23 static ossimTrace traceDebug(
"ossimTiling:debug");
28 :theTilingDistance(0,0),
31 theDeltaType(ossimTilingDeltaType_TOTAL_PIXELS),
32 theOutputSizeInBytes(0),
34 theNumberOfBytesPerPixelPerBand(1),
35 thePaddingSizeInPixels(0.0, 0.0),
40 theTotalHorizontalTiles(0),
41 theTotalVerticalTiles(0),
44 theEdgeToEdgeFlag(false)
54 <<
"ossimTiling::initialize DEBUG: Entered..." 55 <<
"\nBounding rect === " << boundingRect
99 <<
"DEBUG: Geographic input bounds = " 109 <<
"DEBUG: Geographic input bounds stretched = " 118 <<
"DEBUG: Geographic input bounds clamped = " 183 <<
"\nossimTiling::initialize DEBUG: Leaving..." << std::endl;
241 origin.
lon + (deltaPerPixel.
x/2.0),
262 origin.
y - (deltaPerPixel.
y/2.0) ) );
278 if(traceDebug()&&resultProjection.
valid())
284 <<
"ossimTiling::next DEBUG: rect = " << resultingBounds
285 <<
"\nproj = " << projKwl
286 <<
"\ntileName = " << resultingName
287 <<
"\norigin = " << origin << std::endl;
340 <<
"ossimTiling::validate()\n" 341 <<
"Map projeciton requires tiling in angular units but the" 342 <<
"\nspacing is in non angular" << std::endl;
364 <<
"ossimTiling::validate()" 365 <<
"\nMap projeciton requires tiling using linear spacing" 366 <<
" but the spacing is in non linear" << std::endl;
376 <<
"ossimTiling::validate()" 377 <<
"\nthe image projection is null and so not valid" 384 <<
"ossimTiling::validate() the delta is too small or is negative" 385 <<
"value = " <<
theDelta << std::endl;
392 <<
"ossimTiling::validate()" 393 <<
"\nthe tiling distance is too small or is negative" 400 <<
"ossimTiling::validate() the image rect has nans" 507 bool result =
getRowCol(row, col, tileId);
568 unitConverter.setValue(result.
y,
574 unitConverter.setValue(result.
x,
578 unitConverter.setValue(result.
y,
615 latString << setfill(
'0') << setw(2) << fabs(origin.
lat);
616 lonString << setfill(
'0') << setw(3) << fabs(origin.
lon);
620 resultingName +=
"S";
624 resultingName +=
"N";
626 resultingName += latString.str().
c_str();
629 resultingName +=
"W";
633 resultingName +=
"E";
635 resultingName += lonString.str().
c_str();
636 resultingName +=
".hgt";
656 resultingName = resultingName.
substitute(
"%r%",
657 rowString.str().c_str());
658 resultingName = resultingName.
substitute(
"%c%",
659 colString.str().c_str());
660 resultingName = resultingName.
substitute(
"%i%",
661 idString.str().c_str());
662 resultingName = resultingName.
substitute(
"%oc",
663 oColString.str().c_str());
664 resultingName = resultingName.
substitute(
"%or",
665 oRowString.str().c_str());
674 if(ul.
lat > 90) ul.
lat = 90.0;
675 if(lr.
lat < -90.0) lr.
lat = -90.0;
677 if(ul.
lon < -180) ul.
lon = -180;
678 if(lr.
lon > 180) lr.
lon = 180;
684 const char* prefix)
const 692 tilingDistance.str().c_str(),
697 "tiling_distance_type",
726 "padding_size_in_pixels",
727 padding.str().c_str(),
738 "output_size_in_bytes",
746 "output_bytes_per_pixel_per_band",
769 const char* paddingSizeInPixels = kwl.
find(prefix,
770 "padding_size_in_pixels");
771 if (paddingSizeInPixels)
782 if (kwl.
numberOf(prefix,
"output_size_in_"))
784 lookup = kwl.
find(prefix,
"output_size_in_bytes");
789 lookup = kwl.
find(prefix,
"output_size_in_kilo_bytes");
794 lookup = kwl.
find(prefix,
"output_size_in_mega_bytes");
804 lookup = kwl.
find(prefix,
"output_bands");
809 lookup = kwl.
find(prefix,
"output_bytes_per_pixel_per_band");
819 static_cast<ossim_int32>(floor(sqrt((
double)pixelsPerBand)));
839 const char* tilingDistance = kwl.
