Public Member Functions | Protected Attributes | List of all members
ossimMemoryImageSource Class Reference
#include <ossimMemoryImageSource.h>
Inheritance diagram for ossimMemoryImageSource:
ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimMemoryImageSource ()
 ossimMemoryImageSource (const ossimMemoryImageSource &src)
ossimMemoryImageSourcedup () const
void setImage (ossimRefPtr< ossimImageData > image)
void setImage (ossimScalarType scalarType, ossim_uint32 numberOfBands, ossim_uint32 width, ossim_uint32 height)
void setRect (ossim_uint32 ulx, ossim_uint32 uly, ossim_uint32 width, ossim_uint32 height)
virtual bool canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const
virtual void initialize ()
 save state is not implemented for this source and only passes to the base. More...
 loadState is here so one can construct a memory source as a blank tile. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
ossimRefPtr< ossimImageDatam_image
ossimRefPtr< ossimImageDatam_result
ossimRefPtr< ossimImageGeometrym_geometry
ossimIrect m_boundingRect
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 17 of file ossimMemoryImageSource.h.
◆ ossimMemoryImageSource() [1/2]
ossimMemoryImageSource::ossimMemoryImageSource ( )
Definition at line 16 of file ossimMemoryImageSource.cpp.
References m_boundingRect, and ossimIrect::makeNan().
17  :ossimImageSource(0, 0, 1, true, false)
18 {
20 }
ossimImageSource(ossimObject *owner=0)
void makeNan()
Definition: ossimIrect.h:329
◆ ossimMemoryImageSource() [2/2]
ossimMemoryImageSource::ossimMemoryImageSource ( const ossimMemoryImageSource src)
inline
Definition at line 21 of file ossimMemoryImageSource.h.
22  :ossimImageSource(src),
24  m_result(0),
27  {
28  }
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimImageData > m_image
ossimRefPtr< ossimImageGeometry > m_geometry
virtual ossimObject * dup() const
ossimRefPtr< ossimImageData > m_result
Creates a new instance of ossimImageGeometry with the same transform and projection.
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimMemoryImageSource::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
virtual
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 162 of file ossimMemoryImageSource.cpp.
164 {
165  return false;
166 }
◆ dup()
ossimMemoryImageSource* ossimMemoryImageSource::dup ( ) const
inlinevirtual
Definition at line 29 of file ossimMemoryImageSource.h.
30  {
31  return new ossimMemoryImageSource(*this);
32  }
◆ getBoundingRect()
ossimIrect ossimMemoryImageSource::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 126 of file ossimMemoryImageSource.cpp.
References ossimImageSource::getBoundingRect(), m_boundingRect, m_image, and ossimRefPtr< T >::valid().
127 {
128  if(resLevel == 0)
129  {
130  if(m_image.valid())
131  {
132  return m_boundingRect;
133  }
134  }
135
136  return ossimImageSource::getBoundingRect(resLevel);
137 }
bool valid() const
◆ getDecimationFactor()
void ossimMemoryImageSource::getDecimationFactor ( ossim_uint32  resLevel,
ossimDpt result
) const
virtual
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 178 of file ossimMemoryImageSource.cpp.
References ossimDpt::x, and ossimDpt::y.
180 {
181  if (resLevel == 0)
182  {
183  result.x = 1.0;
184  result.y = 1.0;
185  }
186  else
187  {
188  result.x = 1.0 / (1<<resLevel);
189  result.y = result.x;
190  }
191 }
double y
Definition: ossimDpt.h:165
double x
Definition: ossimDpt.h:164
◆ getDecimationFactors()
void ossimMemoryImageSource::getDecimationFactors ( std::vector< ossimDpt > &  decimations) const
virtual
Will return an array of all decimations for each resolution level.
Definition at line 193 of file ossimMemoryImageSource.cpp.
194 {
195  decimations.push_back(ossimDpt(1.0,1.0));
196 }
◆ getImageGeometry()
virtual ossimRefPtr<ossimImageGeometry> ossimMemoryImageSource::getImageGeometry ( )
inlinevirtual
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world) Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 67 of file ossimMemoryImageSource.h.
68  {
69  return m_geometry;
70  }
◆ getMaxPixelValue()
double ossimMemoryImageSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 114 of file ossimMemoryImageSource.cpp.
