ossimRS1SarModel.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Oscar Kramer
6 //
7 // Description:
8 //
9 // Sensor Model for Radarsat1 SAR sensor.
10 //
11 //*******************************************************************
12 // $Id:$
13
15 #include <cstdio>
16 #include <fstream>
17 #include <iomanip>
18 #include <iostream>
19 #include <sstream>
20 #include <string>
21 #include <ossim/base/ossimTrace.h>
22 #include <ossim/matrix/newmat.h>
25
26
27 using namespace std;
28 using namespace ossim;
29
30 static ossimTrace traceDebug("ossimRS1SarModel:debug");
31
32 static const double SEC_PER_DAY = 86400.0;
33 static const double NOMINAL_ORBIT_ELEVATION = 798000.0; // m
34 static const double DEG_PER_SEC = 0.004178074;
35 static const double INTRACK_OFFSET_SIGMA = 1000.0; // meters
36 static const double CRTRACK_OFFSET_SIGMA = 300.0;
37 static const double RADIAL_OFFSET_SIGMA = 300.0;
38 static const double LINE_SCALE_SIGMA = 0.01;
39 static const double SKEW_SIGMA = 0.1; // deg
40 static const double ORIENTATION_SIGMA = 0.2; // deg
41 static const double EARTH_ANGULAR_VELOCITY = 7.2921151467e-05; // radians/sec
42 static const char* IMAGING_MODE_ID[] =
43 {"UNKNOWN", "SCN", "SCW", "SGC", "SGF", "SGX", "SLC", "SPG", "SSG","RAW","ERS"};
44
45 //******************************************************************************
46 // Default.
47 //******************************************************************************
49 : theCeosData (0),
50  theImagingMode (UNKNOWN_MODE)
51 {
53 }
54
55 //******************************************************************************
56 // Takes a ossimFilename& directory containing support data, initializes the model,
57 // and writes out the initial geometry file.
58 //******************************************************************************
60  :
61  theCeosData (0),
62  theImagingMode (UNKNOWN_MODE)
63 {
64  static const char MODULE[] = "Constructor ossimRS1SarModel(ossimFilename)";
65  if (traceDebug()) CLOG << "entering..." << endl;
66
68
69  // Parse the CEOS data files:
70  ossimFilename dataDirName (imageFile.path());
71  initFromCeos(dataDirName);
73  {
74  return;
75  }
77  return;
78
79  // Parse the image data file for the local ORPs interpolator:
80  if ((theImagingMode == SCN) || (theImagingMode == SCW))
82  else
84
85  // Establish the ephemeris interpolator:
87
88  initAdjParms();
90
91  if (traceDebug()) CLOG << "returning..." << endl;
92  return;
93 }
94
95
96 //******************************************************************************
97 // DESTRUCTOR: ~ossimRS1SarModel
98 //******************************************************************************
100 {
102 }
103
104 //******************************************************************************
105 // loadSate()
106 //******************************************************************************
107 bool ossimRS1SarModel::loadState(const ossimKeywordlist& /* kwl */, const char* /* prefix */)
108 {
109  // NOT YET IMPLEMENTED
110  setErrorStatus();
111  return false;
112 }
113
114 //******************************************************************************
115 // saveState()
116 //******************************************************************************
117 bool ossimRS1SarModel::saveState(ossimKeywordlist& /* kwl */, const char* /* prefix */) const
118 {
119  // NOT YET IMPLEMENTED
120  setErrorStatus();
121  return false;
122 }
123
124 //*************************************************************************************************
127 //*************************************************************************************************
128 void ossimRS1SarModel::imagingRay(const ossimDpt& image_point, ossimEcefRay& /* image_ray */) const
129 {
130  const char* MODULE = "ossimRS1SarModel::imagingRay()";
131
132  // Apply offset, scale, skew, and rotation to image point:
133  ossimDpt offset (theImageSize.line/2.0, theImageSize.samp/2.0);
134  ossimDpt ip1 = image_point - offset;
135  ossimDpt ip2;
140
141  // Offset point back to origin of image:
142  ip1 = ip2 + offset;
143
144  // Given new line number, obtain the interpolated ORP:
145  ossimEcefPoint localORP;
146  if ((theImagingMode == SCN) || (theImagingMode == SCW))
147  {
148  ossimGpt gpt (theLatGrid(ip1.x, ip1.y), theLonGrid(ip1.x, ip1.y), theRefHeight);
149  localORP = ossimEcefPoint(gpt);
150  }
151  else
152  {
153  NEWMAT::ColumnVector orpPos(3);
154  theLocalOrpInterp->interpolate(ip1.line, orpPos);
155  localORP = ossimEcefPoint(orpPos[0], orpPos[1], orpPos[2]);
156  }
157
158  // Establish imaging line time (zero-Doppler time):
159  double arpTime = theFirstLineTime + ip1.line*theTimePerLine;
160
161  NEWMAT::ColumnVector arpEph(3);
162  theArpPosInterp->interpolate(arpTime, arpEph);
163  ossimEcefPoint ecfArpPos (arpEph[0], arpEph[1], arpEph[2]);
164
165  theArpVelInterp->interpolate(arpTime, arpEph);
166  ossimEcefVector ecfArpVel (arpEph[0], arpEph[1], arpEph[2]);
167
168  // Need to correct the velocity vector by the earth rotational velocity:
169  ossimEcefVector earthVel
170  (-ecfArpPos.y()*EARTH_ANGULAR_VELOCITY, ecfArpPos.x()*EARTH_ANGULAR_VELOCITY, 0.0);
171  ecfArpVel = ecfArpVel - earthVel;
172
173  // Compute a vehicle space with Z near intrack, X normal to Z and range
174  // vector to ORP (slant range normal), and Y in range direction.
