Classes | Public Types | Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
ossimRpfCacheTileSource Class Reference
#include <ossimRpfCacheTileSource.h>
Inheritance diagram for ossimRpfCacheTileSource:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Classes
struct  ossimFrameEntryData
 Protected structure that is only used internally by this class. More...
Public Types
enum  ossimRpfCacheProductType { OSSIM_PRODUCT_TYPE_UNKNOWN = 0, OSSIM_PRODUCT_TYPE_CIB = 1, OSSIM_PRODUCT_TYPE_CADRG = 2 }
 Basic enumeration. More...
 ossimRpfCacheTileSource ()
 Default constructor. More...
 This method is defined in the base class ossimObject. More...
virtual void close ()
 Closes this image handler and deletes any allocated data. More...
virtual bool open ()
 Pure virtual open. More...
 Returns a pointer to an ossimImageDataObject given a rectangluar region of interest. More...
 Method to get a tile. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Satisfies pure virtual requirement from ImageHandler class. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
 Method to load the state of an object from a keyword list. More...
Populates the geometry object with image geometry information. More...
 This method allows you to query the scalar type of the output data. More...
 This method allows you to query the number of input bands. More...
 This method allows one to query the number of output bands. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
bool isValidRLevel (ossim_uint32 reduced_res_level) const
bool isOpen () const
 Determines if its open if there eists a table of contents object. More...
bool isCib () const
bool isCadrg () const
 Gets a property for matching name. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
static const ossim_uint32 CIBCADRG_FRAME_WIDTH = 1536
 CONSTANT representing the width of a Frame. More...
static const ossim_uint32 CIBCADRG_FRAME_HEIGHT = 1536
 CONSTANT representing the height of a Frame. More...
virtual ~ossimRpfCacheTileSource ()
 Destructor. More...
void setActualImageRect ()
 Will shift the rect and clamp it so not to go outside the -180 to 180 degree range. More...
void checkLongitude (ossim_float64 &leftLon, const ossim_float64 &rightLon) const
 Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180.0 degrees. More...
virtual bool setEntryToRender (ossim_uint32 index)
 Sets the entry to render. More...
vector< ossimFrameEntryDatagetIntersectingEntries (const ossimIrect &rect)
 It is important to note that each frame is organized into an easting northing type orientation. More...
void fillTile (const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile)
 This is a wrapper for the fill cib and fill cadrg. More...
void fillSubTileCib (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
 Will uncompress the CIB file using a VQ decompression algorithm. More...
void fillSubTileCadrg (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
 Will uncompress the CADRG file using a VQ decompression algorithm. More...
void allocateForProduct ()
 Will allocate an internal buffer for the given product. More...
void deleteAll ()
void populateLut ()
bool buildFrameEntryArray (ossimFilename imageFile)
virtual void completeOpen ()
virtual ~ossimReferenced ()
ossimIrect m_actualImageRect
 This holds the image bounds for the current entry. More...
unsigned char * m_compressedBuffer
 This is for storage of a single compressed buffer. More...
unsigned char * m_uncompressedBuffer
 This is used as a buffer to uncompress the data to. More...
ossim_uint32 m_numberOfLines
 This will be computed based on the frames organized within the directory. More...
ossim_uint32 m_numberOfSamples
 This is the actual data returned from a getTile request. More...
std::vector< ossimStringm_fileNames
 The size of the input frames. More...
ossimIpt m_tileSize
 The size of the output tile. More...
ossimRpfCacheProductType m_productType
 Holds the enumeration specifying the product type. More...
ossimRpfFramem_workFrame
ossim_float64 m_bBox_LL_Lon
ossim_float64 m_bBox_LL_Lat
ossim_float64 m_bBox_UR_Lon
ossim_float64 m_bBox_UR_Lat
ossim_uint32 m_numOfFramesVertical
ossim_uint32 m_numOfFramesHorizontal
std::vector< std::vector< ossimRpfFrameEntry > > m_frameEntryArray
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 22 of file ossimRpfCacheTileSource.h.
◆ ossimRpfCacheProductType
Basic enumeration.
This should be either a CIB or a CADRG product type.
Enumerator
Definition at line 31 of file ossimRpfCacheTileSource.h.
◆ ossimRpfCacheTileSource()
ossimRpfCacheTileSource::ossimRpfCacheTileSource ( )
Initializes all internal attributes to a default state.
Definition at line 51 of file ossimRpfCacheTileSource.cpp.
52  :
54
55  // a CADRG and CIBis a 64*64*12 bit buffer and must divide by 8 to
56  // convert to bytes
57  m_compressedBuffer(new ossim_uint8[(64*64*12)/8]),
58
59  // whether CIB or CADRG we will alocate the buffer
60  // to the larger of the 2 (CADRG is 3 bands)
61  m_uncompressedBuffer(new ossim_uint8[256*256*3]),
62
63  m_numberOfLines(0),
65  m_tile(0),
66  m_fileNames(),
67  m_tileSize(128, 128),
70  m_bBox_LL_Lon(0.0),
71  m_bBox_LL_Lat(0.0),
72  m_bBox_UR_Lon(0.0),
73  m_bBox_UR_Lat(0.0),
77 {
78  if (traceDebug())
79  {
81  << "ossimRpfCacheTileSource::ossimRpfCacheTileSource entered...\n";
82 #ifdef OSSIM_ID_ENABLED
84  << "OSSIM_ID: " << OSSIM_ID << "\n";
85 #endif
86  }
87
89
90 }
std::vector< ossimString > m_fileNames
ossimRefPtr< ossimImageData > m_tile
ossimIpt m_tileSize
void makeNan()
Definition: ossimIrect.h:329
ossimImageHandler()
Constructor (default):
unsigned char ossim_uint8
◆ ~ossimRpfCacheTileSource()
ossimRpfCacheTileSource::~ossimRpfCacheTileSource ( )
protectedvirtual
Destructor.
Will return allocated memory back to the heap.
Definition at line 92 of file ossimRpfCacheTileSource.cpp.
References close(), m_compressedBuffer, m_uncompressedBuffer, and m_workFrame.
93 {
95  {
96  delete [] m_compressedBuffer;
98  }
100  {
101  delete [] m_uncompressedBuffer;
103  }
104  if(m_workFrame)
105  {
106  delete m_workFrame;
107  m_workFrame = 0;
108  }
109  close();
110 }
virtual void close()
Member Function Documentation
◆ allocateForProduct()
void ossimRpfCacheTileSource::allocateForProduct ( )
protected
If the product is a CIB then it is a single band OSSIM_UCHAR buffer and if its a CADRG it is a 3 band OSSIM_UCHAR buffer.
Definition at line 1111 of file ossimRpfCacheTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_compressedBuffer, m_productType, m_tile, m_uncompressedBuffer, OSSIM_PRODUCT_TYPE_CIB, and OSSIM_PRODUCT_TYPE_UNKNOWN.
1112 {
1114  {
1115  return;
1116  }
1118  {
1119  delete [] m_uncompressedBuffer;
1121  }
1122  if(m_compressedBuffer)
1123  {
1124  delete [] m_compressedBuffer;
1125  m_compressedBuffer = 0;
1126  }
1127
1128  // a CADRG and CIBis a 64*64*12 bit buffer and must divide by 8 to
1129  // convert to bytes
1130  m_compressedBuffer = new ossim_uint8[(64*64*12)/8];
1132  {
1133  m_uncompressedBuffer = new ossim_uint8[256*256];
1134  }
1135  else
1136  {
1137  m_uncompressedBuffer = new ossim_uint8[256*256*3];
1138  }
1139
1141  m_tile->initialize();
1142 }
virtual void initialize()
Initialize the data buffer.
