10 #ifndef ossimImageHandlerMtAdaptor_HEADER 11 #define ossimImageHandlerMtAdaptor_HEADER 1 55 virtual bool isOpen()
const;
73 void setUseCache(
bool use_cache);
74 void writeTime()
const;
virtual bool open()=0
Pure virtual open.
ossimRefPtr< ossimImageHandler > m_adaptedHandler
ossim_uint32 d_cacheTileSize
Intended mainly to provide a mechanism for mutex-locking access to a shared resource during a getTile...
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
bool canConnectMyInputTo(ossim_int32 inputIndex, const ossimConnectableObject *object) const
Connection rule.
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
Retuns the min pixel value.
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
virtual void close()
For debugging purposes. To be removed with final release:
static const char * ADAPTEE_ID_KW
virtual ossim_uint32 getImageTileWidth() const =0
ossimRefPtr< ossimCacheTileSource > m_cache
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
ossimRefPtr< ossimImageData > d_fauxTile
