ossimImageCacheTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Mingjie Su
8 //
9 //********************************************************************
10 // $Id: ossimImageCacheTileSource.cpp 2644 2011-05-26 15:20:11Z oscar.kramer $
11 #include <algorithm>
12 using namespace std;
13
15
22 #include <ossim/base/ossimCommon.h>
28 #include <ossim/base/ossimDatum.h>
29 #include <ossim/base/ossimNotify.h>
32
33 #include <ossim/base/ossimTrace.h>
35
36 static ossimTrace traceDebug = ossimTrace("ossimImageCacheTileSource:debug");
37
38 #ifdef OSSIM_ID_ENABLED
39 static const char OSSIM_ID[] = "$Id: ossimImageCacheTileSource.cpp 2644 2011-05-26 15:20:11Z oscar.kramer $";
40 #endif
41
42 RTTI_DEF1(ossimImageCacheTileSource, "ossimImageCacheTileSource", ossimImageCacheBase)
43
45  :
47  m_tile(0),
48  m_imageHandler(0),
49  m_minPixelValue(ossim::nan()),
50  m_maxPixelValue(ossim::nan()),
51  m_nullPixelValue(ossim::nan())
52 {
53 }
54
56 {
57  if(m_imageHandler.valid())
58  {
59  m_imageHandler = 0;
60  }
61  close();
62 }
63
65 {
66  return ossimString("ImageCache");
67 }
68
70 {
71  return ossimString("ImageCache reader");
72 }
73
74
76 {
77  deleteAll();
78 }
79
81 {
82  if(traceDebug())
83  {
84  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageCacheTileSource::open(): Entered....." << std::endl;
85  }
86
87  ossimFilename imageFile = theImageFile;
88  bool result = true;
89
90  if(isOpen() == false)
91  {
92  close();
93  result = false;
94  }
95
96  if(result)
97  {
98  if (m_fileNames.size() == 0 && m_frameEntryArray.size() == 0)
99  {
100  if (buildFrameEntryArray(imageFile) == false)
101  {
102  return false;
103  }
104  }
105
106  //---
107  // Adjust image rect so not to go over the -180 to 180 and -90 to 90
108  // bounds.
109  //---
110  setActualImageRect();
111
112  // Set the base class image file name.
113  theImageFile = imageFile;
114  m_tile = ossimImageDataFactory::instance()->create(this, this);
115  m_tile->initialize();
116  completeOpen();
117  }
118
119  if(traceDebug())
120  {
121  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimImageCacheTileSource::open(): Leaving at line" << __LINE__ << std::endl;
122  }
123
124  return result;
125 }
126
128 {
129  static const char MODULE[] = "ossimImageCacheTileSource::buildFrameEntryArray";
130  if ( traceDebug() )
131  {
132  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered..." << endl;
133  }
134
135  std::ifstream in((imageFile).c_str() );
136  std::string line;
137  ossim_uint32 index = 0; // used throughout
138  ossim_uint32 frameWidth = 0;
139  ossim_uint32 frameHeight = 0;
140  while( in.good() )
141  {
142  // Read in a line.
143  std::getline(in, line);
144  ossimString tmpStr = ossimString(line);
145  if (index == 0)
146  {
147  std::vector<ossimString> box_lat_lon;
148  tmpStr.split(box_lat_lon, "|");
149  if (box_lat_lon.size() == 4)
150  {
151  std::vector<ossimString> pixelInfos = box_lat_lon[3].split(",");
152  if (pixelInfos.size() == 3)
153  {
154  m_minPixelValue = ossimString::toFloat64(pixelInfos[0]);
155  m_maxPixelValue = ossimString::toFloat64(pixelInfos[1]);
156  m_nullPixelValue = ossimString::toFloat64(pixelInfos[2]);
157  }
158  }
159  }
160  else if (index == 1)
161  {
162  std::vector<ossimString> frame_lat_lon = tmpStr.split("|");
163  ossimFilename firstFile = frame_lat_lon[0];
164  if(m_workFrame->parseFile(firstFile) == ossimErrorCodes::OSSIM_ERROR)
165  {
166  m_imageHandler = ossimImageHandlerRegistry::instance()->open(firstFile);
167  if (m_imageHandler.valid())
168  {
169  frameWidth = m_imageHandler->getBoundingRect().width();
170  frameHeight = m_imageHandler->getBoundingRect().height();
171  break;
172  }
173  }
174  else
175  {
176  return false;
177  }
178  }
179  ++index;
180  }
181  in.close();
182
183  return ossimImageCacheBase::buildFrameEntryArray(imageFile, frameWidth, frameHeight);
184 }
185
187  const ossimIrect& rect, ossim_uint32 resLevel)
188 {
189  if (m_tile.valid())
190  {
191  // Image rectangle must be set prior to calling getTile.