◆ buildFrameEntryArray()
bool ossimRpfCacheTileSource::buildFrameEntryArray ( ossimFilename  imageFile)
protected
Definition at line 190 of file ossimRpfCacheTileSource.cpp.
191 {
192  static const char MODULE[] = "ossimRpfCacheTileSource::buildFrameEntryArray";
193  if ( traceDebug() )
194  {
195  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered..." << endl;
196  }
197
198  std::ifstream in((imageFile).c_str() );
199
200  std::string line;
201  ossim_uint32 index = 0; // used throughout
202  while( in.good() )
203  {
204  // Read in a line.
205  std::getline(in, line);
206
207  ossimString tmpStr = ossimString(line);
208  if (!tmpStr.empty())
209  {
210  if (index == 0)
211  {
212  std::vector<ossimString> box_lat_lon;
213  tmpStr.split(box_lat_lon, "|");
214
215  if (box_lat_lon.size() > 2)
216  {
217  std::vector<ossimString> ll;
218  std::vector<ossimString> ur;
219
220  box_lat_lon[0].split(ll, ",");
221  box_lat_lon[1].split(ur, ",");
222  ossimString bandStr = box_lat_lon[2];
223
224  m_bBox_LL_Lon = ll[0].toFloat64();
225  m_bBox_LL_Lat = ll[1].toFloat64();
226  m_bBox_UR_Lon = ur[0].toFloat64();
227  m_bBox_UR_Lat = ur[1].toFloat64();
228
230
231  ossim_int32 bands = ossimString(bandStr).toInt32();
232  if (bands == 1)
233  {
235  }
236  else if (bands == 3)
237  {
239  }
240  }
241  else
242  {
243  return false;
244  }
245  }
246  else if (index == 1)
247  {
248  m_fileNames.push_back(tmpStr);
249  std::vector<ossimString> frame_lat_lon = tmpStr.split("|");
250  if (frame_lat_lon.size() > 2)
251  {
252  ossimString ll_lon_lat = frame_lat_lon[1];
253  ossimString ur_lon_lat = frame_lat_lon[2];
254  ossim_float64 ll_lon = ossimString(ll_lon_lat.split(",")[0]).toDouble();
255  ossim_float64 ll_lat = ossimString(ll_lon_lat.split(",")[1]).toDouble();
256  ossim_float64 ur_lon = ossimString(ur_lon_lat.split(",")[0]).toDouble();
257  ossim_float64 ur_lat = ossimString(ur_lon_lat.split(",")[1]).toDouble();
258
259  checkLongitude(ll_lon, ur_lon);
260
261  ossim_float64 bBox_lat_diff = std::fabs(m_bBox_UR_Lat - m_bBox_LL_Lat);
262  ossim_float64 bBox_lon_diff = std::fabs(m_bBox_UR_Lon - m_bBox_LL_Lon);
263
264  ossim_float64 lat_diff = std::fabs(ur_lat - ll_lat);
265  ossim_float64 lon_diff = std::fabs(ur_lon - ll_lon);
266
267  m_numOfFramesVertical = static_cast<ossim_uint32>(bBox_lat_diff/lat_diff + 0.5);
268  m_numOfFramesHorizontal = static_cast<ossim_uint32>(bBox_lon_diff/lon_diff + 0.5);
269
272
273  if ( traceDebug() )
274  {
276  << "\nscene height in degrees: " << bBox_lat_diff
277  << "\nscene width in degrees: " << bBox_lon_diff
278  << "\nframe height in degrees: " << lat_diff
279  << "\nframe width in degrees: " << lon_diff
280  << "\nframes vertical: " << m_numOfFramesVertical
281  << "\nframes horizontal: " << m_numOfFramesHorizontal
282  << "\nlines: " << m_numberOfLines
283  << "\nsamples: " << m_numberOfSamples << "\n";
284  }
285  }
286  else
287  {
288  return false;
289  }
290  }
291  else
292  {
293  m_fileNames.push_back(tmpStr);
294  }
295
296  } // matches: if (!tmpStr.empty())
297
298  ++index;
299
300  } // matches: while( in.good() )
301  in.close();
302
304  for(index = 0; index < m_frameEntryArray.size(); ++index)
305  {
307  }
308
309  for(index = 0; index < m_fileNames.size(); ++index)
310  {
311  ossimString tmpStr = m_fileNames[index];
312  std::vector<ossimString> frameInfos = tmpStr.split("|");
313  if (frameInfos.size() > 1)
314  {
315  ossimString fileName = frameInfos[0];
316  ossimString ll_lon_lat = frameInfos[1];
317  ossimString ur_lon_lat = frameInfos[2];
318  double ll_lon = ossimString(ll_lon_lat.split(",")[0]).toDouble();
319  double ll_lat = ossimString(ll_lon_lat.split(",")[1]).toDouble();
320  double ur_lon = ossimString(ur_lon_lat.split(",")[0]).toDouble();
321  double ur_lat = ossimString(ur_lon_lat.split(",")[1]).toDouble();
322
323  checkLongitude(ll_lon, ur_lon);
324
325  ossim_float64 tmpColPostion = std::fabs(ll_lon - m_bBox_LL_Lon);
326  ossim_float64 tmpFrameLon = std::fabs(ur_lon - ll_lon);
327
328  ossim_float64 tmpRowPostion = std::fabs(m_bBox_UR_Lat - ur_lat);
329  ossim_float64 tmpFrameLat = std::fabs(ur_lat - ll_lat);
330
331  ossim_uint32 colNum = static_cast<ossim_uint32>(tmpColPostion/tmpFrameLon + 0.5);
332  ossim_uint32 rowNum = static_cast<ossim_uint32>(tmpRowPostion/tmpFrameLat + 0.5);
333
334  if (colNum >= m_numOfFramesHorizontal)
335  {
336  colNum = m_numOfFramesHorizontal-1; // Clamp to last column.
337  }
338
339  if (rowNum >= m_numOfFramesVertical)
340  {
341  rowNum = m_numOfFramesVertical-1; // Clamp to last row.
342  }
343
344  ossimRpfFrameEntry tempEntry;
345  tempEntry.setEntry(ossimFilename(""), fileName);
346  m_frameEntryArray[rowNum][colNum] = tempEntry;
347  }
348  else
349  {
350  return false;
351  }
352  }
353
354  return true;
355 }
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
std::istream & getline(std::istream &is, ossimString &str, char delim)
Definition: ossimString.h:916
ossim_int32 toInt32() const
double ossim_float64
unsigned int ossim_uint32
void setEntry(const ossimFilename &rootDirectory, const ossimFilename &pathToFrameFileFromRoot)
void checkLongitude(ossim_float64 &leftLon, const ossim_float64 &rightLon) const
Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180...
bool empty() const
Definition: ossimString.h:411
int ossim_int32
◆ checkLongitude()
void ossimRpfCacheTileSource::checkLongitude ( ossim_float64 leftLon,
const ossim_float64 rightLon
) const
protected
Parameters
leftLonLeft hand side longitude of scene. This is the value that will be flipped to -180 if test is true.
rightLonRight hand side of scene.
Definition at line 357 of file ossimRpfCacheTileSource.cpp.
References ossim::almostEqual().
359 {
360  //---
361  // Test for scene coordinates being 180 to 180 and adjust leftLon to -180
362  // if so.
363  //
364  // NOTE:
365  // Setting tolerance to 1/7200 about 15 meters.
366  // Not sure if this is too loose or not. (drb)
367  //---
368  const ossim_float64 TOLERANCE = 0.000138889; // 1/7200 about 15 meters.
369
370  if ( ossim::almostEqual(leftLon, 180.0, TOLERANCE) )
371  {
372  if ( ossim::almostEqual(rightLon, 180.0, TOLERANCE) )
373  {
374  leftLon = -180.0;
375  }
376  }
377 }
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
◆ close()
void ossimRpfCacheTileSource::close ( )
virtual
Definition at line 123 of file ossimRpfCacheTileSource.cpp.