References ossimImageData::getMaxPix(), ossimImageSource::getMaxPixelValue(), getNumberOfInputBands(), m_image, and ossimRefPtr< T >::valid().
115 {
116  if(m_image.valid())
117  {
118  if(band < getNumberOfInputBands())
119  {
120  return m_image->getMaxPix(band);
121  }
122  }
124 }
virtual const ossim_float64 * getMaxPix() const
bool valid() const
virtual ossim_uint32 getNumberOfInputBands() const
◆ getMinPixelValue()
double ossimMemoryImageSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 102 of file ossimMemoryImageSource.cpp.
References ossimImageData::getMinPix(), ossimImageSource::getMinPixelValue(), getNumberOfInputBands(), m_image, and ossimRefPtr< T >::valid().
103 {
104  if(m_image.valid())
105  {
106  if(band < getNumberOfInputBands())
107  {
108  return m_image->getMinPix(band);
109  }
110  }
112 }
bool valid() const
virtual const ossim_float64 * getMinPix() const
◆ getNullPixelValue()
double ossimMemoryImageSource::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 90 of file ossimMemoryImageSource.cpp.
References ossimImageData::getNullPix(), ossimImageSource::getNullPixelValue(), getNumberOfInputBands(), m_image, and ossimRefPtr< T >::valid().
91 {
92  if(m_image.valid())
93  {
94  if(band < getNumberOfInputBands())
95  {
96  return m_image->getNullPix(band);
97  }
98  }
100 }
bool valid() const
virtual const ossim_float64 * getNullPix() const
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimMemoryImageSource::getNumberOfDecimationLevels ( ) const
virtual
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 173 of file ossimMemoryImageSource.cpp.
174 {
175  return 1;
176 }
◆ getNumberOfInputBands()
ossim_uint32 ossimMemoryImageSource::getNumberOfInputBands ( ) const
virtual
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 66 of file ossimMemoryImageSource.cpp.
References ossimImageData::getNumberOfBands(), m_image, and ossimRefPtr< T >::valid().
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), and getNumberOfOutputBands().
67 {
68  if(m_image.valid())
69  {
70  return m_image->getNumberOfBands();
71  }
72  return 0;;
73 }
bool valid() const
◆ getNumberOfOutputBands()
ossim_uint32 ossimMemoryImageSource::getNumberOfOutputBands ( ) const
virtual
Definition at line 75 of file ossimMemoryImageSource.cpp.
References getNumberOfInputBands().
Referenced by getTile().
76 {
77  return getNumberOfInputBands();
78 }
◆ getOutputScalarType()
ossimScalarType ossimMemoryImageSource::getOutputScalarType ( ) const
virtual
Definition at line 80 of file ossimMemoryImageSource.cpp.
References ossimImageSource::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), m_image, and ossimRefPtr< T >::valid().
81 {
82  if(m_image.valid())
83  {
84  return m_image->getScalarType();
85  }
86
88 }
bool valid() const
◆ getTile()
ossimRefPtr< ossimImageData > ossimMemoryImageSource::getTile ( const ossimIrect rect,
virtual
Returns
Definition at line 139 of file ossimMemoryImageSource.cpp.
References ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getNumberOfOutputBands(), getOutputScalarType(), ossimIrect::hasNans(), ossimIrect::height(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), m_boundingRect, m_image, m_result, ossimImageData::makeBlank(), OSSIM_BSQ, ossimImageData::setImageRectangle(), ossimRefPtr< T >::valid(), ossimImageData::validate(), and ossimIrect::width().
141 {
142  if(!isSourceEnabled()||!m_image.valid()||m_boundingRect.hasNans()) return 0;
143  if(!m_result.valid())
144  {
146  m_result->initialize();
147  }
148
150  m_result->makeBlank();
151  ossimIrect clampRect = m_image->getImageRectangle().clipToRect(rect);
152
155  OSSIM_BSQ);
156
157  m_result->validate();
158  return m_result;
159 }
bool valid() const
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual void initialize()
Initialize the data buffer.
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual ossimIrect getImageRectangle() const
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual void makeBlank()
bool hasNans() const
Definition: ossimIrect.h:337
◆ initialize()
void ossimMemoryImageSource::initialize ( )
virtual
Definition at line 168 of file ossimMemoryImageSource.cpp.
References m_result.
169 {
170  m_result = 0;
171 }
◆ loadState()
bool ossimMemoryImageSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 215 of file ossimMemoryImageSource.cpp.
