ossimImageCacheBase.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Mingjie Su
8 //
9 //********************************************************************
10 // $Id: ossimImageCacheBase.cpp 2685 2011-06-07 16:24:41Z david.burken $
11 #include <algorithm>
12 using namespace std;
13
15
21 #include <ossim/base/ossimCommon.h>
27 #include <ossim/base/ossimDatum.h>
28 #include <ossim/base/ossimNotify.h>
36 #include <ossim/base/ossimEndian.h>
37 #include <ossim/base/ossimTrace.h>
39
40 static ossimTrace traceDebug = ossimTrace("ossimImageCacheBase:debug");
41
42 #ifdef OSSIM_ID_ENABLED
43 static const char OSSIM_ID[] = "$Id: ossimImageCacheBase.cpp 2685 2011-06-07 16:24:41Z david.burken $";
44 #endif
45
46 RTTI_DEF1(ossimImageCacheBase, "ossimImageCacheBase", ossimImageHandler)
47
49  :
51  m_actualImageRect(),
52  m_numberOfLines(0),
53  m_numberOfSamples(0),
54  m_numberOfBands(0),
55  m_fileNames(),
56  m_tileSize(128, 128),
57  m_workFrame(new ossimRpfFrame),
58  m_bBox_LL_Lon(0.0),
59  m_bBox_LL_Lat(0.0),
60  m_bBox_UR_Lon(0.0),
61  m_bBox_UR_Lat(0.0),
62  m_numOfFramesVertical(0),
63  m_numOfFramesHorizontal(0),
64  m_frame_width(0),
65  m_frame_height(0),
66  m_frameEntryArray()
67 {
68  if (traceDebug())
69  {
71  << "ossimImageCacheBase::ossimImageCacheBase entered...\n";
72 #ifdef OSSIM_ID_ENABLED
74  << "OSSIM_ID: " << OSSIM_ID << "\n";
75 #endif
76  }
77
78  m_actualImageRect.makeNan();
79
80 }
81
83 {
84  if(m_workFrame)
85  {
86  delete m_workFrame;
87  m_workFrame = 0;
88  }
89  close();
90 }
91
93 {
94  deleteAll();
95 }
96
98 {
99  //return (theTableOfContents!=0);
100  ossimString ext = theImageFile.ext().downcase();
101
102  if(ext == "rpf")
103  {
104  return true;
105  }
106  else
107  {
108  return false;
109  }
110 }
111
113  ossim_uint32 frameWidth,
114  ossim_uint32 frameHeight)
115 {
116  static const char MODULE[] = "ossimImageCacheBase::buildFrameEntryArray";
117  if ( traceDebug() )
118  {
119  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered..." << endl;
120  }
121
122  // use to check if tiles have overlap pixels
123  ossim_float64 avgLat = 0.0;
124  ossim_float64 avgLon = 0.0;
125
126  m_frame_width = frameWidth;
127  m_frame_height = frameHeight;
128
129  std::ifstream in((imageFile).c_str() );
130
131  std::string line;
132  ossim_uint32 index = 0; // used throughout
133  while( in.good() )
134  {
135  // Read in a line.