References deleteAll().
Referenced by ~ossimRpfCacheTileSource().
124 {
125  deleteAll();
126 }
◆ deleteAll()
void ossimRpfCacheTileSource::deleteAll ( )
protected
Definition at line 1144 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::theOverview.
Referenced by close().
1145 {
1146  theOverview = 0;
1147 }
ossimRefPtr< ossimImageHandler > theOverview
◆ establishDecimationFactors()
void ossimRpfCacheTileSource::establishDecimationFactors ( )
protectedvirtual
Virtual method determines the decimation factors at each resolution level.
This base class implementation computes the decimation by considering the ratios in image size between resolution levels, with fuzzy logic for rounding ratios to the nearest power of 2 if possible. Derived classes need to override this method if the decimations are provided as part of the image metadata.
Definition at line 1307 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::establishDecimationFactors(), and ossimImageHandler::theDecimationFactors.
1308 {
1309  theDecimationFactors.clear();
1310
1311  // Just needed to set the first R level here, the base class can do the rest:
1313 }
std::vector< ossimDpt > theDecimationFactors
virtual void establishDecimationFactors()
◆ fillSubTileCadrg()
void ossimRpfCacheTileSource::fillSubTileCadrg ( const ossimRpfFrame aFrame,
const ossimIrect tileRect,
const ossimFrameEntryData frameEntryData,
ossimImageData tile
protected
Parameters
aFrameFrame that overlaps the requested tile rect.
tileRectThe region requested to render.
frameEntryDataThe frame entry data.
Definition at line 832 of file ossimRpfCacheTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfFrame::fillSubFrameBuffer(), ossimRpfFrame::getColorGrayscaleTable(), ossimRpfFrame::getCompressionSection(), ossimRpfCompressionSection::getTable(), ossimIrect::height(), ossimImageData::loadTile(), m_compressedBuffer, m_uncompressedBuffer, OSSIM_BSQ, ossimRpfCacheTileSource::ossimFrameEntryData::thePixelCol, ossimRpfCacheTileSource::ossimFrameEntryData::thePixelRow, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by fillTile().
837 {;
838 // first let's grab the absolute position of the frame rectangle in pixel space
839  ossimIrect frameRect(frameEntryData.thePixelCol,
840  frameEntryData.thePixelRow,
841  frameEntryData.thePixelCol + CIBCADRG_FRAME_WIDTH - 1,
842  frameEntryData.thePixelRow + CIBCADRG_FRAME_HEIGHT - 1);
843
844
845 // now clip it to the tile
846  ossimIrect clipRect = tileRect.clipToRect(frameRect);
847
848  const ossimRpfCompressionSection* compressionSection = aFrame.getCompressionSection();
849
850  if(!compressionSection)
851  {
852  return;
853  }
854
855  const vector<ossimRpfColorGrayscaleTable>& colorTable =
856  aFrame.getColorGrayscaleTable();
857
858 // ESH 03/2009 -- Partial fix for ticket #646.
859 // Crash fix on reading RPFs: Make sure the colorTable vector
860 // has entries before trying to make use of them.
861  int numTables = (int)colorTable.size();
862  if ( numTables <= 0 )
863  {
864  return;
865  }
866
867  ossim_uint8 *tempRows[3];
868
869  tempRows[0] = m_uncompressedBuffer;
870  tempRows[1] = (m_uncompressedBuffer + 256*256);
871  tempRows[2] = (tempRows[1] + 256*256);
872
873 // find the shift to 0,0
874  ossimIpt tempDelta(clipRect.ul().x - frameEntryData.thePixelCol,
875  clipRect.ul().y - frameEntryData.thePixelRow);
876
877
878 // In order to compute the subframe we will need the corner offsets of
879 // the upper left of the frame and the upper left of the clip rect. The
880 // clip rect should be completely within the frame. This just translates the value
881 // to make the upper left of the frame be 0,0.
882 //
883  ossimIrect offsetRect(tempDelta.x,
884  tempDelta.y,
885  tempDelta.x + clipRect.width()-1,
886  tempDelta.y + clipRect.height()-1);
887
888 // each subframe is 64x64. We will actually use 256x256 since
889 // we will be uncompressing them. Note CADRG is a 256x256 tile
890 // compressed to 64x64x12 bit data
891 //
892  ossimIrect subFrameRect(offsetRect.ul().x/256,
893  offsetRect.ul().y/256,
894  (offsetRect.lr().x)/256,
895  (offsetRect.lr().y)/256);
896
897  ossim_uint32 readPtr = 0;
898
899  ossim_int32 row = 0;
900  ossim_int32 col = 0;
901  ossim_uint32 i = 0;
902  ossim_uint32 j = 0;
903  ossim_int32 upperY = subFrameRect.lr().y;
904  ossim_int32 upperX = subFrameRect.lr().x;
905  ossim_int32 lowerY = subFrameRect.ul().y;
906  ossim_int32 lowerX = subFrameRect.ul().x;
907  for(row = lowerY; row <= upperY; ++row)
908  {
909  for(col = lowerX; col <= upperX; ++col)
910  {
911  readPtr = 0;
912  if(aFrame.fillSubFrameBuffer(m_compressedBuffer, 0, row, col))
913  {
914  for (i = 0; i < 256; i += 4)
915  {
916  for (j = 0; j < 256; j += 8)
917  {
918  ossim_uint16 firstByte = m_compressedBuffer[readPtr++] & 0xff;
919  ossim_uint16 secondByte = m_compressedBuffer[readPtr++] & 0xff;
920  ossim_uint16 thirdByte = m_compressedBuffer[readPtr++] & 0xff;
921
922  //because dealing with half-bytes is hard, we
923  //uncompress two 4x4 tiles at the same time. (a
924  //4x4 tile compressed is 12 bits )
925  // this little code was grabbed from openmap software.
926
927  /* Get first 12-bit value as index into VQ table */
928  // I think we need to swap
929  ossim_uint16 val1 = (firstByte << 4) | (secondByte >> 4);
930
931  /* Get second 12-bit value as index into VQ table*/
932  ossim_uint16 val2 = ((secondByte & 0x000F) << 8) | thirdByte;
933
934  for (ossim_uint32 t = 0; t < 4; ++t)
935  {
936  for (ossim_uint32 e = 0; e < 4; ++e)
937  {
938  ossim_uint16 tableVal1 = compressionSection->getTable()[t].theData[val1*4 + e] & 0xff;
939  ossim_uint16 tableVal2 = compressionSection->getTable()[t].theData[val2*4 + e] & 0xff;
940
941  ossim_uint32 pixindex = ((i+t)*256) +
942  (j + e);
943  const ossim_uint8* color1 = colorTable[0].getStartOfData(tableVal1);
944  const ossim_uint8* color2 = colorTable[0].getStartOfData(tableVal2);
945
946
947  tempRows[0][pixindex] = color1[0];
948  tempRows[1][pixindex] = color1[1];
949  tempRows[2][pixindex] = color1[2];
950
951  tempRows[0][pixindex+4] = color2[0];
952  tempRows[1][pixindex+4] = color2[1];
953  tempRows[2][pixindex+4] = color2[2];
954  } //for e
955  } //for t
956  } /* for j */
957  } //for i
958  }
959  else
960  {
961  memset(m_uncompressedBuffer, 0, 256*256*3);
962  }
963  ossim_int32 tempCol = col*256;
964  ossim_int32 tempRow = row*256;
965  ossimIrect subRectToFill(frameRect.ul().x + tempCol,
966  frameRect.ul().y + tempRow,
967  frameRect.ul().x + tempCol + 255,
968  frameRect.ul().y + tempRow + 255);
970  subRectToFill,
971  OSSIM_BSQ);
972  }
973  }
974 }
const std::vector< ossimRpfCompressionOffsetTableData > & getTable() const
ossim_uint32 height() const
Definition: ossimIrect.h:487
const ossimIpt & ul() const
Definition: ossimIrect.h:274
unsigned short ossim_uint16
const vector< ossimRpfColorGrayscaleTable > & getColorGrayscaleTable() const
Definition: ossimRpfFrame.h:80
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
bool fillSubFrameBuffer(ossim_uint8 *buffer, ossim_uint32 spectralGroup, ossim_uint32 row, ossim_uint32 col) const
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
const ossimRpfCompressionSection * getCompressionSection() const
Definition: ossimRpfFrame.h:76
int ossim_int32
◆ fillSubTileCib()
void ossimRpfCacheTileSource::fillSubTileCib ( const ossimRpfFrame aFrame,
ossimImageData tile
protected
Parameters
Definition at line 976 of file ossimRpfCacheTileSource.cpp.
