ossimRpfCacheTileSource.h
Go to the documentation of this file.
1 //-----------------------------------------------------------------------
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: See top level LICENSE.txt file.
5 //
6 // Author: Garrett Potts
7 //
8 // Description: This class give the capability to access tiles from the
9 // input frames.
10 //
11 //-----------------------------------------------------------------------
12 //$Id: ossimRpfCacheTileSource.h 1361 2010-08-26 00:24:22Z david.burken $
13 #ifndef ossimRpfCacheTileSource_HEADER
14 #define ossimRpfCacheTileSource_HEADER 1
17
18 class ossimRpfToc;
19 class ossimRpfTocEntry;
20 class ossimRpfFrame;
21
23 {
24 public:
25
32  {
33  OSSIM_PRODUCT_TYPE_UNKNOWN = 0,
34  OSSIM_PRODUCT_TYPE_CIB = 1,
35  OSSIM_PRODUCT_TYPE_CADRG = 2
36  };
37
44
52  virtual ossimString getShortName()const;
53
61  virtual ossimString getLongName()const;
62
66  virtual void close();
67
70  virtual bool open();
71
83  ossim_uint32 resLevel = 0);
84
97  virtual bool getTile(ossimImageData* result, ossim_uint32 resLevel=0);
98
105  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
106
113  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
114
121  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const;
122
123
132  virtual bool saveState(ossimKeywordlist& kwl,
133  const char* prefix=0)const;
134
161  virtual bool loadState(const ossimKeywordlist& kwl,
162  const char* prefix=0);
163
196
207  virtual ossimScalarType getOutputScalarType() const;
208
216  virtual ossim_uint32 getNumberOfInputBands()const;
217
225  virtual ossim_uint32 getNumberOfOutputBands()const;
226
230  virtual ossim_uint32 getTileWidth() const;
231
235  virtual ossim_uint32 getTileHeight() const;
236
243  virtual ossim_uint32 getImageTileWidth() const;
244
251  virtual ossim_uint32 getImageTileHeight() const;
252
253  virtual bool setCurrentEntry(ossim_uint32 entryIdx);
254
255  virtual void getEntryList(std::vector<ossim_uint32>& entryList)const;
256
262  bool isValidRLevel(ossim_uint32 reduced_res_level) const;
263
269  bool isOpen()const;
270
272  bool isCib() const;
273
275  bool isCadrg() const;
276
282  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name)const;
283
288
293
294
295 protected:
301  virtual ~ossimRpfCacheTileSource();
302
307  void setActualImageRect();
308
318  void checkLongitude(ossim_float64& leftLon, const ossim_float64& rightLon) const;
319
329  {
331  :theRow(-1),
332  theCol(-1),
333  thePixelRow(-1),
334  thePixelCol(-1)
335  {}
337  ossim_int32 col,
338  ossim_int32 pixelRow,
339  ossim_int32 pixelCol,
340  const ossimRpfFrameEntry& entry)
341  :theRow(row),
342  theCol(col),
343  thePixelRow(pixelRow),
344  thePixelCol(pixelCol),
345  theFrameEntry(entry)
346  {}
348  :theRow(rhs.theRow),
349  theCol(rhs.theCol),
350  thePixelRow(rhs.thePixelRow),
351  thePixelCol(rhs.thePixelCol),
352  theFrameEntry(rhs.theFrameEntry)
353  {}
359  };
360
365  virtual bool setEntryToRender(ossim_uint32 index);
366
378  vector<ossimFrameEntryData> getIntersectingEntries(const ossimIrect& rect);
379
390  void fillTile(const ossimIrect& tileRect,
391  const vector<ossimFrameEntryData>& framesInvolved,
392  ossimImageData* tile);
393
401  void fillSubTileCib(const ossimRpfFrame& aFrame,
402  const ossimIrect& tileRect,
403  const ossimFrameEntryData& frameEntryData,
404  ossimImageData* tile);
405
413  void fillSubTileCadrg(const ossimRpfFrame& aFrame,
414  const ossimIrect& tileRect,
415  const ossimFrameEntryData& frameEntryData,
416  ossimImageData* tile);
417
423  void allocateForProduct();
424
425  void deleteAll();
426
427  void populateLut();
428
429  bool buildFrameEntryArray(ossimFilename imageFile);
430  virtual void establishDecimationFactors();
431
432
437
441  unsigned char* m_compressedBuffer;
442
446  unsigned char* m_uncompressedBuffer;
447
454
461
466
470  std::vector<ossimString> m_fileNames;
471
476
482
484
485  // data to use in property retrieval
486
493
494  std::vector< std::vector<ossimRpfFrameEntry> > m_frameEntryArray;
495
496 TYPE_DATA
497 };
498
499 #endif /* #ifndef ossimRpfCacheTileSource_HEADER */
virtual bool open()=0
Pure virtual open.
std::vector< ossimString > m_fileNames
The size of the input frames.
Protected structure that is only used internally by this class.
ossimIrect m_actualImageRect
This holds the image bounds for the current entry.
#define OSSIMDLLEXPORT
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Returns the default processing tile height.
ossimFrameEntryData(const ossimFrameEntryData &rhs)
virtual ossimString getShortName() const
Definition: ossimObject.cpp:48
Returns the default processing tile width.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool isOpen() const =0
double ossim_float64
ossimRefPtr< ossimImageData > m_tile
This is the actual data returned from a getTile request.
ossimFrameEntryData(ossim_int32 row, ossim_int32 col, ossim_int32 pixelRow, ossim_int32 pixelCol, const ossimRpfFrameEntry &entry)
static const ossim_uint32 CIBCADRG_FRAME_HEIGHT
CONSTANT representing the height of a Frame.
ossimRpfCacheProductType
Basic enumeration.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
ossimRpfCacheProductType m_productType
Holds the enumeration specifying the product type.
unsigned int ossim_uint32
unsigned char * m_compressedBuffer
This is for storage of a single compressed buffer.
virtual ossimString getLongName() const
Definition: ossimObject.cpp:53
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
Virtual method determines the decimation factors at each resolution level.
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
ossimIpt m_tileSize
The size of the output tile.
std::vector< std::vector< ossimRpfFrameEntry > > m_frameEntryArray
This class defines an abstract Handler which all image handlers(loaders) should derive from...
static const ossim_uint32 CIBCADRG_FRAME_WIDTH
CONSTANT representing the width of a Frame.
unsigned char * m_uncompressedBuffer
This is used as a buffer to uncompress the data to.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
ossim_uint32 m_numberOfSamples
This will be computed based on the frames organized within the directory.
ossim_uint32 m_numberOfLines
int ossim_int32