192  m_tile->setImageRectangle(rect);
193
194  if ( getTile( m_tile.get(), resLevel ) == false )
195  {
196  if (m_tile->getDataObjectStatus() != OSSIM_NULL)
197  {
198  m_tile->makeBlank();
199  }
200  }
201  }
202
203  return m_tile;
204 }
205
207  ossim_uint32 resLevel)
208 {
209  bool status = false;
210
211  //---
212  // Not open, this tile source bypassed, or invalid res level,
213  // return a blank tile.
214  //---
215  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
216  result && (result->getNumberOfBands() == getNumberOfOutputBands()))
217  {
218  if ( resLevel > 0 )
219  {
220  status = getOverviewTile(resLevel, result);
221  }
222
223  if (!status) // Did not get an overview tile.
224  {
225  status = true;
226
227  ossimIrect rect = result->getImageRectangle();
228
229  ossimIrect imageRect = getImageRectangle();
230
231  if ( rect.intersects(imageRect) )
232  {
233  //---
234  // Start with a blank tile in case there is not total coverage
235  // for rect.
236  //---
237  result->makeBlank();
238
239  vector<ossimFrameEntryData> frames = getIntersectingEntries(rect);
240  if(frames.size() > 0)
241  {
242  //---
243  // Now lets render each frame. Note we will have to find
244  // subframes
245  // that intersect the rectangle of interest for each frame.
246  //---
247  fillTile(rect, frames, result);
248
249  // Revalidate tile status.
250  result->validate();
251  }
252  }
253  else
254  {
255  result->makeBlank();
256  }
257  }
258  }
259  return status;
260 }
261
263  const ossimIrect& tileRect,
264  const vector<ossimFrameEntryData>& framesInvolved,
265  ossimImageData* tile)
266 {
267  ossim_uint32 idx = 0;
268  for(idx = 0; idx < framesInvolved.size(); ++idx)
269  {
270  if (m_imageHandler.valid())
271  {
272  if (m_imageHandler->getFilename() != framesInvolved[idx].theFrameEntry.getFullPath())
273  {
274  m_imageHandler = 0;
275  m_imageHandler = ossimImageHandlerRegistry::instance()->open(framesInvolved[idx].theFrameEntry.getFullPath());
276  }
277  }
278  else
279  {
280  m_imageHandler = ossimImageHandlerRegistry::instance()->open(framesInvolved[idx].theFrameEntry.getFullPath());
281  }
282
283  if (m_imageHandler.valid())
284  {
285  if (m_imageHandler->isOpen() == false)
286  {
287  m_imageHandler->open(framesInvolved[idx].theFrameEntry.getFullPath());
288  }
289
290  ossimIrect frameRect(framesInvolved[idx].thePixelCol,
291  framesInvolved[idx].thePixelRow,
292  framesInvolved[idx].thePixelCol + m_frame_width - 1,
293  framesInvolved[idx].thePixelRow + m_frame_height - 1);
294
295  ossimIrect clipRect = tileRect.clipToRect(frameRect);
296
297  ossimIpt tempDelta(clipRect.ul().x - framesInvolved[idx].thePixelCol,
298  clipRect.ul().y - framesInvolved[idx].thePixelRow);
299
300  ossimIrect offsetRect(tempDelta.x,
301  tempDelta.y,
302  tempDelta.x + clipRect.width()-1,
303  tempDelta.y + clipRect.height()-1);
304
305  //if the current image size is different from the default size, resample the image data
306  if ( ( m_imageHandler->getBoundingRect().width() != m_frame_width ) ||
307  ( m_imageHandler->getBoundingRect().height() != m_frame_height ) )
308  {
309
310  //calculate the ratio
311  ossim_float64 widthRatio = static_cast<ossim_float64>(m_imageHandler->getBoundingRect().width())/static_cast<ossim_float64>(m_frame_width);
312  ossim_float64 heightRatio = static_cast<ossim_float64>(m_imageHandler->getBoundingRect().height())/static_cast<ossim_float64>(m_frame_height);
313
314  //initialize the rect bounding for getting image data from image handler
315  ossimDpt ul(offsetRect.ul().x*widthRatio, offsetRect.ul().y*heightRatio);
316  ossimDpt lr(offsetRect.lr().x*widthRatio, offsetRect.lr().y*heightRatio);
317
318  //---
319  // Floor, ceil to avoid rect size of zero from ul, lr, delta being only fractional
320  // resulting in size of 0 if cast to an int or passed to ossim<int>::round().
321  //---
322  ossimIrect actualOffsetRect(static_cast<ossim_int32>(std::floor(ul.x)),
323  static_cast<ossim_int32>(std::floor(ul.y)),
324  static_cast<ossim_int32>(std::ceil(lr.x)),
325  static_cast<ossim_int32>(std::ceil(lr.y)));
326
327  //get accurate rect in case the actual rect is larger than the rect of image
328  actualOffsetRect = actualOffsetRect.clipToRect(m_imageHandler->getBoundingRect());
329
330  ossimRefPtr<ossimImageData> imageData = m_imageHandler->getTile(actualOffsetRect);
331  if (imageData.valid())
332  {
333  ossimFilterResampler* resampler = new ossimFilterResampler();
334
335  double denominatorY = 1.0;
336  double denominatorX = 1.0;
337  if(clipRect.height() > 2) // Cannot be zero.