981 {
982  // first let's grab the absolute position of the frame rectangle in pixel
983  // space
984  ossimIrect frameRect(frameEntryData.thePixelCol,
985  frameEntryData.thePixelRow,
986  frameEntryData.thePixelCol + CIBCADRG_FRAME_WIDTH - 1,
987  frameEntryData.thePixelRow + CIBCADRG_FRAME_HEIGHT - 1);
988
989
990  // now clip it to the tile
991  ossimIrect clipRect = tileRect.clipToRect(frameRect);
992
993  const ossimRpfCompressionSection* compressionSection = aFrame.getCompressionSection();
994
995  if(!compressionSection)
996  {
997  return;
998  }
999
1000  const vector<ossimRpfColorGrayscaleTable>& colorTable =
1001  aFrame.getColorGrayscaleTable();
1002
1003  // ESH 03/2009 -- Partial fix for ticket #646.
1004  // Crash fix on reading RPFs: Make sure the colorTable vector
1005  // has entries before trying to make use of them.
1006  int numTables = (int)colorTable.size();
1007  if ( numTables <= 0 )
1008  {
1009  return;
1010  }
1011
1012  // check to see if it does overlap. If it doesn't then the width and height
1013  // will be a single point
1014  {
1015  ossim_uint8 *tempRow;
1016
1017  tempRow = m_uncompressedBuffer;
1018
1019  // find the shift to 0,0
1020  ossimIpt tempDelta(clipRect.ul().x - frameEntryData.thePixelCol,
1021  clipRect.ul().y - frameEntryData.thePixelRow);
1022
1023  // In order to compute the subframe we will need the corner offsets of
1024  // the upper left of the frame and the upper left of the clip rect. The
1025  // clip rect should be completely within the frame. This just translates the value
1026  // to make the upper left of the frame be 0,0.
1027  //
1028  ossimIrect offsetRect(tempDelta.x,
1029  tempDelta.y,
1030  tempDelta.x + clipRect.width()-1,
1031  tempDelta.y + clipRect.height()-1);
1032
1033  // each subframe is 64x64. We will actually use 256x256 since
1034  // we will be uncompressing them. Note CADRG is a 256x256 tile
1035  // compressed to 64x64x12 bit data
1036  //
1037  ossimIrect subFrameRect(offsetRect.ul().x/256,
1038  offsetRect.ul().y/256,
1039  (offsetRect.lr().x)/256,
1040  (offsetRect.lr().y)/256);
1041
1042  ossim_int32 row = 0;
1043  ossim_int32 col = 0;
1044  ossim_uint32 i = 0;
1045  ossim_uint32 j = 0;
1046  ossim_uint32 readPtr = 0;
1047  for(row = subFrameRect.ul().y; row <= subFrameRect.lr().y; ++row)
1048  {
1049  for(col = subFrameRect.ul().x; col <= subFrameRect.lr().x; ++col)
1050  {
1051  readPtr = 0;
1052  if(aFrame.fillSubFrameBuffer(m_compressedBuffer, 0, row, col))
1053  {
1054  for (i = 0; i < 256; i += 4)
1055  {
1056  for (j = 0; j < 256; j += 8)
1057  {
1058  ossim_uint16 firstByte = m_compressedBuffer[readPtr++] & 0xff;
1059  ossim_uint16 secondByte = m_compressedBuffer[readPtr++] & 0xff;
1060  ossim_uint16 thirdByte = m_compressedBuffer[readPtr++] & 0xff;
1061
1062  //because dealing with half-bytes is hard, we
1063  //uncompress two 4x4 tiles at the same time. (a
1064  //4x4 tile compressed is 12 bits )
1065  // this little code was grabbed from openmap software.
1066
1067  /* Get first 12-bit value as index into VQ table */
1068  // I think we need to swap
1069  ossim_uint16 val1 = (firstByte << 4) | (secondByte >> 4);
1070
1071  /* Get second 12-bit value as index into VQ table*/
1072  ossim_uint16 val2 = ((secondByte & 0x000F) << 8) | thirdByte;
1073
1074  for (ossim_uint32 t = 0; t < 4; ++t)
1075  {
1076  for (ossim_uint32 e = 0; e < 4; ++e)
1077  {
1078  ossim_uint16 tableVal1 = compressionSection->getTable()[t].theData[val1*4 + e] & 0xff;
1079  ossim_uint16 tableVal2 = compressionSection->getTable()[t].theData[val2*4 + e] & 0xff;
1080
1081  ossim_uint32 pixindex = ((i+t)*256) + (j + e);
1082  const ossim_uint8* color1 = colorTable[0].getStartOfData(tableVal1);
1083  const ossim_uint8* color2 = colorTable[0].getStartOfData(tableVal2);
1084
1085
1086  tempRow[pixindex] = color1[0];
1087  tempRow[pixindex + 4] = color2[0];
1088  } //for e
1089  } //for t
1090  } /* for j */
1091  } //for i
1092  }
1093  else
1094  {
1095  memset(m_uncompressedBuffer, 0, 256*256);
1096  }
1097  ossim_int32 tCol = col*256;
1098  ossim_int32 tRow = row*256;
1099  ossimIrect subRectToFill(frameRect.ul().x + tCol,
1100  frameRect.ul().y + tRow,
1101  frameRect.ul().x + tCol + 255,
1102  frameRect.ul().y + tRow + 255);
1104  subRectToFill,
1105  OSSIM_BSQ);
1106  }
1107  }
1108  }
1109 }
ossim_int32 y
ossim_int32 x
int ossim_int32
◆ fillTile()
void ossimRpfCacheTileSource::fillTile ( const ossimIrect tileRect,
const vector< ossimFrameEntryData > &  framesInvolved,
ossimImageData tile
protected
It takes the frames involved that were found in the getIntersectingEntries and call the appropriate fill cib or fill cadrg on each frame entry data. It will loop through making sure that the frame file exists before calling the associated fill routines.
Parameters
tileRectRegion to fill.
framesInvolvedAll intersecting frames used to render the region.
Definition at line 798 of file ossimRpfCacheTileSource.cpp.
References fillSubTileCadrg(), fillSubTileCib(), m_productType, m_workFrame, ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CIB, and ossimRpfFrame::parseFile().
Referenced by getTile().
802 {
803  ossim_uint32 idx = 0;
804  for(idx = 0;
805  idx < framesInvolved.size();
806  ++idx)
807  {
808
809  if(m_workFrame->parseFile(framesInvolved[idx].theFrameEntry.getFullPath())
811  {
812  // we will fill a subtile. We pass in which frame it is and the position of the frame.
813  // the actual pixel will be 1536*row and 1536 *col.