175  // Note the application of the position adjustable parameter to the space's
176  // origin (after the range vector was established):
177  ossimEcefVector rangeVector = localORP - ecfArpPos;
178  ossimEcefVector rangeNormal = rangeVector.cross(ecfArpVel);
179  // ossimEcefVector zDirection = rangeNormal.cross(rangeVector);
180  ossimLsrSpace localVehicleSpace (ossimEcefPoint(ecfArpPos + thePosCorrection), // origin
181  rangeNormal, // X-direction
182  rangeVector, 0); // Y-direction (Z not specified
183  double local_orp_range = rangeVector.length();
184
185  // Compute slant range distance to pixel in question:
186  double slant_range = local_orp_range;
187  switch (theImagingMode)
188  {
189  case SLC:
191  slant_range += thePixelSpacing.samp*ip1.samp;
192  else
193  slant_range += (theImageSize.samp-1.0-ip1.samp) * thePixelSpacing.samp;
194  break;
195
196  case SGC:
197  case SGF:
198  case SGX:
199  case ERS:
200  {
201  // Compute the slant range as a polynomial expansion given ground range
202  double ground_range;
204  ground_range = ip1.samp * thePixelSpacing.samp;
205  else
206  ground_range = (theImageSize.samp - 1.0 - ip1.samp) *
208  // double delta_g_i = 1.0;
209  // for (int 0=1; i<6; i++)
210  double delta_g_i = ground_range;
211  for (int i=1; i<6; i++) // NOTE: not using offset (i=0) term
212  {
213  slant_range += theSrGrCoeff[i] * delta_g_i;
214  delta_g_i *= ground_range;
215  }
216  }
217  break;
218
219  case SCN:
220  case SCW:
221  slant_range = local_orp_range;
222  break;
223
224  default:
225  CLOG << "ERROR: Invalid imaging mode encountered." << endl;
226  setErrorStatus();
227  }
228 }
229
230 //*************************************************************************************************
231 // PUBLIC METHOD: ossimRS1SarModel::lineSampleHeightToWorld(image_point, height, is_inside_image)
232 //
233 // Performs image to ground projection.
234 //*************************************************************************************************
236  const double& height_ellip,
237  ossimGpt& worldPt) const
238 {
239  static const char MODULE[] = "ossimRS1SarModel::lineSampleHeightToWorld()";
240  if (traceDebug()) CLOG << "entering..." << endl;
241
242  // static const int MAX_NUM_ITERS = 50;
243  // static const double MAX_ELEV_DIFF = 0.001;
244
245  ossimEcefRay imaging_ray;
246  imagingRay(image_point, imaging_ray);
247  worldPt = imaging_ray.intersectAboveEarthEllipsoid(height_ellip);
248
249  if (traceDebug()) CLOG << "returning..." << endl;
250 }
251
252 //******************************************************************************
253 // This method sets theImagingMode data member given a character string
254 // abbreviation of the mode.
255 //******************************************************************************
257 {
258  static const char MODULE[] = "ossimRS1SarModel::setImagingMode(modeStr)";
259  if (traceDebug()) CLOG << "entering..." << endl;
260
261  bool illegal_mode = false;
262
263  if (strcmp(modeStr, "SCN") == 0)
264  {
266  }
267  else if (strcmp(modeStr, "SCW") == 0)
268  {
270  }
271  else if (strcmp(modeStr, "SGC") == 0)
272  {
274  }
275  else if (strcmp(modeStr, "SGF") == 0)
276  {
278  }
279  else if (strcmp(modeStr, "SGX") == 0)
280  {
282  }
283  else if (strcmp(modeStr, "SLC") == 0)
284  {
286  }
287  else if (strcmp(modeStr, "SPG") == 0)
288  {
290  illegal_mode = true;
291  }
292  else if (strcmp(modeStr, "SSG") == 0)
293  {
295  illegal_mode = true;
296  }
297  else if (strcmp(modeStr, "RAW") == 0)
298  {
300  illegal_mode = true;
301  }
302  else if (strcmp(modeStr, "ERS") == 0)
303  {
305  }
306  else
307  {
309  illegal_mode = true;
310  }
311
312  // Test for ERS product:
314  {
315  char buf[] = "xxx";
316  strncpy(buf, &(theCeosData->textRec()->product_type[8]), 3);
317  if (strcmp(buf, "ERS") == 0)
318  {
320  illegal_mode = false;
321  }
322  }
323
324  // Filter the imaging modes that are not handled:
325  if (illegal_mode)
326  {
327  CLOG << "\n\t ERROR: The imaging mode <"
328  << IMAGING_MODE_ID[(int) theImagingMode]
329  << "> is currently not supported. \n" << endl;
331  }
332
333  if (traceDebug()) CLOG << "returning..." << endl;
334 }
335
336
337 //******************************************************************************
338 // Initialize various data members from the CEOS records.