136  std::getline(in, line);
137
138  ossimString tmpStr = ossimString(line);
139  if (!tmpStr.empty())
140  {
141  if (index == 0)
142  {
143  std::vector<ossimString> box_lat_lon;
144  tmpStr.split(box_lat_lon, "|");
145
146  if (box_lat_lon.size() > 2)
147  {
148  std::vector<ossimString> ll;
149  std::vector<ossimString> ur;
150
151  box_lat_lon[0].split(ll, ",");
152  box_lat_lon[1].split(ur, ",");
153  ossimString bandStr = box_lat_lon[2];
154
155  m_bBox_LL_Lon = ll[0].toFloat64();
156  m_bBox_LL_Lat = ll[1].toFloat64();
157  m_bBox_UR_Lon = ur[0].toFloat64();
158  m_bBox_UR_Lat = ur[1].toFloat64();
159
160  checkLongitude(m_bBox_LL_Lon, m_bBox_UR_Lon);
161
162  m_numberOfBands = ossimString(bandStr).toInt32();
163  }
164  else
165  {
166  return false;
167  }
168  }
169  else if (index == 1)
170  {
171  m_fileNames.push_back(tmpStr);
172  std::vector<ossimString> frame_lat_lon = tmpStr.split("|");
173  if (frame_lat_lon.size() > 2)
174  {
175  ossimString ll_lon_lat = frame_lat_lon[1];
176  ossimString ur_lon_lat = frame_lat_lon[2];
177  ossim_float64 ll_lon = ossimString(ll_lon_lat.split(",")[0]).toDouble();
178  ossim_float64 ll_lat = ossimString(ll_lon_lat.split(",")[1]).toDouble();
179  ossim_float64 ur_lon = ossimString(ur_lon_lat.split(",")[0]).toDouble();
180  ossim_float64 ur_lat = ossimString(ur_lon_lat.split(",")[1]).toDouble();
181
182  checkLongitude(ll_lon, ur_lon);
183
184  ossim_float64 bBox_lat_diff = std::fabs(m_bBox_UR_Lat - m_bBox_LL_Lat);
185  ossim_float64 bBox_lon_diff = std::fabs(m_bBox_UR_Lon - m_bBox_LL_Lon);
186
187  ossim_float64 lat_diff = std::fabs(ur_lat - ll_lat);
188  ossim_float64 lon_diff = std::fabs(ur_lon - ll_lon);
189
190  m_numOfFramesVertical = static_cast<ossim_uint32>(bBox_lat_diff/lat_diff + 0.5);
191  m_numOfFramesHorizontal = static_cast<ossim_uint32>(bBox_lon_diff/lon_diff + 0.5);
192
193  avgLon = std::fabs(bBox_lon_diff/m_numOfFramesHorizontal);
194  avgLat = std::fabs(bBox_lat_diff/m_numOfFramesVertical);
195
196  m_numberOfLines = m_numOfFramesVertical*m_frame_height;
197  m_numberOfSamples = m_numOfFramesHorizontal*m_frame_width;
198
199  if ( traceDebug() )
200  {
202  << "\nscene height in degrees: " << bBox_lat_diff
203  << "\nscene width in degrees: " << bBox_lon_diff
204  << "\nframe height in degrees: " << lat_diff
205  << "\nframe width in degrees: " << lon_diff
206  << "\nframes vertical: " << m_numOfFramesVertical
207  << "\nframes horizontal: " << m_numOfFramesHorizontal
208  << "\nlines: " << m_numberOfLines
209  << "\nsamples: " << m_numberOfSamples << "\n";
210  }
211  }
212  else
213  {
214  return false;
215  }
216  }
217  else
218  {
219  m_fileNames.push_back(tmpStr);
220  }
221
222  } // matches: if (!tmpStr.empty())
223
224  ++index;
225
226  } // matches: while( in.good() )
227  in.close();
228
229  m_frameEntryArray.resize(m_numOfFramesVertical);
230  for(index = 0; index < m_frameEntryArray.size(); ++index)
231  {
232  m_frameEntryArray[index].resize(m_numOfFramesHorizontal);
233  }
234
235  for(index = 0; index < m_fileNames.size(); ++index)
236  {
237  ossimString tmpStr = m_fileNames[index];
238  std::vector<ossimString> frameInfos = tmpStr.split("|");
239  if (frameInfos.size() > 1)
240  {
241  ossimString fileName = frameInfos[0];
242  ossimString ll_lon_lat = frameInfos[1];
243  ossimString ur_lon_lat = frameInfos[2];
244  double ll_lon = ossimString(ll_lon_lat.split(",")[0]).toDouble();
245  double ll_lat = ossimString(ll_lon_lat.split(",")[1]).toDouble();
246  double ur_lon = ossimString(ur_lon_lat.split(",")[0]).toDouble();
247  double ur_lat = ossimString(ur_lon_lat.split(",")[1]).toDouble();
248
249  checkLongitude(ll_lon, ur_lon);
250
251  ossim_float64 tmpColPostion = std::fabs(ll_lon - m_bBox_LL_Lon);
252  ossim_float64 tmpFrameLon = std::fabs(ur_lon - ll_lon);
253
254  if (std::fabs(tmpFrameLon - avgLon) > 0.002)
255  {
256  ossimNotify(ossimNotifyLevel_WARN) << fileName << " has overlap pixels with other image." << std::endl;
257  return false;
258  }
259
260  ossim_float64 tmpRowPostion = std::fabs(m_bBox_UR_Lat - ur_lat);
261  ossim_float64 tmpFrameLat = std::fabs(ur_lat - ll_lat);
262
263  if (std::fabs(tmpFrameLat - avgLat) > 0.002)
264  {
265  ossimNotify(ossimNotifyLevel_WARN) << fileName << " has overlap pixels with other image." << std::endl;
266  return false;
267  }
268
269  ossim_uint32 colNum = static_cast<ossim_uint32>(tmpColPostion/tmpFrameLon + 0.5);
270  ossim_uint32 rowNum = static_cast<ossim_uint32>(tmpRowPostion/tmpFrameLat + 0.5);
271
272  if (colNum >= m_numOfFramesHorizontal)
273  {
274  colNum = m_numOfFramesHorizontal-1; // Clamp to last column.