815  {
817  tileRect,
818  framesInvolved[idx],
819  tile);
820  }
821  else
822  {
824  tileRect,
825  framesInvolved[idx],
826  tile);
827  }
828  }
829  }
830 }
void fillSubTileCib(const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
static const ossimErrorCode OSSIM_OK
ossimErrorCode parseFile(const ossimFilename &filename, bool minimalParse=false)
void fillSubTileCadrg(const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
◆ getEntryList()
void ossimRpfCacheTileSource::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
virtual
Parameters
entryListThis is the list to initialize with entry indexes.
Note
This implementation returns puts one entry "0" in the list.
Definition at line 730 of file ossimRpfCacheTileSource.cpp.
731 {
732  entryList.push_back(0);
733 }
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimRpfCacheTileSource::getImageGeometry ( )
virtual
This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not. Keywords supported by this class are:
*  datum:    // datum code>   // Datum code
*  ul_lat:   // upper left latitude
*  ul_lon:   // upper left longitude
*  ll_lat:   // lower left latitude
*  ll_lon:   // lower left longitude
*  lr_lat:   // lower right latitude
*  lr_lon:   // lower right longitude
*  ur_lat:   // upper right latitude
*  ur_lon:   // upper right longitude
*  number_input_bands:
*  number_output_bands:
*  number_lines:
*  number_samples:
*  decimal_degrees_per_pixel_lat:  // specifies the spacing per pixel along Y direction
*  decimal_degrees_per_pixel_lon:  // specifies the spacing per pixel along X direction
*  origin_latitude:                // specifies the origin or center of the projector for the latitude
*  central_meridian:               // specifies the origin or center of the projector for the longitude
*  tie_point_lat:     // tie point lat.  Represents the latitude of the upper left center of pixel
*  tie_point_lon:     // tie point lon.  Represents the longitude of the upper left center of pixel
*  zone:              // zone read from the CIB/CADRG boundary info
*  type:              // class name of the object for factory driven reconstruction
*  map_scale:         // Map scale of the image
See also
ossimImageSource for further code example on using the geometry.
Definition at line 545 of file ossimRpfCacheTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordNames::DATUM_KW, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimRefPtr< T >::get(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), ossimImageHandler::initImageParameters(), ossimDpt::lat, ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimImageGeometry::loadState(), ossimDpt::lon, ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, m_bBox_LL_Lat, m_bBox_LL_Lon, m_bBox_UR_Lat, m_bBox_UR_Lon, ossimKeywordNames::NUMBER_INPUT_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_OUTPUT_BANDS_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimImageHandler::theGeometry, ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, ossimKeywordNames::TIE_POINT_XY_KW, ossimDpt::toString(), ossimKeywordNames::TYPE_KW, ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, and ossimRefPtr< T >::valid().
546 {
547  if (theGeometry.valid()) return theGeometry;
548
549  // datum
550  // WGS 84
551  ossimKeywordlist kwl;
552  const char* prefix = 0; // legacy
553  kwl.add(prefix,
555  "WGE",
556  true);
557
562
563  double latInterval = fabs(ul.latd() - lr.latd())/ getNumberOfLines();
564  double lonInterval = fabs(ul.lond() - ur.lond())/ getNumberOfSamples();
565
566  kwl.add(prefix,
568  ul.latd(),//-(latInterval/2.0),
569  true);
570
571  kwl.add(prefix,
573  ul.lond(),//+(lonInterval/2.0),
574  true);
575
576  kwl.add(prefix,
578  ll.latd(),//+(latInterval/2.0),
579  true);
580
581  kwl.add(prefix,
583  ll.lond(),//+(lonInterval/2.0),
584  true);
585
586  kwl.add(prefix,
588  lr.latd(),//+(latInterval/2.0),
589  true);
590
591  kwl.add(prefix,
593  lr.lond(),//-(lonInterval/2.0),
594  true);
595
596  kwl.add(prefix,
598  ur.latd(),//-(latInterval/2.0),
599  true);
600
601  kwl.add(prefix,
603  ur.lond(),//-(latInterval/2.0),
604  true);
605
606  kwl.add(prefix,
609  true);
610
611  kwl.add(prefix,
614  true);
615
616  kwl.add(prefix,
619  true);
620
621  kwl.add(prefix,
624  true);
625
626
627  //---
628  // Make a projection to get the easting / northing of the tie point and
629  // the scale in meters. This will only be used by the CIB.
630  //---
631  kwl.add(prefix,
633  "WGE",
634  true);
635
636  ossimGpt origin((ul.latd()+lr.latd())*.5,
637  (ul.lond()+lr.lond())*.5,
638  0.0);
639
640  double deltaLatPerPixel = latInterval;
641  double deltaLonPerPixel = lonInterval;
642
643  ossimDpt tie;
644
645  tie.lat = ul.latd() - deltaLatPerPixel/2.0;
646  tie.lon = ul.lond() + deltaLonPerPixel/2.0;
647
648  kwl.add(prefix,
650  tie.toString(),
651  true);
652
653  kwl.add(prefix,
655  deltaLatPerPixel,
656  true);
657
658  kwl.add(prefix,
660  deltaLonPerPixel,
661  true);
662
663  kwl.add(prefix,
665  origin.latd(),
666  true);
667
668  kwl.add(prefix,
670  origin.lond(),
671  true);
672
673  kwl.add(prefix,
675  ul.latd()-(deltaLatPerPixel/2.0),
676  true);
677
678  kwl.add(prefix,
680  ul.lond()+(deltaLonPerPixel/2.0),
681  true);
682
683  kwl.add(prefix,
685  "ossimEquDistCylProjection",
686  true);
687
688  // Capture this for next time.
690  theGeometry->loadState(kwl, prefix);
691
692  // Set image things the geometry object should know about.
694
695  return theGeometry;
696 }
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
static const char * DATUM_KW
static const char * CENTRAL_MERIDIAN_KW
static const char * UL_LAT_KW
bool valid() const
Definition: ossimRefPtr.h:75
Attempts to initialize a transform and a projection given the KWL.
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
static const char * NUMBER_INPUT_BANDS_KW
static const char * LR_LON_KW
static const char * TYPE_KW
static const char * LR_LAT_KW
double lat
Definition: ossimDpt.h:165
static const char * TIE_POINT_XY_KW
static const char * LL_LON_KW
static const char * NUMBER_OUTPUT_BANDS_KW
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
static const char * LL_LAT_KW
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
double lon
Definition: ossimDpt.h:164
static const char * ORIGIN_LATITUDE_KW
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
virtual ossim_uint32 getNumberOfInputBands() const
static const char * UL_LON_KW
static const char * UR_LAT_KW
static const char * UR_LON_KW
static const char * TIE_POINT_LAT_KW
static const char * NUMBER_SAMPLES_KW
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
◆ getImageRectangle()
ossimIrect ossimRpfCacheTileSource::getImageRectangle ( ossim_uint32  reduced_res_level = 0) const
virtual
Parameters
reduced_res_levelWhich res level to get the bounds for. 0 represents the default and is the full resolution.
Returns
A rectangle representing the bounds for the passed in resolution level.
Definition at line 537 of file ossimRpfCacheTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Referenced by getIntersectingEntries(), and getTile().
538 {
539  return ossimIrect(0, // upper left x
540  0, // upper left y
541  getNumberOfSamples(reduced_res_level) - 1, // lower right x
542  getNumberOfLines(reduced_res_level) - 1); // lower right y
543 }
◆ getImageTileHeight()
ossim_uint32 ossimRpfCacheTileSource::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 1203 of file ossimRpfCacheTileSource.cpp.
1204 {
1205  return 256;
1206 }
◆ getImageTileWidth()
ossim_uint32 ossimRpfCacheTileSource::getImageTileWidth ( ) const
virtual
Definition at line 1198 of file ossimRpfCacheTileSource.cpp.