339 //******************************************************************************
341 {
342  static const char MODULE[] = "ossimRS1SarModel::initFromCeos()";
343  if (traceDebug()) CLOG << "entering..." << endl;
344
345  // Instantiate a CeosData object:
346  theCeosData = new ossimCeosData(fname);
347
349  const dataset_sum_rec* dsr = theCeosData->dataSetSumRec();
350  const proc_parm_rec* ppr = theCeosData->procParmRec();
351  char buf[1024];
352
353  // Set imaging mode:
354  strncpy(buf, &(theCeosData->volDescRec()->logvol_id[11]), 3);
355  buf[3] = '\0';
356  setImagingMode(buf);
357
358  // Determine whether ascending or descending path acquisition. This flag
359  // dictates whether the first or last pixel of a line is of shorter range:
360  if (theImagingMode == ERS)
361  {
363  }
364  else
365  {
366  if (dsr->asc_des[0] == 'A')
368  else if (dsr->asc_des[0] == 'D')
370  else
371  {
372  CLOG << "ERROR: Direction Flag: " << dsr->asc_des << " not supported"
373  << endl;
375  setErrorStatus();
376  if (traceDebug()) CLOG << "returning with error..." << endl;
377  return;
378  }
379  }
380
381  // Image (Product) ID:
382  buf[8] = '\0';
383  strncpy(buf, theCeosData->volDescRec()->product_id, 8);
384  theImageID = buf;
385
386  // pixel spacing in range:
387  buf[16] = '\0';
388  strncpy(buf, dsr->pix_spacing, 16);
389  thePixelSpacing.samp = atof(buf);
390
391  // pixel spacing in azimuth:
392  strncpy(buf, dsr->line_spacing, 16);
393  buf[16] = '\0';
394  thePixelSpacing.line = atof(buf);
395
396  // The ground reference point (ORP) latitude:
397  ossimGpt grp;
398  strncpy(buf, dsr->pro_lat, 16);
399  buf[16] = '\0';
400  grp.lat = atof(buf);
401
402  // The ground reference point (ORP) longitude:
403  strncpy(buf, dsr->pro_long, 16);
404  buf[16] = '\0';
405  grp.lon = atof(buf);
406
407  // The ground reference point (ORP) elevation:
408  strncpy(buf, dsr->terrain_h, 16);
409  buf[16] = '\0';
410  grp.hgt = atof(buf);
411  theORP = ossimEcefPoint(grp);
412  theRefHeight = grp.hgt;
413
414  // Illumination elevation:
415  strncpy(buf, dsr->incident_ang, 8);
416  buf[8] = '\0';
417  double incidence = atof(buf);
418  theIllumElevation = 90.0 - incidence;
419
420  // Illumination azimuth -- need to determine whether sensor is in normal
421  // right-looking mode or "antarctic" (left-looking) mode:
422  strncpy(buf, dsr->plat_head, 8);
423  theIllumAzimuth = atof(buf);
424  char sensor_orientation[] = "123456789";
425  strncpy(sensor_orientation, ppr->sens_orient, 9);
426  if (strcmp(sensor_orientation, "ANTARCTIC") == 0)
427  {
428  theIllumAzimuth -= 90.0;
429  if (theIllumAzimuth < 0.0) theIllumAzimuth += 360.0;
430  }
431  else
432  {
433  theIllumAzimuth += 90.0;
434  if (theIllumAzimuth >= 360.0) theIllumAzimuth -= 360.0;
435  }
436
437  // Determine the number of lines per image and pixels per line. NOTE: if
438  // image is scan mode, the number of lines must be computed indirectly.
439  if ((theImagingMode == SCN) || (theImagingMode == SCW))
440  {
441  FILE* fptr = fopen(theCeosData->imageFile().chars(), "r");
442  if (!fptr)
443  {
444  CLOG << " ERROR:\n\tCannot open CEOS image file: "
445  << theCeosData->imageFile() << endl;
446  setErrorStatus();
447  return;
448  }
449  fseek(fptr, 0, SEEK_END);
450  long byte_count = ftell(fptr);
451  buf[6] = '\0';
452  strncpy(buf, theCeosData->imopDescRec()->l_dataset, 6);
453  int lengthOfRec = atoi(buf);
454  theImageSize.line = (byte_count - sizeof(*theCeosData->imopDescRec()))
455  /lengthOfRec;
456  fclose(fptr);
457  }
458  else
459  {
460  strncpy(buf, theCeosData->imopDescRec()->n_dataset, 6);
461  buf[6] = '\0';
462  theImageSize.line = atoi(buf);
463  }
464  strncpy(buf, theCeosData->imopDescRec()->nleft, 4);
465  buf[4] = '\0';
466  int left_pixels = atoi(buf);
467  strncpy(buf, theCeosData->imopDescRec()->ngrp, 8);
468  buf[8] = '\0';
469  int data_pixels = atoi(buf);
470  strncpy(buf, theCeosData->imopDescRec()->nright, 4);
471  buf[4] = '\0';
472  int right_pixels = atoi(buf);
473  theImageSize.samp = left_pixels + data_pixels + right_pixels;
474
475  // If ground range product, need to read the ground-to-slant range
476  // conversion coefficients from the proc_parm_rec. NOTE: only single-look
477  // products handled properly. ScanSAR requires reading multiple coefficient
478  // sets. See MDA Detailed Processing Parameter Record Description sec.3.84.
479  if ((theImagingMode==SGC) ||
480  (theImagingMode==SGF) ||
481  (theImagingMode==SGX) ||
482  (theImagingMode==ERS))
483  {
484  buf[16] = '\0';
485  for (int i=0; i<6; i++)
486  {
487  strncpy(buf, ppr->srgr_coefset[0].srgr_coef[i], 16);
488  theSrGrCoeff[i] = atof(buf);
489  }
490  }
491  else
492  {
493  theSrGrCoeff[0] = 0.0;
494  theSrGrCoeff[1] = 1.0; // note 1.0 here (should never be accessed)
495  theSrGrCoeff[2] = 0.0;
496  theSrGrCoeff[3] = 0.0;
497  theSrGrCoeff[4] = 0.0;
498  theSrGrCoeff[5] = 0.0;
499  }
500
501  if (traceDebug())
502  {
503  CLOG << "DEBUG -- "
504  << "\n\t theDirectionFlag = " << theDirectionFlag
505  << "\n\t thePixelSpacing = " << thePixelSpacing
506  << "\n\t theORP = " << theORP
507  << "\n\t theRefHeight = " << theRefHeight
508  << "\n\t theImageSize = " << theImageSize
509  << "\n\t sensor_orientation = " << sensor_orientation
510  << "\n\t theIllumElevation = " << theIllumElevation
511  << "\n\t theIllumAzimuth = " << theIllumAzimuth
512  << endl;
513  }
514
515  if (traceDebug()) CLOG << "returning..." << endl;
516 }
517
518
519 //******************************************************************************
520 // This method sets the rigorous model adjustable parameters to
521 // their initial values.
