ossimImageGeometryRegistry.cpp
Go to the documentation of this file.
1 //**************************************************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description: Class implementation of ossimImageGeometryRegistry. See .h file for class documentation.
8 //
9 //**************************************************************************************************
10 // $Id$
17 {
18  if(!m_instance)
19  {
23  }
24
25  return m_instance;
26 }
27
29 {
30  bool result = false;
31  ossim_uint32 idx = 0;
32  for(;((idx < m_factoryList.size())&&!result); ++idx)
33  {
34  result = m_factoryList[idx]->extendGeometry(handler);
35  }
36
37  return result;
38 }
39
41 {
43
44  ossimRefPtr<ossimImageGeometry> geomResult = dynamic_cast<ossimImageGeometry*>(obj.get());
45
46  obj = 0;
47
48  return geomResult.release();
49 }
50
52  const char* prefix)const
53 {
55
56  ossimRefPtr<ossimImageGeometry> geomResult = dynamic_cast<ossimImageGeometry*>(obj.get());
57
58  obj = 0;
59
60  return geomResult.release();
61 }
62
64  ossim_uint32 entryIdx)const
65 {
66  ossimImageGeometry* result = 0;
67  ossim_uint32 idx = 0;
68  for(;((idx < m_factoryList.size())&&!result); ++idx)
69  {
70  result = m_factoryList[idx]->createGeometry(filename, entryIdx);
71  }
72
73  return result;
74 }
static ossimImageGeometryRegistry * instance()
static ossimImageGeometryFactory * instance()
static ossimObjectFactoryRegistry * instance()
virtual bool extendGeometry(ossimImageHandler *handler) const
virtual ossimImageGeometry * createGeometry(const ossimString &typeName) const
RTTI_DEF1(ossimImageGeometryRegistry, "ossimImageGeometryRegistry", ossimImageGeometryFactoryBase)
unsigned int ossim_uint32
T * release()
Definition: ossimRefPtr.h:93
void registerFactory(T *factory, bool pushToFrontFlag=false)
Will register a factory to the factory list.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
static ossimImageGeometryRegistry * m_instance
ossimObject * createObjectFromRegistry(const ossimString &typeName) const
This is the base object return for all objects in the system.
