ossimUsgsDemTileSource.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: MIT
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description:
8 //
9 // Contains class declaration of ossimUsgsDemTileSource.
10 // The ossimUsgsDemTileSource class is derived from ossimImageHandler and
11 // is intended to be an image handler for USGS dem files.
12 //
13 //********************************************************************
14 // $Id: ossimUsgsDemTileSource.h 19640 2011-05-25 15:58:00Z oscarkramer $
15
16 #ifndef ossimUsgsDemTileSource_HEADER
17 #define ossimUsgsDemTileSource_HEADER
18
20
21 class ossimImageData;
22 class ossimDemGrid;
23
25 {
26 public:
27
29
30  virtual ossimString getShortName() const;
31  virtual ossimString getLongName() const;
32
42  virtual bool open();
43
44  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tile_rect,
45  ossim_uint32 resLevel=0);
46
59  virtual bool getTile(ossimImageData* result, ossim_uint32 resLevel=0);
60
65  virtual ossim_uint32 getNumberOfInputBands() const;
66  virtual ossim_uint32 getNumberOfOutputBands() const;
67
72  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
73
78  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
79
80  virtual double getNullPixelValue(ossim_uint32 band=0)const;
81  virtual double getMinPixelValue(ossim_uint32 band=0)const;
82  virtual double getMaxPixelValue(ossim_uint32 band=0)const;
83
88  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const;
89
94  virtual bool saveState(ossimKeywordlist& kwl,
95  const char* prefix=0)const;
96
107  virtual bool loadState(const ossimKeywordlist& kwl,
108  const char* prefix=0);
109
110
114  virtual ossimScalarType getOutputScalarType() const;
115
119  virtual ossim_uint32 getTileWidth() const;
120
124  virtual ossim_uint32 getTileHeight() const;
125
132  virtual ossim_uint32 getImageTileWidth() const;
133
140  virtual ossim_uint32 getImageTileHeight() const;
141
142  virtual bool isOpen()const;
143
148
149 protected:
150
161
162  virtual ~ossimUsgsDemTileSource();
163  // Disallow operator= and copy constrution...
166
170  template <class T> bool fillBuffer(T, // dummy template variable
171  const ossimIrect& tile_rect,
172  const ossimIrect& clip_rect,
173  ossimImageData* tile);
174
175  void gatherStatistics();
176
182  bool theFeetFlag; // elevation units = feet
184
190
191 TYPE_DATA
192 };
193
194 #endif // #ifndef ossimUsgsDemTileSource_HEADER
virtual bool open()=0
Pure virtual open.
ossimScalarType theScalarType
This can be either OSSIM_SINT16 or OSSIM_FLOAT32.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
const ossimImageSource & operator=(const ossimImageSource &)
Returns the default processing tile height.
Definition: ossimObject.cpp:48
Returns the default processing tile width.
virtual bool isOpen() const =0
Retuns the min pixel value.
double ossim_float64
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
Definition: ossimObject.cpp:53
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
#define OSSIM_DLL
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
