18 #ifndef ossimTiffTileSource_HEADER 19 #define ossimTiffTileSource_HEADER 1 33 class ossimTiffOverviewTileSource;
34 class TiffStreamAdaptor;
38 friend class TiffStreamAdaptor;
67 bool open( std::shared_ptr<ossim::istream>& str,
68 const std::string& connectionString );
158 const char* prefix=0)
const;
165 const char* prefix=0);
167 virtual bool isOpen()
const;
212 void setApplyColorPaletteFlag(
bool flag);
213 bool getApplyColorPaletteFlag()
const;
217 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
218 bool isColorMapped()
const;
261 void adjustToStartOfTile(
ossimIpt& pt)
const;
276 bool loadFromRgbaU8Tile(
const ossimIrect& tile_rect,
280 bool loadFromRgbaU8Strip(
284 bool loadFromRgbaU8aStrip(
288 bool loadFromU16Strip(
const ossimIrect& clip_rect,
291 bool loadFromScanLine(
294 bool loadFromTile(
297 void setReadMethod();
312 void validateMinMaxNull();
338 bool allocateBuffer();
virtual bool open()=0
Pure virtual open.
std::vector< ossim_uint32 > theImageTileWidth
std::vector< ossim_uint32 > theOutputBandList
ossim_int32 theCompressionType
ossim_float64 theMaxSampleValue
ossim_uint32 theCurrentTiffRlevel
ossim_uint32 theCurrentTileWidth
std::shared_ptr< ossim::TiffIStreamAdaptor > m_streamAdaptor
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
std::vector< ossim_uint32 > theRowsPerStrip
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
unsigned short ossim_uint16
ossim_uint32 theCurrentTileHeight
virtual ossimString getShortName() const
ossim_uint16 theSamplesPerPixel
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
ossim_uint16 theNumberOfDirectories
std::vector< ossim_uint32 > theImageDirectoryList
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
ossim_uint32 theBufferRLevel
virtual bool isOpen() const =0
Retuns the min pixel value.
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
ossim_float64 theNullSampleValue
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
bool theApplyColorPaletteFlag
virtual ossimString getLongName() const
virtual void close()
ossim_uint16 theBitsPerSample
ossim_uint32 theBytesPerPixel
ossim_float64 theMinSampleValue
virtual bool isBandSelector() const
Indicates whether or not the image handler can control output band selection via the setOutputBandLis...
std::vector< ossim_uint32 > theImageLength
virtual ossim_uint32 getImageTileWidth() const =0
ossimScalarType theScalarType
std::vector< ossim_uint16 > thePhotometric
std::vector< ossim_uint16 > thePlanarConfig
This class defines an abstract Handler which all image handlers(loaders) should derive from...
std::vector< ossim_uint32 > theImageTileLength
ossim_uint16 theCurrentDirectory
ossim_uint16 theSampleFormatUnit
std::vector< ReadMethod > theReadMethod
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
std::vector< ossim_uint32 > theImageWidth
ossim_uint32 theBufferSize
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
