16 #ifndef ossimNitfTileSource_HEADER 17 #define ossimNitfTileSource_HEADER 1 27 struct jpeg_decompress_struct;
35 READ_MODE_UNKNOWN = 0,
80 bool open( std::shared_ptr<ossim::istream>& str,
81 const std::string& connectionString );
128 const char* prefix=0)
const;
135 const char* prefix=0);
168 virtual bool isOpen()
const;
181 virtual void getEntryList(std::vector<ossim_uint32>& entryList)
const;
199 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
206 bool getCacheEnabledFlag()
const;
213 void setCacheEnabledFlag(
bool flag);
236 virtual bool getRgbBandList(std::vector<ossim_uint32>& bandList)
const;
246 void setBoundingRectangle(
const ossimIrect& imageRect);
273 virtual bool parseFile();
287 virtual bool allocate();
296 virtual bool allocateBuffers();
307 virtual void initializeScalarType();
312 virtual void initializeSwapBytesFlag();
317 virtual void initializeReadMode();
322 void initializeBandCount();
335 bool initializeBlockSize();
343 virtual bool initializeImageRect();
348 void initializeCacheSize();
353 virtual void initializeCacheTileInterLeaveType();
360 void initializeCacheTile();
365 virtual void initializeCompressedBuf();
370 virtual void initializeOutputTile();
375 void initializeLut();
416 bool getPosition(std::streamoff& position,
431 std::streampos getBandOffset()
const;
436 std::streampos getBlockOffset()
const;
444 bool isVqCompressed(
const ossimString& compressionCode)
const;
473 virtual bool scanForJpegBlockOffsets();
496 bool loadJpegQuantizationTables(jpeg_decompress_struct& cinfo)
const;
503 bool loadJpegHuffmanTables(jpeg_decompress_struct& cinfo)
const;
virtual bool open()=0
Pure virtual open.
std::vector< ossim_uint32 > theEntryList
ossim_uint32 theNumberOfInputBands
std::shared_ptr< ossim::istream > theFileStr
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
ossimRefPtr< ossimNitfFile > theNitfFile
std::vector< ossim_uint32 > theNitfBlockSize
const ossimImageSource & operator=(const ossimImageSource &)
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
ossim_uint32 theReadBlockSizeInBytes
ossimInterleaveType theCacheTileInterLeaveType
std::vector< ossim_uint8 > theCompressedBuf
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual bool isOpen() const =0
Retuns the min pixel value.
ossim_uint32 theBlockSizeInBytes
ossim_uint32 theNumberOfImages
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual bool getRgbBandList(std::vector< ossim_uint32 > &bandList) const
Convenience method to get the zero based rgb output band list.
ossimRefPtr< ossimImageData > theCacheTile
virtual ossimString getLongName() const
virtual void close()
virtual ossim_uint32 getCurrentEntry() const
ossimAppFixedTileCache::ossimAppFixedCacheId theCacheId
virtual ossim_uint32 getNumberOfEntries() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
virtual void establishDecimationFactors()
Virtual method determines the decimation factors at each resolution level.
ossim_int32 ossimAppFixedCacheId
ossimScalarType theScalarType
virtual ossim_uint32 getImageTileWidth() const =0
ossim_uint32 theCurrentEntry
This class defines an abstract Handler which all image handlers(loaders) should derive from...
std::vector< ossim_uint32 > theSelectorBandList
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossimIrect theBlockImageRect
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
unsigned char ossim_uint8
std::vector< ossim_uint32 > theOutputBandList
std::vector< ossimRefPtr< ossimNitfImageHeader > > theNitfImageHeader
std::vector< std::streamoff > theNitfBlockOffset
ossim_uint32 theNumberOfOutputBands