275  }
276
277  if (rowNum >= m_numOfFramesVertical)
278  {
279  rowNum = m_numOfFramesVertical-1; // Clamp to last row.
280  }
281
282  ossimRpfFrameEntry tempEntry;
283  tempEntry.setEntry(ossimFilename(""), fileName);
284  m_frameEntryArray[rowNum][colNum] = tempEntry;
285  }
286  else
287  {
288  return false;
289  }
290  }
291
292  return true;
293 }
294
296  const ossim_float64& rightLon) const
297 {
298  //---
299  // Test for scene coordinates being 180 to 180 and adjust leftLon to -180
300  // if so.
301  //
302  // NOTE:
303  // Setting tolerance to 1/7200 about 15 meters.
304  // Not sure if this is too loose or not. (drb)
305  //---
306  const ossim_float64 TOLERANCE = 0.000138889; // 1/7200 about 15 meters.
307
308  if ( ossim::almostEqual(leftLon, 180.0, TOLERANCE) )
309  {
310  if ( ossim::almostEqual(rightLon, 180.0, TOLERANCE) )
311  {
312  leftLon = -180.0;
313  }
314  }
315 }
316
318 {
319  return m_numberOfBands;
320 }
321
323 {
324  return m_numberOfBands;
325 }
326
328 {
329  if (reduced_res_level == 0)
330  {
331  return m_numberOfLines;
332  }
333  else if (theOverview.valid())
334  {
335  return theOverview->getNumberOfLines(reduced_res_level);
336  }
337
338  return 0;
339 }
340
342 {
343  if (reduced_res_level == 0)
344  {
345  return m_numberOfSamples;
346  }
347  else if (theOverview.valid())
348  {
349  return theOverview->getNumberOfSamples(reduced_res_level);
350  }
351
352  return 0;
353 }
354
356 {
357  m_actualImageRect = ossimIrect(0,0,m_numberOfLines, m_numberOfSamples);
358 }
359
361 {
362  return ossimIrect(0, // upper left x
363  0, // upper left y
364  getNumberOfSamples(reduced_res_level) - 1, // lower right x
365  getNumberOfLines(reduced_res_level) - 1); // lower right y
366 }
367
368
369
371 {
372  return m_tileSize.x;
373 }
374
376 {
377  return m_tileSize.y;
378 }
379
380 void ossimImageCacheBase::getEntryList(std::vector<ossim_uint32>& entryList)const
381 {
382  entryList.push_back(0);
383 }
384
386 {
387  if (reduced_res_level == 0)
388  {
389  return true;
390  }
391  else if (theOverview.valid())
392  {
393  return theOverview->isValidRLevel(reduced_res_level);
394  }
395  else
396  {
397  return false;
398  }
399 }
400
401 vector<ossimImageCacheBase::ossimFrameEntryData> ossimImageCacheBase::getIntersectingEntries(const ossimIrect& rect)
402 {
403  vector<ossimFrameEntryData> result;
404
405  // make sure we have the Toc entry to render
406  if(!isOpen()) return result;
407
408  ossimIrect imageRect = getImageRectangle();
409  if(rect.intersects(imageRect))
410  {
411  ossimIrect clipRect = rect.clipToRect(imageRect);
412  ossimIrect frameRect(clipRect.ul().x/m_frame_width,
413  clipRect.ul().y/m_frame_height,
414  clipRect.lr().x/m_frame_width,
415  clipRect.lr().y/m_frame_height);
416
417  for(ossim_int32 row = frameRect.ul().y; row <= frameRect.lr().y; ++row)
418  {
419  for(ossim_int32 col = frameRect.ul().x; col <= frameRect.lr().x; ++col)
420  {
421  ossimRpfFrameEntry tempEntry = m_frameEntryArray[row][col];