1199 {
1200  return 256;
1201 }
◆ getIntersectingEntries()
vector< ossimRpfCacheTileSource::ossimFrameEntryData > ossimRpfCacheTileSource::getIntersectingEntries ( const ossimIrect rect)
protected
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
Parameters
rectthe current region to render.
Returns
The list of entry data objects found for this rect.
Definition at line 762 of file ossimRpfCacheTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfFrameEntry::exists(), getImageRectangle(), ossimIrect::intersects(), isOpen(), ossimIrect::lr(), m_frameEntryArray, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
763 {
764  vector<ossimFrameEntryData> result;
765
766  // make sure we have the Toc entry to render
767  if(!isOpen()) return result;
768
769  ossimIrect imageRect = getImageRectangle();
770  if(rect.intersects(imageRect))
771  {
772  ossimIrect clipRect = rect.clipToRect(imageRect);
773  ossimIrect frameRect(clipRect.ul().x/CIBCADRG_FRAME_WIDTH,
774  clipRect.ul().y/CIBCADRG_FRAME_HEIGHT,
775  clipRect.lr().x/CIBCADRG_FRAME_WIDTH,
776  clipRect.lr().y/CIBCADRG_FRAME_HEIGHT);
777
778  for(ossim_int32 row = frameRect.ul().y; row <= frameRect.lr().y; ++row)
779  {
780  for(ossim_int32 col = frameRect.ul().x; col <= frameRect.lr().x; ++col)
781  {
782  ossimRpfFrameEntry tempEntry = m_frameEntryArray[row][col];
783  if(tempEntry.exists())
784  {
785  result.push_back(ossimFrameEntryData(row,
786  col,
789  tempEntry));
790  }
791  }
792  }
793  }
794
795  return result;
796 }
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_int32 y
ossim_int32 x
bool isOpen() const
int ossim_int32
◆ getLongName()
ossimString ossimRpfCacheTileSource::getLongName ( ) const
virtual
This class overrides the default implementation to return its own long name.
Returns
The long name for this class as an ossimString.
Definition at line 117 of file ossimRpfCacheTileSource.cpp.
118 {
119  return ossimString("RpfCache reader");
120 }
◆ getNumberOfInputBands()
ossim_uint32 ossimRpfCacheTileSource::getNumberOfInputBands ( ) const
virtual
If an image is band selectable this will allow one to select the bands you wish to read in. This indicates that the number of input bands might not match the number of output bands.
Returns
Implements ossimImageSource.
Definition at line 462 of file ossimRpfCacheTileSource.cpp.
References m_productType, OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, and OSSIM_PRODUCT_TYPE_UNKNOWN.
Referenced by getImageGeometry().
463 {
464  switch(m_productType)
465  {
467  {
468  return 0;
469  }
471  {
472  return 1;
473  }
475  {
476  return 3;
477  }
478  }
479
480  return 0;
481 }
◆ getNumberOfLines()
ossim_uint32 ossimRpfCacheTileSource::getNumberOfLines ( ossim_uint32  reduced_res_level = 0) const
virtual
Parameters
reduced_res_levelThe reduced res level to query number of lines from.
Returns
The number of lines in the image.
Definition at line 504 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), m_numberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry(), and getImageRectangle().
505 {
506  if (reduced_res_level == 0)
507  {
508  return m_numberOfLines;
509  }
510  else if (theOverview.valid())
511  {
512  return theOverview->getNumberOfLines(reduced_res_level);
513  }
514
515  return 0;
516 }
bool valid() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
◆ getNumberOfOutputBands()
ossim_uint32 ossimRpfCacheTileSource::getNumberOfOutputBands ( ) const
virtual
This might not be the same as the n umber of input bands.
See also
getNumberOfInputBands().
Returns
Definition at line 483 of file ossimRpfCacheTileSource.cpp.
Referenced by getImageGeometry(), and getTile().
484 {
485  switch(m_productType)
486  {
488  {
489  return 0;
490  }
492  {
493  return 1;
494  }
496  {
497  return 3;
498  }
499  }
500
501  return 0;
502 }
◆ getNumberOfSamples()
ossim_uint32 ossimRpfCacheTileSource::getNumberOfSamples ( ossim_uint32  reduced_res_level = 0) const
virtual
Parameters
reduced_res_levelThe reduced res level to query number of samples from.
Returns
The number of samples in the image.
Definition at line 518 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), m_numberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
519 {
520  if (reduced_res_level == 0)
521  {
522  return m_numberOfSamples;
523  }
524  else if (theOverview.valid())
525  {
526  return theOverview->getNumberOfSamples(reduced_res_level);
527  }
528
529  return 0;
530 }
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimRpfCacheTileSource::getOutputScalarType ( ) const
virtual
This is simply the data type, i.e. whether its OSSIM_FLOAT, OSSIM_DOUBLE, OSSIM_UCHAR, ... etc. This means that if there are bands of different scalar types from a single image then they must be casted to the highest precision type.
See also
ossimConstants.h for all ossimScalarType.
Returns
The output scalar type.
Definition at line 698 of file ossimRpfCacheTileSource.cpp.
References OSSIM_UCHAR.
699 {
700  return OSSIM_UCHAR;
701 }
8 bit unsigned iteger
◆ getProperty()
ossimRefPtr< ossimProperty > ossimRpfCacheTileSource::getProperty ( const ossimString name) const
virtual
Parameters
nameThe name of the property to get.
Returns
Returns property matching "name".
Definition at line 1218 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::getProperty(), m_productType, OSSIM_PRODUCT_TYPE_CADRG, and OSSIM_PRODUCT_TYPE_CIB.
1219 {
1220  if(name == "file_type")
1221  {
1223  {
1224  return new ossimStringProperty("file_type", "CIB");
1225  }
1227  {
1228  return new ossimStringProperty("file_type", "CADRG");
1229  }
1230  return 0;
1231  }
1232  return ossimImageHandler::getProperty(name);
1233 }
◆ getShortName()
ossimString ossimRpfCacheTileSource::getShortName ( ) const
virtual
This class overrides the default implementation to return its own short name.
Returns
The short name for this class as an ossimString.
Definition at line 112 of file ossimRpfCacheTileSource.cpp.
113 {
114  return ossimString("RpfCache");
115 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimRpfCacheTileSource::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Parameters
rectThe region of interest to return.
resLevelFrom which resolution set are we querying (default is 0 full res).
Returns
The ossimImageData object to the caller.
Definition at line 379 of file ossimRpfCacheTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
381 {
382  if (m_tile.valid())
383  {
384  // Image rectangle must be set prior to calling getTile.
385  m_tile->setImageRectangle(rect);
386
387  if ( getTile( m_tile.get(), resLevel ) == false )
388  {
390  {
391  m_tile->makeBlank();
392  }
393  }
394  }
395
396  return m_tile;
397 }
bool valid() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
virtual void makeBlank()
◆ getTile() [2/2]
bool ossimRpfCacheTileSource::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 399 of file ossimRpfCacheTileSource.cpp.
References fillTile(), getImageRectangle(), ossimImageData::getImageRectangle(), getIntersectingEntries(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), m_productType, ossimImageData::makeBlank(), OSSIM_PRODUCT_TYPE_UNKNOWN, status, and ossimImageData::validate().
401 {
402  bool status = false;
403
404  //---
405  // Not open, this tile source bypassed, or invalid res level,
406  // return a blank tile.
407  //---
408  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
409  result && (result->getNumberOfBands() == getNumberOfOutputBands()) &&
411  {
412  if ( resLevel > 0 )
413  {
414  //---
415  // Check for overview tile. Some overviews can contain r0 so always
416  // call even if resLevel is 0 (if overview is not virtual). Method
417  // returns true on success, false on error.
418  //---
419  status = getOverviewTile(resLevel, result);
420  }
421
422  if (!status) // Did not get an overview tile.
