement. More... | |
virtual void | initialize () |
initialize Does nothing in this class. More... | |
virtual bool | openOverview () |
Searches for an overview. More... | |
virtual bool | openOverview (const ossimFilename &overview_file) |
Calls closeOverview(), then attempts to open the overview_file. More... | |
virtual void | closeOverview () |
If theOverview is initialized it will be deleted and set to NULL. More... | |
virtual const ossimImageHandler * | getOverview () const |
virtual bool | hasOverviews () const |
virtual ossimFilename | createDefaultOverviewFilename () const |
virtual ossimFilename | createDefaultGeometryFilename () const |
virtual ossimFilename | createDefaultMetadataFilename () const |
virtual ossimFilename | createDefaultHistogramFilename () const |
virtual ossimFilename | createDefaultValidVerticesFilename () const |
virtual bool | writeValidImageVertices (const std::vector< ossimIpt > &vertices, const ossimFilename &file=ossimFilename("")) |
Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices". More... | |
virtual bool | openValidVertices (const ossimFilename &vertices_file) |
Opens the valid image vertices file and sets theValidImageVerticesFile variable. More... | |
virtual bool | openValidVertices () |
Creates vertices file name based on image, then tries to open. More... | |
virtual bool | open (const ossimFilename &imageFile, ossim_uint32 entryIndex) |
Opens the image file. More... | |
virtual bool | open (const ossimFilename &imageFile) |
virtual bool | open (std::shared_ptr< ossim::ImageHandlerState > state) |
virtual bool | buildHistogram (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histogram for image file. More... | |
virtual bool | buildAllHistograms (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histograms for all image entries. More... | |
virtual bool | buildOverview (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for theImageFile. More... | |
virtual bool | buildAllOverviews (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for all image entries. More... | |
virtual bool | buildOverview (const ossimFilename &filename, ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build an over file for filename. More... | |
ossimRefPtr< ossimMultiResLevelHistogram > | getImageHistogram () const |
Fetches the current entry image's histogram. More... | |
virtual void | setImageGeometry (ossimImageGeometry *geom) |
Sets the image geometry object. More... | |
virtual void | saveImageGeometry () const |
Saves the image geometry to a file that will be made based on the image file name. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
Returns zero-based bounding rectangle of the image. More... | |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
This returns all decimation for all levels. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
This returns the total number of decimation levels. More... | |
virtual ossim_uint32 | getNumberOfReducedResSets () const |
This method is obsolete. More... | |
virtual void | setFilename (const ossimFilename &filename) |
Sets the filename. More... | |
virtual const ossimFilename & | getFilename () const |
Returns the filename. More... | |
virtual bool | isValidRLevel (ossim_uint32 resLevel) const |
Determines if the passed in reslution level is valid. More... | |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
Connection rule. More... | |
virtual void | getValidImageVertices (vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual bool | isBandSelector () const |
Indicates whether or not the image handler can control output band selection via the setOutputBandList method. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &band_list) |
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled. More... | |
virtual bool | setOutputToInputBandList () |
If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity. More... | |
virtual bool | isIdentityBandList (const std::vector< ossim_uint32 > &bandList) const |
Convenience method to see if band list is identity. More... | |
virtual bool | isImageTiled () const |
Indicates whether or not the image is tiled internally. More... | |
virtual bool | hasMetaData () const |
virtual ossimRefPtr< ossimNBandLutDataObject > | getLut () const |
virtual bool | hasLut () const |
virtual void | loadMetaData () |
There is an external file with an omd extension. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Retuns the min pixel value. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | setMinPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set min pixel value. More... | |
