Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimImageGeometryRegistry Class Reference
#include <ossimImageGeometryRegistry.h>
Inheritance diagram for ossimImageGeometryRegistry:
ossimImageGeometryFactoryBase ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry > ossimBaseObjectFactory ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimImageGeometryRegistry ()
virtual ossimImageGeometrycreateGeometry (const ossimString &typeName) const
virtual ossimImageGeometrycreateGeometry (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossimImageGeometrycreateGeometry (const ossimFilename &filename, ossim_uint32 entryIdx) const
virtual bool extendGeometry (ossimImageHandler *handler) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimImageGeometryFactoryBase
virtual ossimObjectcreateObject (const ossimString &typeName) const
 Creates an object given a type name. More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
- Public Member Functions inherited from ossimBaseObjectFactory
 ossimBaseObjectFactory ()
virtual ~ossimBaseObjectFactory ()
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
- Public Member Functions inherited from ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry >
 ossimFactoryListInterface ()
void addFactory (ossimImageGeometryFactoryBase *factory)
 This is for backward compatability and calls registerFactory for simple adds. More...
bool isFactoryRegistered (ossimImageGeometryFactoryBase *factory) const
 Public access method to determine if a factory is already registered to this list. More...
void registerFactory (ossimImageGeometryFactoryBase *factory, bool pushToFrontFlag=false)
 Will register a factory to the factory list. More...
void unregisterFactory (ossimImageGeometryFactoryBase *factory)
 Will remove the factory from the registry. More...
void unregisterFactory (const ossimString &factoryTypeName)
 Will remove the factory from the registry by name. More...
void unregisterAllFactories ()
 Will remove all factories from the registry. More...
void registerFactoryToFront (ossimImageGeometryFactoryBase *factory)
 Inserts the factory to the front of the list. More...
void registerFactoryBefore (ossimImageGeometryFactoryBase *factory, ossimImageGeometryFactoryBase *beforeThisFactory)
 Will insert the factory before the beforeThisFactory. More...
void getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const
 Will add all object types the factories can allocate. More...
ossimObjectcreateObjectFromRegistry (const ossimString &typeName) const
 This is the base object return for all objects in the system. More...
ossimObjectcreateObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const
ossimImageGeometrycreateNativeObjectFromRegistry (const ossimString &typeName) const
 This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More...
ossimImageGeometrycreateNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const
static ossimImageGeometryRegistryinstance ()
- Static Public Member Functions inherited from ossimBaseObjectFactory
static ossimBaseObjectFactoryinstance ()
 ossimImageGeometryRegistry (const ossimImageGeometryRegistry &rhs)
void operator= (const ossimImageGeometryRegistry &)
virtual ~ossimReferenced ()
- Protected Member Functions inherited from ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry >
bool findFactory (ossimImageGeometryFactoryBase *factory) const
 Utility to find a factory in the list. More...
static ossimImageGeometryRegistrym_instance = 0
Additional Inherited Members
- Public Types inherited from ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry >
typedef std::vector< ossimImageGeometryFactoryBase *> FactoryListType
typedef ossimImageGeometryFactoryBase FactoryType
typedef ossimImageGeometry NativeReturnType
- Protected Attributes inherited from ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry >
std::mutex m_factoryListMutex
FactoryListType m_factoryList
Detailed Description
Definition at line 17 of file ossimImageGeometryRegistry.h.
◆ ~ossimImageGeometryRegistry()
virtual ossimImageGeometryRegistry::~ossimImageGeometryRegistry ( )
inlinevirtual
Definition at line 22 of file ossimImageGeometryRegistry.h.
22 {m_instance=0;}
static ossimImageGeometryRegistry * m_instance
◆ ossimImageGeometryRegistry() [1/2]
ossimImageGeometryRegistry::ossimImageGeometryRegistry ( )
inlineprotected
◆ ossimImageGeometryRegistry() [2/2]
ossimImageGeometryRegistry::ossimImageGeometryRegistry ( const ossimImageGeometryRegistry rhs)
inlineprotected
Member Function Documentation
◆ createGeometry() [1/3]
ossimImageGeometry * ossimImageGeometryRegistry::createGeometry ( const ossimString typeName) const
virtual
Implements ossimImageGeometryFactoryBase.