find(prefix,
841 const char* tilingDistanceType = kwl.
find(prefix,
842 "tiling_distance_type");
843 const char* delta = kwl.
find(prefix,
846 const char* deltaType = kwl.
find(prefix,
849 result = tilingDistance&&tilingDistanceType&&delta&&deltaType&&paddingSizeInPixels;
874 deltaValues >>
x >>
y;
888 if(
ossimString(deltaType).downcase().contains(
"total"))
898 lookup = kwl.
find(prefix,
"edge_to_edge");
928 <<
"\ntheNumberOfBytesPerPixelPerBand: " <<
935 out <<
"\ntheMapProjection:\n";
940 out <<
"theMapProjection is not set.";
958 <<
"ossimTiling::getConvertedTilingDistance WARNING" 959 <<
" projection not set!" << endl;
RTTI_DEF1(ossimTiling, "ossimTiling", ossimObject)
ossimTilingDeltaType theDeltaType
bool isAngularUnit(ossimUnitType unitType) const
virtual ossimObject * dup() const =0
bool isLinearUnit(ossimUnitType unitType) const
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
ossim_uint32 numberOf(const char *str) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
ossimUnitType theTilingDistanceUnitType
The unit type for "theDelta", and "theTilingDistance".
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
const ossimDpt & ul() const
ossim_uint32 height() const
bool contains(char aChar) const
Numeric to string methods.
ossimRefPtr< ossimMapProjection > theMapProjection
virtual bool isGeographic() const
const ossimIpt & ul() const
bool initialize(const ossimMapProjection &proj, const ossimIrect &boundingRect)
ossim_int64 theTotalVerticalTiles
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
void getTileName(ossimString &resultingName, ossim_int64 row, ossim_int64 col, ossim_int64 id) const
const ossimIpt & ll() const
void setTilingDistance(const ossimDpt &tilingDistance, ossimUnitType unitType)
void getConvertedTilingDistance(ossimDpt &pt) const
ossimCoordSysOrientMode orientMode() const
virtual void setMetersPerPixel(const ossimDpt &gsd)
const ossimDatum * datum() const
datum().
void clampGeographic(ossimDrect &rect) const
ossim_int32 toInt32() const
ossimDpt getDeltaPerPixel() const
virtual ossimGpt lineSampleToWorld(const ossimDpt &projectedPoint) const
ossimDpt theDelta
If (theDeltaType == ossimTilingDeltaType_TOTAL_PIXELS) then this is the size of the tile in pixels li...
void setTileNameMask(const ossimString &mask)
This sets the tilename mask.
virtual void lineSampleToEastingNorthing(const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
bool toBool() const
String to numeric methods.
virtual ossimGpt origin() const
ossim_int64 theTotalTiles
ossimString getTileNameMask() const
ossim_uint32 theNumberOfBytesPerPixelPerBand
Output number of bytes per pixel.
ossim_int64 theOutputSizeInBytes
If set tiling size is controlled by the desired output size in bytes.
const ossimIpt & lr() const
bool getOrigin(ossimDpt &origin, ossim_int64 tileId) const
bool getRowCol(ossim_int64 &row, ossim_int64 &col, ossim_int64 tileId) const
ossim_uint32 width() const
ossim_int64 theTotalHorizontalTiles
Generic print method.
const ossimIpt & ur() const
ossim_uint32 theNumberOfBands
Output number of bands.
ossimString theTileNameMask
ossimDpt theTilingDistance
The size of a tile in theTilingDistanceUnitType.
void stretchToTileBoundary(const ossimDpt &widthHeight)
ossimDpt thePaddingSizeInPixels
const ossimDpt & ur() const
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
ossim_int64 toInt64() const
virtual void setUlTiePoints(const ossimGpt &gpt)
std::basic_istringstream< char > istringstream
Class for char input memory streams.
bool next(ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) const
float distance(double lat1, double lon1, double lat2, double lon2, int units)
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
const ossimDpt & lr() const
bool theEdgeToEdgeFlag
This flags the code to shift the tie point so that the edge of the pixel falls on the tile boundary...
Prints data members to stream.
void setDelta(const ossimDpt &delta, ossimTilingDeltaType deltaType)
This sets the pixel delta.
std::basic_ostream< char > ostream
Base class for char output streams.