522 //******************************************************************************
524 {
525  // Adjustable model not yet implemented
526 #if 0
527
528  static const char* MODULE = "ossimRS1SarModel::initAdjParms()";
529  if (traceDebug()) CLOG << "entering..." << endl;
530
531  theInTrackOffset = (init_adj_parm[INTRACK_OFFSET]+adj_parm[INTRACK_OFFSET])
532  * adj_sigma[INTRACK_OFFSET];
533
534  theCrTrackOffset = (init_adj_parm[CRTRACK_OFFSET]+adj_parm[CRTRACK_OFFSET])
535  * adj_sigma[CRTRACK_OFFSET];
536
537  theRadialOffset = (init_adj_parm[RADIAL_OFFSET]+adj_parm[RADIAL_OFFSET])
538  * adj_sigma[RADIAL_OFFSET];
539
540  theLineScale = (init_adj_parm[LINE_SCALE]+adj_parm[LINE_SCALE])
541  * adj_sigma[LINE_SCALE];
542
543  theSkew = (init_adj_parm[SKEW]+adj_parm[SKEW])
544  * adj_sigma[SKEW];
545
546  theOrientation = (init_adj_parm[ORIENTATION]+adj_parm[ORIENTATION]);
547
548  // Initialize base-class initial adjustable parameter array:
549  init_adj_parm[INTRACK_OFFSET] = theInTrackOffset/adj_sigma[INTRACK_OFFSET];
550  init_adj_parm[CRTRACK_OFFSET] = theCrTrackOffset/adj_sigma[CRTRACK_OFFSET];
551  init_adj_parm[RADIAL_OFFSET] = theRadialOffset/adj_sigma[RADIAL_OFFSET];
552  init_adj_parm[LINE_SCALE] = theLineScale/adj_sigma[LINE_SCALE];
553  init_adj_parm[SKEW] = theSkew/adj_sigma[SKEW];
554  init_adj_parm[ORIENTATION] = theOrientation/adj_sigma[ORIENTATION];
555
556  // Initialize sensor adjustable parameter description strings:
557  strncpy (adj_desc[INTRACK_OFFSET], "intrack_offset", MAX_DESC_CHARS);
558  strncpy (adj_desc[CRTRACK_OFFSET], "crtrack_offset", MAX_DESC_CHARS);
559  strncpy (adj_desc[RADIAL_OFFSET], "radial_offset", MAX_DESC_CHARS);
560 // strncpy (adj_desc[SAMP_SCALE], "samp_scale", MAX_DESC_CHARS);
561  strncpy (adj_desc[LINE_SCALE], "line_scale", MAX_DESC_CHARS);
562  strncpy (adj_desc[SKEW], "image_skew", MAX_DESC_CHARS);
563  strncpy (adj_desc[ORIENTATION], "image_orientation",MAX_DESC_CHARS);
564
565  // Initialize the adj_parms (parameter corrections) to 0:
566  for (int i=0; i<num_adj_parm; i++)
567  adj_parm[i] = 0.0;
568
569  if (traceDebug()) CLOG << "returning..." << endl;
570 #endif
571 }
572
573
574 //******************************************************************************
575 // This method parses the SAR header information associated with the
576 // ephemeris state vectors, and instantiates a Lagrange interpolator object
577 // for interpolating intermediate ehemeris states.
578 //******************************************************************************
580 {
581  static const char MODULE[] = "ossimRS1SarModel::establishEphemeris()";
582  if (traceDebug()) CLOG << "entering..." << endl;
583
584  char buf[23];
585
586  // Establish pointer to platform position data record:
587  const pos_data_rec* pdr = theCeosData->posDataRec();
588
589  // Establish the Greenwich mean hour angle at time of first sample:
590  char gha_str [23];
591  strncpy(gha_str, pdr->hr_angle, 22);
592  gha_str[22] = '\0';
593  theGHA = atof(gha_str);
594
595  // Fetch number of points in record and allocate memory:
596  strncpy(buf, pdr->ndata, 4);
597  buf[4] = '\0';
598  int numPoints = atoi(buf);
599
600  // Fetch sampling period:
601  strncpy(buf, pdr->data_int, 22);
602  buf[22] = '\0';
603  double sampling_period = atof(buf);
604
605  // Establish the first sample time's day:
606  strncpy(buf, pdr->gmt_day, 4);
607  buf[4] = '\0';
608  int first_day = atoi(buf);
609  double time_offset = (double) (first_day - theFirstLineDay)*SEC_PER_DAY;
610
611  // Establish the first sample time in seconds from beginning of day:
612  strncpy(buf, pdr->gmt_sec, 22);
613  buf[22] = '\0';
614  theEphFirstSampTime = atof(buf) + time_offset;
615
616  int i, j;
617  double sample_time = theEphFirstSampTime;
618  buf[22] = '\0';
619  NEWMAT::ColumnVector eciArpPos(3);
620  NEWMAT::ColumnVector eciArpVel(3);
621  NEWMAT::ColumnVector ecfArpPos(3);
622  NEWMAT::ColumnVector ecfArpVel(3);
623  NEWMAT::ColumnVector earthVel(3);
624  NEWMAT::Matrix xform;
627
628  // Loop over each point, converting them to vectors:
629  for (i=0; i<numPoints; i++)
630  {
631  for (j=0; j<3; j++)
632  {
633  strncpy(buf, pdr->pos_vect[i].pos[j], 22);
634  eciArpPos[j] = atof(buf);
635  strncpy(buf, pdr->pos_vect[i].vel[j], 22);
636  eciArpVel[j] = atof(buf)/1000.0;
637  }
638
639  // Convert pos and vel vectors from ECI to ECF:
640  eciToEcfXform(sample_time, xform);
641  ecfArpPos = xform*eciArpPos;
642  ecfArpVel = xform*eciArpVel;
643  theArpPosInterp->addData(sample_time, ecfArpPos);
644
645  // Correct velocity for earth rotation:
646  earthVel[0] = -ecfArpPos[1]*EARTH_ANGULAR_VELOCITY;
647  earthVel[1] = ecfArpPos[0]*EARTH_ANGULAR_VELOCITY;
648  earthVel[2] = 0.0;
649  ecfArpVel = ecfArpVel - earthVel;
650  theArpVelInterp->addData(sample_time, ecfArpVel);
651
652  sample_time += sampling_period;
653  }
654
655  if (traceDebug())
656  {
657  CLOG << "DEBUG -- "
658  << "\n\t theGHA: " << theGHA
659  << "\n\t numPoints: " << numPoints
660  << "\n\t sampling_period: " << sampling_period
661  << "\n\t theEphFirstSampTime: " << theEphFirstSampTime << endl;
662  }
663
664  if (traceDebug()) CLOG << "returning..." << endl;
665 }
666
667
668 //******************************************************************************
669 // Returns 3x3 transform to rotate ECI into ECF. The argument is
670 // in seconds of the day.
