9 #ifndef ossimMemoryImageSource_HEADER 10 #define ossimMemoryImageSource_HEADER 1 26 m_boundingRect(src.m_boundingRect)
ossimMemoryImageSource(const ossimMemoryImageSource &src)
This will return the bounding rect of the source.
ossimMemoryImageSource * dup() const
virtual ossim_uint32 getNumberOfDecimationLevels() const
Will return the number of resolution levels.
ossimRefPtr< ossimImageData > m_image
ossimRefPtr< ossimImageGeometry > m_geometry
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
unsigned int ossim_uint32
ossimIrect m_boundingRect
virtual void setImageGeometry(ossimImageGeometry *geom)
Default implementation sets geometry of the first input to the geometry specified.
ossimRefPtr< ossimImageData > m_result
virtual void initialize()=0
virtual bool canConnectMyInputTo(ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0
required to be overriden by derived classes
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
virtual void getDecimationFactors(std::vector< ossimDpt > &decimations) const
Will return an array of all decimations for each resolution level.