422  if(tempEntry.exists())
423  {
424  result.push_back(ossimFrameEntryData(row,
425  col,
426  row*m_frame_height,
427  col*m_frame_width,
428  tempEntry));
429  }
430  }
431  }
432  }
433
434  return result;
435 }
436
438 {
439  theOverview = 0;
440 }
441
443  const char* prefix)const
444 {
445  bool result = ossimImageHandler::saveState(kwl, prefix);
446
447  return result;
448 }
449
451  const char* prefix)
452 {
453  const char* MODULE = "ossimImageCacheBase::loadState";
454
455  if(traceDebug())
456  {
457  CLOG << "Entering..." << endl;
458  }
459  bool result = ossimImageHandler::loadState(kwl, prefix);
460
461  if(!result)
462  {
463  if(traceDebug())
464  {
465  CLOG << "Leaving..." << endl;
466  }
467  return false;
468  }
469  const char* lookup = 0;
470  lookup = kwl.find(ossimString(prefix), "entry");
471  ossim_int32 entry = ossimString(lookup).toInt32();
472
473  // if an entry is specified then
474  // call the open with an entry number
475  if(lookup)
476  {
477  if(traceDebug())
478  {
479  CLOG << "Leaving..." << endl;
480  }
481  result = ossimImageHandler::open(theImageFile);
482  setCurrentEntry(entry);
483  return result;
484  }
485
486  result = ossimImageHandler::open(theImageFile);
487
488  return result;
489 }
490
492 {
493  return 256;
494 }
495
497 {
498  return 256;
499 }
500
502 {
503  theDecimationFactors.clear();
504
505  // Just needed to set the first R level here, the base class can do the rest:
507 }
508
510 {
511  if (theGeometry.valid()) return theGeometry;
512
513  // datum
514  // WGS 84
515  ossimKeywordlist kwl;
516  const char* prefix = 0; // legacy
517  kwl.add(prefix,
519  "WGE",
520  true);
521
522  ossimGpt ul(m_bBox_UR_Lat,m_bBox_LL_Lon);
523  ossimGpt ll(m_bBox_LL_Lat,m_bBox_LL_Lon);
524  ossimGpt ur(m_bBox_UR_Lat,m_bBox_UR_Lon);
525  ossimGpt lr(m_bBox_LL_Lat,m_bBox_UR_Lon);
526
527  double latInterval = fabs(ul.latd() - lr.latd())/ getNumberOfLines();
528  double lonInterval = fabs(ul.lond() - ur.lond())/ getNumberOfSamples();
529
530  kwl.add(prefix,
532  ul.latd(),//-(latInterval/2.0),
533  true);
534
535  kwl.add(prefix,
537  ul.lond(),//+(lonInterval/2.0),
538  true);
539
540  kwl.add(prefix,
542  ll.latd(),//+(latInterval/2.0),
543  true);
544
545  kwl.add(prefix,
547  ll.lond(),//+(lonInterval/2.0),
548  true);
549
550  kwl.add(prefix,
552  lr.latd(),//+(latInterval/2.0),
553  true);
554
555  kwl.add(prefix,
557  lr.lond(),//-(lonInterval/2.0),
558  true);
559
560  kwl.add(prefix,
562  ur.latd(),//-(latInterval/2.0),
563  true);
564
565  kwl.add(prefix,
567  ur.lond(),//-(latInterval/2.0),
568  true);
569
570  kwl.add(prefix,
572  getNumberOfInputBands(),
573  true);
574
575  kwl.add(prefix,
577  getNumberOfOutputBands(),
578  true);
579
580  kwl.add(prefix,
582  getNumberOfLines(),
583  true);
584
585  kwl.add(prefix,
587  getNumberOfSamples(),
588  true);
589
590
591  //---
592  // Make a projection to get the easting / northing of the tie point and
593  // the scale in meters. This will only be used by the CIB.