virtual void | setMaxPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set max pixel value. More... | |
virtual void | setNullPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set null pixel value. More... | |
virtual void | getEntryName (ossim_uint32 entryIdx, std::string &name) const |
bool | useEntryIndex () const |
Convenience method to determine if entry index should be used for support files, e.g. More... | |
ossimFilename | getOverviewFile () const |
ossimFilename | getFilenameWithThisExtension (const ossimString &ext, bool set_e0_prefix=false) const |
Returns the image file with extension set using supplentary directory for dirname if set. More... | |
void | getFilenameWithThisExt (const ossimString &ext, ossimFilename &f) const |
ossim_uint32 | getStartingResLevel () const |
void | setStartingResLevel (ossim_uint32 level) |
bool | getOpenOverviewFlag () const |
void | setOpenOverviewFlag (bool flag) |
Sets theOpenOverviewFlag. More... | |
virtual void | setSupplementaryDirectory (const ossimFilename &dir) |
Sets the supplementary directory. More... | |
virtual const ossimFilename & | getSupplementaryDirectory () const |
Returns the supplementary directory. More... | |
const ossimString & | getImageID () const |
Fetches the image ID. More... | |
void | setImageID (const ossimString &id) |
Sets the image ID in case it is externally generated. More... | |
ossimPixelType | getPixelType () const |
Returns the raster pixel alignment type. More... | |
virtual bool | getRgbBandList (std::vector< ossim_uint32 > &bandList) const |
Convenience method to get the zero based rgb output band list. More... | |
template<class T > | |
std::shared_ptr< T > | getStateAs () |
std::shared_ptr< const T > | getStateAs () const |
std::shared_ptr< ossim::ImageHandlerState > | getState () |
std::shared_ptr< const ossim::ImageHandlerState > | getState () const |
void | setState (std::shared_ptr< ossim::ImageHandlerState > state) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimMetadataInterface () | |
virtual | ~ossimMetadataInterface () |
virtual destructor. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () |
Method to get geometry from hdf file. More... | |
ossimRefPtr< ossimProjection > | processCoarseGridProjection (H5::DataSet &latDataSet, H5::DataSet &lonDataSet, const ossimIrect &validRect) const |
Gets projection from Latitude, Longitude, Height datasets if present. More... | |
bool | getLatLonDatasetNames (H5::H5File *h5File, std::string &latName, std::string &lonName) const |
Get dataset names for Latiitude and Longitude datasets. More... | |
bool | getLatLonDatasets (H5::H5File *h5File, H5::DataSet &latDataSet, H5::DataSet &lonDataSet) const |
bool | getDataSetRect (std::string &name, std::string &lonName) const |
virtual bool | open () |
open method. More... | |
void | allocate () |
Allocates the tile. More... | |
void | addImageDatasetEntries (const std::vector< std::string > &names) |
Adds image datasets from list of names. More... | |
bool | isNppMission (H5::H5File *h5File) const |
virtual ossimRefPtr< ossimImageGeometry > | getExternalImageGeometry () const |
virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () const |
virtual bool | getOverviewTile (ossim_uint32 resLevel, ossimImageData *result) |
Method to get an overview tile. More... | |
bool | initVertices (const char *file) |
Opens file and attempts to initialize the valid image vertices. More... | |
virtual void | completeOpen () |
Will complete the opening process. More... | |
void | initImageParameters (ossimImageGeometry *geom) const |
Convenience method to set things needed in the image geometry from the image handler. More... | |
virtual void | establishDecimationFactors () |
Virtual method determines the decimation factors at each resolution level. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &inBandList, std::vector< ossim_uint32 > &outBandList) |
Convenience method to set output band list. More... | |
void | getFilenameWithNoExtension (ossimFilename &f) const |
Get filename with no extension, using supplentary directory for dirname if set. More... | |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimImageHandlerOverviewCompressionType { OSSIM_OVERVIEW_COMPRESSION_NONE = 0, OSSIM_OVERVIEW_COMPRESSION_JPEG, OSSIM_OVERVIEW_COMPRESSION_LZW, OSSIM_OVERVIEW_COMPRESSION_DEFLATE, OSSIM_OVERVIEW_COMPRESSION_PACKBITS } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
Definition at line 35 of file ossimH5Reader.h.
ossimH5ImageHandler::ossimH5ImageHandler | ( | ) |
default constructor
Definition at line 61 of file ossimH5Reader.cpp.
virtual destructor
Definition at line 84 of file ossimH5Reader.cpp.