References ossimString::c_str(), ossimString::empty(), ossimKeywordlist::find(), ossimImageData::getImageRectangle(), ossimImageData::initialize(), ossimImageSource::loadState(), ossimImageGeometry::loadState(), ossimImageData::loadState(), m_boundingRect, m_geometry, m_image, and m_result.
216 {
217  bool returnResult = ossimImageSource::loadState(kwl, prefix);
218  m_geometry = 0;
219  if(returnResult)
220  {
221  ossimString imagePrefix = ossimString(prefix) + "image.";
222  ossimString geomPrefix = ossimString(prefix) + "geom.";
223
224  ossimString type = kwl.find(imagePrefix, "type");
225  if(!type.empty())
226  {
227  m_image = new ossimImageData();
228  returnResult = m_image->loadState(kwl, imagePrefix.c_str());
229  m_image->initialize();
231  }
232
233  if(returnResult)
234  {
235  type = kwl.find(geomPrefix, "type");
236  if(!type.empty())
237  {
239  returnResult = m_geometry->loadState(kwl, geomPrefix.c_str());
240  }
241  }
242  }
243  m_result = 0;
244  return returnResult;
245 }
Attempts to initialize a transform and a projection given the KWL.
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
◆ saveState()
bool ossimMemoryImageSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 199 of file ossimMemoryImageSource.cpp.
References m_geometry, m_image, ossimImageSource::saveState(), ossimImageGeometry::saveState(), ossimImageData::saveState(), and ossimRefPtr< T >::valid().
200 {
201
202  ossimString imagePrefix = ossimString(prefix) + "image.";
203  ossimString geomPrefix = ossimString(prefix) + "geom.";
204  if(m_image.valid())
205  {
206  m_image->saveState(kwl, imagePrefix);
207  }
208  if(m_geometry.valid())
209  {
210  m_geometry->saveState(kwl, geomPrefix);
211  }
212  return ossimImageSource::saveState(kwl, prefix);
213 }
bool valid() const
Saves the transform (if any) and projection (if any) states to the KWL.
◆ setImage() [1/2]
void ossimMemoryImageSource::setImage ( ossimRefPtr< ossimImageData image)
◆ setImage() [2/2]
void ossimMemoryImageSource::setImage ( ossimScalarType  scalarType,
ossim_uint32  width,
ossim_uint32  height
Definition at line 36 of file ossimMemoryImageSource.cpp.
References ossimImageData::getImageRectangle(), ossimImageData::initialize(), m_boundingRect, m_image, and m_result.
40 {
41  m_image = new ossimImageData(0,
42  scalarType,
43  numberOfBands,
44  width,
45  height);
47
49  m_result = 0;
50 }
◆ setImageGeometry()
virtual void ossimMemoryImageSource::setImageGeometry ( ossimImageGeometry geom)
inlinevirtual
Default implementation sets geometry of the first input to the geometry specified.
Definition at line 73 of file ossimMemoryImageSource.h.
Referenced by ossimHlzTool::initProcessingChain(), and ossimViewshedTool::initProcessingChain().
74  {
75  m_geometry = geom;
76  }
◆ setRect()
void ossimMemoryImageSource::setRect ( ossim_uint32  ulx,
ossim_uint32  uly,
ossim_uint32  width,
ossim_uint32  height
Definition at line 52 of file ossimMemoryImageSource.cpp.
References ossimImageData::getImageRectangle(), m_boundingRect, m_image, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
56 {
57  if(m_image.valid())
58  {
60  ulx + (width-1),
61  uly + (height-1)));
63  }
64 }
bool valid() const
Member Data Documentation
◆ m_boundingRect
ossimIrect ossimMemoryImageSource::m_boundingRect
protected
◆ m_geometry
ossimRefPtr<ossimImageGeometry> ossimMemoryImageSource::m_geometry
protected
Definition at line 91 of file ossimMemoryImageSource.h.
Referenced by loadState(), and saveState().
◆ m_image
ossimRefPtr<ossimImageData> ossimMemoryImageSource::m_image
protected
◆ m_result
ossimRefPtr<ossimImageData> ossimMemoryImageSource::m_result
protected
Definition at line 90 of file ossimMemoryImageSource.h.
Referenced by getTile(), initialize(), loadState(), and setImage().