594  //---
595  kwl.add(prefix,
597  "WGE",
598  true);
599
600  ossimGpt origin((ul.latd()+lr.latd())*.5,
601  (ul.lond()+lr.lond())*.5,
602  0.0);
603
604  double deltaLatPerPixel = latInterval;
605  double deltaLonPerPixel = lonInterval;
606
607  ossimDpt tie;
608
609  tie.lat = ul.latd() - deltaLatPerPixel/2.0;
610  tie.lon = ul.lond() + deltaLonPerPixel/2.0;
611
612  kwl.add(prefix,
614  tie.toString(),
615  true);
616
617  kwl.add(prefix,
619  deltaLatPerPixel,
620  true);
621
622  kwl.add(prefix,
624  deltaLonPerPixel,
625  true);
626
627  kwl.add(prefix,
629  origin.latd(),
630  true);
631
632  kwl.add(prefix,
634  origin.lond(),
635  true);
636
637  kwl.add(prefix,
639  ul.latd()-(deltaLatPerPixel/2.0),
640  true);
641
642  kwl.add(prefix,
644  ul.lond()+(deltaLonPerPixel/2.0),
645  true);
646
647  kwl.add(prefix,
649  "ossimEquDistCylProjection",
650  true);
651
652  // Capture this for next time.
653  theGeometry = new ossimImageGeometry;
654  theGeometry->loadState(kwl, prefix);
655
656  // Set image things the geometry object should know about.
657  initImageParameters( theGeometry.get() );
658
659  return theGeometry;
660 }
661
virtual bool open()=0
Pure virtual open.
virtual ossim_uint32 getNumberOfInputBands() const
This method allows you to query the number of input bands.
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
static const char * DATUM_KW
#define CLOG
Definition: ossimTrace.h:23
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
static const char * CENTRAL_MERIDIAN_KW
static const char * UL_LAT_KW
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
bool isValidRLevel(ossim_uint32 reduced_res_level) const
Attempts to initialize a transform and a projection given the KWL.
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
virtual ossim_uint32 getImageTileWidth() const
Protected structure that is only used internally by this class.
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
static const char * NUMBER_INPUT_BANDS_KW
const ossimIpt & ul() const
Definition: ossimIrect.h:274
static const char * LR_LON_KW
Method to load the state of an object from a keyword list.
std::istream & getline(std::istream &is, ossimString &str, char delim)
Definition: ossimString.h:916
This method allows one to query the number of output bands.
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
double latd() const
Definition: ossimGpt.h:87
static const char * TYPE_KW
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Satisfies pure virtual requirement from ImageHandler class.
virtual ossim_uint32 getTileHeight() const
Returns the height of the output tile.
vector< ossimFrameEntryData > getIntersectingEntries(const ossimIrect &rect)
It is important to note that each frame is organized into an easting northing type orientation...
ossim_int32 toInt32() const
double ossim_float64
static const char * LR_LAT_KW
double lat
Definition: ossimDpt.h:165
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
static const char * TIE_POINT_XY_KW
void setActualImageRect()
Will shift the rect and clamp it so not to go outside the -180 to 180 degree range.
static const char * LL_LON_KW
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Populates the geometry object with image geometry information.
unsigned int ossim_uint32
static const char * NUMBER_OUTPUT_BANDS_KW
void setEntry(const ossimFilename &rootDirectory, const ossimFilename &pathToFrameFileFromRoot)
ossim_float64 toFloat64() const
void checkLongitude(ossim_float64 &leftLon, const ossim_float64 &rightLon) const
Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180...
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
static const char * LL_LAT_KW
const ossimIpt & lr() const
Definition: ossimIrect.h:276
bool isOpen() const
Determines if its open if there eists a table of contents object.
double lon
Definition: ossimDpt.h:164
virtual ossim_uint32 getImageTileHeight() const
virtual void establishDecimationFactors()
Virtual method determines the decimation factors at each resolution level.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
static const char * ORIGIN_LATITUDE_KW
virtual void close()
Closes this image handler and deletes any allocated data.
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
This class defines an abstract Handler which all image handlers(loaders) should derive from...
bool buildFrameEntryArray(ossimFilename imageFile, ossim_uint32 frameWidth, ossim_uint32 frameHeight)
ossim_int32 y
Definition: ossimIpt.h:142
static const char * UL_LON_KW
virtual ~ossimImageCacheBase()
Destructor.
static const char * UR_LAT_KW
static const char * UR_LON_KW
bool empty() const
Definition: ossimString.h:411
ossim_int32 x
Definition: ossimIpt.h:141
static const char * TIE_POINT_LAT_KW
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
static const char * NUMBER_SAMPLES_KW
int ossim_int32
virtual ossim_uint32 getTileWidth() const
Returns the width of the output tile.