References close(), and isOpen().
protected |
names | List of dataset paths from hdf5 file. |
Definition at line 370 of file ossimH5Reader.cpp.
References ossim_hdf5::getExtents(), ossimH5ImageDataset::initialize(), ossimH5Options::instance(), ossimH5Options::isDatasetRenderable(), m_entries, and m_h5File.
This will add metadata to keyword list if found. Implemented to pass specific data to keyword list if found, e.g. acquisition_date, sensor_id, country_code
Satisfies pure virtual ossimMetadataInterface::addMetadata(...)
kwl | Initialized by this. |
prefix | e.g. "image0." (can be empty) |
Implements ossimMetadataInterface.
Definition at line 920 of file ossimH5Reader.cpp.
References ossimKeywordlist::addPair(), ossim_hdf5::getDatasetAttributeValue(), ossim_hdf5::getGroupAttributeValue(), m_h5File, and ossimString::string().
protected |
Allocates the tile.
Definition at line 92 of file ossimH5Reader.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_mutex, and m_tile.
Referenced by getTile().
Close method.
Definition at line 511 of file ossimH5Reader.cpp.
References ossimImageHandler::close(), m_entries, m_h5File, m_projection, and m_tile.
Referenced by ~ossimH5ImageHandler().
Definition at line 469 of file ossimH5Reader.cpp.
Definition at line 602 of file ossimH5Reader.cpp.
References m_currentEntry.
protected |
entryList | This is the list to initialize with entry indexes. |
Definition at line 545 of file ossimH5Reader.cpp.
References m_entries.
Example given from HDF5 file:
entry_name: /All_Data/VIIRS-IMG-GTM-EDR-GEO_All/QF1_VIIRSGTMGEO
entryIdx | Zero based entry index. If out of range name will be cleared. |
name | Initialized by this. |
Definition at line 536 of file ossimH5Reader.cpp.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 607 of file ossimH5Reader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), m_mutex, and ossimImageHandler::theGeometry.
Note that rrds 0 is the highest resolution rrds.
Definition at line 222 of file ossimH5Reader.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Implements ossimImageHandler.
Definition at line 454 of file ossimH5Reader.cpp.
Definition at line 449 of file ossimH5Reader.cpp.
protectedvirtual |
Definition at line 647 of file ossimH5Reader.cpp.
References ossimRefPtr< T >::get(), ossim_hdf5::getBilinearProjection(), getLatLonDatasetNames(), isOpen(), m_currentEntry, m_entries, m_h5File, m_projection, processCoarseGridProjection(), ossimImageGeometry::setProjection(), and ossimRefPtr< T >::valid().
Referenced by getImageGeometry().
protected |
h5File | Pointer to file. |
latName | Initializes by this. |
lonName | Initializes by this. |
Definition at line 729 of file ossimH5Reader.cpp.
References ossimString::contains(), and ossim_hdf5::getDatasetNames().
Referenced by getInternalImageGeometry(), and getLatLonDatasets().
protected |
Initializes | lat and lon data sets. |
latDataSet | Initialized by this. |
lonDataSet | Initialized by this. |
Definition at line 774 of file ossimH5Reader.cpp.
References ossimFilename::dirCat(), ossimFilename::exists(), ossim_hdf5::getGroupAttributeValue(), getLatLonDatasetNames(), ossimFilename::path(), status, ossimString::string(), and ossimImageHandler::theImageFile.
Definition at line 464 of file ossimH5Reader.cpp.
Definition at line 853 of file ossimH5Reader.cpp.
References ossimImageHandler::getNullPixelValue(), getOutputScalarType(), and OSSIM_FLOAT32.
Definition at line 531 of file ossimH5Reader.cpp.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 474 of file ossimH5Reader.cpp.