Definition at line 40 of file ossimImageGeometryRegistry.cpp.
References ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry >::createObjectFromRegistry(), ossimRefPtr< T >::get(), and ossimRefPtr< T >::release().
Referenced by ossimKakaduJpipHandler::getImageGeometry().
41 {
43
44  ossimRefPtr<ossimImageGeometry> geomResult = dynamic_cast<ossimImageGeometry*>(obj.get());
45
46  obj = 0;
47
48  return geomResult.release();
49 }
T * release()
Definition: ossimRefPtr.h:93
ossimObject * createObjectFromRegistry(const ossimString &typeName) const
◆ createGeometry() [2/3]
ossimImageGeometry * ossimImageGeometryRegistry::createGeometry ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Definition at line 51 of file ossimImageGeometryRegistry.cpp.
53 {
55
56  ossimRefPtr<ossimImageGeometry> geomResult = dynamic_cast<ossimImageGeometry*>(obj.get());
57
58  obj = 0;
59
60  return geomResult.release();
61 }
T * release()
◆ createGeometry() [3/3]
ossimImageGeometry * ossimImageGeometryRegistry::createGeometry ( const ossimFilename filename,
) const
virtual
Definition at line 63 of file ossimImageGeometryRegistry.cpp.
References ossimFactoryListInterface< ossimImageGeometryFactoryBase, ossimImageGeometry >::m_factoryList.
65 {
66  ossimImageGeometry* result = 0;
67  ossim_uint32 idx = 0;
68  for(;((idx < m_factoryList.size())&&!result); ++idx)
69  {
70  result = m_factoryList[idx]->createGeometry(filename, entryIdx);
71  }
72
73  return result;
74 }
unsigned int ossim_uint32
◆ extendGeometry()
bool ossimImageGeometryRegistry::extendGeometry ( ossimImageHandler handler) const
virtual
◆ getTypeNameList()
virtual void ossimImageGeometryRegistry::getTypeNameList ( std::vector< ossimString > &  typeList) const
inlinevirtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Reimplemented from ossimBaseObjectFactory.
Definition at line 56 of file ossimImageGeometryRegistry.h.
References ossimFactoryListInterface< T, NativeType >::getAllTypeNamesFromRegistry().
57  {
59  }
void getAllTypeNamesFromRegistry(std::vector< ossimString > &typeList) const
◆ instance()
ossimImageGeometryRegistry * ossimImageGeometryRegistry::instance ( )
static
Definition at line 16 of file ossimImageGeometryRegistry.cpp.
References ossimImageGeometryFactory::instance(), ossimObjectFactoryRegistry::instance(), m_instance, ossimImageGeometryRegistry(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
Referenced by ossimERSTileSource::getImageGeometry(), ossimKakaduJpipHandler::getImageGeometry(), ossimplugins::ossimRadarSat2TiffReader::getImageGeometry(), ossimplugins::ossimTerraSarTiffReader::getImageGeometry(), ossimGdalTileSource::getImageGeometry(), ossimUsgsDemTileSource::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimOpjJp2Reader::getImageGeometry(), ossimJpegTileSource::getImageGeometry(), ossimMG4LidarReader::getImageGeometry(), ossimGeoPdfReader::getImageGeometry(), ossimMrSidReader::getImageGeometry(), ossimH5ImageHandler::getImageGeometry(), ossimLasReader::getImageGeometry(), ossimKakaduJp2Reader::getImageGeometry(), ossimGpkgReader::getImageGeometry(), ossimImageHandler::getImageGeometry(), ossimInit::initializeDefaultFactories(), ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
17 {
18  if(!m_instance)
19  {
23  }
24
25  return m_instance;
26 }
static ossimImageGeometryFactory * instance()
static ossimObjectFactoryRegistry * instance()
void registerFactory(T *factory, bool pushToFrontFlag=false)
◆ operator=()
void ossimImageGeometryRegistry::operator= ( const ossimImageGeometryRegistry )
inlineprotected
Definition at line 69 of file ossimImageGeometryRegistry.h.
69 {}
Member Data Documentation
◆ m_instance
ossimImageGeometryRegistry * ossimImageGeometryRegistry::m_instance = 0
staticprotected
Definition at line 70 of file ossimImageGeometryRegistry.h.
Referenced by instance().