423  {
424  status = true;
425
426  ossimIrect rect = result->getImageRectangle();
427
428  ossimIrect imageRect = getImageRectangle();
429
430  if ( rect.intersects(imageRect) )
431  {
432  //---
433  // Start with a blank tile in case there is not total coverage
434  // for rect.
435  //---
436  result->makeBlank();
437
438  vector<ossimFrameEntryData> frames = getIntersectingEntries(rect);
439  if(frames.size() > 0)
440  {
441  //---
442  // Now lets render each frame. Note we will have to find
443  // subframes
444  // that intersect the rectangle of interest for each frame.
445  //---
446  fillTile(rect, frames, result);
447
448  // Revalidate tile status.
449  result->validate();
450  }
451  }
452  else
453  {
454  result->makeBlank();
455  }
456  }
457  }
458
459  return status;
460 }
vector< ossimFrameEntryData > getIntersectingEntries(const ossimIrect &rect)
It is important to note that each frame is organized into an easting northing type orientation...
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
bool isValidRLevel(ossim_uint32 reduced_res_level) const
virtual ossimIrect getImageRectangle() const
return status
void fillTile(const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile)
bool isOpen() const
◆ getTileHeight()
ossim_uint32 ossimRpfCacheTileSource::getTileHeight ( ) const
virtual
Definition at line 708 of file ossimRpfCacheTileSource.cpp.
References m_tileSize, and ossimIpt::y.
709 {
710  return m_tileSize.y;
711 }
ossimIpt m_tileSize
ossim_int32 y
◆ getTileWidth()
ossim_uint32 ossimRpfCacheTileSource::getTileWidth ( ) const
virtual
Definition at line 703 of file ossimRpfCacheTileSource.cpp.
References m_tileSize, and ossimIpt::x.
704 {
705  return m_tileSize.x;
706 }
ossimIpt m_tileSize
ossim_int32 x
◆ isCadrg()
bool ossimRpfCacheTileSource::isCadrg ( ) const
Returns
true if CADRG
Definition at line 1213 of file ossimRpfCacheTileSource.cpp.
References m_productType, and OSSIM_PRODUCT_TYPE_CADRG.
1214 {
1216 }
◆ isCib()
bool ossimRpfCacheTileSource::isCib ( ) const
Returns
true if CIB
Definition at line 1208 of file ossimRpfCacheTileSource.cpp.
References m_productType, and OSSIM_PRODUCT_TYPE_CIB.
1209 {
1211 }
◆ isOpen()
bool ossimRpfCacheTileSource::isOpen ( ) const
virtual
Returns
True if the handler is open and flase otherwise.
Definition at line 128 of file ossimRpfCacheTileSource.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimImageHandler::theImageFile.
Referenced by getIntersectingEntries(), getTile(), and setEntryToRender().
129 {
130  //return (theTableOfContents!=0);
132
133  if(ext == "rpf")
134  {
135  return true;
136  }
137  else
138  {
139  return false;
140  }
141 }
ossimString ext() const
◆ isValidRLevel()
bool ossimRpfCacheTileSource::isValidRLevel ( ossim_uint32  reduced_res_level) const
virtual
Parameters
reduced_res_levelpassed in resolution level.
Returns
True if the reduced_res_level is within an acceptable range and false otherwise.
Definition at line 746 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::isValidRLevel(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
747 {
748  if (reduced_res_level == 0)
749  {
750  return true;
751  }
752  else if (theOverview.valid())
753  {
754  return theOverview->isValidRLevel(reduced_res_level);
755  }
756  else
757  {
758  return false;
759  }
760 }
bool valid() const
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
◆ loadState()
bool ossimRpfCacheTileSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Loading with a prefix.
cibCadrgHandler->laodState(kwl, "handler1.");
Loading without a prefix.
cibCadrgHandler->laodState(kwl);
Since all objects are factory created you can go through the registry and pass the keyword list in.
Parameters
kwlKeywordlist that holds the state information for this object.
prefixprefix value prepended to all keywords to uniquely locate the state attributes for this object.
Definition at line 1157 of file ossimRpfCacheTileSource.cpp.
1159 {
1160  const char* MODULE = "ossimRpfCacheTileSource::loadState";
1161
1162  if(traceDebug())
1163  {
1164  CLOG << "Entering..." << endl;
1165  }
1166  bool result = ossimImageHandler::loadState(kwl, prefix);
1167
1168  if(!result)
1169  {
1170  if(traceDebug())
1171  {
1172  CLOG << "Leaving..." << endl;
1173  }
1174  return false;
1175  }
1176  const char* lookup = 0;
1177  lookup = kwl.find(ossimString(prefix), "entry");
1178  ossim_int32 entry = ossimString(lookup).toInt32();
1179
1180  // if an entry is specified then
1181  // call the open with an entry number
1182  if(lookup)
1183  {
1184  if(traceDebug())
1185  {
1186  CLOG << "Leaving..." << endl;
1187  }
1189  setCurrentEntry(entry);
1190  return result;
1191  }
1192
1194
1195  return result;
1196 }
virtual bool open()=0
Pure virtual open.
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
#define CLOG
Definition: ossimTrace.h:23
int ossim_int32
◆ open()
bool ossimRpfCacheTileSource::open ( )
virtual
Pure virtual open.
Derived classes must implement.
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
Definition at line 143 of file ossimRpfCacheTileSource.cpp.
144 {
145  if(traceDebug())
146  {
147  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRpfCacheTileSource::open(): Entered....." << std::endl;
148  }
149
150  ossimFilename imageFile = theImageFile;
151  bool result = true;
152
153  if(isOpen() == false)
154  {
155  close();
156  result = false;
157  }
158
159  if(result)
160  {
161  if (m_fileNames.size() == 0 && m_frameEntryArray.size() == 0)
162  {
163  if (buildFrameEntryArray(imageFile) == false)
164  {
165  return false;
166  }
167  }
168
169  setCurrentEntry(0);
170  //---
171  // Adjust image rect so not to go over the -180 to 180 and -90 to 90
172  // bounds.
173  //---
175
176  // Set the base class image file name.
177  theImageFile = imageFile;
179  m_tile->initialize();
180  }
181
182  if(traceDebug())
183  {
184  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRpfCacheTileSource::open(): Leaving at line" << __LINE__ << std::endl;
185  }
186
187  return result;
188 }
bool buildFrameEntryArray(ossimFilename imageFile)
void setActualImageRect()
bool isOpen() const
◆ populateLut()
void ossimRpfCacheTileSource::populateLut ( )
protected
Definition at line 1235 of file ossimRpfCacheTileSource.cpp.
References ossimRpfFrame::getColorGrayscaleTable(), m_fileNames, m_productType, ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_UINT8, ossimRpfFrame::parseFile(), and ossimImageHandler::theLut.
Referenced by setEntryToRender().
1236 {
1237  theLut = 0;
1238  if(m_fileNames.size() > 0)
1239  {
1240  // bool found = false;
1241  ossimRpfFrameEntry tempEntry;
1242  ossimRpfFrame aFrame;
1243  ossimFilename fileName = m_fileNames[0].split("|")[0];
1244  // if (fileName.exists())
1245  // {
1246  // found = true;
1247  // }
1248
1249  if(aFrame.parseFile(fileName)
1251  {
1252  const vector<ossimRpfColorGrayscaleTable>& colorTable =
1253  aFrame.getColorGrayscaleTable();
1254
1255  // ESH 03/2009 -- Partial fix for ticket #646.
1256  // Crash fix on reading RPFs: Make sure the colorTable vector
1257  // has entries before trying to make use of them.