671 //******************************************************************************
672 void ossimRS1SarModel::eciToEcfXform(const double& acq_time, NEWMAT::Matrix& xform) const
673 {
674  static const char MODULE[] = "ossimRS1SarModel::eciToEcfXform(acq_time)";
675  if (traceDebug()) CLOG << "entering..." << endl;
676
677  // Determine time elapsed since ephemeris first sample time:
678  double delta_t = acq_time - theEphFirstSampTime;
679
680  // Compute GHA at time of this image line (in degrees):
681  double gha = theGHA + delta_t*DEG_PER_SEC;
682  if (gha >= 360.0)
683  gha -=360.0;
684  else if (gha < 0.0)
685  gha += 360.0;
686
687  // Establish rotation:
688  double cos_gha = ossim::cosd(gha);
689  double sin_gha = ossim::sind(gha);
690
691  // Establish rotation matrix:
692  xform = ossimMatrix3x3::create(cos_gha, sin_gha, 0.0,
693  -sin_gha, cos_gha, 0.0,
694  0.0, 0.0, 1.0);
695  if (traceDebug())
696  {
697  CLOG << "DEBUG -- "
698  << "\n\t acq_time = " << acq_time
699  << "\n\t delta_t = " << delta_t
700  << "\n\t gha = " << gha << endl;
701  }
702
703  if (traceDebug()) CLOG << "returning..." << endl;
704 }
705
706
707 //******************************************************************************
708 // PRIVATE METHOD: ossimRS1SarModel::establishOrpInterp()
709 //
710 // This method reads the image data file for obtaining the local ORPs (taken
711 // to be the lat-lon of the nearest pixel for each line), and the zero-doppler
712 // time for each line. These ORPs are used for computing SPNs.
713 //
714 // The processed data records correspond to lines of imagery. Accompanying
715 // each data line is the lat-lon (at the ellipsoid) of the first, middle, and
716 // last sample of the line, the time of zero-doppler (broadside) imaging for
717 // the line.
718 //
719 // A Lagrange interpolator is established with N data points representing the
720 // local ORPs and their corresponding image line numbers
721 // uniformly distributed over the image.
722 //
723 // If the image is a ground range product, need to also read the ground-to-
724 // slant range conversion coefficients.
725 //
726 //******************************************************************************
728 {
729  static const char MODULE[] = "ossimRS1SarModel::establishOrpInterp()";
730  if (traceDebug()) CLOG << "entering..." << endl;
731
732  if (traceDebug())
733  CLOG << "DEBUG -- " << endl;
734
735  static const int NUM_DATA_POINTS = 11;
736
737  desc_rec descRec;
738  pdr_prefix_rec prefix;
739  int sizeOfDescRec = sizeof(descRec);
740  int sizeOfPrefRec = sizeof(prefix);
741  int headerSize = sizeOfDescRec + sizeOfPrefRec;
742  char buf[] = "123456";
743  ossimGpt localOrp (0.0, 0.0, theRefHeight);
744  std::vector<double> line_numbers_list;
745  std::vector<NEWMAT::ColumnVector> orpVectorList; // X, Y, Z
746
747  if (traceDebug())
748  {
749  CLOG << "DEBUG:"
750  << "\nsizeOfDescRec: " << sizeOfDescRec
751  << "\nsizeOfPrefRec: " << sizeOfPrefRec << endl;
752  }
753
754  // Open the image data file given the image directory name and seek to first
755  // SAR data record:
756  FILE* fptr = fopen(theCeosData->imageFile().chars(), "r");
757  if (!fptr)
758  {
759  CLOG << "ERROR: Could not open data file <" << theCeosData->imageFile()
760  << ">" << endl;
761  setErrorStatus();
762  return;
763  }
764  fseek(fptr, theCeosData->imopDescRec()->desc.length, SEEK_SET);
765
766  // Declare some constants and variables used in loop:
767  int last_line = (int) theImageSize.line - 1;
768  int delta_line = (int)ceil(last_line/((double)NUM_DATA_POINTS-1.0));
769  int line_number = 0;
770
771  // Compute the number of SAR data bytes to skip to reach prefix of next
772  // record of interest:
773  strncpy(buf, theCeosData->imopDescRec()->l_dataset, 6);
774  int record_size = atoi(buf);
775
776  // Loop over each imaging line:
777  int index;
779  for (index=0; index<NUM_DATA_POINTS; index++)
780  {
781  if (traceDebug())
782  clog << "\t Processing ORP for line number " << line_number << endl;
783
784  // Read the image line prefix info:
785  fread(&descRec, sizeOfDescRec, 1, fptr);
786  fread(&prefix, sizeOfPrefRec, 1, fptr);
787
788  // Verify correct line number being read:
789  if ((prefix.line_num-1) != line_number)
790  {
791  CLOG << "\n\tERROR: Synchronization error reading image file. "
792  << "Expected line number " << line_number+1
793  << " but read line number " << prefix.line_num << "." << endl;
794  setErrorStatus();
795  fclose(fptr);
796  fptr = 0;
797  return;