References m_currentEntry, and m_entries.
Referenced by getNumberOfOutputBands(), and getTile().
Definition at line 417 of file ossimH5Reader.cpp.
References ossimImageHandler::getNumberOfLines(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 486 of file ossimH5Reader.cpp.
References getNumberOfInputBands().
Definition at line 433 of file ossimH5Reader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 492 of file ossimH5Reader.cpp.
References m_currentEntry, m_entries, and OSSIM_SCALAR_UNKNOWN.
Referenced by getNullPixelValue().
Overrides ossimImageHandler::getProperty.
name | Property name to get. |
Definition at line 895 of file ossimH5Reader.cpp.
References ossimString::string().
Overrides ossimImageHandler::getPropertyNames.
propertyNames | Array to initialize. |
Definition at line 913 of file ossimH5Reader.cpp.
References ossimImageHandler::getPropertyNames().
Satisfies pure virtual from TileSource class.
Definition at line 100 of file ossimH5Reader.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_mutex, m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 129 of file ossimH5Reader.cpp.
References ossimIrect::area(), ossimIrect::clipToRect(), ossimIrect::completely_within(), getImageRectangle(), ossimImageData::getImageRectangle(), getNullPixelValue(), ossimImageData::getNumberOfBands(), getNumberOfInputBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossim_hdf5::getScalarType(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::loadBand(), m_currentEntry, m_entries, m_mutex, ossimImageData::makeBlank(), OSSIM_FLOAT32, ossimReferenced::ref(), ossim::scalarSizeInBytes(), status, ossimReferenced::unref(), and ossimImageData::validate().
protected |
Definition at line 833 of file ossimH5Reader.cpp.
References ossim_hdf5::getGroupAttributeValue().
Definition at line 504 of file ossimH5Reader.cpp.
References m_currentEntry, m_entries, m_h5File, and true.
Referenced by getInternalImageGeometry(), getTile(), setCurrentEntry(), and ~ossimH5ImageHandler().
Definition at line 236 of file ossimH5Reader.cpp.
References ossimImageHandler::loadState(), and open().
protectedvirtual |
open method.
Definition at line 247 of file ossimH5Reader.cpp.
Referenced by loadState().
protected |
latDataSet | H5::DataSet& to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Latitude |
lonDataSet | H5::DataSet& to layer, e.g. /All_Data/VIIRS-DNB-GEO_All/Longitude |
Definition at line 698 of file ossimH5Reader.cpp.
References ossimRefPtr< T >::get().
Referenced by getInternalImageGeometry().
Definition at line 230 of file ossimH5Reader.cpp.
References ossimImageHandler::saveState().
entryIdx | Entry number to select. |
Definition at line 555 of file ossimH5Reader.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), isOpen(), m_currentEntry, m_entries, m_tile, ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
property | to set. |
Definition at line 871 of file ossimH5Reader.cpp.
References ossimProperty::getName(), ossimString::string(), and ossimRefPtr< T >::valid().
protected |
Definition at line 290 of file ossimH5Reader.h.
Referenced by getCurrentEntry(), getInternalImageGeometry(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and setCurrentEntry().
protected |
Definition at line 289 of file ossimH5Reader.h.
Referenced by addImageDatasetEntries(), close(), getEntryList(), getEntryNames(), getInternalImageGeometry(), getNumberOfEntries(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and setCurrentEntry().
protected |
Definition at line 288 of file ossimH5Reader.h.
Referenced by addImageDatasetEntries(), addMetadata(), close(), getInternalImageGeometry(), and isOpen().
protected |
Definition at line 293 of file ossimH5Reader.h.
Referenced by allocate(), getImageGeometry(), and getTile().
protected |
Definition at line 292 of file ossimH5Reader.h.
Referenced by close(), and getInternalImageGeometry().
protected |
Definition at line 291 of file ossimH5Reader.h.
Referenced by allocate(), close(), getTile(), and setCurrentEntry().