1258  int numTables = (int)colorTable.size();
1259
1260  ossim_uint32 numElements = (numTables > 0) ? colorTable[0].getNumberOfElements() : 0;
1261  if(numElements > 0)
1262  {
1265  {
1266  theLut = new ossimNBandLutDataObject(numElements,
1267  3,
1268  OSSIM_UINT8);
1269  }
1270  else
1271  {
1272  theLut = 0;
1273  return;
1274  }
1275  ossim_uint32 idx = 0;
1276
1277  for(idx = 0; idx < numElements;++idx)
1278  {
1279  const ossim_uint8* startOfData = colorTable[0].getStartOfData(idx);
1280  switch(m_productType)
1281  {
1283  {
1284  (*theLut)[idx][0] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1285  (*theLut)[idx][1] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1286  (*theLut)[idx][2] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1287  break;
1288  }
1290  {
1291  (*theLut)[idx][0] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1292  (*theLut)[idx][1] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[1]);
1293  (*theLut)[idx][2] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[2]);
1294  break;
1295  }
1296  default:
1297  {
1298  break;
1299  }
1300  }
1301  }
1302  }
1303  }
1304  }
1305 }
class ossimNBandLutDataObject
ossimRefPtr< ossimNBandLutDataObject > theLut
8 bit unsigned integer
◆ saveState()
bool ossimRpfCacheTileSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Parameters
kwlKeywordlist to save the state of the object to.
prefixprefix to prepend to the keywords. This will help uniquely identify each keyword if multiple objects are saved to the same list.
Returns
True if successfully saved the state of the object and false otherwise.
Definition at line 1149 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::saveState().
1151 {
1152  bool result = ossimImageHandler::saveState(kwl, prefix);
1153
1154  return result;
1155 }
◆ setActualImageRect()
void ossimRpfCacheTileSource::setActualImageRect ( )
protected
Definition at line 532 of file ossimRpfCacheTileSource.cpp.
References m_actualImageRect, m_numberOfLines, and m_numberOfSamples.
533 {
535 }
◆ setCurrentEntry()
bool ossimRpfCacheTileSource::setCurrentEntry ( ossim_uint32  entryIdx)
virtual
Parameters
entryIdxEntry number to select.
Note
The implementation does nothing. Derived classes that handle multiple images should override.
Returns
true if it was able to set the current entry and false otherwise.
Definition at line 713 of file ossimRpfCacheTileSource.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), setEntryToRender(), ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
714 {
715  // Clear the geometry.
716  theGeometry = 0;
717
718  // Must clear or openOverview will use last entries.
720
721  if(!setEntryToRender(entryIdx))
722  {
723  return false;
724  }
725  completeOpen();
726
727  return true;
728 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
virtual bool setEntryToRender(ossim_uint32 index)
virtual void completeOpen()
Will complete the opening process.
◆ setEntryToRender()
bool ossimRpfCacheTileSource::setEntryToRender ( ossim_uint32  index)
protectedvirtual
Definition at line 735 of file ossimRpfCacheTileSource.cpp.
References isOpen(), and populateLut().
Referenced by setCurrentEntry().
736 {
737  if(isOpen())
738  {
739  populateLut();
740  return true;
741  }
742
743  return false;
744 }
bool isOpen() const
Member Data Documentation
◆ CIBCADRG_FRAME_HEIGHT
const ossim_uint32 ossimRpfCacheTileSource::CIBCADRG_FRAME_HEIGHT = 1536
static
This should be 1536.
Definition at line 292 of file ossimRpfCacheTileSource.h.
Referenced by fillSubTileCadrg(), fillSubTileCib(), and getIntersectingEntries().
◆ CIBCADRG_FRAME_WIDTH
const ossim_uint32 ossimRpfCacheTileSource::CIBCADRG_FRAME_WIDTH = 1536
static
Definition at line 287 of file ossimRpfCacheTileSource.h.
◆ m_actualImageRect
ossimIrect ossimRpfCacheTileSource::m_actualImageRect
protected
Definition at line 436 of file ossimRpfCacheTileSource.h.
Referenced by setActualImageRect().
◆ m_bBox_LL_Lat
ossim_float64 ossimRpfCacheTileSource::m_bBox_LL_Lat
protected
Definition at line 488 of file ossimRpfCacheTileSource.h.
◆ m_bBox_LL_Lon
ossim_float64 ossimRpfCacheTileSource::m_bBox_LL_Lon
protected
Definition at line 487 of file ossimRpfCacheTileSource.h.
◆ m_bBox_UR_Lat
ossim_float64 ossimRpfCacheTileSource::m_bBox_UR_Lat
protected
Definition at line 490 of file ossimRpfCacheTileSource.h.
◆ m_bBox_UR_Lon
ossim_float64 ossimRpfCacheTileSource::m_bBox_UR_Lon
protected
Definition at line 489 of file ossimRpfCacheTileSource.h.
◆ m_compressedBuffer
unsigned char* ossimRpfCacheTileSource::m_compressedBuffer
protected
Definition at line 441 of file ossimRpfCacheTileSource.h.
Referenced by allocateForProduct(), fillSubTileCadrg(), fillSubTileCib(), and ~ossimRpfCacheTileSource().
◆ m_fileNames
std::vector<ossimString> ossimRpfCacheTileSource::m_fileNames
protected
Definition at line 470 of file ossimRpfCacheTileSource.h.
Referenced by populateLut().
◆ m_frameEntryArray
std::vector< std::vector<ossimRpfFrameEntry> > ossimRpfCacheTileSource::m_frameEntryArray
protected
Definition at line 494 of file ossimRpfCacheTileSource.h.
Referenced by getIntersectingEntries().
◆ m_numberOfLines
ossim_uint32 ossimRpfCacheTileSource::m_numberOfLines
protected
The CibCadrg have fixed size frames of 1536x1536 and we must count how many there are.
Definition at line 453 of file ossimRpfCacheTileSource.h.
Referenced by getNumberOfLines(), and setActualImageRect().
◆ m_numberOfSamples
ossim_uint32 ossimRpfCacheTileSource::m_numberOfSamples
protected
Definition at line 460 of file ossimRpfCacheTileSource.h.
Referenced by getNumberOfSamples(), and setActualImageRect().
◆ m_numOfFramesHorizontal
ossim_uint32 ossimRpfCacheTileSource::m_numOfFramesHorizontal
protected
Definition at line 492 of file ossimRpfCacheTileSource.h.
◆ m_numOfFramesVertical
ossim_uint32 ossimRpfCacheTileSource::m_numOfFramesVertical
protected
Definition at line 491 of file ossimRpfCacheTileSource.h.
◆ m_productType
ossimRpfCacheProductType ossimRpfCacheTileSource::m_productType
protected
The product type can be a CIB or a CADRG product.
Definition at line 481 of file ossimRpfCacheTileSource.h.
Referenced by allocateForProduct(), fillTile(), getNumberOfInputBands(), getNumberOfOutputBands(), getProperty(), getTile(), isCadrg(), isCib(), and populateLut().
◆ m_tile
ossimRefPtr<ossimImageData> ossimRpfCacheTileSource::m_tile
protected
Definition at line 465 of file ossimRpfCacheTileSource.h.
Referenced by allocateForProduct(), and getTile().
◆ m_tileSize
ossimIpt ossimRpfCacheTileSource::m_tileSize
protected
Definition at line 475 of file ossimRpfCacheTileSource.h.
Referenced by getTileHeight(), and getTileWidth().
◆ m_uncompressedBuffer
unsigned char* ossimRpfCacheTileSource::m_uncompressedBuffer
protected
Definition at line 446 of file ossimRpfCacheTileSource.h.
◆ m_workFrame
ossimRpfFrame* ossimRpfCacheTileSource::m_workFrame
mutableprotected
Definition at line 483 of file ossimRpfCacheTileSource.h.
Referenced by fillTile(), and ~ossimRpfCacheTileSource().