338  {
339  denominatorY = clipRect.height()-1.0;
340  }
341  if(clipRect.width() > 2) // Cannot be zero.
342  {
343  denominatorX = clipRect.width()-1.0;
344  }
345
346  //create a tile and set the rect size
347  ossimRefPtr<ossimImageData> tmpTile = (ossimImageData*)imageData->dup();
348  tmpTile->setImageRectangle(offsetRect);
349  tmpTile->makeBlank();
350
351  ossimDpt deltaUl(((actualOffsetRect.ll().x - actualOffsetRect.ul().x)/denominatorX),
352  ((actualOffsetRect.ll().y - actualOffsetRect.ul().y)/denominatorY));
353  ossimDpt deltaUr(((actualOffsetRect.lr().x - actualOffsetRect.ur().x)/denominatorX),
354  ((actualOffsetRect.lr().y - actualOffsetRect.ur().y)/denominatorY));
355  ossimDpt length(offsetRect.width(),offsetRect.height());
356
357  //resample the image data
358  resampler->resample(imageData,
359  tmpTile,
360  actualOffsetRect.ul(),
361  actualOffsetRect.ur(),
362  deltaUl,
363  deltaUr,
364  length);
365
366  tile->loadTile(tmpTile->getBuf(), clipRect, OSSIM_BSQ);
367
368  tmpTile = 0;
369  delete resampler;
370  resampler = 0;
371  }
372  }
373  else
374  {
375  ossimRefPtr<ossimImageData> imageData = m_imageHandler->getTile(offsetRect);
376  if (imageData.valid())
377  {
378  tile->loadTile(imageData->getBuf(), clipRect, OSSIM_BSQ);
379  }
380  }
381  }
382  }
383 }
384
386 {
387  if (m_imageHandler.valid())
388  {
389  return m_imageHandler->getOutputScalarType();
390  }
391  return OSSIM_UCHAR;
392 }
393
395 {
396  if (ossim::isnan(m_minPixelValue))
397  {
399  }
400  return m_minPixelValue;
401 }
402
404 {
405  if (ossim::isnan(m_maxPixelValue))
406  {
408  }
409  return m_maxPixelValue;
410 }
411
413 {
414  if (ossim::isnan(m_nullPixelValue))
415  {
417  }
418  return m_nullPixelValue;
419 }
420
422 {
423  if (m_imageHandler.valid())
424  {
425  return m_imageHandler->getNumberOfInputBands();
426  }
427  return m_numberOfBands;
428 }
429
431 {
432  if (m_imageHandler.valid())
433  {
434  return m_imageHandler->getNumberOfInputBands();
435  }
436  return m_numberOfBands;
437 }
virtual bool open()=0
Pure virtual open.
void fillTile(const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile)
bool buildFrameEntryArray(ossimFilename imageFile)
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
bool valid() const
Definition: ossimRefPtr.h:75
double nan()
Definition: ossimCommon.h:135
This code was derived from https://gist.github.com/mshockwave.
Definition: Barrier.h:8
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Returns a pointer to an ossimImageDataObject given a rectangluar region of interest.
ossim_uint32 height() const
Definition: ossimIrect.h:487
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual ossimString getShortName() const
This method is defined in the base class ossimObject.
static const ossimErrorCode OSSIM_ERROR
std::istream & getline(std::istream &is, ossimString &str, char delim)
Definition: ossimString.h:916
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
virtual ossim_uint32 getNumberOfInputBands() const
This method allows you to query the number of input bands.
virtual ~ossimImageCacheTileSource()
Destructor.
virtual ossimString getLongName() const
This method allows you to query the scalar type of the output data.
virtual void initialize()
Initialize the data buffer.
virtual ossimObject * dup() const
virtual bool open()
Pure virtual open.
Retuns the min pixel value.
double ossim_float64
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
unsigned int ossim_uint32
ossim_float64 toFloat64() const
virtual ossimIrect getImageRectangle() const
This method allows one to query the number of output bands.
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossimScalarType
return status
virtual void makeBlank()
bool buildFrameEntryArray(ossimFilename imageFile, ossim_uint32 frameWidth, ossim_uint32 frameHeight)
ossim_int32 y
Definition: ossimIpt.h:142
virtual void resample(const ossimRefPtr< ossimImageData > &input, ossimRefPtr< ossimImageData > &output, const ossimDpt &ul, const ossimDpt &ur, const ossimDpt &deltaUl, const ossimDpt &deltaUr, const ossimDpt &length)
static ossimImageHandlerRegistry * instance()
Returns zero-based bounding rectangle of the image.
ossim_int32 x
Definition: ossimIpt.h:141
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
virtual void close()
Closes this image handler and deletes any allocated data.
8 bit unsigned iteger
bool isnan(const float &v)
Definition: ossimCommon.h:91