798  }
799
800  // Latch the imaging time for the first line collected:
801  if (index == 0)
802  {
804  theFirstLineTime = (double) prefix.acq_date.acq_msec/1000.0;
805  }
806
807  // Read the local ORP for this line and convert to ECF:
809  {
810  localOrp.lat = (double) prefix.lat_first / 1.0e6;
811  localOrp.lon = (double) prefix.long_first / 1.0e6;
812  }
813  else
814  {
815  localOrp.lat = (double) prefix.lat_last / 1.0e6;
816  localOrp.lon = (double) prefix.long_last / 1.0e6;
817  }
818
819  theLocalOrpInterp->addData(line_number, ossimEcefPoint(localOrp).toVector());
820
821  // Update the line number for next record, insuring we don't go passed
822  // the last line:
823  line_number += delta_line;
824  if (line_number > last_line)
825  {
826  delta_line -= line_number - last_line; // adjust for fseek below
827  line_number = last_line;
828  }
829
830  // Advance to read the next prefix record of interest:
831  fseek(fptr, (delta_line)*record_size-headerSize, SEEK_CUR);
832  }
833
834  // Compute time interval between each line, handle possible day rollover:
835  double lastLineTime = (double) prefix.acq_date.acq_msec/1000.0;
836  if ((lastLineTime-theFirstLineTime) > (SEC_PER_DAY/2.0))
837  lastLineTime -= SEC_PER_DAY;
838  else if ((theFirstLineTime-lastLineTime) > (SEC_PER_DAY/2.0))
839  lastLineTime += SEC_PER_DAY;
840  theTimePerLine = (lastLineTime - theFirstLineTime)/line_number;
841
842  if (traceDebug())
843  {
844  clog << "\n\t line_number (last) = " << line_number
845  << "\n\t last_line (in image) = " << last_line
846  << "\n\t theFirstLineTime = " << theFirstLineTime
847  << "\n\t lastLineTime = " << lastLineTime
848  << "\n\t theTimePerLine = " << theTimePerLine
849  << endl;
850  }
851
852  if (traceDebug()) CLOG << "returning..." << endl;
853 }
854
855 //******************************************************************************
856 // This method establishes a common mean intrack-crosstrack-radial LSR
857 // space at the ARP.
858 //******************************************************************************
860 {
861  static const char MODULE[] = "ossimRS1SarModel::establishVehicleSpace()";
862  if (traceDebug()) CLOG << "entering..." << endl;
863
864  // Obtain the imaging time when the vehicle is at the ARP:
865  double line = theImageSize.line/2.0;
866  double arpTime = theFirstLineTime + line*theTimePerLine;
867
868  // Obtain the ephemeris at this time:
869  NEWMAT::ColumnVector arpPos(3);
870  theArpPosInterp->interpolate(arpTime, arpPos);
871  NEWMAT::ColumnVector arpVel(3);
872  theArpVelInterp->interpolate(arpTime, arpVel);
873
874  // Convert ephemeris to ECF:
875  NEWMAT::Matrix xform;
876  eciToEcfXform(arpTime, xform);
877  ossimEcefPoint ecfArpPos (xform * arpPos);
878  ossimEcefVector ecfArpVel (xform * arpVel);
879
880  // Need to correct the velocity vector by the earth rotational velocity:
881  ossimEcefVector earthVel(-ecfArpPos.y()*EARTH_ANGULAR_VELOCITY,
882  ecfArpPos.x()*EARTH_ANGULAR_VELOCITY,
883  0.0);
884  ecfArpVel = ecfArpVel - earthVel;
885
886  // Establish LSR space for intrack-crosstrack-radial at vehicle:
887  ossimEcefVector intrackDir (ecfArpVel);
888  ossimEcefVector crtrackDir (ecfArpPos.data().cross(intrackDir.data()));
889  theVehicleSpace = ossimLsrSpace (ecfArpPos, intrackDir, crtrackDir, 0);
890
891  if (traceDebug())
892  {
893  CLOG << "DEBUG -- "
894  << "\n\t theVehicleSpace: " << theVehicleSpace << endl;
895  }
896
897  if (traceDebug()) CLOG << "returning..." << endl;
898 }
899
900
901 //******************************************************************************
902 // For scan-mode imagery, this method interpolates the lat/lon given the image pixel.
903 //******************************************************************************
905 {
906  static const char MODULE[] = "ossimRS1SarModel::interpolatedScanORP(gDblPoint)";
907  if (traceDebug()) CLOG << "entering..." << endl;
908
909  ossimGpt gpt;
910  gpt.lat = theLatGrid(orp);
911  gpt.lon = theLonGrid(orp);
912
913  // Convert to ECF:
914  orp_ecf = ossimEcefPoint(gpt);
915
916  if (traceDebug()) CLOG << "returning..." << endl;
917 }
918
919
920 //******************************************************************************
921 // PRIVATE METHOD: ossimRS1SarModel::establishOrpGrid()
922 //
923 // This method establishes a grid of lat-lon across the image for interpolating
924 // the geographic point on the ellipsoid given a pixel value. This is used for
925 // scan-mode imagery for obtaining a local ORP.
926 //
927 //******************************************************************************
929 {
930  static const char MODULE[] = "ossimRS1SarModel::establishOrpGrid()";
931  if (traceDebug()) CLOG << "entering..." << endl;
932
933  if (traceDebug())
934  {
935  CLOG << "DEBUG -- " << endl;
936  }
937
938  static const int NUM_GRID_POINTS_U = 11;
939
940  desc_rec descRec;
941  pdr_prefix_rec prefix;
942  int sizeOfDescRec = sizeof(descRec);
943  int sizeOfPrefRec = sizeof(prefix);
944  int headerSize = sizeOfDescRec + sizeOfPrefRec;
945  char buf[] = "123456";
946  ossimDpt gridSize ((double) NUM_GRID_POINTS_U, 3.0);
947  ossimDpt cellSize (theImageSize.line/gridSize.u, theImageSize.samp/gridSize.v);
948
949  // Because we are doing integer arithmetic, it will be necessary to
950  // consider the last grid cells as being of a slightly different size:
951  //theLastGridCellSize.line = theImageSize.line - 1.0 -
952  // (theGridSize.u-2.0)*theGridCellSize.u;
953  //theLastGridCellSize.samp = theImageSize.samp - 1.0 -
954  // (theGridSize.v-2.0)*theGridCellSize.v;
955
956  // Open the image data file given the image directory name and seek to first
957  // SAR data record:
958  FILE* fptr = fopen(theCeosData->imageFile().chars(), "r");
959  if (!fptr)
960  {
961  CLOG << "ERROR: Could not open data file <" << theCeosData->imageFile()
962  << ">" << endl;
963  setErrorStatus();
964  return;
965  }
966  fseek(fptr, theCeosData->imopDescRec()->desc.length, SEEK_SET);
967
968  // Declare some constants and variables used in loop:
969  int last_line = (int) theImageSize.line - 1;
970  int delta_line = (int) cellSize.u;
971  int line_number = 0;
972
973  // Allocate memory for coarse grid:
974  theLatGrid.initialize(gridSize, ossimDpt(0,0), ossimDpt(1,1));
975  theLonGrid.initialize(gridSize, ossimDpt(0,0), ossimDpt(1,1));
976
977  // Compute the number of SAR data bytes to skip to reach prefix of next
978  // record of interest:
979  strncpy(buf, theCeosData->imopDescRec()->l_dataset, 6);
980  int record_size = atoi(buf);
981  int test_line = (int) gridSize.u - 2;
982
983  // Loop over each imaging line:
984  for (int u=0; u<(int)gridSize.u; u++)
985  {
986  if (traceDebug())
987  {
988  clog << "\t Processing grid line number " << u << endl;
989  }
990
991  // Read the image line prefix info:
992  fread(&descRec, sizeOfDescRec, 1, fptr);
993  fread(&prefix, sizeOfPrefRec, 1, fptr);
994
995  // Verify correct line number being read:
996  if ((prefix.line_num-1) != line_number)
997  {
998  CLOG << "\n\tERROR: Synchronization error reading image file. "
999  << "Expected line number " << line_number+1
1000  << " but read line number " << prefix.line_num << "." << endl;
1001  setErrorStatus();
1002  fclose(fptr);
1003  fptr = 0;
1004  return;
1005  }
1006
1007  // Latch the imaging time for the first line collected:
1008  if (u == 0)
1009  {
1010  theFirstLineDay = prefix.acq_date.acq_day;
1011  theFirstLineTime = (double) prefix.acq_date.acq_msec/1000.0;
1012  }
1013
1014  // Read the ground points for this line:
1015  theLatGrid.setNode(u, 0, (double) prefix.lat_first /1.0e6);
1016  theLatGrid.setNode(u, 1, (double) prefix.lat_mid /1.0e6);
1017  theLatGrid.setNode(u, 2, (double) prefix.lat_last /1.0e6);
1018  theLonGrid.setNode(u, 0, (double) prefix.long_first/1.0e6);
1019  theLonGrid.setNode(u, 1, (double) prefix.long_mid /1.0e6);
1020  theLonGrid.setNode(u, 2, (double) prefix.long_last /1.0e6);
1021
1022  // Update the line number for next record, insuring we don't go passed
1023  // the last line:
1024  if (u == test_line)
1025  {
1026  delta_line = last_line - line_number;
1027  line_number = last_line;
1028  }
1029  else
1030  {
1031  line_number += delta_line;
1032  }
1033
1034  //***
1035  // Advance to read the next prefix record of interest:
1036  //***
1037  fseek(fptr, (delta_line)*record_size-headerSize, SEEK_CUR);
1038  }
1039
1040  // Compute time interval between each line, handle possible day rollover:
1041  double lastLineTime = (double) prefix.acq_date.acq_msec/1000.0;
1042  if ((lastLineTime-theFirstLineTime) > (SEC_PER_DAY/2.0))
1043  {
1044  lastLineTime -= SEC_PER_DAY;
1045  }
1046  else if ((theFirstLineTime-lastLineTime) > (SEC_PER_DAY/2.0))
1047  {
1048  lastLineTime += SEC_PER_DAY;
1049  }
1050  theTimePerLine = (lastLineTime - theFirstLineTime)/line_number;
1051
1052  if (traceDebug())
1053  {
1054  clog << "\n\t line_number (last) = " << line_number
1055  << "\n\t last_line (in image) = " << last_line
1056  << "\n\t theFirstLineTime = " << theFirstLineTime
1057  << "\n\t lastLineTime = " << lastLineTime
1058  << "\n\t theTimePerLine = " << theTimePerLine
1059  << endl;
1060  }
1061
1062  if (traceDebug()) CLOG << "returning..." << endl;
1063 }
1064
1065 //******************************************************************************
1066 // PRIVATE METHOD: deallocateMemory()
1067 //
1068 // This method permits the partial destruction of the object so that it may
1069 // be reconstructed without invoking the destructor.
1070 //
1071 //******************************************************************************
1073 {
1074  static const char MODULE[] = "ossimRS1SarModel::deallocateMemory()";
1075  if (traceDebug()) CLOG << "entering..." << endl;
1076
1077  theArpPosInterp = 0;
1078  theArpVelInterp = 0;
1079  theLocalOrpInterp = 0;
1080  theCeosData = 0;
1081  theLatGrid.clear();
1082  theLonGrid.clear();
1083
1084  if (traceDebug()) CLOG << "returning..." << endl;
1085 }
1086
1087
const ossimColumnVector3d & data() const
ossimRefPtr< ossimLagrangeInterpolator > theArpPosInterp
ossimRefPtr< ossimLagrangeInterpolator > theLocalOrpInterp
bool interpolate(const double &t, NEWMAT::ColumnVector &result) const
ossimColumnVector3d cross(const ossimColumnVector3d &rhs) const
char pos[3][22]
RTTI_DEF1_INST(ossimGeneralRasterTileSource, "ossimGeneralRasterTileSource", ossimImageHandler) static ossimTrace traceDebug("ossimGeneralRasterTileSource for(ossim_uint32 i=0;i< aList.size();++i)
#define CLOG
Definition: ossimTrace.h:23
char gmt_sec[22]
ossimEcefPoint intersectAboveEarthEllipsoid(const double &heightAboveEllipsoid, const ossimDatum *aDatum=ossimDatumFactory::instance() ->wgs84()) const
struct pos_vect_rec pos_vect[64]
double u
Definition: ossimDpt.h:164
void addData(const double &t, const NEWMAT::ColumnVector &data)
static const ossimErrorCode OSSIM_OK
bool valid() const
Definition: ossimRefPtr.h:75
ossimEcefVector cross(const ossimEcefVector &) const
ossimString theImageID
double samp
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
Fulfills ossimObject base-class pure virtuals.
ossim_int32 long_first
ossimEcefPoint theORP
This code was derived from https://gist.github.com/mshockwave.
Definition: Barrier.h:8
const imop_desc_rec * imopDescRec() const
char incident_ang[8]
double y
Definition: ossimDpt.h:165
void interpolatedScanORP(const ossimDpt &orp, ossimEcefPoint &orp_ecf) const
ossim_int32 line_num
double x() const
void initialize(const ossimIpt &size, const ossimDpt &origin, const ossimDpt &spacing, double null_value=OSSIM_DEFAULT_NULL_PIX_DOUBLE)
char srgr_coef[6][16]
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
ossim_int32 acq_msec
char gmt_day[4]
double sind(double x)
Definition: ossimCommon.h:260
char sens_orient[9]
struct srgr_coefset_rec srgr_coefset[20]
struct acq_date_rec acq_date
const ossimFilename & imageFile() const
DirectionFlag theDirectionFlag
char n_dataset[6]
ossim_int32 long_last
char terrain_h[16]
double line
ossim_int32 lat_last
OSSIM_DLL void toVector(std::vector< ossimDpt > &result, const ossimString &stringOfPoints)
Will take a string list separated by spaces and convert to a vector of ossimDpts. ...
bool errorStatus() const
virtual void imagingRay(const ossimDpt &image_point, ossimEcefRay &image_ray) const
Given an image point, returns a ray originating at some arbitrarily high point (in this model at the ...
ossim_float64 lon
Definition: ossimGpt.h:266
virtual ~ossimRS1SarModel()
ossimRefPtr< ossimLagrangeInterpolator > theArpVelInterp
ossimEcefVector thePosCorrection
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
char pix_spacing[16]
const text_rec * textRec() const
ossim_int32 lat_mid
ossim_int32 acq_day
static NEWMAT::Matrix create()
double cosd(double x)
Definition: ossimCommon.h:259
ImagingMode theImagingMode
const pos_data_rec * posDataRec() const
char product_id[8]
Definition: ossimCeosData.h:60
char line_spacing[16]
double length() const
char hr_angle[22]
ossimDblGrid theLonGrid
if(yy_init)
char vel[3][22]
ossimDblGrid theLatGrid
ossim_int32 samp
Definition: ossimIpt.h:141
void setImagingMode(char *modeStr)
virtual ossimErrorCode getErrorStatus() const
double y() const
void eciToEcfXform(const double &julianDay, NEWMAT::Matrix &xform) const
const proc_parm_rec * procParmRec() const
virtual void lineSampleHeightToWorld(const ossimDpt &imagePt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
Establishes geographic 3D point given image line, sample and ellipsoid height.
double x
ossim_int32 lat_first
ossimLsrSpace theVehicleSpace
ossim_int32 line
Definition: ossimIpt.h:142
char l_dataset[6]
ossim_float64 lat
Definition: ossimGpt.h:265
const dataset_sum_rec * dataSetSumRec() const
char logvol_id[16]
Definition: ossimCeosData.h:43
ossimFilename path() const
char product_type[40]
Definition: ossimCeosData.h:95
ossim_int32 long_mid
void setNode(const ossimIpt &p, const double &value)
Definition: ossimDblGrid.h:107
ossim_int32 length
Definition: ossimCeosData.h:29
void initFromCeos(const ossimFilename &dataDir)
double v
char data_int[22]
ossimRefPtr< ossimCeosData > theCeosData
struct desc_rec desc
const vol_desc_rec * volDescRec() const
